6069-471-005
6069-471-005
    DIGILENT(迪芝伦)
    DIGILENT - 6069-471-005 - Multifunction Temperature & Voltage Devices, 1 kSPS, 24bit, 32I/P, 4O/P, 2...
6069-471-005 数据手册
USB-2416 Series 24-Bit Multifunction Temperature & Voltage Devices Features • Measure thermocouples or voltage • 32 analog inputs, expandable to 64 • 24-bit resolution • 1 kS/s sampling • Up to 4 analog outputs • 8 digital I/O, expandable to 24 • Two counters • Regulated power supply included Supported Operating Systems The USB-2416 Series offers high-resolution voltage or thermocouple measurements along with digital I/O. Analog output functionality is available with the USB-2416-4AO. • Windows® 11/10/8/7/Vista®/ XP 32/64-bit • Linux® Overview The USB-2416 Series offers exceptional performance and accuracy for voltage and temperature measurements. Designed for the USB bus, each device provides up to 32 analog input channels with 24-bit resolution, 8 digital I/O and two counter inputs. The USB-2416-4AO also features four analog outputs. Connect to the AI-EXP32 expansion device for an additional 32 channels of analog input and 16 digital I/O lines. Analog inputs are user-configurable for voltage or thermocouple input on a perchannel basis. Analog Input Each device provides 32 SE/16 DIFF analog inputs, expandable to 64 SE/32 DIFF. Software-selectable voltage input ranges are configurable per-channel. USB-2416 Series devices can sample analog input channels at up to 1 kS/s. Open thermocouple detection is automatically enabled for thermocouple measurements. The USB-2416-4AO provides four 16-bit analog outputs with a ±10 V output range. The analog outputs can be updated at a maximum rate of 1 kS/s (systemdependent). USB-2416 Series Selection Chart Analog Inputs Throughput Rate Analog Outputs Digital I/O Counters USB-2416 32 SE/16 DIFF Up to 1 kS/s — 8 2 USB-2416-4AO 32 SE/16 DIFF Up to 1 kS/s 4 8 2 USB-2416 with AI-EXP32 64 SE/32 DIFF Up to 1 kS/s — 24 2 USB-2416-4AO with AI-EXP32 64 SE/32 DIFF Up to 1 kS/s 4 24 2 (508) 946-5100 1 USB-2416 Series devices provide eight digital I/O lines with read/write rates of 500 port or single bit reads per second. Each DIO channel is an open-drain. Digital outputs can sink up to 150 mA for direct drive applications. The maximum sink current is 150 mA per eight-channel bank, or if all eight channels are used, 18 mA (maximum) per channel. Counter Input Analog Output (USB-2416-4AO Only) Model Measurement Computing Digital I/O Each device has two 32-bit event counters that accept frequency inputs up to 1 MHz. The internal counter increments when the TTL levels transition from low to high. Channel Expansion with the AI-EXP32 The AI-EXP32 expansion device provides an additional 32 SE/16 DIFF analog inputs and 16 DIO lines. The AI-EXP32 supports all analog/thermocouple input and digital I/O features of the USB-2416 Series devices to which it is connected. The USB-2416 Series docks directly to the AI-EXP32 with an expansion connector on each device (see page 5). No additional cable is required. Refer to the hardware user’s guide for detailed information. The AI-EXP32 receives power from the connected USB-2416 Series device. info@mccdaq.com mccdaq.com USB-2416 Series Features Calibration Power The USB-2416 Series is factory-calibrated using a NIST-traceable calibration process. Specifications are guaranteed for one year. The USB-2416 Series receives power from the PS-5V2AEPS external supply that ships with the device. The USB-2416 Series also supports field calibration for users to calibrate the device locally with the InstaCal utility. USB-2416 Series Block Diagram Voltage circuit Mux ADC Input Multiplexers PGA TC input circuit Screw terminals DGND +2.5 V GND DIO 8 Digital isolator Isolated microcontroller