6069-410-056
6069-410-056
    DIGILENT(迪芝伦)
    DIGILENT - 6069-410-056 - Relay Interface Device, Electromechanical, USB 1.1, USB 2.0, USB 3.0, SPDT...
6069-410-056 数据手册
USB DIO High Voltage and Relay USB-PDISO8, USB-ERB, and USB-SSR Series Features • USB-PDISO8 Series − 8 Form C relays − 8 isolated AC or DC inputs • USB-ERB Series USB-PDISO8 Series USB-ERB Series − 8 or 24 Form C singlepole double-throw (SPDT) electromechanical relays. USB-SSR Series Overview • USB-SSR Series − 8 or 24 input or output channels to control and monitor solid state relays. Measurement Computing DIO high voltage and relay USB product offerings include the USB-PDISO8 Series, USB-ERB Series, and USB-SSR Series. The USB-PDISO8 Series offers eight isolated AC or DC inputs and eight electromechanical relays in a single digital I/O system. The USB-ERB Series enables a PC or laptop to control eight to 24 electromechanical relays. • Screw terminal or header connectors The USB-SSR Series can monitor and control eight to 24 standard size solid state relay (SSR) I/O modules (relays sold separately). • Heavy-duty chassis with integrated mounting slots All devices in these series come in a heavy-duty metal enclosure with integrated mounting slots, which ensures that the devices are rugged enough for any DAQ application. • Includes external power supply (required for all devices) Relay Contacts and Connectors SSR Digital I/O Control Modules USB-PDISO8/USB-ERB Series Only USB-SSR Series Only The USB-PDISO8 and USB-ERB Series devices provide screw terminal connections to the relay contacts. The USB-PDISO8/40 provides relay connections through a 40 pin connector. Each relay has a normally closed (NC), common (C), and normally open (NO) contact. Relays on all devices are controlled by digital I/O lines. Supported Operating Systems • Windows 11/10/8/7/Vista®/XP 32/64‑bit • Linux® The USB-SSR08 provides mounting locations for eight SSR digital I/O modules, and the USB-SSR24 provides mounting locations for 24 SSR modules. The SSR modules use a standard color scheme to help quickly identify the module type installed. SSR digital I/O modules are relay control modules that provide 4000 Vrms of optical isolation. Digital input modules sense AC/DC voltages from field devices and convert them to digital TTL signals. Digital output modules use TTL signals to switch and control AC/DC loads. A wide selection of SSR digital I/O modules are available to switch or sense a large range of AC or DC voltages. Compatible SSR modules are available separately (refer to SSR Digital I/O Modules on page 10). USB-PDISO8 Series, USB-ERB Series, and USB-SSR Series Selection Chart Model Relay Channels Contact Rating Daisy Chain Support* Signal I/O Connector USB-PDISO8 8 Form C (SPDT) 6 amps at 240 VAC/28 VDC ✔ 40-pin screw terminal USB-PDISO8/40 8 Form C (SPDT) 6 amps at 240 VAC/28 VDC ✔ 40-pin header connector USB-ERB08 8 Form C (SPDT) 6 amps at 240 VAC/28 VDC ✔ 24-pin screw terminal USB-ERB24 24 Form C (SPDT) 6 amps at 240 VAC/28 VDC ✔ 72-pin screw terminal USB-SSR08 8 Solid State Relay Modules – ✔ 16-pin screw terminal USB-SSR24 24 Solid State Relay Modules – ✔ 48-pin screw terminal * Use standard/included USB cable for communications daisy chain; user-supplied custom cable required for power daisy chain Measurement Computing (508) 946-5100 1 info@mccdaq.com mccdaq.com USB DIO High Voltage and Relay Features Daisy Chaining Multiple Devices I/O Module Type Switch USB-SSR Series devices have an onboard switch to configure each module group for either input or output. MCC high-voltage/relay DIO devices can be optionally daisy chained to connect to the USB bus through the high-speed hub on the host device. Up to four MCC USB devices can be daisy chained to a single USB port on the PC using the standard/ included USB cables. Devices are shipped with all modules configured for output. Input and output modules cannot be mixed within a group. Positive and negative relay contacts