6069-410-054
6069-410-054
    DIGILENT(迪芝伦)
    DIGILENT - 6069-410-054 - Voltage and Current Output Module, MCC USB-3104, USB Device, 8 Channels, 1...
6069-410-054 数据手册
USB-3100 Series USB Voltage and Current Output Features • 4, 8, or 16 analog outputs • 16-bit resolution • Update rates from 100 S/s to 100 kS/s • 4, 8, or 16 analog current outputs available • High-drive output available The USB-3100 Series provides up to 16 voltage/current output channels, with some devices offering high-drive analog outputs. The USB-3101FS includes 4 simultaneous output channels with 250 Vrms channel-to-ground isolation. Overview The USB-3100 Series are voltage and current output USB 2.0 full-speed devices. Each device provides four, eight, or 16 voltage outputs. The USB-3102/3104/3106 also provide four, eight, or 16 current outputs. All devices provide synchronous and concurrent voltage updates. All USB-3100 Series devices except the USB‑3101FS provide eight digital I/O lines and one 32-bit event counter. Analog Output Synchronous DAC Updates All USB-3100 Series devices provide either four, eight, or 16 channels of 16-bit analog output. All USB-3100 Series devices except the USB-3101FS have a synchronous DAC load connection pin that simultaneously updates DAC outputs on multiple devices. You can configure this with software as an input (slave mode) or as an output (master mode). USB-3101FS: Each channel has a fixed ±10 V voltage output range. Outputs can be updated individually or simultaneously. Each channel has a D/A converter (DAC) that produces a voltage signal. Each channel also has ±30 V overvoltage and indefinite short-circuit protection. The USB-3101FS has 250 Vrms channel-toground isolation that protects the device and computer from ground spikes and ensures a reliable data stream, making it suitable for high-voltage applications. All Other USB-3100 Series Devices: Each channel is software-selectable for either a bipolar voltage output range of ±10 V or a unipolar range of 0 V to 10 V. Channel outputs can be updated individually or simultaneously. • Digital I/O, counter/timer available • Synchronous update available Supported Operating Systems • Windows® 11/10/8/7/Vista®XP 32/64-bit • Linux® (except for USB-3101FS) Digital I/O All USB-3100 Series devices except the USB-3101FS have eight bidirectional DIO lines. All digital pins are floating by default. A screw terminal connection is provided to configure for pull-up (+5 V) or pull-down (0 V). Counter Input Each USB-3100 Series device except for the USB-3101FS has a 32-bit event counter for counting TTL pulses. The counter increments when the TTL levels transition from low to high. The counter accepts frequency inputs of up to 1 MHz. USB-3100 Series Selection Chart Model Voltage Output Update Rate Current Output DIO Counter/ Timer Isolation USB-3101 4 100 S/s — 8 1 — USB-3102 4 100 S/s 4 8 1 — USB-3103 8 100 S/s — 8 1 — USB-3104 8 100 S/s 8 8 1 — USB-3105 16 100 S/s — 8 1 — Current Output (USB-3102/3104/3106 Only) USB-3106 16 100 S/s 16 8 1 — USB-3110 4 high-drive 100 S/s — 8 1 — These devices provide 0 mA to 20 mA of current output. Each DAC controls a voltage/current channel pair simultaneously. Each channel pair can be updated individually or simultaneously. USB-3112 8 high-drive 100 S/s — 8 1 — USB-3114 16 high-drive 100 S/s — 8 1 — USB-3101FS 4 100 kS/s — — — Measurement Computing (508) 946-5100 1 info@mccdaq.com 250 Vrms ch-to-gnd mccdaq.com USB-3100 Series Software Software Support The USB-3100 Series is supported by the software in the table below. Ready-to-Run Applications DAQami™ InstaCal™ TracerDAQ™ and TracerDAQ Pro Data acquisition companion software with drag-and-drop