Quad DAC Non-isolated micocontroller USB 4 USB-2416-4AO only Measurement Computing (508) 946-5100 2 info@mccdaq.com mccdaq.com USB-2416 Series Software Software Support USB-2416 Series devices are supported by the software in the table below. Ready-to-Run Applications DAQami™ Data acquisition companion software with drag-and-drop interface that is used to acquire, view, and log data, and generate signals. DAQami can be configured to log analog, digital, and counter channels, and to view that data in real-time or post-acquisition on user-configurable displays. Logged data can be exported for use in Excel® or MATLAB®. Windows OS DAQami is included with the free MCC DAQ Software bundle. InstaCal™ TracerDAQ™ and TracerDAQ Pro An interactive installation, configuration, and test utility for MCC hardware. Windows OS InstaCal is included with the free MCC DAQ Software bundle. Virtual strip chart, oscilloscope, function generator, and rate generator applications used to generate, acquire, analyze, display, and export data. Supported features may vary by hardware. The Pro version provides enhanced features. Windows OS TracerDAQ is included with the free MCC DAQ Software bundle. TracerDAQ Pro is available as a purchased software download. General-Purpose Programming Support Universal Library™ (UL) for Windows Library for developing applications in C, C++, VB, C# .Net, VB .Net, and Python on Windows. The UL for Windows is included with the free MCC DAQ Software bundle. The UL Python API for Windows is available on GitHub (github.com/mccdaq/mcculw). Library for developing applications in C, C++, and Python on Linux. UL for Linux® UL for Linux is available on GitHub (github.com/mccdaq/uldaq). Open-source, third-party Linux drivers are also available for supported MCC devices. Application-Specific Programming Support ULx for NI LabVIEW™ DASYLab® Measurement Computing A comprehensive library of VIs and example programs for NI LabVIEW that is used to develop custom applications that interact with most MCC devices. Windows OS ULx for NI LabVIEW is included with the free MCC DAQ Software bundle. Icon-based data acquisition, graphics, control, and analysis software that allows users to create complex applications in minimal time without text-based programming. Windows OS DASYLab is available as a purchased software download. An evaluation version is available for 28 days. (508) 946-5100 3 info@mccdaq.com mccdaq.com USB-2416 Series Specifications Analog Voltage Output (USB-2416-4AO only) All specifications are subject to change without notice. Typical for 25 °C unless otherwise specified. All specifications apply to all temperature and voltage input channels unless otherwise specified. Leave unused VDACx channels disconnected. The output voltage defaults to 0 V when the host PC is reset, shut down or suspended. The duration of the output transient depends on the enumeration process of the host PC. Typically, the output of the USB-2416-4AO is stable after two seconds. Digital to analog converter: DAC8555 Number of channels: 4, 16-bit Output ranges Calibrated: ±10 V Uncalibrated: ±10.05 V, software configurable Output transient: Host PC is reset, powered on, suspended or a reset command is issued to device Duration: 2 s Amplitude: 2 V p-p Initial power on Duration: 50 ms Amplitude: 5 V peak Differential non-linearity: ±25 LSB, typ, ±1 LSB max Output current: VDACx pins, ±3.5 mA max Output short-circuit protection: VDACx connected to AGND, unlimited duration Output coupling: DC VDACx readback: Each output independently measured by the A/D converter, Power on and reset state: DACs cleared to zero-scale, 0 V, ±50 mV Output noise: 30 µVrms Settling time: To rated accuracy, 10 V step, 45 µs Slew rate: 1.0 V/µs