are brought out to screw terminals for field wiring connections. Make sure adequate power is provided to each connected device. You can use an independent power supply for each device, or connect a user-supplied custom cable to daisy chain power. Relay Configuration Switches USB‑ERB/USB-SSR Series Only Voltage Drop Devices are shipped with all relay banks/module groups configured for non-inverted logic and pull-up (relays/modules inactive on power-up). Supply Current A drop in voltage occurs with each device connected in a daisy chain configuration. The voltage drop between the power supply input and the daisy chain output is 0.5 V maximum. Factor in this voltage drop when configuring a daisy chain system to ensure that at least 6.0 VDC is provided to the last device in the chain. USB-SSR Series and USB-ERB Series devices have two onboard switches for configuring the relay logic polarity and output relay power-up state for each relay bank/SSR module group. The current configuration of each switch can be read back with software. The following devices may require addition external power adapters depending on the number of connected devices: Differential Isolated Digital Inputs USB-PDISO8 Series Only All eight inputs on USB-PDISO8 Series devices can be driven by either AC (50 Hz to 1000 Hz) or DC voltage, and can be read back as a single byte. Each input has a software-selectable filter with a time constant of 5 ms (200 Hz). The filter is required for AC inputs, and recommended for most DC inputs. Each module group can be set to either input or output (default). Input and output modules cannot be mixed within a group. Device External Power Consumption (All Relays/SSR Modules On) USB-PDISO8 Series Draws 820 mA from the 1.67 A supply USB-ERB08 Draws 750 mA from the 1.67 A supply USB-ERB24 Draws 1.5 A from 3 A supply USB-SSR24 Draws 800 mA from the 1.67 A supply USB-SSR08 Draws 300 mA from the 1.67 A supply Some devices may require their own external power supply in a daisy chain configuration. Up to eight optically isolated (500 V) digital input connection pairs are available from the signal I/O connector on USB-PDISO8 Series devices. If unsure as to how much current an application requires, MCC recommends providing separate power to each connected device. Each signal is applied to a bridge rectifier so that the input is not polarity-sensitive. External Power USB-PDISO8 Series devices require between 6.5 V and 12.5 V of external power. USB-SSR Series and USB-ERB Series devices require between 6.0 V and 12.5 V of external power. An external power connection using the included external power supply is required to activate relays and SSR modules, and to run tests in software. • USB-PDISO8 Series devices, USB-SSR Series devices, and the USB-ERB08 are powered by a 9 V, 1.67 A external power supply (CB-PWR-9) that ships with each device. • The USB-ERB24 is powered by an external 9 V, 3 A regulated power supply (CB-PWR-9V3A) that ships with the device. Measurement Computing (508) 946-5100 2 info@mccdaq.com mccdaq.com USB DIO High Voltage and Relay Software Software Support The USB-PDISO8, USB-ERB, and USB-SSR Series devices are supported by the software in the table below. Ready-to-Run Applications DAQami™ InstaCal™ TracerDAQ™ and TracerDAQ Pro (USB-PDISO8 Series digital inputs only) Data acquisition companion software with drag-and-drop interface that is used to acquire, view, and log data, and generate signals. DAQami can be configured to log analog, digital, and counter channels, and to view that data in real-time or post-acquisition on user-configurable displays. Logged data can be exported for use in Excel® or MATLAB®. Windows OS DAQami is included with the free MCC DAQ Software bundle. Install DAQami and try the fully-functional software for 30 days. After 30 days, all features except for data logging and data export will continue to be available – data logging and data export features can be unlocked by purchasing