6069-410-024
6069-410-024
    DIGILENT(迪芝伦)
    High-Precision Thermocouple Measurement USB/Ethernet System
6069-410-024 数据手册
TC-32 and TC-32-EXP USB/Ethernet-Based High-Precision Thermocouple Measurement Devices Features • USB and Ethernet interface • 32 differential thermocouple (TC) inputs with 24-bit resolution − Expandable to 64 TC inputs with TC-32-EXP expansion module − TC channel-to-host isolation A TC-32 connected to a TC-32-EXP device provides up to 64 TC inputs, 16 digital inputs, and 64 digital outputs which can be configured as alarms. All DIO channels are isolated. Overview The TC-32 and TC-32-EXP offer exceptional performance and accuracy for thermocouple (TC) measurement applications at a low cost per channel. Offering both Ethernet and USB ports, the TC-32 provides 32 channels of 24-bit resolution for medium channel installations. The TC-32-EXP adds 32 high-precision channels to support larger installations. − Easy-to-connect mini-jack connectors − 3 S/s per channel maximum sample rate − Cold-junction compensation (CJC) sensor per channel − Open thermocouple detection • 8 digital inputs and 32 digital outputs/alarms Accuracy is designed into the product with sigma-delta 24-bit ADCs, differential inputs, TC-to-host isolation and cold-junction compensation (CJC) for each channel to reduce the effects of thermal gradients. − Expandable to 16 digital inputs/64 digital outputs with TC-32-EXP expansion device With digital alarming notifications when a temperature exceeds programmed limits, the TC-32 and TC-32-EXP offer the perfect solution for temperature monitoring applications including server rooms, refrigerated storage, and long-run test cells − Isolated from TC inputs and host Channel Expansion with the TC-32-EXP Connect a TC-32-EXP expansion device to double the number of TC inputs (64), digital inputs (16), and digital outputs/ alarms (64). The TC-32-EXP connects to the host TC-32 through a 40-pin expansion connector. The host TC-32 provides all power to the TC-32-EXP The TC-32-EXP supports all of the TC input and digital I/O features of the host TC-32, including built-in cold-junction compensation and open thermocouple detection. USB or Ethernet Interface TC Input • 19” rack mountable Connect up to 32 differential TC input channels using the four groups of eight mini-jack connectors on the front panel of each device. • Requires external power (power adapter included with TC-32) Both the TC-32 and TC-32-EXP support a maximum sample rate of 3 S/s per channel, and TC types J, K, R, S, T, N, E, and B. TC types are software-selectable per channel. • Windows 11/10/8/7/ Vista® 32/64-bit • Linux® • Android™ Cold-Junction Compensation (CJC) Each TC input on TC-32 devices has a high-resolution CJC sensor that provides a local cold-junction temperature reference point. This feature ensures the highest level of temperature measurement accuracy. The TC-32 can communicate with a host device through either USB or 10/100 Ethernet. By offering both USB and Ethernet ports, the TC-32 is the perfect solution for local or remote monitoring. Measurement Computing − 50-pin header connector (cable sold separately) (508) 946-5100 Supported Operating Systems Data Linearization After the device performs CJC correction, an onboard microcontroller automatically linearizes the TC data using National Institute of Standards and Technology (NIST) linearization coefficients for the selected TC type. The data is then output as a 32-bit floating point value in the configured format (voltage or temperature). 