Throughput Single-channel: 1000 S/s max, system-dependent Multi-channel: 1000 S/s /#ch max, system-dependent Calibrated absolute accuracy Range: ±10 V Accuracy (±LSB): 16.0 Calibrated absolute accuracy components Range: ±10 v % of reading: ±0.0183 Offset (±mV): 1.831 Temp drift (%/°C): 0.00055 Absolute accuracy at FS (±mV): 3.661 Relative accuracy Range: ±10 V Relative accuracy (±LSB): 4.0 typical Analog Input A/D converter type: ADS1256, 24-bit Sigma Delta A/D data rates: 3750 samples per second (S/s), 2000 S/s, 1000 S/s, 500 S/s, 100 S/s, 60 S/s, 50 S/s, 25 S/s, 10 S/s, 5 S/s, 2.5 S/s Throughput Single channel: 2.5 Hz to 1102.94 Hz, software-selectable Multiple channels: 0.16 Hz to 1102.94 Hz, software-selectable Number of channels: Up to 32 channels individually software configurable as single-ended or differential; thermocouples require differential mode Input isolation: 500 VDC min between field wiring and USB interface Channel configurations: Temperature sensor input, software programmable to match sensor type; voltage input Input voltage range Thermocouple mode: ±0.078125 V Voltage mode: ±20 V, ±10 V, ±5 V, ±2.5 V, ±1.25 V, ±0.625 V, ±0.3125 V, ±0.15625 V, ±0.078125 V, software configurable Absolute maximum input voltage: CxH-CxL relative to GND, ±30 V max (power on), ±10 V max (power off) Input impedance: 2 GΩ (power on), 390 Ω (power off) Input leakage current: ±10.6 nA Input capacitance: 590 pf Maximum working voltage (signal+common mode): Voltage mode (±20 V): ±20.01 V max Voltage mode (all other voltage ranges): ±10.25 V max Common mode rejection ratio Thermocouple mode (fIN = 60 Hz): 110 dB Voltage mode (fIN = 60 Hz, all input ranges): 90 dB ADC resolution: 24 bits Crosstalk: Adjacent channels,100 dB Input Coupling: DC Channel gain queue: Up to 64 elements, software configurable channel and range Warm-up time: 45 minutes min Open thermocouple detect: Enabled when configured for a thermocouple sensor CJC sensor accuracy: 15 °C to 35 °C, ±0.15 °C typ; 0 °C to 55 °C, ±0.5 °C max Channel Configurations Channel Category Configuration CxH/CxL Thermocouple 16 differential CxH/CxL Voltage Up to 32, individually configurable as either single ended or differential Digital Input Number of I/O: 8 Configuration: independently read from (DIN) or written to (DOUT) Input voltage range: 0 V to 15 V Input type: CMOS (Schmitt trigger) Input characteristics: 47 kW pull-up/pull-down resistor, 28 kW series resistor Maximum input voltage range: 0 V to 20 V max (power on/off, relative to DGND) Pull-up/pull-down configuration: All pins pulled up to +5 V via individual 47 kΩ resistors; pull-down is available with an onboard jumper. Transfer rate (software paced): 500 port reads or single bit reads per second typical. Input high voltage: 1.3 V min, 2.2 V max Input low voltage: 1.5 V max, 0.6 V min Schmitt trigger hysteresis: 0.4 V min, 1.2 V max Compatible Sensors Thermocouple Sensor Types J: –210 °C to 1200 °C T: –270 °C to 400 °C K: –270 °C to 1372 °C N: –270 °C to 1300 °C R: –50 °C to 1768 °C E: –270 °C to 1000 °C S: –50 °C to 1768 °C B: 0 °C to 1820 °C Digital Output Number of I/O: 8 Configuration: independently read from (DIN) or written to (DOUT) Output characteristics: 47 kΩ pull-up, open drain (DMOS transistor) Pull-up configuration: All pins pulled up to +5 V via individual 47 kΩ resistors. Transfer rate (software paced) Digital output: 500 port writes or single bit writes per second typical. Output voltage range: 0 V to 5 V (no external pull up resistor, internal 47 kΩ pull-up resistors connected to 5 V by default); 0 V to 15 V max Drain to source breakdown voltage: 50 V min Off state leakage current: 0.1 µA Sink current capability: 150 mA max (continuous) per output pin, 150 mA max (continuous) for