the software. An interactive installation, configuration, and test utility for MCC hardware. Windows OS InstaCal is included with the free MCC DAQ Software bundle. Virtual strip chart, oscilloscope, function generator, and rate generator applications used to generate, acquire, analyze, display, and export data. Supported features may vary by hardware. The Pro version provides enhanced features. Windows OS TracerDAQ is included with the free MCC DAQ Software bundle. TracerDAQ Pro is available as a purchased software download. General-Purpose Programming Support Universal Library™ (UL) for Windows Library for developing applications in C, C++, VB, C# .Net, VB .Net, and Python on Windows. The UL for Windows is included with the free MCC DAQ Software bundle. The UL Python API for Windows is available on GitHub (github.com/mccdaq/mcculw). Library for developing applications in C, C++, and Python on Linux. UL for Linux® UL for Linux is available on GitHub (github.com/mccdaq/uldaq). Open-source, third-party Linux drivers are also available for supported MCC devices. Application-Specific Programming Support ULx for NI LabVIEW™ DASYLab® MATLAB Driver ® A comprehensive library of VIs and example programs for NI LabVIEW that is used to develop custom applications that interact with most MCC devices. Windows OS ULx for NI LabVIEW is included with the free MCC DAQ Software bundle. Icon-based data acquisition, graphics, control, and analysis software that allows users to create complex applications in minimal time without text-based programming. Windows OS DASYLab is available as a purchased software download. An evaluation version is available for 28 days. High-level language and interactive environment for numerical computation, visualization, and programming. The Mathworks Data Acquisition Toolbox™ allows users to acquire data from most MCC PCI and USB devices. Visit www.MathWorks.com for more information about the Data Acquisition Toolbox. Measurement Computing (508) 946-5100 3 info@mccdaq.com mccdaq.com USB DIO High Voltage and Relay Specifications - USB-PDISO8 Series USB-PDISO8 Series Block Diagram Differential Isolated Inputs Form C Relay Outputs 0 to 7 7 Relays 0 to Inputs 0 to Relays 0 to 7 7Signal I/OInputs Control Control Control Connector Control USB-PDISO8: 24 screw terminals USB-PDISO8/40: 40-pin connector Control Registers 9V Nominal External Power 8 CLo Power Monitor CHi Power Regulator Relay Driver USB Controller 8 Specifications USB 2.0 USB Interface Voltage range (AC with filter) Input high: 6.0 Vrms min (50 Hz to 1000 Hz) Input low: 1.5 Vrms max (50 Hz to 1000 Hz) Response Filter disabled: 20 µs Filter enabled: 5 ms Filters Time constant: 5 ms (200 Hz) Filter control: Software-selectable for each input. Power-up /reset: Filters disabled All specifications are subject to change without notice. Typical for 25 °C unless otherwise specified. USB-PDISO8 Series Relay specifications Number: 8 Contact configuration: 8 FORM C (SPDT) NO, NC, and Common available at connector. Contact rating: 6 A @ 240 VAC or 28 VDC resistive (refer to Main Connector on page 5) Contact resistance: 100 mΩ max Operate time: 10 ms max Release time USB-PDISO8: 5 ms max USB-PDISO8/40: 10 ms max Vibration: 10 Hz to 55 Hz (dual amplitude 1.5 mm) Shock: 10 G (11 ms) Dielectric isolation: 500 V (1 minute) Life expectancy: 10 million mechanical operations, min Power on RESET state: Not energized. NC in contact to Common. Power USB +5 V input voltage range: 4.75 V to 5.25 V USB +5 V supply current: All modes of operation: 10 mA max External power input: 9 V nominal External power supply (required): MCC p/n CB-PWR-9: 9 V @ 1.67 A Voltage supervisor limits - PWR LED 6.5 V > Vext or Vext > 12.5 V: PWR LED = Off (power fault) USB-PDISO8 Series devices monitor the external +9 V power supply voltage with a voltage supervisory circuit. If this power supply exceeds its specified limit, the PWR LED turns off, indicating a power fault condition. 