4050300008974
4050300008974
    OTHER
4050300008974 数据手册
Product datasheet L 13 W/640 Basic T5 Short | Tubular fluorescent lamps 16 mm, short, with G5 base _ Shops Supermarkets and department stores Public buildings __ _ Ideal for cost-effective creative illumination and decoration Very good luminous flux maintenance throughout the life of the lamp Slim and compact May 2, 2021, 11:19:06 L 13 W/640 © 2021, OSRAM GmbH. All rights reserved. Page 1 of 6 Product datasheet Technical data Electrical data Nominal wattage 13.00 W Rated lamp efficacy (HF data 25 °C) Under clarification by authority and standardization body Rated wattage 13.00 W Photometrical data __ Rated lamp efficacy (standard condition) 64 lm/W Color rendering index Ra ≥60 Rated luminous flux 830 lm Luminous flux at 830 lm Light color 640 Rated color temperature 4000 K Nominal luminous flux 830 lm Light color (designation) Cool White Rated LLMF at 2,000 h 0.85 Rated LLMF at 4,000 h 0.78 Rated LLMF at 6,000 h 0.72 Rated LLMF at 8,000 h 0.68 Color temperature 4000 K Luminous flux 830 lm Dimensions & weight Tube diameter 16 mm Length 517.0 mm Length with base excl. base pins/connection 517.00 mm Diameter 16.0 mm May 2, 2021, 11:19:06 L 13 W/640 © 2021, OSRAM GmbH. All rights reserved. Page 2 of 6 Product datasheet Product weight 45.00 g Outer bulb T16 Maximum diameter 16.0 mm Temperatures & operating conditions Rated ambient temp.w.max.luminous flux 35.0 °C Lifespan 1) Lifespan 8000 h Rated lamp survival factor at 2,000 h 0.99 Rated lamp survival factor at 4,000 h 0.99 Rated lamp survival factor at 6,000 h 0.95 Rated lamp survival factor at 8,000 h 0.81 Operation mode LLMF/LSF HF Rated lamp life time 10000 h 1) With CCG/LLCG Additional product data __ Base (standard designation) G5 Mercury content 2.5 mg Appropriate disposal acc. to WEEE Yes Capabilities Suitable for indoor Yes Certificates & standards Energy efficiency class A Energy consumption 15 kWh/1000h Country specific categorizations Order reference May 2, 2021, 11:19:06 L 13 W/640 L 13W/640 © 2021, OSRAM GmbH. All rights reserved. Page 3 of 6 Product datasheet Light Distribution FL_640 __ System guarantee OSRAM System+ Guarantee in combination with OSRAM ECGs QUICKTRONIC QT 1x May 2, 2021, 11:19:06 L 13 W/640 QUICKTRONIC INTELLIGENT QT i 1x QTP 5 1x © 2021, OSRAM GmbH. All rights reserved. Page 4 of 6 Product datasheet QUICKTRONIC INTELLIGENT QT i 2x QTP 5 2x Logistical Data Product code Product description Packaging unit (Pieces/Unit) Dimensions (length x width x height) Volume Gross weight 4050300008974 L 13 W/640 Shipping carton box 25 Pieces Sleeves 550 mm x 115 mm x 106 mm 6.70 dm³ 1638.00 g The mentioned product code describes the smallest quantity unit which can be ordered. One shipping unit can contain one or more single products. When placing an order, for the quantity please enter single or multiples of a shipping unit. __ References / Links For more information on QUICKTRONIC electronic control gear go to www.osram.com/QUICKTRONIC Disclaimer Subject to change without notice. Errors and omission excepted. Always make sure to use the most recent release. May 2, 2021, 11:19:06 L 13 W/640 © 2021, OSRAM GmbH. All rights reserved. Page 5 of 6 Product datasheet L 13 W/640 Basic T5 Short | Tubular fluorescent lamps 16 mm, short, with G5 base Product name Product name ECG EAN Nominal current Nominal wattage + Power loss Power factor λ [PIM] Luminous flux at 35 °C L 13 W/640 QT-ECO 1x4-16/220-240 S 4050300638584 0.08 A 15.00 W 0.60 c 950 lm Product name Product name ECG EAN Number of lighting outlets L 13 W/640 QT-ECO 1x4-16/220-240 S 4050300638584 1 __ May 2, 2021, 11:19:06 L 13 W/640 © 2021, OSRAM GmbH. All rights reserved. Page 6 of 6
4050300008974 价格&库存
很抱歉,暂时无法提供与“4050300008974”相匹配的价格&库存,您可以联系我们找货
