410-359
410-359
    DIGILENT(迪芝伦)
410-359 数据手册
410-359 Pmod BLE: Bluetooth Low Energy Interface The Digilent Pmod BLE (Revision A) is a powerful peripheral module meant for use with any UART enabled development board. This Pmod employs the Roving Networks RN4870 to create a fully integrated Bluetooth Low Energy interface. This chip features an onboard Bluetooth stack that makes connecting and communicating with any Bluetooth 4.0+ device possible through simple UART commands. The RN4870 also features four built in GATT services: Device Information, Airpatch, BeaconThings, and UART Transparent data streaming. It also allows up to five custom public services and up to 4 custom private services, each allowing up to eight custom characteristics. The PmodBLE is a cheap, versatile, low energy addition to the wireless Pmod library. Features          Fully Qualified Bluetooth® Low Energy Module On-Board Bluetooth 4.2 Low Energy Stack Certified to FCC, IC, CE, KCC, NCC and SRRC ASCII Command Interface API Secure communication AES128 Encryption Remote Configuration Over The Air Small PCB size for flexible designs 1.0“ x 0.8” (2.57 cm × 2.03 cm) 12-pin Pmod connector with UART interface Follows Digilent Pmod Interface Specification Type 3A Specifications Parameter Power Supply Voltage Min 1.9 Typical 3.3 Max 3.6 Units V Baud Rate 2400 115200 921000 bps 10 kbps Data Rate (Transparent UART) Parameter Value RX Sensitivity TX Power Frequency Band -90 dBm 0 dBm 2.402 - 2.480 GHz Pinout Table Diagram Pin 1 Signal RTS Description Ready to Send 2 RXD Receive Data 3 TXD Transmit Data 4 CTS Clear to Send 5 GND Power Supply Ground 6 VCC Power Supply (3.3V/5V) 7 P1_2 Configurable GPIO 8 RST_N Reset (Active Low) 9 MODE App/Test Mode pin 10 P1_6/STATUS Configurable Connection Status 11 GND Power Supply Ground 12 VCC Power Supply (3.3V/5V) Jumpers The Pmod BLE has one jumper connected to the MODE pin. When left unshorted, the PmodBLE will start up in standard application mode. When shorted and power cycled, the board will go into test mode, which is used to update the firmware on the RN4870. There is also an unloaded jumper J2 which provides access to 3 configurable pins P1_3, P1_7, and P2_7. Physical Dimensions The pins on the pin header are spaced 100 mil apart. The PCB is 1.011 inches (2.570 cm) long on the sides parallel to the pins on the pin header and 0.8 inches (2.032 cm) long on the sides perpendicular to the pin header. The PCB on the RN4780 module extends the length of the PCB approximately .158 in (4.00 mm) and is .355 in (9.00 mm) wide. Functional Description The Pmod BLE uses a 12-pin Pmod port and communicates via UART on the top row of pins. The bottom row of pins include 2 GPIO pins, a reset pin, and a mode pin that is used to update the firmware of the BLE module. The typical application for the Pmod BLE is to replace a wired UART connection between two Bluetooth capable devices. When paired with an Android, Linux, Mac OS X, or Windows computer, the Pmod BLE behaves like a serial port similar to how a USBUART bridge or RS-232 serial port behaves. The Pmod BLE can be easily configured from the Bluetooth connected computer by entering a “Command Mode” that allows settings such as UART baud rate to be programmed into non-volatile configuration registers. When used with another Pmod BLE, a wireless UART bridge can be achieved with no need for software configuration of the Bluetooth link. This is accomplished by entering a command mode while connected to the PmodBLE through UART. Once in command mode, the device can connect to any BLE address using the “C,0,” command. In this way you can communicate wirelessly between two embedded devices without complicated software like is required with WiFi or 802.15.4 solutions. Communicate wirelessly with simple serial prints and reads! WARNING: Hot-plugging (un-plugging or plugging in the device while powered) the Pmod BLE can possibly wipe the internal memory on the device. Fixing this requires a UART terminal connection between a PC and the Pmod BLE. Serial Communication The Pmod BLE communicates with the host board via the UART protocol. By default, the UART interface uses a baud rate of 115.2 kbps, 8 data bits, no parity, and a single stop bit. The startup baud rate may be customized to predefined rates or set to a specific user customized baud rate ranging from 2400 bps to 921 kbps. By default, the PmodBLE is configured as a transparent UART device. UART data sent to the PmodBLE will be sent directly to the device it is connected to and vice versa. Command mode can be entered by sending the module the characters “$$$” to which it will respond “CMD> ”. When in command mode, the module will respond to a large number of commands allowing the user to customizing the module for specific applications. In order to exit command mode, send “—” (three minus signs in a row followed by the carriage return character) to which the device will respond “END”. Remote configuration, or configuration over a Bluetooth connection, is possible using the command “!,1”. It is important to note that any of the “set” commands available for the Pmod BLE must be followed by a power cycle to take effect in any design. GPIO The reset pin (RST) on J1 is active low. If the RST pin is pulled low, the device will undergo a hard reset until the RST pin is pulled high. This hard reset performs similarly to a power cycling of the device. The P1_6/STATUS pin directly reflects the connection status of the device. STATUS is driven low by the device when connected and is driven high otherwise. P1_6 can be reconfigured to several different functions using the SW command (see RN4970 User Guide). The P1_2 GPIO pin can be written to by entering command mode and sending the command “|O,08,0X\r\n” (replace X with 8 to set the pin high, or 0 to set the pin low). It can also be read from using the command “|I,08”. P1_2 can also be reconfigured to several different functions using the SW command.
410-359 价格&库存
很抱歉,暂时无法提供与“410-359”相匹配的价格&库存,您可以联系我们找货