6.5 V ≤ Vext < 12.5 V: PWR LED = On External power consumption All relays on, 100 mA downstream hub power: 820 mA typ, 900 mA max All relays off, 0 A downstream hub power: 200 mA typ, 230 mA max Isolated inputs Number: 8 Isolation: 500 V Resistance: 1.6 KΩ min Voltage range (DC) Input high: +5.0 VDC min or –5.0 VDC min Input low: +1.5 VDC max or –1.5 VDC max Input range: 30 VDC max Measurement Computing (508) 946-5100 4 info@mccdaq.com mccdaq.com USB DIO High Voltage and Relay Specifications - USB-PDISO8 Series Mechanical External power output USB-PDISO8 dimensions (L × W × H) PCB: 304.3 × 121.9 × 20.0 mm (12.0 × 4.8 × 0.8 in.) Enclosure: 342.9 × 125.7 × 58.9 mm (13.5 × 4.95 × 2.32 in.) USB-PDISO8/40 dimensions (L × W × H) PCB: 304.3 × 121.9 × 17.8 mm (12.0 × 4.8 × 0.7 in.) Enclosure: 342.9 × 125.7 × 58.9 mm (13.5 × 4.95 × 2.32 in.) External power output - current range: 4.0 A max The daisy chain power output option allows multiple MCC USB products with a USB hub output port to be powered from a single external-power source in a daisy-chain fashion. The voltage drop between the device power supply input and the daisy-chain output is 0.5 V maximum. Users must plan for this drop to assure the last device in the chain receives at least 6.5 VDC. A user-supplied custom cable is required to daisy chain multiple devices. External power output: Voltage drop between power input and daisy chain power output: 0.5 V max Environmental Operating temperature range: 0 °C to 70 °C Storage temperature range USB-PDISO8: -40 °C to 100 °C USB-PDISO8/40: -40 °C to 85 °C Humidity: 0% to 95% non-condensing USB Specifications USB Type-B connector: Input USB device type: USB 2.0 (full-speed) Device compatibility: USB 1.1, USB 2.0 USB-PDISO8: Hardware revision F and later are also compatible with USB 3.0. The revision is indicated on the part number label on the housing – 197241X-01 – where X is the hardware revision. USB-PDISO8/40: Hardware revision C and later are also compatible with USB 3.0. The revision is indicated on the part number label on the housing – 197242X-01 – where X is the hardware revision. USB Type-A connector: Downstream hub output port USB hub type: Supports USB 2.0 high-speed, full-speed and low-speed operating points; self-powered, 100 mA max downstream VBUS capability Compatible products: MCC USB products with a USB hub output port USB cable type (upstream and downstream): A-B cable, UL type AWM 2527 or equivalent (min 24 AWG VBUS/GND, min 28 AWG D+/D-) USB cable length: 3 meters max Main Connector USB-PDISO8 Connector type: Screw terminal Wire gauge range: 12 AWG to 22 AWG USB-PDISO8/40 Connector type: P14: 40-pin header Compatible cables C40FF-x: 40-conductor ribbon cable, female both ends, x = length in feet. C40-37F-x: 40-pin IDC to 37-pin female D connector, x = length in feet. Compatible accessory products Using the C40FF-x cable: CIO-MINI40 Using the C40-37F-x cable: CIO-MINI37 Max current: 1 A USB-ERB08 Block Diagram 9.0 V External Power Power Monitor Power Regulator 6 NC C NO 5 Channel Relay6 3relay Switch S1 (inv/non-inv) Measurement Computing 8 NC C NO Channel Relay4 5relay Channel Relay7 2relay NC C NO 2 Channel Relay8 1relay NC C NO 1 4 Load 4 Channel Relay5 4relay Relay Driver driver 7 Channel Relay3 6relay NC C NO USB Microcontroller Channel Relay2 7relay 3 USB Interface 4 NC C NO Relay Driver driver NC C NO Channel Relay1 8relay NC C NO Screw terminal Switch S2 (pull-up/down) (508) 946-5100 5 info@mccdaq.com mccdaq.com USB DIO High Voltage and Relay Specifications - USB-ERB Series Relay 14 Relay 13 Relay 12 USB USB Interface Interface USB Microcontroller Relay 11 Relay driver Driver 8 Relay 10 Relay 9 Relay 8 Switch Switch S1 S1 (inv/non-inv) ) (inv/non-inv) Relay 7 Switch Switch S2 S2 (pull-up/down) (pull-up/down)) Relay 6 Relay Driver driver 8 Relay 5 Relay 4 Relay 3 Relay 2 Relay 1 USB-ERB Series Number of relays USB-ERB08: 8 USB-ERB24: 24 Relay configuration USB-ERB08: 2 banks of 4 USB-ERB24: 2 banks of 8 and 2 banks of 4 Contact configuration USB-ERB08: 8 Form C (SPDT) normally open (NO), normally closed (NC) and common (C) available at screw terminals USB-ERB24: 24 FORM C (SPDT) NO, NC and C available at screw terminals Contact rating: 5 A @ 240 VAC or 28 VDC resistive Contact resistance: 100 mΩ max (initial value) Operate time: 10 ms max Release time: 5 ms max Vibration: 10 Hz to 55 Hz (dual amplitude 1.5 mm) Shock: 10 G (11 ms) Dielectric isolation Between relay open contact: 300 VAC, 50/60 Hz (1 minute) Between PCB output lines: 500 VAC, 50/60 Hz (1 minute) Life expectancy: 10 million mechanical operations, min Power on RESET state S2 = pull-up: Energized. NO in contact with Common S2 = pull-down: Not energized. NC in contact with Common (508) 946-5100 24 23 22 21 20 19 18 17 16 15 Relay control logic polarity: User-configurable per bank through switch S1 for invert or non-invert (default). Switch settings for polarity can be read back with software over the USB bus. Switch settings do not affect the power‑on condition. Non-invert mode: When 0 is written or read back via the USB bus, relays are not energized. Invert mode: When 0 is written or read back via the USB bus, relays are energized. Pull-up/pull-down (controls relay power on state): User-configurable per bank through switch S2 for pull-down (default) or pull-up. Switch settings can be read back with software. • Pull-down puts the relays in non-energized mode on power up. • Pull-up puts the relays in energized mode on power up. Output Specifications Measurement Computing 14 Relay 15 13 Relay 16 Power Regulator 12 Relay 17 11 Relay 18 10 Relay 19 9 4 8 Relay Driver driver 7 Relay 20 6 Relay 21 5 Power Monitor Relay 22 4 9.0 V External Power 3 4 2 Relay 23 Relay Driver driver Screw terminal 1 Relay 24 NC C NO NC C NO NC C NO NC C NO NC C NO NC C NO NC C NO NC C NO NC C NO NC C NO NC C NO NC C NO NC C NO NC C NO NC C NO NC C NO NC C NO NC C NO NC C NO NC C NO NC C NO NC C NO NC C NO NC C NO USB-ERB24 Block Diagram Power USB +5 V input voltage range: 4.75 V min to 5.25 V max USB +5 V supply current (all modes of operation): 10 mA max Voltage supervisor limits - PWR LED 6.0 V > Vext or Vext > 12.5 V: PWR LED = Off (power fault) 6.0 V ≤ Vext < 12.5 V: PWR LED = On The daisy chain power output option allows multiple MCC USB Series products with a USB hub output port to be powered from a single external power source in a daisy chain fashion. The voltage drop between the device power supply input and the daisy chain output is 0.5 V max. Users must plan for this drop to assure the last device in the chain receives at least 6.0 VDC. External power consumption All relays on, 100 mA downstream hub power USB-ERB08: 750 mA typ, 850 mA max USB-ERB24: 1.5 A typ, 1.8 A max All relays off, 100 A downstream hub power USB-ERB08: 170 mA typ, 200 mA max USB-ERB24 230 mA typ, 270 mA max 6 info@mccdaq.com mccdaq.com USB DIO High Voltage and Relay Specifications - USB-ERB Series External Power Input USB cable type (upstream and downstream): A-B cable, UL type AWM 2527 or equivalent (min 24 AWG VBUS/GND, min 28 AWG D+/D-). USB cable length: 3 meters max. External power input: +6.0 VDC to 12.5 VDC (9 VDC power supply included) External power supply (included) USB-ERB08 MCC p/n CB-PWR-9: 9 V @ 1.67 A USB-ERB24 MCC p/n CB-PWR-9V3A: 9 V ±10% @ 3 A Relay Contact Pull-Up/Down Option Relays NO contact pull-up (to USB +5 V)/pull-down, user installed USB-ERB08: R1, R3, R5, R7, R10, R12, R14, R16 USB-ERB24: R35, R36, R41, R43, R45, R47, R49, R51, R87, R89, R91, R93, R96, R98, R100, R102, R103, R105, R107, R109, R112, R114, R116, R118 Relays NC contact pull-up (to USB +5 V)/pull-down, user installed USB-ERB08: R2, R4, R6, R8, R9, R11, R13, R15 USB-ERB24: R37, R40, R42,R44, R46, R48, R50, R52, R88, R90, R92, R94, R95, R97, R99, R101, R104, R106, R108, R110, R111, R113, R115, R117 External Power Output External power output (current range): 4.0 A max External power output (voltage