GPS-NMO
GPS-NMO
    PCTEL
    1.575GHz GNSS,GPS 圆顶 RF 天线 1.565GHz ~ 1.585GHz 1dBic NMO NMO 安装座
GPS-NMO 数据手册
GNSS ANTENNAS GPS L1 Antennas GPS-NMO Series Mobile Mount, Low-Profile Active, 26 dB GPS Antenna RoHS COMPLIANT PCTEL’s GPS active NMO mount antenna provides superior performance with the industry’s smallest NMO mountable footprint. The GPS-NMO antenna features a custom tuned frequency ceramic patch element, 15 KV ESD circuit protection, a twostage low noise amplifier and a SAW filter, that provides excellent out-of-band signal rejection performance and consistently clear signal while minimizing loss-of-lock. The GPS-NMO features an attractive, compact housing environmentally tested for both fixed or mobile applications. Its innovative tab design supports higher reliability and repeatable performance at GPS frequencies than button pin designs can provide. The product is available in black or white housing options to suit a wide variety of installation applications. Features • • • • GPS-NMO Attractive, low-profile design for maximum overhead clearance 2.7-5 Volt operation 15 KV ESD circuit protection Mates with all 1-1/8”-18 thread NMO mounts, including 3/4” mounts STANDARD CONFIGURATION Model GPS-NMO Mount Radome Does not include mounting hardware. Black Compatible with all 1-1/8”-18 thread NMO mounts, including 3/4” mounts*. ELECTRICAL SPECIFICATIONS - GNSS ANTENNA Model GPS-NMO Frequency Range LNA Gain Element Gain @ 3.3VDC: 26 dB @ 5VDC: 26 dB 1575.42MHz ±10 MHz Noise Figure Out of Band Rejection ± 50 MHz: 30 dB ± 60 MHz: 50 dB 2.1 dB (Typical) 1 dBic ELECTRICAL SPECIFICATIONS - GNSS ANTENNA, continued Model Current Draw DC Voltage Nominal Impedance Polarization GPS-NMO
GPS-NMO 价格&库存
很抱歉,暂时无法提供与“GPS-NMO”相匹配的价格&库存,您可以联系我们找货