interface that is used to acquire, view, and log data, and generate signals. DAQami can be configured to log analog, digital, and counter channels, and to view that data in real-time or post-acquisition on user-configurable displays. Logged data can be exported for use in Excel® or MATLAB®. Windows OS DAQami is included with the free MCC DAQ Software bundle. Install DAQami and try the fully-functional software for 30 days. After 30 days, all features except for data logging and data export will continue to be available – data logging and data export features can be unlocked by purchasing the software. An interactive installation, configuration, and test utility for MCC hardware. Windows OS InstaCal is included with the free MCC DAQ Software bundle. Virtual strip chart, oscilloscope, function generator, and rate generator applications used to generate, acquire, analyze, display, and export data. Supported features may vary by hardware. The Pro version provides enhanced features. Windows OS TracerDAQ is included with the free MCC DAQ Software bundle. TracerDAQ Pro is available as a purchased software download. General-Purpose Programming Support Universal Library™ (UL) for Windows UL for Linux® (except for the USB‑3101FS) Library for developing applications in C, C++, VB, C# .Net, VB .Net, and Python on Windows. The UL for Windows is included with the free MCC DAQ Software bundle. The UL Python API for Windows is available on GitHub (github.com/mccdaq/mcculw). Library for developing applications in C, C++, and Python on Linux. UL for Linux is available on GitHub (github.com/mccdaq/uldaq). Open-source, third-party Linux drivers are also available for supported MCC devices. Application-Specific Programming Support ULx for NI LabVIEW™ DASYLab ® MATLAB® driver (except for the USB‑3101FS) Measurement Computing A comprehensive library of VIs and example programs for NI LabVIEW that is used to develop custom applications that interact with most MCC devices. Windows OS ULx for NI LabVIEW is included with the free MCC DAQ Software bundle. Icon-based data acquisition, graphics, control, and analysis software that allows users to create complex applications in minimal time without text-based programming. Windows OS DASYLab is available as a purchased software download. An evaluation version is available for 28 days. High-level language and interactive environment for numerical computation, visualization, and programming. The Mathworks Data Acquisition Toolbox™ allows users to acquire data from most MCC PCI and USB devices. Visit www.MathWorks.com for more information about the Data Acquisition Toolbox. (508) 946-5100 2 info@mccdaq.com mccdaq.com USB-3100 Series Block Diagrams USB-3106 Block Diagram With 16 channels of analog voltage/current output, the USB-3106 contains a superset of the analog output features of these USB-3100 Series devices: • USB-3101: 4 voltage output channels • USB-3102: 4 voltage/current output channels • USB-3103: 8 voltage output channels • USB-3104: 8 voltage/current output channels • USB-3105: 16 voltage output channels Analog Voltage/Current Output 4 D/A Analog Voltage/Current Output 4 SPI Analog Voltage/Current Output 4 D/A DIO 8 Channels Analog Voltage/Current Output Microcontroller 4 D/A 4 8 (508) 946-5100 4 SPI Event Counter 1(32-bit) Full-Speed USB 2.0 Compliant Interface 4 1 SYNCLD 1 5 V Regulated Power Supply USB Measurement Computing D/A 4 3 info@mccdaq.com mccdaq.com USB-3100 Series Block Diagrams USB-3114 Block Diagram With 16 channels of high-drive analog voltage output, the USB-3114 contains a superset of the analog output features of these USB-3100 Series devices: • USB-3110: 4 voltage output channels • USB-3112: 8 voltage output channels High-Drive Analog Voltage Output High-Drive Analog Voltage Output 4 D/A 4 SPI High-Drive Analog Voltage Output 4 D/A DIO 8 Channels D/A 4 4 SPI High-Drive Analog Voltage Output Microcontroller 4 D/A 4 Event Counter 1(32-bit) Full-Speed USB 2.0 Compliant Interface 8 4 1 SYNCLD 1 5 V Regulated Power Supply USB USB High-Speed USB 2.0 Compliant Interface Measurement Computing Microcontroller (508) 946-5100 Isolation barrier USB-3101FS Block Diagram Isolated DAC Amp Overvoltage Short-circuit Protection AO 0 COM Isolated DAC Amp Overvoltage Short-circuit Protection AO 1 COM Isolated DAC Amp Overvoltage Short-circuit Protection AO 2 COM Isolated DAC Amp Overvoltage Short-circuit Protection AO 3 COM 4 info@mccdaq.com mccdaq.com USB-3100 Series Specifications Specifications – all devices except USB-3101FS Absolute Accuracy – Calibrated Output ±10 V: ±4.0 LSB 0 V to 10 V: ±22.0 LSB Relative Accuracy (±LSB) ±10 V , 0 V to 10 V: 4.0 typ, 12.0 max Analog Voltage Output Analog Current Output (USB-3102/3104/3106) D/A Converter: DAC8554 Number of Channels USB-3101/3102/3110: 4 USB-3103/3104/3112: 8 USB-3105/3106/3114: 16 On the USB-3102/3104/3106, each DAC8554 output controls a voltage and current output channel-pair simultaneously. Writing to voltage channel 0 also updates current channel 0; conversely, writing to current channel 0 also updates voltage channel 0. Disconnect unused voltage and current output channels. Resolution: 16 bits Output Ranges (Software-Selectable) Calibrated: ±10 V, 0 V to 10 V Uncalibrated: ±10.2 V, –0.04 V to 10.08 V Output Transient ±10 V to (0 V to 10 V) or (0 V to 10 V) to ±10 V Range Selection: The output defaults to 0 V when the output voltage range is reconfigured, the host computer is reset, shut down, or suspended, or a reset command is issued to the device. Duration: 5 µs typ Amplitude: 5 V p-p typ Host Computer is Reset, Powered On, Suspended, or a Reset Command is Issued to Device: The duration depends on the enumeration process of the host computer. Typically, the output is stable after two seconds. Duration: 2 s typ Amplitude: 2 V p-p typ Initial Power On Duration: 50 ms typ Amplitude: 5 V peak typ Differential Nonlinearity: The max specification applies to the operating temperature range, and accounts for max errors due to the software calibration algorithm (Cal mode) and DAC8554 nonlinearities Calibrated: ±1.25 LSB typ, –2 LSB to +1 LSB max Uncalibrated: ±0.25 LSB typ, ±1 LSB max Output Current VOUTx Pins USB-3101 through USB-3106: ±3.5 mA typ USB-3110: ±40 mA max USB-3112/3114: ±40 mA max single channel, ±180 mA total load current Output Short-Circuit Protection VOUTx Connected to AGND USB-3101 through USB-3106: Indefinite USB-3110/3112/3114: ±100 ms max Output Coupling: DC Power On and Reset State DACs Cleared to Zero-Scale: 0 V, ±50 mV typ Output Range: 0 V to 10 V Output Noise 0 V to 10 V Range: 14.95 µVrms typ ±10 V Range: 31.67 µVrms typ Settling Time To 1 LSB Accuracy: 25 µS typ Slew Rate USB-3101 Through USB-3106 0 V to 10 V Range: 1.20 V/µS typ ±10 V Range: 1.20 V/µS typ USB-3110/3112/3114 0 V to 10 V Range: 2.0 V/µS typ ±10 V Range: 4.0 V/µS typ Throughput Single-channel: 100 Hz max, system-dependent Multichannel: 100 Hz/#ch max, system-dependent Number of Channels USB-3102: 4 USB-3104: 8 USB-3106: 16 Each DAC8554 output controls a voltage and current output channel-pair simultaneously. Writing to voltage channel 0 also updates current channel 0; conversely, writing to current channel 0 also updates voltage channel 0. Disconnect unused voltage and current output channels. Resolution: 16 bits Output Ranges Calibrated: 0 mA to 20 mA typ Uncalibrated: 0 