4300-1070B
4300-1070B
    PRESSMASTER
    PRESSMASTER - 4300-1070B - BT6A - VC DIE FOR BT3002, TZC
4300-1070B 数据手册
Original line PCC-5310 1,46/4,52 mm .057/.178" 1,46/5,18 mm .057/.204" 1,46/6,81 mm .057/.268" 1,69/3,25 mm .067/.128" 1,69/4,52 mm .067/.178" 1,69/5,41 mm .067/.213" The PCC-5310 is a precision, ratchet crimp tool designed to provide consistent and reliable crimp connections on coaxial connectors Calibration To calibrate this tool the pre-load has to be measured. Gauge is required to ensure that the die is according to specification. For more information; See instruction sheet. Symmetric dies for right and left handed operation Ergonomic handles for low effort crimping Ratchet action to ensure full crimp cycle with safety release Durable - minimum of 50,000 cycles. Tool is factory set with a precise eccentric cam adjustment function to guarantee performance Technical data Prod.code: Lenght: Height: Weight: Connector: Distributors address info PCC-5310 200 mm / 7,87" 164 mm / 6,46" 530 gr / 1,17 lbs Coaxial
4300-1070B 价格&库存
很抱歉,暂时无法提供与“4300-1070B”相匹配的价格&库存,您可以联系我们找货