1 info@mccdaq.com mccdaq.com TC-32 and TC-32-EXP Features Open-Thermocouple Detection (OTD) TC-32 devices are equipped with OTD for all TC input channels. When enabled, OTD allows users to monitor their TCs and determine if they are broken or disconnected. Connecting TCs to CommonMode Voltage Sources Thermocouple inputs are isolated and thermocouple common-mode voltage may deviate up to 48 VDC or 3.5 VAC (at 60 Hz) from chassis ground without any negative impact to measurement accuracy. Common-mode voltages between channels, however, should not vary more than ±1.4 VDC (refer to Common mode voltage range specifications on page 4 for more information). Digital I/O and Alarms The TC-32 provides up to 8 digital inputs and 32 digital outputs that are electrically isolated from the host device and from the TC-32 analog circuits. This configuration allows users to optionally configure a digital output as an alarm for each TC channel. When configured as an alarm, the digital output line is driven to the appropriate state determined by the alarm options and input temperature. Users can also use the alarm outputs to control a device or application that indicates: The TC-32 can connect to an Ethernet or USB port. Both the TC-32 and TC-32-EXP include 50-pin connectors that provide access to all DIO channels. Adding the TC-32-EXP expansion device doubles the channel count of the system. Alarm Input Modes lowing alarm error modes: Users can set independent temperature thresholds T1 and T2 for each alarm and enable one of the the following alarm input modes: • Alarm disabled; digital output line can be used for normal operation • Trigger alarm when input temperature ≥ T1; reset alarm when input temperature < T2 Alarm enabled; active low output (output line goes low when alarm condition is met) • Trigger alarm when input temperature ≤ T1; reset alarm when input temperature > T2 Alarm enabled; active high output (output line goes high when alarm condition is met) • Alarm output may be latched and will not clear unless explicitly cleared by the user • • • Trigger alarm when input temperature is < T1 or > T2 Alarm Error Modes • when a software-selectable temperature threshold has been exceeded Users can set the conditions that trigger each alarm by selecting the following alarm error modes: • when an open TC has been detected • • when the common mode voltage is out of range Trigger alarm based on temperature reading only • Trigger alarm based on temperature reading, open thermocouple detected, or common-mode voltage error All alarm mode settings can be configured with InstaCal. • Trigger alarm based on open thermocouple detected or commonmode voltage out-of-range error only Alarm Output Modes Users can set the behavior of each digital/ alarm output by selecting one of the fol- Measurement Computing (508) 946-5100 2 Power The TC-32 requires external power. A 5 V, 10 W power adapter (PS-5V2AEPS) is included with the TC-32. The TC-32 provides power to the TC-32-EXP when they are connected. Calibration Both the TC-32 and TC-32-EXP are factory-calibrated using a NIST-traceable calibration process. Specifications are guaranteed for one year. For calibration beyond one year, return the device to the factory for recalibration. The TC-32 and TC-32-EXP devices also support field calibration so that users can calibrate a device locally. info@mccdaq.com mccdaq.com TC-32 and TC-32-EXP Software Software Support The TC-32 and TC-32-EXP are supported by the software in the table below. Ready-to-Run Applications Data acquisition companion software with drag-and-drop interface that is used to acquire, view, and log data, and generate signals. DAQami can be configured to log analog, digital, and counter channels, and to view that data in real-time or post-acquisition on user-configurable displays. Logged data can be exported for use in Excel® or MATLAB®. Windows OS DAQami™ DAQami is included with the free MCC DAQ Software bundle. An interactive installation, configuration, and test utility for MCC hardware. Windows OS InstaCal™ InstaCal is included with the free MCC DAQ Software bundle. TracerDAQ™ and TracerDAQ Pro Virtual strip chart, oscilloscope, function generator, and rate generator applications used to generate, acquire, analyze, display, and export data. Supported features may vary by hardware. The Pro version provides enhanced features. Windows OS TracerDAQ is included with the free MCC DAQ Software bundle. TracerDAQ Pro is available as a purchased software download. General-Purpose Programming Support Universal Library™ (UL) for Windows UL for Android ™ Library for developing applications in C, C++, VB, C# .Net, VB .Net, and Python on Windows. The UL for Windows is included with the free MCC DAQ Software bundle. The UL Python API for Windows is available on GitHub (https://github.com/mccdaq/mcculw). Programming library of Java classes for programmers who develop apps for Android-based tablets and phones. UL for Android communicates with select MCC DAQ devices. Supports Android project development on Windows, Linux, Mac OS X UL for Android is included with the free MCC DAQ Software bundle. Library for developing applications in C, C++, and Python on Linux. UL for Linux ® UL for Linux is available on GitHub (https://github.com/mccdaq/uldaq). Open-source, third-party Linux drivers are also available for supported MCC devices. Application-Specific Programming Support ULx for NI LabVIEW™ DASYLab ® Measurement Computing A comprehensive library of VIs and example programs for NI LabVIEW that is used to develop custom applications that interact with most MCC devices. Windows OS ULx for NI LabVIEW is included with the free MCC DAQ Software bundle. Icon-based data acquisition, graphics, control, and analysis software that allows users to create complex applications in minimal time without text-based programming. Windows OS DASYLab is available as a purchased software download. An evaluation version is available for 28 days. (508) 946-5100 3 info@mccdaq.com mccdaq.com TC-32 and TC-32-EXP Specifications TC-32 and TC-32-EXP Block Diagram TC 0+ (high) TC 0– (low) TC 31+ (high) TC 31– (low) TC Connectors CJC Sensors (32) 16 (Ch 0-15) Input Filters CJC I/O (0-31) 24-bit ADC Mux Isolated Microcontroller Digital Isolator VREF 16 (Ch 16-31) Input Filters 24-bit ADC Mux 32 Digital Inputs Digital Isolator Digital Outputs and Alarms SPI +3.3 VA +5 VA +12 VA Isolated DC-DC +5 VA Isolated Power Supplies Microcontroller USB Ethernet +3.3 V Regulator Isolated Power Supplies +5 V Overvoltage/Negative Supply Protection Ext. Power Isolation Barrier Control Signals Control Signals +12 VA +5 VA +3.3 VA Expansion Connector (Expansion/Host Device) Expansion Connector Ex xpansion Connector (Host /Expansion /Expansion (Host Device) Device)) User I/O Connector +3.3 V 8 TC-32 Only Isolation Barrier Specifications Common mode voltage range TCx channel to TCx channel: ±1.40 V TCx channel relative to chassis ground, fin = 60 Hz: ±3.5 VAC p-p TCx channel relative to chassis ground: ±48 VDC When thermocouple sensors are connected to different common mode voltages, the channels with floating thermocouples sensors are biased to approximately the average value of the applied common mode voltages. Each of the applied common mode voltages must then be less than or equal to the average common mode voltage ±1.40 V or [CMVapplied ≤ (CMVaverage ±1.4 V)]. Input noise (50 Hz or 60 Hz filtering): 510 nV rms Gain error: 50 Hz or 60 Hz filtering: 0.004 % FSR Offset error: 50 Hz or 60 Hz filtering: 3 µV Measurement sensitivity (smallest change in temperature that can be detected) Thermocouple type J,K,T,E,N: 0.05 °C Thermocouple type R,S: 0.10 °C Thermocouple type B: 0.15 °C Warm-up time: 20 minutes min Open thermocouple detect response time: 1 s CJC sensor accuracy (0 °C to 45 °C): ±0.20 °C typ, ±0.40 °C max All specifications are subject to change without notice. Typical for 25 °C unless otherwise specified. These specifications apply to both the TC-32 and TC-32-EXP unless noted otherwise. Thermocouple Input A/D converter type: Delta-Sigma A/D resolution: 24-bit Number of channels: 32 (64 when TC-32 connected to TC-32-EXP) Filtering options: 50 Hz or 60 Hz noise filtering, software-selectable Isolation between any TC input channel and chassis ground: 500 VDC absolute max Channel configuration: Software-selectable to match TC sensor type Differential input voltage range: ±78.125 mV Absolute maximum input