4320-1017
4320-1017
    PRESSMASTER
4320-1017 数据手册
Product Embla RA VBC Embla RA VBC is a self adjusting stripping and cutting tool, 0.1-4 mm²/AWG 28-12, V-blade. Pistol grip provides stress free comfort, particularly when operating parallel to a table or workbench. Tool-less interchangeable stripping cassettes allow a wide and diverse stripping capacity Widest stripping capacity of any tool of its type Durable, integrated wire cutting capability Cutting capacity: Flexible wires, 10 mm²/8 AWG. Rigid wires, 1.5 mm² /16 AWG Fine adjustability for thin or thick insulation, without damage to wire conductors At the end of the stripping function, the stripping blades open and remain open to facilitate easy and snag free wire removal from the tool Ergonomic: strong, durable, and comfortable ergonomic design Replacement stripping cassettes and cutting blades available. Reliable: Frame and mechanism life span exceeds 150,000 cycles (tested with 1.5 mm²/AWG 16 PVC cable). Pressmaster AB P.O. Box 3, Industrivägen SE-796 21 Älvdalen, Sweden Tel: +46 (0)251-451 00 info@pressmaster.se www.pressmaster.com TECHNICAL DATA Length: 144 mm/5.67" Width: 23 mm/0.9" Height: 168 mm/6.61" Weight: 165 gr/0.37 lb Wire size: 0.1-4 mm2 / AWG 28-12 Stripping dimensions mm/mm2: 3-18 mm/adjustable Stripping dimensions inch/AWG: 0.12-0.71/adjustable Cable: PVC/PTFE and similar Description: Self-adjusting cutting and stripping tool for electrical installation and equipment wires in PVC and PTFE insulation. V blade knifes for easier strip cycle with hard insulations. Life span, cycles: 150,000 (tested with 1.5 mm²/AWG 16 PVC cable) All three cassettes (grey, red and blue) are available as separate items. Pressmaster AB P.O. Box 3, Industrivägen SE-796 21 Älvdalen, Sweden Tel: +46 (0)251-451 00 info@pressmaster.se www.pressmaster.com
4320-1017
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光耦器件,用于隔离输入和输出电路,保护电路不受外部干扰。
3. 引脚分配:EL817共有6个引脚,分别为1脚阳极,2脚阴极,3脚集电极,4脚发射极,5脚GND,6脚VCC。
4. 参数特性:工作温度范围为-40℃至+85℃,隔离电压为5000Vrms。
5. 功能详解:EL817通过光电效应实现信号传输,具有高速响应和低功耗特点。
6. 应用信息:广泛应用于通信、工业控制、医疗设备等领域。
7. 封装信息:采用DIP6封装方式。
4320-1017 价格&库存
很抱歉,暂时无法提供与“4320-1017”相匹配的价格&库存,您可以联系我们找货
