4320-0617
4320-0617
    PRESSMASTER
4320-0617 数据手册
Tor Heavy-Duty Cable Stripping Tool Tor is a professional stripping tool for cables of all insulation types. Supplied with both small and large hooks to allow a cable stripping capacity of 4.5mm to 40mm. Ì Large capacity: Interchangeable hook feature means that Tor can replace two or more similar products in the toolbox. Ì Easy to use: Positive locking positions for circular, lengthways and spiral strips. Ì No special tools required to change hooks. Ì Durable: Replacement cutting blades can be stored in a pocket located within the tool body. Ì Reliable: Tested to over 100,000 cycles Tor Stripping Tool Insulation Thickness (mm) Up to 4.5mm Cable Capacity Large Hook (mm) 20 - 40mm Dia Cable Capacity Small Hook (mm) 4.5 - 25mm Dia Length Weight 150mm 116g 246715 Price Each Descritption Stripping Tool (2 Hooks) Spare Blade Sets Small Hook, Spare Large Hook, Spare Blade, Spare Mfrs. List No. Order Code 4320-0617 422-8893 4320-0620 4320-0619 4320-0618 422-8960 422-8972 422-8959
4320-0617 价格&库存
很抱歉,暂时无法提供与“4320-0617”相匹配的价格&库存,您可以联系我们找货