voltage (between any two TCx inputs): ±25 V (power on), ±25 V (power off) Differential input impedance 50 Hz filtering, power on: 26 MΩ 60 Hz filtering, power on: 20 MΩ Input current Open thermocouple detect disabled: 2 nA Open thermocouple detect enabled: 75 nA Common mode rejection 50 Hz filtering, at DC and fin=50 Hz: 110 dB 60 Hz filtering at DC and fin=60 Hz: 110 dB Noise rejection 50 Hz filtering at fin=50 Hz: 80 dB typ 60 Hz filtering at fin=60 Hz: 80 dB typ Input bandwidth 50 Hz filtering: 22 Hz 60 Hz filtering: 26 Hz Crosstalk between any two TC inputs: -90 dB Sample rate: 3 Hz max (per channel) The enabled thermocouple inputs are continuously converted at the maximum A/D converter rate. Measurement Computing (508) 946-5100 Channel Configuration Thermocouple (J, K, S, R, B, E, T, N): 32 differential channels Channel configuration is stored on EEPROM external to the isolated microcontroller by the firmware whenever any item is modified. Modification is performed by commands issued from an external application, and the configuration is made non-volatile through the use of the EEPROM. Compatible Thermocouple Sensors Thermocouple J: –210 °C to 1200 °C K: –270 °C to 1372 °C S: –50 °C to 1768 °C R: –50 °C to 1768 °C 4 B: 0 °C to 1820 °C E: –270 °C to 1000 °C T: –270 °C to 400 °C N: –270 °C to 1300 °C info@mccdaq.com mccdaq.com TC-32 and TC-32-EXP Specifications Accuracy Thermocouple measurement accuracy specifications include polynomial linearization, cold-junction compensation, and system noise. The accuracy specifications assume the device is operated within its enclosure and with the enclosure in a horizontal, upright orientation. The device should also be warmed up for the recommended 20 minutes. If the maximum digital output load of 3.2 amps is applied, add an additional 0.30 °C to the typical and maximum accuracy specifications listed below. Errors shown do not include inherent thermocouple error. Contact your thermocouple supplier for details on the actual thermocouple accuracy error. Thermocouple Measurement Accuracy, Including CJC Measurement Error All Specifications are (±) Accuracy Error Sensor Type Sensor Temperature Maximum, 15 °C to 35 °C Typical, 15 °C to 35 °C Maximum, 0 °C to 45 °C Typical, 0 °C to 45 °C J –210 °C 1.965 °C 0.910 °C 2.167 °C 0.989 °C K 0 0.787 °C 0.361 °C 0.816 °C 0.375 °C 1200 °C 0.752 °C 0.371 °C 1.148 °C 0.508 °C –210 °C 2.295 °C 1.061 °C 2.520 °C 1.152 °C 0 0.821 °C 0.376 °C 0.852 °C 0.392 °C 1372 °C 1.029 °C 0.504 °C 1.560 °C 0.688 °C –50 2.467 °C 1.111 °C 2.655 °C 1.223 °C S 250 °C 1.835 °C 0.825 °C 1.961 °C 0.904 °C 1768 °C 0.893 °C 0.361 °C 1.519 °C 0.590 °C R B E T N –50 2.609 °C 1.174 °C 2.810 °C 1.293 °C 250 °C 1.862 °C 0.837 °C 1.992 °C 0.918 °C 1768 °C 0.754 °C 0.305 °C 1.346 °C 0.520 °C 250 °C 2.450 °C 1.090 °C 2.707 °C 1.254 °C 700 °C 0.937 °C 0.424 °C 1.136 °C 0.520 °C 1820 °C 0.610 °C 0.300 °C 1.056 °C 0.467 °C –200 °C 1.754 °C 0.811 °C 1.933 °C 0.880 °C 0 0.775 °C 0.355 °C 0.806 °C 0.369 °C 1000 °C 0.657 °C 0.323 °C 0.989 °C 0.437 °C –200 °C 2.005 °C 0.923 °C 2.207 °C 1.005 °C 0 0.836 °C 0.382 °C 0.874 °C 0.400 °C 400 °C 0.544 °C 0.255 °C 0.659 °C 0.297 °C –200 °C 2.255 °C 1.038 °C 2.481 °C 1.134 °C 0 0.908 °C 0.415 °C 0.949 °C 0.437 °C 1300 °C 0.718 °C 0.357 °C 1.157 °C 0.510 °C Digital Input Number of inputs: 8 channels (16 when TC-32 connected to TC-32-EXP) Configuration: Fixed input Input voltage range: 0 V to +15 V Input type: CMOS (Schmitt trigger) Input characteristics: 100 kΩ pull-up resistor, 28.7 kΩ series resistor Maximum input voltage range: 0 V to +20 V max (power on/off, relative to IGND pins) Pull-up configuration: All pins pulled up to +5 V via individual 100 kΩ resistors using slide switch SW5. SW5 default position are on (pulled up). Transfer rate (software paced): 500 port reads per second typ Measurement Computing Input high voltage: 1.3 V min, 2.2 V max Input low voltage: 1.5 V max, 0.6 V min Schmitt trigger hysteresis: 0.4 V min, 1.2 V max Digital Output Number of