mA to 25 mA typ Compliance voltage range (calibrated output): 8 V min, 36 V max. Formulas to calculate the max load resistance for current output circuit operation: Calibrated output: Load Resistance = (compliance voltage – 6 V)/0.020 A Uncalibrated output: Load Resistance = (compliance voltage – 6 V)/0.025 A Differential Nonlinearity Calibrated: ±1.25 LSB typ, –2 LSB to 1 LSB max Uncalibrated: ±0.25 LSB typ, –1 LSB to 1 LSB max The max specification applies to the entire operating temperature range, and accounts for max errors due to the software calibration algorithm (in calibrated mode only) and the DAC8554 nonlinearities. Absolute accuracy: ±0.05% of full-scale range (compliance voltage = 13 V, load resistance = 100 Ω) IOUTx leakage current: 100 nA typ for each individual IOUT channel (all zeros written to IOUTx channel Settling time: 25 µS typ (full scale step to 1 LSB accuracy; compliance voltage = 12 V, load resistance = 500 Ω Throughput Single-channel: 100 Hz max, system-dependent Multichannel: 100 Hz/#ch max, system-dependent Analog Output Calibration Recommended Warm-Up Time: 15 minutes min Onboard Precision Reference DC Level: 5.000 V ±1 mV max. Tempco: ±10 ppm/°C max. Long-Term Stability: ±10 ppm/SQRT(1000 hrs) Calibration Method USB-3101 Through USB-3106: Software calibration USB-3110/3112/3114: SW calibration (Voutx Rload = 20 mA fixed resistive load) Calibration Interval: 1 year Digital I/O Digital Logic Type: CMOS Number of I/O: 8 Configuration: Independently-configured for input or output Pull-Up/Pull-Down Configuration: Software-selectable; all pins floating (default) For pull-down, connect the DIO CTL pin to a DGND pin. For pull-up, connect the DIO CTL pin to the +5 V pin. Digital I/O Input Loading: TTL (default); 47 kΩ (pull-up/pull down configurations) Digital I/O Transfer Rate (System-Paced): System-dependent, 33 to 1000 port reads/writes or single bit reads/writes per second. Input High Voltage: 2.0 V min, 5.5 V absolute max Input Low Voltage: 0.8 V max, –0.5 V absolute min Output High Voltage (IOH = –2.5 mA): 3.8 V min Output Low Voltage (IOL = 2.5 mA) : 0.7 V max Power On and Reset State: Input Synchronous DAC Load Absolute Accuracy Components – Calibrated Output Range (V) % of Reading Offset (mV) Temp. Drift (%/°C) ±10 ±0.0183 ±1.831 0.00055 ±3.661 mV 0 to 10 ±0.0183 ±0.915 0.00055 ±2.746 mV Measurement Computing Pin name: SYNCLD, Schmitt trigger input, over-current protected with a 200 Ω series resistor. Power On and Reset State: Input Pin Type: Bidirectional; output the internal D/A LOAD signal, or receive the D/A LOAD signal from an external source. Termination: Internal 100 kΩ pull-down Input Clock Rate: 100 Hz max Absolute Accuracy at FS (508) 946-5100 5 info@mccdaq.com mccdaq.com USB-3100 Series Specifications Environmental Clock Pulse Width Input: 1 µs min Output: 5 µs min Input Leakage Current: ±1.0 µA typ Input High Voltage: 4.0 V min, 5.5 V absolute max Input Low Voltage: 1.0 V max, –0.5 V absolute min Output High Voltage IOH = –2.5 mA: 3.3 V min No Load: 3.8 V min Output Low Voltage IOL = 2.5 mA: 1.1 V max No Load: 0.6 V max When set for input, the analog outputs can be updated immediately or when a positive edge is detected with software. SYNCLD must be at a low logic level for DAC outputs to be updated immediately. If an external source is pulling the pin high, no update occurs. Operating temperature USB-3101/3103/3105: 0 ˚C to 70 ˚C All other devices: 0 ˚C to 50 ˚C Storage temperature: –40 ˚C to 85 ˚C Relative humidity (RH): 0% to 90% RH, noncondensing Power Supply current (USB enumeration):
6069-410-054 价格&库存
很抱歉,暂时无法提供与“6069-410-054”相匹配的价格&库存,您可以联系我们找货
  • 1+4594.826731+594.41098
库存:32
