FMD9023-CP
FMD9023-CP
    PCTEL
    915MHz ISM,LoRa,LPWAN 模块 RF 天线 902MHz ~ 928MHz 3dBic N 型母头 连接器安装
FMD9023-CP 数据手册
INDUSTRIAL WIRELESS ANTENNAS Power Line Monitoring Antenna FMD9023-CP FMD9023-CP Power Line Monitoring Antenna RoHS COMPLIANT The low profile FMD9023-CP antenna has a circular polarized hemispherical radiation pattern designed to cover 902-928 MHz frequencies. The circular polarization enables communication regardless of polarization of paired antennas. Features • Low profile • Compact overmolded design • Ideal for pad mount and enclosure installations where low visual impact is necessary to discourage tampering or vandalism • RF performance, including circular polarization, pattern coverage, and gain levels, optimized for deployment in electric utility networks • Incorporates an integrated type N female bulkhead connector with optional integrated gasket to secure antenna to the mounting surface and provide a watertight seal FMD9023-CP STANDARD CONFIGURATION Model Connector FMD9023-CP N Female ELECTRICAL SPECIFICATIONS - RF ANTENNA Frequency Range Gain VSWR 902-928 MHz 3 dBic < 1.5:1 Main Beam 0° Beamwidth 105° Main Beam 90° Beamwidth 105° ELECTRICAL SPECIFICATIONS - RF ANTENNA, continued Nominal Impedance Polarization 50 ohms Right hand circular MECHANICAL SPECIFICATIONS Dimensions Weight Temperature Range 3.98 L x 3.98 W x 0.52 H in (101 L x 101 W x 13 H mm) 0.25 lbs -40°C to +70°C PCTEL, Inc. WEB: www.antenna.com INDUSTRIAL WIRELESS ANTENNAS Power Line Monitoring Antenna FMD9023-CP Patterns 330 340 RoHS COMPLIANT 0 350 10 20 30 320 330 40 310 50 300 260 250 240 90 270 100 260 120 130 140 210 200 190 180 170 160 40 50 60 70 280 110 220 30 290 80 −35 −30 −25 −20 −15 −10 −5 230 20 300 70 280 270 10 310 60 −10 −15 −20 −25 −30 −35 0 350 320 290 −5 340 150 0° Cut* 80 −5 −10 −15 −20 −25 −30 −35 −35 −30 −25 −20 −15 −10 −5 90 100 250 110 240 120 230 130 220 140 210 200 190 180 170 160 150 90° Cut* Outline Dimensional Drawing *Measured in free space PCTEL, Inc. WEB: www.antenna.com
FMD9023-CP 价格&库存
很抱歉,暂时无法提供与“FMD9023-CP”相匹配的价格&库存,您可以联系我们找货
