410-068
410-068
    DIGILENT(迪芝伦)
410-068 数据手册
Digilent PmodRS232™ Converter Module Board Reference Manual ® www. di gi l ent i nc. com Revision: June 6, 2012 Note: This document applies to REV B of the board. 215 E Main Suite D | Pullman, WA 99163 (509) 334 6306 Voice and Fax Overview The PmodRS232 Converter Module Board (the RS232 module) translates voltage from the logic levels used by Digilent system boards to the RS232 voltage used for serial communications. The RS232 module creates a two-way I/O exchange by converting RS232 voltage to logic level voltage and converting logic voltage to RS232 voltage. RS-232 voltage levels are -3 to -12V for a logic ‘1’, and +3 to +12 for a logic ‘0’. Features include: Pins 1,4,6 are tied for handshaking. CTS 1 RTS 2 TXD 3     an Analog Devices ADM3232E RS232 transceiver a DB9 connector and 6-pin header transmit and receive data functions optional RTS and CTS handshaking functions small form factor (1.00” x 1.30”). Functional Description The RS232 module provides two transmit buffers and two receive buffers. A transmit buffer converts a logic-level signal on its input to an RS232 voltage-level signal on its output. A receive buffer converts an RS232 voltagelevel signal on its input to a logic-level signal on its output. The RS232 module can be configured as either a 3-wire DTE serial port (with one transmitter for transmit-data signals, one Doc: 502-068 JP1 JP2 RXD 4  1 GND 5 VCC 6 6 Analog Devices ADM3232E RS232 Transceiver 2 7 3 8 4 NC 9 DB9 DCE Connector The RS232 module is configured as a data communications equipment (DCE) device. It connects to data terminal equipment (DTE) devices, such as the serial port on a PC, using a straight-through cable. 5 J1 RS232 Module Block Diagram receiver for receive-data signals, and a signalground connection), or as a 5-wire DTE serial port with an additional transmitter and receiver for RTS and CTS handshaking signals, respectively. The RS232 module is designed to work with either Digilent programmable logic system boards or embedded control boards. Most Digilent system boards (like the Basys, Nexys or Cerebot) have 6-pin connectors that allow the RS232 module to plug directly into the page 1 of 2 Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. PmodRS232 Reference Manual system board or to connect via a Digilent 6-pin cable. Some older Digilent boards may need a Digilent Module Interface Board (MIB) and a 6pin cable to connect to the RS232 module. The MIB plugs into the system board and the cable connects the MIB to the RS232 module. (1) CTS (2) RTS (3) TXD (4) RXD (5) GND (6) Vcc (3.3 - 5V) RS232 Module Connector J1 The RS232 module is wired as a DTE device. RS232 signals are named from the perspective of the DCE. The TXD signal carries data from the DCE to the DTE, therefore, the TXD signal on pin 3 is connected to the output of a receiver and should be connected to the receive input of a UART on the system board. Similarly, the RXD signal carries data from the DTE to the DCE and is connected to the input of a transmitter on the RS232 module and should be connected to the output of the UART on the system board. Digilent, Inc. www.digilentinc.com or 5-wire operation. Pins 1 and 2 of JP1 are connected to pins 1 and 2 of connector J1, respectively. Pins 1 and 2 of JP2 are connected to the CTS transmitter and the RTS receiver, respectively. To configure the RS232 module as a 3-wire DTE with no handshaking, place a shorting block across the two pins of JP2 and ensure there’s no shorting block on JP1. This loops RTS back to CTS on the RS232 side of the module and leaves pins 1 and 2 unconnected on J1. To configure the RS232 module as a 5-wire DTE with RTS/CTS handshaking, place a shorting block across pin 1 of JP1 and pin 1 of JP2, and place another shorting block across pin 2 of JP1 and pin 2 of JP2. This connects the CTS transmitter to pin 1 of J1 and the RTS receiver to pin 2 of J1. The CTS signal on pin 1 can be connected to the input of a transmitter and the RTS signal on pin 2 can be connected to the output of a receiver. These connections are made using jumper blocks JP1 and JP2, as described below. Digilent embedded control boards, like the Cerebot, have one or more connectors with the UART signals configured correctly for direct connection of the RS232 module. On Digilent programmable logic boards like the Basys or Nexys, a UART must be defined in the logic of the FPGA or CPLD and the appropriate signal connections must be defined to connect the UART to appropriate connector pins. Using Jumper Blocks JP1 and JP2 Jumper blocks JP1 and JP2 are used to configure the RS232 module for either 3-wire www.digilentinc.com page 2 of 2 Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners.
410-068 价格&库存
很抱歉,暂时无法提供与“410-068”相匹配的价格&库存,您可以联系我们找货
  • 1+131.434601+17.01290
库存:126