drop between power input and daisy chain power output: 0.5 V max USB-ERB Series devices monitor the external +9 V power supply voltage with a voltage supervisory circuit. If this power supply exceeds its specified limit, the PWR LED turns off, indicating a power fault condition. A user-supplied custom cable is required to daisy chain multiple devices. Mechanical USB-ERB08 dimensions (L × W × H) PCB: 203.2 × 121 × 20.0 mm (8.0 × 4.8 × 0.8 in.) Enclosure: 241.3 × 125.7 × 58.9 mm (9.50 × 4.95 × 2.32 in.) USB-ERB24 dimensions (L × W × H) PCB: 431.8 × 121 × 20.3 mm (17.0 × 4.8 × 0.8 in.) Enclosure: 482.6 × 125.7 × 58.9 mm (19.00 × 4.95 × 2.32 in.) USB Specifications USB Type-B connector: Input USB device type: USB 2.0 (full-speed) Device compatibility: USB 1.1, USB 2.0 USB-ERB08: Hardware revision E and later are also compatible with USB 3.0. The revision is indicated on the part number label on the housing – 193776X-01L – where X is the hardware revision. USB-ERB24: Hardware revision G and later are also compatible with USB 3.0. The revision is indicated on the part number label on the housing – 193773X-01L – where X is the hardware revision. USB Type-A connector: Downstream hub output port USB hub type: Supports USB 2.0 high-speed, full-speed and low-speed operating points; self-powered, 100 mA max downstream VBUS capability Compatible products: MCC USB Series devices Main Connector Connector type: Screw terminal Wire gauge range: 12 to 22 AWG Environmental Operating temperature range: 0 to 70 °C Storage temperature range: -40 to 100 °C Humidity: 0% to 95% non-condensing USB-SSR Series USB-SSR08 Block Diagram 9.0 V External Power Power Monitor Switch S1 (I/O Type) Power Regulator SSR modules 1 to 4 (Port C LO) SSR module SSR module SSR module Bidiectional Buffer USB Microcontroller SSR SSR module module SSR SSR module module SSR SSR module module 4 Bidiectional Buffer 500 mA USB 2.0 Compliant Interface 8 7 +-+- SSR SSR module module 6 5 4 3 +-+- +-+- SSR module 2 1 +-+- Load 4 SSR modules 5 to 8 (Port C HI) Screw Terminal Measurement Computing Switch S3 (Pull-Up/Down) (508) 946-5100 7 info@mccdaq.com Switch S2 (Inv/Non-Inv) mccdaq.com USB DIO High Voltage and Relay Specifications - USB-SSR Series USB-SSR24 Block Diagram SSR Module 4 SSR Module 3 SSR Module 2 SSR Module 1 SSR Module 7 SSR Module 8 Power Monitor SSR Module 11 SSR Module 12 Power Regulator 8 USB Microcontroller 4 Bidiectional Buffer 4 Bidiectional Buffer 500 mA USB 2.0 Compliant Interface SSR Module 24 SSR Module 23 SSR Module 22 SSR Modules 17-20 (Port CL) I/O module logic polarity: Selectable with switch S2. Switch settings for polarity can be read back with software. Default to non-inverted. For input modules, invert mode returns a 1 when module is active; non-invert mode returns a 0 when module is active. For output modules, invert mode allows users to write a 1 to activate the module; non-invert mode allows users to write a 0 to activate the module. Pull-up/pull-down on digital I/O lines: Configurable with switch S3 with 2.2 kΩ resistor network. Switch settings for pull-up/pull-down selection can be read back with software. Default to pull-up. Switch settings are applicable during power up conditions of output modules only. Modules are active Low. When switch to Pull-up, modules are inactive on power up. When switched to pulldown, modules are active on power up. USB-SSR08 Modules 1-4: Selectable with switch S1 in the CL position as either input or output (default) modules. Switch settings for direction can be read back with software. Do not mix input and output modules within this bank of four. Modules 5-8: User-selectable with switch S1 in the CH position as either input modules or output (default) modules. Switch settings for direction can be read back with software. Do not mix input and output modules within this bank of four. USB-SSR24 Modules 1-8: Selectable with switch S1 in the A position as either input or output (default) modules Switch