all eight channels DMOS transistor on-resistance (drain to source): 4 Ω Accuracy Refer to the user’s guide for thermocouple and voltage measurement accuracy tables. Throughput Rate The maximum throughput is 1.1 kS/s aggregate. Users can set conversion rates on a per-channel basis. Refer to the hardware user’s guide for single- and multichannel throughput rates. Measurement Computing (508) 946-5100 4 info@mccdaq.com mccdaq.com USB-2416 Series Ordering Counter Input Mechanical Pin name: CTR0, CTR1 Number of channels: 2 Resolution: 32-bits Counter type: Event counter Input type: Schmitt trigger, rising edge triggered Counter read/writes rates: System dependent, 500 reads per second Input characteristics: Each CTRx input pin, 562 kΩ to +5 V, 10 kΩ series resistor Input voltage range: ±15 V max Maximum input voltage range: CTR0,CTR1 relative to GND and DGND, ±20 V max (power on/off) Input high voltage: 1.3 V min, 2.2 V max Input low voltage: 1.5 V max, 0.6 V min Schmitt trigger hysteresis: 0.4 V min, 1.2 V max Input bandwidth (–3 dB): 1 MHz Input capacitance: 25 pf Input leakage current: ±120 nA Input frequency: 1 MHz, max High pulse width: 500 ns, min Low pulse width: 500 ns, min Dimensions (L × W × H): 245 × 146 × 50 mm (9.65 × 5.75 × 1.97 in.) User connection length: 5 m (16.40 ft) max Environmental Operating temperature range: 0 °C to 50 °C max Storage temperature range: –40 to 85 °C max Humidity: 0 to 90% non-condensing max These specifications do not apply to the AC power adapter. Power Supply current: Quiescent current, 340 mA Voltage supervisor limits: 4.5 V > Vext or Vext > 5.5 V PWR LED = Off, (power fault); 4.5 V < Vext < 5.5 V, PWR LED = On +5 V user output voltage range: 4.9 V min to 5.1 V max User +5V user output current: Available at terminal block pin 35, 10 mA max Isolation: Measurement system to PC, 500 VDC min AC power adapter: MCC p/n PS-5V2AEPS; included with hardware External power input: +5 VDC, 2.4 A, 12 Watt, 5% regulation Order Information Accessories Hardware Part No. Description USB-2416 24-bit, isolated, high-channel-count USB DAQ device. Includes USB cable and power adapter. USB-2416-4AO 24-bit, isolated, high-channel-count, USB DAQ device with 4 analog outputs. Includes USB cable and power adapter. AI-EXP32 Analog input expansion module for USB-2416 Series USB-2416-Series.indd (508) 946-5100 Description ACC-202 DIN-rail kit. ACC-216 Connector kit with 6 detachable screw terminals. PS-5V2AEPS Replacement power supply, 12-watt. Interchangeable plugs are available separately. 745690-E001 E-type thermocouples wire, fiberglass (0 °C to 482 °C, 32 °F to 900 °F), 1 m 745690-E002 E-type thermocouples wire, fiberglass (0 °C to 482 °C, 32 °F to 900 °F), 2 m 745690-J001 J-type thermocouples wire, fiberglass (0 °C to 482 °C, 32 °F to 900 °F), 1 m 745690-J002 J-type thermocouples wire, fiberglass (0 °C to 482 °C, 32 °F to 900 °F), 2 m 745690-K001 K-type thermocouples wire, fiberglass (0 °C to 482 °C, 32 °F to 900 °F), 1 m 745690-K002 K-type thermocouples wire, fiberglass (0 °C to 482 °C, 32 °F to 900 °F), 2 m 745690-T001 T-type thermocouples wire, fiberglass (0 °C to 482 °C, 32 °F to 900 °F), 1 m 745690-T002 T-type thermocouples wire, fiberglass (0 °C to 482 °C, 32 °F to 900 °F), 2 m Software also Available from MCC The USB-2416 Series docked to the AI-EXP32 Measurement Computing Part No. 5 Part No. Description TracerDAQ Pro Out-of-the-box virtual instrument suite with strip chart, oscilloscope, function generator, and rate generator – professional version DASYLab Icon-based data acquisition, graphics, control, and analysis software info@mccdaq.com mccdaq.com September 2019. Rev 9 © Measurement Computing Corporation
6069-471-005 价格&库存
很抱歉,暂时无法提供与“6069-471-005”相匹配的价格&库存,您可以联系我们找货
