3TO480000CWBD
3TO480000CWBD
    JYJE(晶友嘉)
    SMD3225_4P
    有源晶振
3TO480000CWBD 数据手册
深圳市晶友嘉电子有限公司 SHENZHEN JINGYOUJIA ELECTRONIC CO.,LTD CRYSTAL RESONATOR SPECIFICATIONS 石英晶体谐振器承认书 客户 Customer: 立创商城 型号 Product: 3TO4 客户料号 Code No: C2986075 我司料号 Code No: 3TO480000CWBD 频率 Frequency: 8.000MHz 数量 Sample Quantity: 日期 Date: 2022-3-28 深圳市晶友嘉电子有限公司 SHENZHEN JINGYOUJIA ELECTRONIC CO.,LTD 深圳市龙华区东环二路数字颖博智能园 B 栋 4 楼 TEL: 86-755-32840201 32850080 FAX: 86-755-84269460 供应商确认栏: 制作 Handler 确认 Checked 核审 Approved 戴晓嘉 陈斌 李晨 客户承认栏: 承认 Checked 核审 Approved 深圳市晶友嘉电子有限公司 SHENZHEN JINGYOUJIA ELECTRONIC CO.,LTD 1.Electrical Parameters No. Symb ol Parameters Electrical Specification Condition Min. Type Max. Units 1 Nominal Frequency 2 Operating Temperature Topr -40 - 85 3 Storage Temperature Tstg -55 - 105 4 Frequency Stability 5 Supply Voltage 6 Current Consumption 7 Output Type - CMOS 8 Output Load CL 15 9 Output Voltage High VoH 90%VDD - - V 10 Output Voltage Low VoL - - 10%VD V 11 Rise Time Tr 10%→90%VDD Level - - 8 nS 12 Fall Time Tf 90%→10%VDD Level - - 8 nS 13 Symmetry or Duty Cycle 40 50 60 % 14 Start-up Time - - 10 mS - V 15 16 Enable - - 3.3 TH/T Voltage Low (Logic 1) (Logic 0) Vh Note 2 70%VDD - Vlo Note 2 - - - 1st.Year at 25℃ ℃ V 20 Icc ℃ ppm ±20 Tosc High Disable Note 1 VDD Voltage MHz 8.000 mA pF 30%VD D V 17 Aging 18 Output Disable Time T off - - 150 µS 19 Output Enable Time T on - - 150 µS Page:2 ppm ±3 深圳市晶友嘉电子有限公司 SHENZHEN JINGYOUJIA ELECTRONIC CO.,LTD 3.实物 Product 4.外型尺寸 Outline Dimensions (unit:mm) . Page:3 深圳市晶友嘉电子有限公司 SHENZHEN JINGGUANGHUA ELECTRONIC CO.,LTD 5 .波型条件 WAVEFORM CONDITIONS Waveform measurement system should have a min. bandwidth of 5 times the frequency being tested. 6.回流焊曲线 Reflow Profiles Page:4 深圳市晶友嘉电子有限公司 SHENZHEN JINGYOUJIA ELECTRONIC CO.,LTD 7.机械可靠/信赖性 Mechanical Performance Item 1. 2.. Drop characteristics Shake characteristics Condition Standard Free drop from 50cm height on a hard Frequency change: wooden board for 3 times. (Board is ≤5ppm thickness more than 30 mm.) Rr as specification Shake frequency 10~55Hz, cyc1~2 Frequency change: minutes, swing 1.5mm, direction x/y/z, all ≤5ppm 30 minutes, test after 1 hours. Rr as specification Put crystal into the pressure cabin with 3. Airproof alcohol, keep pressure 0.4~0.5mpa 10 characteristics minutes, then take out and blow for 5 IR≥500MΩ minutes 4. 