settings for direction can be read back with software. Do not mix input and output modules within this bank of eight. Modules 9-16: Selectable with switch S1 in the B position as either input modules or output (default) modules. Switch settings for direction can be read back with software. Do not mix input and output modules within this bank of eight. Modules 17-20: Selectable with switch S1 in the CL position as either input or output (default) modules. Switch settings for direction can be read back with software. Do not mix input and output modules within this bank of four. Modules 21-24: Selectable with switch S1 in the CH position as either input or output (default) modules. Switch settings for direction can be read back with software. Do not mix input and output modules within this bank of four. (508) 946-5100 Switch S2 (Inv/Non-Inv) Switch S3 (Pull-Up/Down) SSR Modules 21-24 (Port CH) I/O Module Configuration Measurement Computing Bidiectional Buffer SSR Module 16 SSR Module 20 SSR Module 15 SSR Module 19 SSR Module 14 SSR Module 18 SSR Module 13 SSR Modules 9-16 (Port B) SSR Module 17 16 15 18 17 24 23 22 21 +-+- +-+- +-+- 20 19 Screw terminal +-+- +-+- +-+- 14 13 Load SSR Module 21 12 11 10 9 8 SSR Module 6 Bidiectional Buffer SSR Module 10 +-+- +-+- +-+- 7 8 SSR Module 5 6 5 4 3 +-+- +-+- SSR Modules 1-8 (Port A) 9.0 V External Power SSR Module 9 2 1 +-+- Switch S1 (I/O Type) Power USB +5 V input voltage range: 4.75 V min to 5.25 V max USB +5 V supply current (all modes of operation) USB-SSR08: Vext or Vext > 12.5 V: PWR LED = Off (power fault) 6.0 V ≤ Vext < 12.5 V: PWR LED = On 8 info@mccdaq.com mccdaq.com USB DIO High Voltage and Relay Specifications - USB-SSR Series Digital I/O Transfer Rates External power consumption All modules on, 100 mA downstream hub power USB-SSR08: 300 mA typ, 360 mA max USB-SSR24: 800 mA typ, 950 mA max All modules off, 0 mA downstream hub power USB-SSR08: 180 mA typ, 220 mA max USB-SSR24: 200 mA typ, 220 mA max Digital I/O transfer rate (software paced): System dependent, 33 to 1000 port reads/writes or single bit reads/writes per second typ. Mechanical USB-SSR08 dimensions (L × W × H) PCB (without modules): 8.0 × 4.8 × 0.885 in. (203.2 × 121.9 × 22.5 mm) Enclosure: 9.50 × 4.95 × 2.32 in. (241.3 × 125.7 × 58.9 mm) USB-SSR24 dimensions (L × W × H) PCB (without modules): 431.8 × 121.9 × 22.5 mm (17.0 × 4.8 × 0.885 in.) Enclosure: 482.6 × 125.7 × 58.9 mm (19.00 × 4.95 × 2.32 in.) External Power Input External power input: +6.0 VDC to 12.5 VDC (9 VDC power supply included) External power supply (included; required for USB-SSR24) MCC p/n CB-PWR-9: 9 V @ 1.67 A Main connector External Power Output Connector type: Screw terminal Wire gauge range: 12 to 22 AWG External power output (current range): 4.0 A max USB-SSR Series devices monitor the external +9 V power supply voltage with a voltage supervisory circuit. If this power supply exceeds its specified limit, the PWR LED turns off, indicating a power fault condition. External power output (voltage drop between power input and daisy chain power output: 0.5 V max The daisy chain power output option allows multiple MCC USB boards to be powered from a single external power source in a daisy chain fashion. The voltage drop between the module power supply input and the daisy chain output is 0.5 V max. Users must plan for this drop to assure the last module in the chain receives at least 6.0 VDC. A user-supplied custom cable is required to daisy chain multiple devices. SSR Digital I/O Modules Specifications for the SSR modules available for the USB-SSR Series are listed below. Digital Input Sensing Modules USB Specifications USB Type-B connector: Input USB device type: USB 2.0 (full-speed) Device compatibility: USB 1.1, USB 2.0 USB-SSR Series revision F and later are also compatible with USB 3.0. The revision determined from the part number label on the housing as follows: USB-SSR08: The part number label on the housing shows as 