4300-3149/AAA
4300-3149/AAA
    PRESSMASTER
4300-3149/AAA 数据手册
Mobile Crimp Tool Quick Fit Snap-In/Out Dies 128-5327 128-5314 Mobile Crimp Tool - Designed for Professionals who carry their tools to work. This lightweight, compact and easy to use tool features SNAP-IN & SNAP-OUT dies covering a wide range of connector products. If you take your tools to work, are often on the move and you demand a quality result from your tools then this highly versatile crimp tool will meet all of your crimp needs. Mftrs. List No. 4300-3149 4300-3129 4300-3128 4300-3127 4300-3153 4300-3154 4300-3150 4300-3151 4300-4146 4300-3141 Description Mobile crimp tool - frame only Die set - Insulated: Red/Blue Mftrs. List No. 4300-3140 4300-3136 Die set - Insulated: Yellow/Mini yel- 4300-3138 low Die set - Ferrules: 0.25-10 4300-3132 Die set - Ferrules: 16-25 Die set - Ferrules: 35-50 Die set - Open barrel: 2.8/110 Die set - Open barrel: 4.8/187 Die set - Open barrel: 6.3/250 Die set - Fiber optic ST/SC/SMA/ SMB/SFR 4300-3144 4300-3137 4300-3139 4300-3147 4300-3148 Description Die set - Coaxial BNC/TNC RG174/ 179 Die set - Coaxial BNC/TNC RG58/ 59/62/71 Die set - Coaxial CATV RG6/59 Die set - Data plug RJ11 6/6 6/4 6/2 Die set - Data plug RJ45 8/8 Die set - Un-insulated 0.35-2.5mm2 Die set - Un-insulated 4-10mm2 Die set - Turned pin 0.14-4mm2 Die set - Turned pin 6 & 10mm2 448824 Mftrs. List No. 4300-3149 4300-3129 4300-3128 4300-3127 4300-3153 4300-3154 4300-3150 4300-3151 4300-4146 4300-3141 4300-3140 4300-3136 4300-3138 4300-3132 4300-3144 4300-3137 4300-3139 4300-3147 4300-3148 Order Code 128-5314 128-5317 128-5316 128-5320 128-5321 128-5322 128-5323 128-5325 128-5326 128-5327 128-5328 128-5329 128-5330 128-5332 128-5331 128-5319 128-5318 128-5333 128-5334 Price Each 33.33 14.24 18.52 18.52 17.09 17.09 33.33 33.33 15.82 22.22 17.09 22.22 13.67 13.01 22.22 14.24 18.52 25.63 33.33
4300-3149/AAA 价格&库存
很抱歉,暂时无法提供与“4300-3149/AAA”相匹配的价格&库存,您可以联系我们找货