5. 6. 7. 8. Weld characteristics Humidity characteristics 260℃ Max, 10 seconds 90% exhibit tin ok Frequency change: +40±2℃ & 90%~95% R.H. 250 hours ≤5ppm Rr as specification Low temperature -30±2℃, 250 hours, put in room characteristics temperature, test after 1 hours. High temperature +85±2℃, 250 hours, put in room characteristics temperature, test after 1 hours. Temperature -30±3℃/30±3 min~+85±2℃/30±3min, 5 cycling cycles Page:5 Frequency change: ≤5ppm Rr as specification Frequency change: ≤5ppm Rr as specification Frequency change: ≤5ppm Rr as specification 深圳市晶友嘉电子有限公司 SHENZHEN JINGYOUJIA ELECTRONIC CO.,LTD 8.Dimension of Inside Package .5 ± 02 08 06 04 3- 10 + 0/-0 0180 .0 08 06 06 0.0 Ho le 04 Ps 01 3.0 3-2.0 ±0.5 02 + 1/- 0 ± 0 .2 0 .4 1. 5 内包装尺寸图 Ho le 01 3. 0 ±0. 5 La b el 17 .0± 0.3 * 1 19. 4 ±1 * 2 G J T * 1 -5032, - 4025: 13.0±0 .3, -3225 : 9.0±0 .3 * 2 -50 32, -4 025:15 .4±1.0 , -322 5 : 11. 4±1.0 *3 -S e ries : 3 30 B C D E H # 2#3 F Q K A Direc tio n z Standard quantity of 3225 : 3.000 pcs/reel z Standard quantity of others : 1.000 pcs/reel z Carrier tape : Antistatic material (PS) z Each reel can be recycled Page:6 深圳市晶友嘉电子有限公司 SHENZHEN JINGYOUJIA ELECTRONIC CO.,LTD 7050 6035 5032 3225 A 5.4±01 3.9±0.1 3.5±0.1 2.9±0.1 B 7.4±0.1 6.4±0.1 5.4±0.1 3.6±0.1 C 16.0±0.2 16.0±0.2 12.0±0.2 10.0±0.2 D 7.5±0.1 7.5±0.1 5.5±0.1 5.5±0.1 E 1.75±0.1 1.75±0.1 1.75±0.1 1.75±0.1 F 8.0±0.1 8.0±0.1 8.0±0.1 4.0±0.1 G 2.0±0.1 2.0±0.1 2.0±0.1 2.0±0.1 H 4.0±0.1 4.0±0.1 4.0±0.1 4.0±0.1 J 1.55±0.05 1.55±0.05 1.5+0.1/0 1.5±0.1/0 K 1.4±0.1 1.5±0.1 1.0±0.1 0.9±0.1 Q 1.6+0.1/0 1.55±0.05 1.6±0.1 1.5±0.1/0 T 0.3±0.05 0.3±0.05 0.25±0.05 0.25±0.05s 9.Inner carton A nt istat ic bag Seal Reel L abl e L able Reel Page:7
3TO480000CWBD
物料型号为3TO4,客户料号为C2986075,我司料号为3TO480000CWBD。
该石英晶体谐振器的频率为8.000MHz,工作温度范围为-40°C至85°C,存储温度范围为-55°C至105°C。
频率稳定性为±20ppm,供电电压为3.3V,电流消耗为20mA,输出类型为CMOS,输出负载为15pF,高电平输出电压为90%VDD,低电平输出电压为10%VDD,上升时间为8ns,下降时间为8ns,占空比为40%-60%,启动时间为10ms。
封装信息包括外型尺寸Outline Dimensions,PAD功能为1: ENABLE CONTROL, 2: GND, 3: OUT, 4: VDD。
回流焊曲线Reflow Profiles和机械可靠性Mechanical Performance也包含在文档中。
内包装尺寸图Dimension of Inside Package和不同封装尺寸参数如7050、6035、5032、3225的详细尺寸数据也提供在文档中。
3TO480000CWBD 价格&库存
很抱歉,暂时无法提供与“3TO480000CWBD”相匹配的价格&库存,您可以联系我们找货
3TO480000CWBD
    • 1+5.10840
    • 10+4.13640
    • 30+3.63960
    库存:3