193779X-01L, where X is the hardware revision USB-SSR24: The part number label on the housing shows as 93782X-01L, where X is the hardware revision MCC part number Input type Isolation voltage Input voltage range Input current @ max line Turn-on time Turn-off time SSR-IAC-05 AC 4000 Vrms 90-140 VAC/DC 8 mA 20 ms 20 ms SSR-IAC-05A High voltage AC 4000 Vrms 180-280 VAC/DC 6 mA 20 ms 20 ms SSR-IDC-05 DC 4000 Vrms 3-32 VDC 18 mA 0.20 ms 0.40 ms 18 mA 5 ms 5 ms SSR-IDC-05NP Non-polarized, 15-32 VAC, 4000 Vrms AC or DC 10-32 VDC Digital Output Switching Modules USB Type-A connector: Downstream hub output port USB hub type: Supports USB 2.0 high-speed, full-speed and low-speed operating points; self-powered, 100 mA max downstream VBUS capability Compatible products: MCC USB Series devices USB cable type (upstream and downstream): A-B cable, UL type AWM 2527 or equivalent (min 24 AWG VBUS/GND, min 28 AWG D+/D-). USB cable length: 3 meters max. MCC part number Output type* Isolation voltage Load voltage range Load current range Turn-on time Turn-off time SSR-OAC-05 AC 4000 Vrms 24-140 VAC 0.03-3.5 A 8.33 ms 8.33 ms SSR-OAC-05A AC 4000 Vrms 24-280 VAC 0.03-3.5 A 8.33 ms 8.33 ms SSR-ODC-05 DC 4000 Vrms 3-60 VDC 0.02-3.5 A 20 µs 50 µs SSR-ODC-05A DC 4000 Vrms 4-200 VDC 0.02-3.5 A 75 µs 750 µs * SPST, normally open Measurement Computing (508) 946-5100 9 info@mccdaq.com mccdaq.com USB DIO High Voltage and Relay Ordering Order Information SSR Digital I/O Modules (USB-SSR Series Only) Hardware Part No. Description USB-PDISO8 USB-based eight Form C relay and eight isolated highvoltage input interface device. Includes power supply and USB cable. USB-PDISO8/40 USB-based eight Form C Relay and eight isolated highvoltage input interface device with 40-pin connector. Includes power supply and USB cable. USB-SSR08 USB-based solid-state eight I/O module interface device. Includes power supply and USB cable. USB-SSR24 USB-based solid-state 24 I/O module interface device. Includes power supply and USB cable. USB-ERB08 USB-based 8-channel electromechanical relay interface device. Includes power supply and USB cable. USB-ERB24 USB-based 24-channel electromechanical relay interface device. Includes power supply and USB cable. CB-PWR-9 Description Replacement power supply, 9 V, for USB-PDISO8 Series, USB-SSR Series, and USB-ERB08. Interchangeable power plugs are available separately. CB-PWR-9V3A Replacement power supply, 9 V, for USB-ERB24 PS-9V1AEPS230V Replacement 230 V power supply, 9 V output, for USB-PDISO8 Series, USB-SSR Series, and USB-ERB08. Interchangeable power plugs are available separately. CIO-MINI40 Description SSR-IAC-05 AC sense input module, 90 to 140 VAC/VDC SSR-IAC-05A AC sense input module, 180 to 280 VAC/VDC SSR-IDC-05 DC sense input module, 3 to 32 VDC SSR-IDC-05NP DC sense input module, 10 to 32 VDC non-polarized SSR-OAC-05 AC switch output module, 24 to 140 VAC, 3.5 A @ 120 VAC, SPST normally open SSR-OAC-05A AC switch output module, 24 to 280 VAC, 3.5 A @ 240 VAC, SPST normally open SSR-ODC-05 DC switch output module, 3 to 60 VDC @ 3.5 A, SPST normally open SSR-ODC-05A DC switch output module, 4 to 200 VDC @ 3.5 A, SPST normally open Software also Available from MCC Accessories and Cables Part No. Part No. Part No. Description DAQami Easy-to-use advanced data logging application to acquire, view, and log data TracerDAQ Pro* Out-of-the-box virtual instrument suite with strip chart, oscilloscope, function generator, and rate generator – professional version DASYLab Icon-based data acquisition, graphics, control, and analysis software * TracerDAQ Pro only supports USB-PDISO8 Series digital inputs; it does not support USB-ERB Series or USB-SSR Series devices. Universal screw-terminal board, 37-pin Measurement Computing DS USB-High-Voltage-Relay-DIO (508) 946-5100 10 info@mccdaq.com mccdaq.com June 2021. Rev 4 © Measurement Computing Corporation
6069-410-056 价格&库存
很抱歉,暂时无法提供与“6069-410-056”相匹配的价格&库存,您可以联系我们找货
    库存:1000
