6069-410-025
6069-410-025
    DIGILENT(迪芝伦)
    MCC E-TC Thermocouple Measurement Ethernet DAQ Device
6069-410-025 数据手册
E-TC Ethernet-based 8-Channel Thermocouple Input Device Features • Eight 24-bit differential thermocouple (TC) inputs with TC channel-to-host isolation − 4 S/s per channel maximum sample rate − Two integrated cold junction compensation (CJC) sensors − Open thermocouple detection − Supports J, K, R, S, T, N, E, and B type thermocouples • 8 digital I/O isolated from TC inputs and host The E-TC devices offers eight thermocouple channels and eight DIO channels which are bitconfigurable for input or output. Output bits can be further configured as thermocouple alarms. − ±24 mA drive capability • 10/100 Ethernet interface Overview The E-TC offers high-accuracy temperature measurement with an Ethernet interface. The device offers the best value per channel and the best possible accuracy because the accuracy of the internal measurement electronics exceeds the accuracy specifications of the thermocouple sensors. The E-TC is functionally equivalent to the USB-TC, making application migration very easy. Ethernet Interface Digital I/O The E-TC has a built-in high-speed communication port. Users can remotely access and configure the device with software over the Internet. The E-TC has eight digital I/O channels that are electrically isolated from the analog circuits. Each bit is individually configurable for input or output. Thermocouple Input Connect up to eight differential thermocouple (TC) input channels to the E-TC. The E-TC supports a maximum sample rate of 4 S/s per channel, and TC types J, K, R, S, T, N, E, and B. TC types are software-selectable per channel. Cold-Junction Compensation The E-TC has two high-resolution coldjunction compensation (CJC) sensors (one per four TC inputs). Open-Thermocouple Detection The E-TC is equipped with open-thermocouple detection (OTD) for all TC input channels. With OTD enabled, users can monitor for broken or disconnected TCs. Measurement Computing − Digital outputs configurable as TC alarms Data can be transferred at rates up to 5 kS/s when the device and host are connected by Ethernet to the same local network. Typical throughput is system-dependent. • Required +5 V external power adapter included Supported Operating Systems • Windows 11/10/8/7/Vista® 32/64-bit • Linux® • Android™ Use the alarm outputs to control a device or application that indicates when a temperature threshold has been exceeded, or to indicate an OTC condition. Counter Input The 32-bit event counter pin counts TTL pulses, and accepts frequency inputs up to 10 MHz. All DIO channels are pulled high by default to 5 V through 47 kΩ resistors with a jumper on the circuit board. Each jumper configures the digital port for pull-up or pull-down. The E-TC requires external power from the 5 volt, 1 amp power adapter (PS-5V1AEPS) included with the device. Temperature Alarms Calibration Each digital output can be optionally configured as an alarm for each TC input. When an alarm is enabled, the output line associated with the alarm is driven to the appropriate state determined by the alarm options and input temperature. The E-TC is factory-calibrated using a NIST-traceable calibration process. Specifications are guaranteed for one year. For calibration beyond one year, return the device to the factory for recalibration. (508) 946-5100 1 Power The E-TC also offers field calibration so that users can calibrate a device locally. info@mccdaq.com mccdaq.com E-TC Software Software Support The E-TC is supported by the software in the table below. Ready-to-Run Applications Data acquisition companion software with drag-and-drop interface that is used to acquire, view, and log data, and generate signals. DAQami can be configured to log analog, digital, and counter channels, and to view that data in real-time or post-acquisition on user-configurable displays. Logged data can be exported for use in Excel® or MATLAB®. Windows OS DAQami™ DAQami is included with the free MCC DAQ Software bundle. An interactive installation, configuration, and test utility for MCC hardware. Windows OS InstaCal™ InstaCal is included with the free MCC DAQ Software bundle. TracerDAQ™ and TracerDAQ Pro Virtual strip chart, oscilloscope, function generator, and rate generator applications used to generate, acquire, analyze, display, and export data. Supported features may vary by hardware. The