HBR3045AHF
HBR3045AHF
    SINO(华微)
    TO-220HF
    电压:45V 电流:15A
HBR3045AHF 数据手册
肖特基势垒二极管 SCHOTTKY BARRIER DIODE R HBR3045A 主要参数 MAIN CHARACTERISTICS IF(AV) 30(2×15)A VRRM 45 V Tj 175 ℃ VF(max) 0.58V (@Tj=125℃) 封装 Package TO-22O TO-220HF APPLICATIONS 用途  High frequency switch  高频开关电源 power supply  低压续流电路和保护电  Free wheeling diodes, 路 polarity protection applications TO-263 产品特性 FEATURES  共阴结构  低功耗,高效率  良好的高温特性  有过压保护环,高可靠性  环保(RoHS)产品  Common cathode structure  Low power loss, high efficiency  High Operating Junction Temperature  Guard ring for overvoltage protection,High reliability  RoHS product TO-3PB TO-247 订货信息 ORDER MESSAGE 订 货 型 号 Order codes 印 记 Marking 封 装 Package 有卤-条管 无卤-条管 有卤-编带 无卤-编带 Halogen-Tube Halogen Free-Tube Halogen-Reel Halogen Free-Reel HBR3045A-CA-B HBR3045A-CA-BR N/A N/A HBR3045A TO-220 HBR3045A-FA-B HBR3045A-FA-BR N/A N/A HBR3045A TO-220HF HBR3045A-S-B HBR3045A-S-BR HBR3045A TO-263 HBR3045A-GD-B HBR3045A-GD-BR N/A N/A HBR3045A TO-3PB HBR3045A-GE-B HBR3045A-GE-BR N/A N/A HBR3045A TO-247 版本(Rev):201908I HBR3045A-S-A HBR3045A-S-AR 1/9 HBR3045A R ABSOLUTE RATINGS (Tc=25℃) 绝对最大额定值 符 号 Symbol 数 值 Value 单 位 Unit 最大反向重复峰值电压 Repetitive peak reverse voltage VRRM 45 V 最大直流阻断电压 Maximum DC blocking voltage VDC 45 V 项 目 Parameter 正向平均整流电流 Average forward current TC=150℃ (TO-220,TO-263 TO-3PB,TO-247) TC=125℃ (TO-220HF) 整个器件 per device 30 IF(AV) A 单 侧 per diode 正向峰值浪涌电流 Surge non repetitive forward current (额定负载 8.3ms 半正弦波—按 JEDEC 方法) 8.3 ms single half-sine-wave (JEDEC Method) 15 IFSM 275 A Tj 175 ℃ TSTG -40~+150 ℃ 最高结温 Maximum junction temperature 储存温度 Storage temperature range 电特性 ELECTRICAL CHARACTERISTICS 项 目 Parameter IR VF 测试条件 Tests conditions Tj =25℃ Tj =125℃ Tj =25℃ Tj =125℃ 最小值 典型值 最大值 Value(min) Value(typ) Value(max) 30 μA 30 mA 0.58 0.65 V 0.54 0.58 V VR=VRRM IF=15A 单位 Unit 热特性 THERMAL CHARACTERISTICS 项 目 Parameter 符 号 Symbol 结到管壳的热阻 Thermal resistance from junction to case TO-220 TO-263 TO-3PB TO-247 TO-220HF 结到环境的热阻 Thermal resistance from junction to ambient TO-220 TO-3PB TO-247 TO-220HF 版本(Rev):20190805I 最小值 Value(min) 最大值 单 位 Value(max) Unit Rth(j-c) 1.7 1.9 1.9 1.9 2.4 ℃/W Rth(j-a) 70 80 80 100 ℃/W 2/9 HBR3045A R 特征曲线 ELECTRICAL CHARACTERISTICS (curves) IF vs VF IR vs VR IF(AV) vs TC CT vs VR 版本(Rev):20190805I 3/9 R 外形尺寸 PACKAGE MECHANICAL DATA TO-220 版本(Rev):20190805I HBR3045A 单位 Unit :mm 4/9 R 外形尺寸 PACKAGE MECHANICAL DATA TO-220HF 版本(Rev):20190805I HBR3045A 单位 Unit :mm 5/9 HBR3045A R 外形尺寸 PACKAGE MECHANICAL DATA TO-263 编带 单位 Unit :mm REEL 版本(Rev):20190805I 6/9 R 外形尺寸 PACKAGE MECHANICAL DATA TO-3PB 版本(Rev):20190805I HBR3045A 单位 Unit :mm 7/9 R 外形尺寸 PACKAGE MECHANICAL DATA TO-247 版本(Rev):20190805I HBR3045A 单位 Unit :mm 8/9 HBR3045A R 注意事项 1.吉林华微电子股份有限公司的产品销售分 为直销和销售代理,无论哪种方式,订货时 请与公司核实。 2.购买时请认清公司商标,如有疑问请与公司 本部联系。 3.在电路设计时请不要超过器件的绝对最大 额定值,否则会影响整机的可靠性。 4.本说明书如有版本变更不另外告知 NOTE 1. Jilin Sino-microelectronics co., Ltd sales its product either through direct sales or sales agent , thus, for customers, when ordering , please check with our company. 2. We strongly recommend customers check carefully on the trademark when buying our product, if there is any question, please don’t be hesitate to contact us. 3. Please do not exceed the absolute maximum ratings of the device when circuit designing. 4. Jilin Sino-microelectronics co., Ltd reserves the right to make changes in this specification sheet and is subject to change without prior notice. 联系方式 CONTACT 吉林华微电子股份有限公司 JILIN SINO-MICROELECTRONICS CO., LTD. 公司地址:吉林省吉林市深圳街 99 号 ADD: No.99 Shenzhen Street, Jilin City, Jilin Province, China. Post Code: 132013 Tel:86-432-64678411 Fax:86-432-64665812 Web Site:www.hwdz.com.cn 邮编:132013 总机:86-432-64678411 传真:86-432-64665812 网址:www.hwdz.com.cn 市场营销部 地址:吉林省吉林市深圳街 99 号 邮编:132013 电话:86-432-64675588 64675688 64678411-3098/3099 传真: 86-432-64671533 版本(Rev):20190805I MARKET DEPARTMENT ADD: No.99 Shenzhen Street, Jilin City, Jilin Province, China. Post Code: 132013 Tel: 86-432-64675588 64675688 64678411-3098/3099 Fax: 86-432-64671533 9/9
HBR3045AHF 价格&库存
很抱歉,暂时无法提供与“HBR3045AHF”相匹配的价格&库存,您可以联系我们找货
