4058075454446
4058075454446
    OTHER
4058075454446 数据手册
Product datasheet ST8V-EM 7.3 W/830 600 mm SubstiTUBE Value | Economic LED tubes for electromagnetic control gears _ General illumination within ambient temperatures from 20…+45 °C Corridors, stairways, parking garages Industry Warehouses Cooling and storage rooms Warehouses Domestic applications Supermarkets and department stores __ _ No bending thanks to glass technology Energy savings of up to 65 % (compared to T8 fluorescent lamp on CCG) Quick, simple and safe replacement without rewiring Instant-on light, therefore ideally suitable in combination with sensor technology Very high resistance to switching loads Also suitable for operation at low temperatures April 16, 2021, 14:28:14 ST8V-EM 7.3 W/830 600 mm © 2021, OSRAM GmbH. All rights reserved. Page 1 of 4 Product datasheet Technical data Electrical data Rated wattage 7.30 W Operating frequency 50…60 Hz Max. lamp no. on circuit break. 10 A (B) 200 Max. lamp no. on circuit break. 16 A (B) 320 Nominal wattage 7.30 W Nominal voltage 220…240 V Nominal current 0.035 A Claimed equiv. conventional lamp power 18 W Photometrical data __ Standard deviation of color matching ≤6 sdcm Rated luminous flux 720 lm Nominal luminous flux 720 lm Rated color temperature 3000 K Color rendering index Ra ≥80 Color temperature 3000 K Light color (designation) Warm White Luminous flux 720 lm Lumen main.fact.at end of nom.life time 0.70 Light technical data Beam angle 190 ° Starting time < 0.5 s Dimensions & weight Product weight April 16, 2021, 14:28:14 ST8V-EM 7.3 W/830 600 mm 100.00 g © 2021, OSRAM GmbH. All rights reserved. Page 2 of 4 Product datasheet Length 603.0 mm Outer bulb T8 Overall length 603.0 mm Diameter 26.7 mm Temperatures & operating conditions Ambient temperature range -20…+45 °C Lifespan Nominal lamp life time 30000 h Rated lamp life time 30000 h Lumen maintenance at end of service life 0.70 Number of switching cycles 200000 Additional product data __ Appropriate disposal acc. to WEEE Yes Mercury content 0.0 mg Mercury-free Yes Base (standard designation) G13 Capabilities Dimmable No Certificates & standards Energy efficiency class A+ Energy consumption 8 kWh/1000h Type of protection IP20 Country specific categorizations Order reference ST8V-0.6M 7,3W/ Logistical Data Product code Product description Packaging unit (Pieces/Unit) Dimensions (length x width x height) Volume Gross weight 4058075454446 ST8V-EM 7.3 W/830 600 mm Shipping carton box 10 Pieces Sleeves 690 mm x 210 mm x 115 mm 16.66 dm³ 1652.00 g The mentioned product code describes the smallest quantity unit which can be ordered. One shipping unit can contain one or more single products. When placing an order, for the quantity please enter single or multiples of a shipping unit. April 16, 2021, 14:28:14 ST8V-EM 7.3 W/830 600 mm © 2021, OSRAM GmbH. All rights reserved. Page 3 of 4 Product datasheet Disclaimer Subject to change without notice. Errors and omission excepted. Always make sure to use the most recent release. __ April 16, 2021, 14:28:14 ST8V-EM 7.3 W/830 600 mm © 2021, OSRAM GmbH. All rights reserved. Page 4 of 4
4058075454446 价格&库存
很抱歉,暂时无法提供与“4058075454446”相匹配的价格&库存,您可以联系我们找货