Pro version provides enhanced features. Windows OS TracerDAQ is included with the free MCC DAQ Software bundle. TracerDAQ Pro is available as a purchased software download. General-Purpose Programming Support Universal Library™ (UL) for Windows UL for Android ™ Library for developing applications in C, C++, VB, C# .Net, VB .Net, and Python on Windows. The UL for Windows is included with the free MCC DAQ Software bundle. The UL Python API for Windows is available on GitHub (https://github.com/mccdaq/mcculw). Programming library of Java classes for programmers who develop apps for Android-based tablets and phones. UL for Android communicates with select MCC DAQ devices. Supports Android project development on Windows, Linux, Mac OS X UL for Android is included with the free MCC DAQ Software bundle. Library for developing applications in C, C++, and Python on Linux. UL for Linux ® UL for Linux is available on GitHub (https://github.com/mccdaq/uldaq). Open-source, third-party Linux drivers are also available for supported MCC devices. Application-Specific Programming Support ULx for NI LabVIEW™ DASYLab ® Measurement Computing A comprehensive library of VIs and example programs for NI LabVIEW that is used to develop custom applications that interact with most MCC devices. Windows OS ULx for NI LabVIEW is included with the free MCC DAQ Software bundle. Icon-based data acquisition, graphics, control, and analysis software that allows users to create complex applications in minimal time without text-based programming. Windows OS DASYLab is available as a purchased software download. An evaluation version is available for 28 days. (508) 946-5100 2 info@mccdaq.com mccdaq.com E-TC Specifications E-TC Block Diagram CH0H CH0L Screw Terminal CH7H CH7L Screw Terminal Isolation Barrier CH0-CH3 CH4-CH7 Input Filters Input Filters 24-bit ADC Digital Isolator 24-bit ADC Microcontroller Ethernet CJC Sensors (2) DIO0-DIO7 Digital I/O Counter +3.3 V Regulator Isolated Isolated Power Power Supply Supply +3.3 V +5 V +5 V Overvoltage/ Negative Supply Protection +3.3 V External Power Isolation Barrier Specifications Measurement sensitivity Thermocouple type J,K,T,E,N: 0.09 °C Thermocouple type R,S: 0.11 °C Thermocouple type B: 0.13 °C Measurement sensitivity is the smallest change in temperature that can be detected. Warm-up time: 20 minutes min Open thermocouple detect response time: 1 second CJC sensor accuracy (0 °C to 45 °C): ±0.20 °C typ, ±0.40 °C max Calibration method: Factory Recommended warm-up time: 20 minutes min Calibration interval: 1 year (factory calibration) All specifications are subject to change without notice. Typical for 25 °C unless otherwise specified. Thermocouple input A/D converters: Delta-Sigma ADC resolution: 24 bits Number of channels: 8 Input isolation (between any TCx channel and digital/chassis ground: 500 VDC absolute max Channel configuration: Software-selectable to match sensor type Differential input voltage range: ±0.128 V (calibration is performed at ±70 mV) Absolute maximum input voltage between any two TCx inputs: ±25 V (power on), ±25 V (power off) Differential input impedance: 40 MΩ Input current Open thermocouple detect disabled: 1 nA Open thermocouple detect enabled: 65 nA Common mode rejection (fIN = 50 Hz or 60 Hz): 100 dB Noise rejection: fIN = 50 Hz or 60 Hz: 75 dB Input bandwidth: 10 Hz Crosstalk between any two TCx inputs: –90 dB Sample rate: 4 Hz max (per channel) The enabled thermocouple inputs are continuously converted at the maximum A/D converter rate. If channels are enabled and have an open thermocouple connection, the sample rate will be lower. Input noise: 250 nV rms Gain error: 0.006 % Offset error: 3 µV Measurement Computing (508) 946-5100 Channel configurations Channel configuration is stored on EEPROM external to the isolated microcontroller by the firmware whenever any item is modified. Modification is performed by commands issued over Ethernet from an external application, and the configuration is made non-volatile through the use of the EEPROM. Thermocouple (J, K, S, R, B, E, T, or N; the factory default configuration is Type J): 8 differential channels Compatible thermocouples J: –210 °C to 1200 °C K: –270 °C to 1372 °C R: –50 °C to 1768 °C S: –50 °C to 1768 °C 3 info@mccdaq.com T: –270 °C to 400 °C N: –270 °C to 1300 °C E: –270 °C to 1000 °C B: 0 °C to 1820 °C mccdaq.com E-TC Specifications Accuracy Thermocouple