MPN
410-341
Description Pmod MTDS
The Digilent Pmod MTDS (Revision A) is a gorgeous 2.8“ touchscreen display with a
powerful on-board microcontroller that performs graphics processing tasks. The display
is a capacitive touchscreen with QVGA resolution (320×240) and 2 finger multi-touch
support.
The most compelling aspect of the Pmod MTDS is the programming experience
provided by its Multi-Touch Display System (MTDS) Firmware and the associated
libraries. These allow you to design sleek, stylish user interfaces very quickly and with
very little code. The timing dependent tasks are handled by the firmware, so integrating
the display into existing projects is also a snap. Some of the key functionality provided
by the libraries include the ability to draw basic shapes and text, draw images stored on
microSD with binary transparency, draw buttons and easily check if they have been
pressed, and check the status and location of the user's two fingers. The libraries are
supported in Arduino IDE and Xilinx SDK, and have been tested with Ardiuno, chipKIT
and Arty host boards.
Features
2.8“ Display with QVGA resolution (320×240)
2 Finger Capacitive touch panel
Powerful PIC32MZ Microcontroller
Design a beautiful UI with only a few lines of code using libraries for Arduino IDE and
Xilinx SDK
Easily draw images with binary transparency from files stored on microSD
Drop stylish buttons and check their status at will using intuitive function calls
For use with Arduino, chipKIT and Arty platforms
6-pin Pmod port with SPI interface
Display Specifications
Size
2.8 inches
Resolution
QVGA (320×240)
Touchscreen
2-Finger Multi-Touch
Electrical
Bus
SPI
Logic Level
3.3V
Physical
Width
3.45 in (8.76 cm)
Length
2.00 in (5.08 cm)
J1 Pinout
Pin 1
~CS
Pin 2
MOSI
Pin 3
MISO
Pin 4
SCLK
Pin 5
GND
Pin 6
VCC
Pin 7
NC
Pin 8
RESET
Pin 9
NC
Pin 10
NC
Pin 11
GND
Pin 12
VCC
Functional Description
The Pmod MTDS has an on-board PIC32MZ microncontroller that is running the MTDS
firmware. To communicate with the device, you must use the MTDS and MyDisp
libraries available and documented on the MTDS resource center. Arduino and chipKIT
host boards should use the Arduino IDE libraries, and Xilinx FPGA or Zynq based host
boards should use the Pmod MTDS IP core and the libraries included with it. After
exporting to Xilinx SDK, follow the README.txt guide included in the examples folder.
JP1 is used to select how to power the display's backlight. A single jumper should be
loaded across 2 of the three pins in order to select the power source. When the jumper
is loaded across the bottom 2 pins the backlight is powered by VCC on the Pmod
connector, and when it is loaded across the top two pins the backlight is powered by an
external power supply attached to J2. This external power supply must meet the
minimum and maximum voltage requirements outlined in the Specifications table above.
The microSD connector allows the MTDS firmware to draw and save images to an
attached microSD card. In order to work properly, the microSD card must be formatted
as FAT32. Image files should be saved as Windows Bitmap files (.bmp).
Serial Communication
The Pmod MTDS communicates with the host board via the SPI protocol.
很抱歉,暂时无法提供与“410-341”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+733.289551+94.86220
