BMYD210G
BMYD210G
    PCTEL
    RF ANT 215-225MHZ YAGI 3 ELEM
BMYD210G 数据手册
PCTEL BLUEWAVE ANTENNAS BMY210G Series Bluewave Yagi Antenna, 215-225 MHz -PRELIMINARY- BMYD210G antenna (top) and BWC1001 mount (right) The BMYD210G has been engineered to meet the requirements of a high gain, broadband, premium quality antenna. This antenna provides 6.5 dBd gain and operates in the 215-225 MHz range. The BMYD210G is manufactured using high strength 6061-T6 Aluminum to withstand heavy ice, high wind and other harsh conditions. The innovative dipole design has an integral feed line and is welded to the boom for extra strength and electrical conductivity. This also eliminates misalignment or fastener problems. The entire antenna is powder coated for appearance and corrosion resistance. A heavy duty clamp is supplied which easily permits horizontal or vertical polarization. The BMYD210G is available with RG213U and Type N-female connector. Features • Elements and boom are manufactured from aircraft quality 6061-T6 aluminum for optimum strength • Antenna is powder coated for corrosion resistance Technical Data Maximum Power: 300 watts Nominal Impedance: 50 ohms Radiator Material: Aluminum 6061-T6 Mounting Method: Includes mounting hardware BWC1001 Connector Option: Type N Female RF/Electrical Specifications Model Frequency Range SWR Horizonal Beamwidth Vertical Beamwidth Front to Back Ratio Nominal Gain BMYD210G 215-225 MHz
BMYD210G 价格&库存
很抱歉,暂时无法提供与“BMYD210G”相匹配的价格&库存,您可以联系我们找货