measurement accuracy specifications include polynomial linearization, cold junction compensation, and system noise. The accuracy specifications assume the device is operated within its enclosure and has been warmed up for the recommended 20 minutes. Errors shown do not include inherent thermocouple error. Contact your thermocouple supplier for details on the actual thermocouple accuracy error. When thermocouples are attached to conductive surfaces, the voltage differential between multiple thermocouples must remain within ±1.8 V. For best results MCC recommends using electrically insulated thermocouples when possible. Thermocouple Measurement Accuracy, including CJC Measurement Error All Specifications are (±). J –210 1.896 0.823 2.228 0.990 0 0.760 0.328 0.815 0.364 S R B E T N Accuracy Error Typical (°C), 15 °C to 35 °C Accuracy Error Typical (°C), 0 °C to 45 °C Sensor Temperature (°C) K Accuracy Error Maximum (°C), 15 °C to 35 °C Accuracy Error Maximum (°C), 0 °C to 45 °C Sensor Type 1200 0.717 0.324 1.336 0.585 –210 2.196 0.938 2.578 1.141 0 0.787 0.334 0.848 0.377 1372 0.974 0.431 1.807 0.786 –50 2.144 0.711 2.566 1.053 250 1.595 0.528 1.888 0.775 1768 0.750 0.178 1.759 0.649 –50 2.266 0.749 2.715 1.113 250 1.617 0.534 1.917 0.786 1768 0.631 0.148 1.579 0.584 250 1.934 0.453 2.552 0.977 700 0.740 0.179 1.128 0.439 1820 0.482 0.137 1.213 0.492 –200 1.700 0.742 1.987 0.884 0 0.752 0.327 0.806 0.360 1000 0.629 0.285 1.142 0.500 –200 1.920 0.817 2.253 0.993 0 0.801 0.339 0.870 0.385 400 0.519 0.223 0.702 0.308 –200 2.125 0.876 2.518 1.101 0 0.857 0.351 0.940 0.412 1300 0.668 0.291 1.352 0.585 Input low voltage threshold: 0.8 V max Input low voltage limit: –0.5 V absolute min, 0 V recommended min Output high voltage: 4.4 V min (IOH = –50 µA); 3.76 V min (IOH = –24 mA) Output low voltage: 0.1 V max (IOL = 50 µA); 0.44 V max (IOL = 24 mA) Digital input/output Digital type: 5 V TTL input / CMOS output Number of I/O: One port of 8 bits, shared with temperature alarms Configuration: Each bit can be independently configured for input or output. Power on conditions: Power on reset is input mode, except when bits are configured to operate as alarms. Pull-up/pull-down configuration: The port has 47 kΩ resistors configurable as pull-up (default) or pull-down via internal jumper W1. Digital I/O transfer rate (system paced): 100 to 5000 reads/writes per second typ on a local network This is the typical throughput when the device and host are both connected by Ethernet to the same local network. Throughput can vary significantly, and typical throughput is not guaranteed, if a wireless connection is involved or data is sent over the internet. Power on and reset state: All bits are input unless the temperature alarm functionality is enabled for them. Input high voltage threshold: 2.0 V min Input high voltage limit: 5.5 V absolute max Measurement Computing (508) 946-5100 Temperature alarms Number of alarms: 8 (one per digital I/O line) Alarm functionality: Each alarm controls its associated digital I/O line as an alarm output. When an alarm is enabled, the I/O line that is associated with the alarm is set to output and driven to the appropriate state determined by the alarm options and input temperature. The alarm configurations are stored in non-volatile memory and loaded at power on. Alarm input modes (T1 and T2 can be independently set for each alarm) Alarm when input temperature >= T1, reset alarm when input temperature < T2 Alarm when input temperature T2 Alarm when input temperature is < T1 or > T2 4 info@mccdaq.com mccdaq.com E-TC Ordering LED displays and the Factory Reset button Alarm error modes Alarm on temperature reading only Alarm on temperature reading or open thermocouple error Alarm on open thermocouple error only Alarm output modes Disabled, digital I/O line may be used for normal operation Enabled, active high output (DIO line goes high when alarm condition is met) Enabled, active low output (DIO line goes low when alarm condition is met) Alarm latency: 1 second Alarm settings are applied when changed and at power-on. Temperatures are constantly converted on enabled channels and processed for alarm conditions regardless of the communications connectivity. Power LED (top) On: 4.2 V < Vext < 5.6 V Off: Vext < 4.2 V, Vext > 5.6 V (power fault) Power and Activity LEDs blink continuously in firmware update mode Activity LED (bottom) On: A valid host connection is