GNSS-HR26PM
GNSS-HR26PM
    PCTEL
    插件
    1.5875GHz GLONASS,GPS,GNSS 封装 RF 天线 1.565GHz ~ 1.61GHz -2dBic SMA 螺柱,通孔
GNSS-HR26PM 数据手册
MOBILE ANTENNAS Shield - Permanent Mount GNSS-HR26PM GNSS-HR26PM Low-Profile Antenna with High Rejection GNSS Technology RoHS COMPLIANT The GNSS-HR26PM vehicle tracking antenna features a light, low-profile housing that is ideal for fleet management applications. Its radome is molded from high grade polymer resin for maximum UV and abrasion resistance under severe environmental conditions. Its electrically shielded LNA PCB assembly and ceramic filter are designed to provide proprietary high out-of-band rejection for optimal integration in congested wireless installations. Features • GPS L1 & GLONASS L1 Frequencies • Proprietary filtering design allows wideband coverage while achieving superior out-of-band rejection for all GNSS frequencies • Rugged, low-profile housing for minimum visibility • 26 dB gain • ESD protection • IP56 ingress protection GNSS-HR26PM STANDARD CONFIGURATION Model Cable Connector** Mount GNSS-HR26PM 5 Meters RG174 (16.4 Feet) SMA Plug 1/2-inch built-in threaded stud mount for 1-inch diameter mounting holes. For up to 1/4-inch (6mm) surfaces ELECTRICAL SPECIFICATIONS - GNSS ANTENNA Frequency Band LNA Gain Element Gain Polarization Out of Band Rejection VSWR 1565-1610 MHz @ 3.0VDC: 26dB (typical) -2 dBic @ 20° Right hand circular f0 = 1586 MHz f0 +/- 50MHz : ≥ 60dBc f0 +/- 60MHz : ≥ 70dBc 2.0:1 maximum ELECTRICAL SPECIFICATIONS - GNSS ANTENNA, continued Current Draw DC Voltage Noise Figure Nominal Impedance < 25 mA (typical) 2.8-6.0 V (operating) ≤ 12.0 V (survivability) < 2.0 dB (typical) 50 ohms MECHANICAL SPECIFICATIONS Dimensions Weight Housing Material 2.5” OD x 0.5” D (63.5 x 12.7 mm) 25 grams Black, UV-Stable ASA ENVIRONMENTAL SPECIFICATIONS Temperature Range -40°C to +85°C (operating) Humidity Mechanical Shock Fluid Shower 95% 25 g maximum Water, salt mist, windshield wiper fluid, detergent with wax: no degradation *When installed according to the manufacturer’s installation instructions. ** Consult Customer Service for other connector options. PCTEL, Inc. WEB: www.antenna.com 47
GNSS-HR26PM
物料型号为 GNSS-HR26PM,是一款低轮廓车载跟踪天线,适用于车队管理应用。
其主要特性包括 GPS L1 和 GLONASS L1 频段、专有的滤波设计、坚固耐用的低轮廓外壳、26 dB 增益、静电放电保护以及 IP56 等级的防护。
引脚分配方面,该天线配置为 5 米 RG174 同轴电缆,带有 SMA 插头,并配有 1/2 英寸内置螺纹安装螺柱,适用于直径为 1 英寸的安装孔,也适用于 1/4 英寸(6 毫米)的表面。
参数特性包括在 1565-1610 MHz 频段工作,具有 3.0VDC 下 26 dB(典型值)的 LNA 增益,-2 dBic@20° 的元件增益,右旋圆极化,以及在 1586 MHz 频点±50MHz 时至少 60dBc、±60MHz 时至少 70dBc 的带外抑制。
电压驻波比(VSWR)最大为 2.0:1,工作电流小于 25 mA(典型值),直流电压为 2.8-6.0V(工作)至 12.0V(耐受),噪声系数小于 2.0 dB(典型值),标称阻抗为 50 欧姆。
功能详解中提到,该天线设计用于提供专有的高带外抑制,以优化在拥挤的无线安装中的集成。
应用信息表明,该天线适用于车队管理等应用,其设计考虑了在恶劣环境下的 UV 和耐磨性。
封装信息显示,天线尺寸为 2.5 英寸外径 x 0.5 英寸高(63.5 x 12.7 毫米),重量为 25 克,外壳材料为黑色、UV 稳定的 ASA。
环境规格包括在 -40°C 至 +85°C 的工作温度范围内操作,95% 的湿度,最大 25 g 的机械冲击,以及对水、盐雾、挡风玻璃雨刷液、含蜡清洁剂的流体冲击测试,无退化现象。
GNSS-HR26PM 价格&库存
很抱歉,暂时无法提供与“GNSS-HR26PM”相匹配的价格&库存,您可以联系我们找货