outputs: 32 channels, shared with alarms (64 when TC-32 connected to TC-32-EXP) Configuration: Open drain output Output characteristics: 100 kΩ pull-up, open drain (DMOS transistor) Pull-up configuration: All pins pulled up to +5 V through individual 100 kΩ resistors using slide switches SW1-SW4. The default positions for SW1-SW4 are on (pulled up.) (508) 946-5100 5 Transfer rate (software paced): 500 port writes per second typ Output voltage range 0 V to +5 V (internal 100 kΩ pull-up resistors connected to +5 V by default) 0 V to +15 V max (using external pull-up resistor) Ground pins labeled IGND are isolated from AGND and chassis ground. Off state leakage current: 0.1 µA Sink current capability: 100 mA max (continuous) per output pin DMOS transistor on-resistance (drain to source): 4 Ω Temperature Alarms Number of alarms: 32, shared with digital output Alarm functionality: Each alarm controls its associated digital output line as an alarm output. When an alarm is enabled, its associated output line is driven to the appropriate state determined by the alarm options and input temperature. The alarm configurations are stored in non-volatile memory and loaded at power on. Alarm input modes (T1 and T2 can be independently set for each alarm) Alarm when input temperature ≥ T1, reset alarm when input temperature < T2 Alarm when input temperature ≤ T1, reset alarm when input temperature > T2 Alarm when input temperature is < T1 or > T2 Alarm error modes Alarm on temperature reading only Alarm on temperature reading, open thermocouple, or common-mode voltage error Alarm on open thermocouple or common-mode voltage error only Alarm output modes Disabled, digital output line may be used for normal operation Enabled, active high output (output line goes high when alarm condition is met) Enabled, active low output (output line goes low when alarm condition is met) Alarm output may be latched and will not clear unless explicitly cleared by the user Alarm latency: 1 second, max Alarm settings are applied when changed and at power-on. Temperatures are constantly converted on enabled channels and processed for alarm conditions regardless of the communications connectivity. Memory EEPROM: 4,096 bytes Microcontroller Type: One high-performance 32-bit RISC microcontroller USB (TC-32 Only) Device type: USB 2.0 full speed Device compatibility: USB 1.1, USB 2.0, USB 3.0 Connector: Standard B Cable length: 5 meters max Power: Self-powered (no USB current consumed) Network (TC-32 Only) Ethernet Connection Ethernet type: 100 Base-TX, 0 Base-T Communication rates: 10/100 Mbps, auto-negotiated Connector: RJ-45, 8 position Cable length: 100 meters max Additional parameters: HP Auto-MDIX support info@mccdaq.com mccdaq.com TC-32 and TC-32-EXP Ordering Order Information Network Interface Protocols used: TCP/IP (IPv4 only), UDP Network ports used: UDP: 54211 (discovery) TCP: 54211 (commands) Network IP configuration: DHCP + link-local, DHCP, static, link-local Network name: TC-32-xxxxxx, where xxxxxx are the lower 6 digits of the device MAC address Network name publication: By NBNS (responds to b-node broadcasts, therefore only available on the local subnet) Hardware Part No. Description TC-32 USB- or Ethernet-based 24-bit, 32-channel thermocouple input device with 8 digital inputs and 32 digital outputs/ alarms. Includes USB cable, Ethernet cable, power supply, and MCC DAQ software. TC-32-EXP 24-bit, 32-channel thermocouple input expansion device for TC-32 with 8 digital inputs and 32 digital outputs/ alarms. Includes 40-pin expansion cable for connection to host TC-32. Network Factory Default Settings Factory default IP address: 192.168.0.101 Factory default subnet mask: 255.255.255.0 Factory default gateway: 192.168.0.1 Factory default DHCP setting: DHCP + link-local enabled Network Security Security implementation: TCP sockets are not opened unless application sends the correct PIN code (stored in non-volatile memory, may be changed by user, default value 0000) Number