established. Blinks: A command is received. Power and Activity LEDs blink continuously in firmware update mode Ethernet connector LEDs Left (green): Link/activity indicator; on when there is a valid Ethernet link, and blinks when network activity is detected. Right (yellow): Speed indicator; on for 100 Mbps, off for 10 Mbps or no link. Factory reset button: Resets network and alarm configuration settings to factory default values. Press and hold for 4 seconds: The Power and Activity LEDs both blink twice and turn off to indicate that network settings have been restored to default values. Release the button to allow the device to reset and use the default settings. If the reset button is released before the two LEDs blink, settings are not affected Hold the reset button at power on: Forces the device into firmware update mode in case of a failed firmware update. In this mode, both LEDs blink together constantly. The device may be returned to normal operation by cycling the power. Counter Counter type: Event counter Number of channels: 1 Input type: Schmitt trigger; fixed 47.5 kΩ pull-down resistor Resolution: 32 bits Schmitt trigger hysteresis: 0.6 V min, 1.7 V max Input high voltage threshold: 1.9 V min, 3.6 V max Input high voltage limit: 5.5 V absolute max Input low voltage threshold: 1.0 V min, 2.3 V max Input low voltage limit: –0.5 V absolute min, 0 V recommended min Input frequency: 10 MHz max High pulse width: 50 ns min Low pulse width: 50 ns min Environment Operating temperature range: 0 °C to 55 °C Storage temperature range: –40 °C to 85 °C Humidity: 0 °C to 90% non-condensing Memory EEPROM: 4,096 bytes Mechanical Power Dimensions: 117.9 × 82.8 × 29.0 mm (4.64 × 3.26 × 1.14 in.) External power supply: 5 V ±5% required; 5 V, 1 A supply provided (PS-5V1AEPS) Supply current: Quiescent current: 177 mA typ This is the total quiescent current requirement for the device that includes the LEDs. This value does not include any potential loading of the digital I/O bits or +VO terminal. User output voltage range (available at +VO terminal): 4.40 V min to 5.25 V max; assumes supplied AC adapter is used User output current: Available at +VO terminal: 10 mA max Isolation: Measurement system to chassis ground: 500 VDC min Screw terminal connector Connector type: Screw terminal Wire gauge range: 16 AWG to 30 AWG Order Information Hardware Network Part No. Description Ethernet connection E-TC Ethernet-based 24-bit, 8-channel thermocouple input device with 8 bit-configurable DIO lines. Includes, Ethernet cable, power supply, and MCC DAQ software. Functionally equivalent to the USB-TC. Ethernet type: 100 Base-TX, 10 Base-T Communication rates: 10/100 Mbps, auto-negotiated Connector: RJ-45, 8 position Cable length: 100 meters (328 feet) max Additional parameters: HP Auto-MDIX support Accessories and Cables Network interface Protocols used: TCP (IPv4 only) and UDP Network ports used UDP: 54211 (discovery) UDP: 6234 (bootloader only) TCP: 54211 (commands) Network IP configuration: DHCP + link-local, DHCP, static, link-local Network name: E-TC-xxxxxx, where xxxxxx are the lower 6 digits of the device MAC address Network name publication: By NBNS; responds to b-node broadcasts, therefore only available on the local subnet Part No. Description PS-5V1AEPS 5 volt, 1 amp power supply. Shipped with the E-TC – interchangeable plugs available separately ACC-205 DIN-rail kit; compatible with the E-TC Software also Available from MCC Network Factory Default Settings Factory default IP address: 192.168.0.101 Factory default subnet mask: 255.255.255.0 Factory default Gateway: 192.168.0.1 Factory default DHCP setting: DHCP + link-local enabled Network Security Part No. Description TracerDAQ Pro Out-of-the-box virtual instrument suite with strip chart, oscilloscope, function generator, and rate generator – professional version DASYLab Icon-based data acquisition, graphics, control, and analysis software Security implementation: TCP sockets are not opened unless application sends the correct PIN connection code; stored in non-volatile memory; may be changed by user; default value is 0000 Number of concurrent sessions: 1 Vulnerabilities: TCP Sequence Number Approximation Vulnerability Measurement Computing DS E-TC.indd (508) 946-5100 5 info@mccdaq.com mccdaq.com April 2020. 4 © Measurement Computing Corporation
6069-410-025 价格&库存
很抱歉,暂时无法提供与“6069-410-025”相匹配的价格&库存,您可以联系我们找货
  • 1+5165.51311
库存:3