of concurrent sessions: 1 Vulnerabilities: TCP Sequence Number Approximation Vulnerability Accessories and Cables Power (TC-32 Only) Supply current: 330 mA typ, 610 mA max; 550 mA typ, 1000 mA max (with TC-32-EXP connected) External power input: +5 VDC ± 5% (+5 VDC power supply provided) Voltage specification applies at barrel plug power input. The power supply provided with the device meets this specification at the rated total power supply current. If a different power supply is used, small line resistances could cause significant voltage drop between the power supply and the barrel plug input. Power switch: Rocker type External power supply (included) MCC p/n PS-5V2AEPS: +5 VDC, 10 W, 5% regulation External power input voltage supervisor limits 4.0 V > Vext > 5.75 V: PWR LED = Off (power fault) 4.0 V < Vext < 5.75 V: PWR LED = On Chassis ground connection: 6-32 screw on rear of enclosure Part No. Description C40FF-x 40-conductor ribbon cable, female to female; x is the length in feet. Replacement expansion cable. C50FF-x 50-conductor ribbon cable, female to female; x is the length in feet. Use for DIO connections. CIO-MINI50 50-pin universal screw-terminal board. SCB-50 50-pin signal connection box. PS-5V2AEPS Replacement power supply for TC-32 – interchangeable plugs available separately Sensors (Sold Separately) Part No. Description CN-144-JM Type J male thermocouple connector CN-144-KM Type K male thermocouple connector CN-144-TM Type T male thermocouple connector 745690-J001 J-type thermocouple wire, fiberglass (0 °C to 482 °C, 32 °F to 900 °F) 1 m 745690-J002 J-type thermocouple wire, fiberglass (0 °C to 482 °C, 32 °F to 900 °F) 2 m 745690-K001 K-type thermocouple wire, fiberglass (0 °C to 482 °C, 32 °F to 900 °F) 1 m 745690-K002 Operating temperature range: 0 °C to 45 °C Storage temperature range: –40 °C to 85 °C Humidity: 0 °C to 90% non-condensing K-type thermocouple wire, fiberglass (0 °C to 482 °C, 32 °F to 900 °F) 2 m 745690-T001 T-type thermocouple wire, fiberglass (0 °C to 260 °C, 32 °F to 500 °F) 1 m Mechanical 745690-T002 T-type thermocouple wire, fiberglass (0 °C to 260 °C, 32 °F to 500 °F) 2 m LED Displays and the Factory Reset Button POWER LED (top): Indicates power on. Blinks when blink command is sent. Both the POWER and ACTIVITY LEDs blink in firmware upgrade mode. ACTIVITY LED: On when there is a valid connection and blinks when a command is sent to the TC-32-EXP. Both the POWER and ACTIVITY LEDs blink in firmware upgrade mode. ALARM LED: Indicates that an alarm condition is met. OPEN TC LED (bottom): Indicates that there is an open thermocouple condition. Factory reset button: When held for 3 seconds, the LEDs turn off for a short time, indicating a reset is in process. When the LEDs turn back on, reset is complete and the factory-default network settings are restored. Environment Dimensions (L × W × H):482.6 × 128.6 × 43.18 mm (19 × 6.15 × 1.74 in.) Signal I/O Connectors Software also Available from MCC User accessible I/O connectors (excluding USB and Ethernet): Thermocouple inputs, digital I/O connector, expansion connector, chassis ground Thermocouple connector type: Thermocouple Mini-Jack Digital I/O connector type: 50-pin IDC header Compatible cable for the 50-pin DIO connector: C50FF-x (where x = length in feet) Compatible accessory products with the C50FF-x cable: CIO-MINI50, SCB-50 Expansion connector type: 40-pin IDC header Compatible cables for the 40-pin expansion connector: C40FF-x (where x = length in feet) Chassis ground connector: 6-32 screw Measurement Computing DS-TC-32 (508) 946-5100 6 Part No. Description TracerDAQ Pro Out-of-the-box virtual instrument suite with strip chart, oscilloscope, function generator, and rate generator – professional version DASYLab Icon-based data acquisition, graphics, control, and analysis software info@mccdaq.com mccdaq.com April 2020. Rev 5 © Measurement Computing Corporation
6069-410-024 价格&库存
很抱歉,暂时无法提供与“6069-410-024”相匹配的价格&库存,您可以联系我们找货
  • 1+20805.06566
库存:3
