Original line
PZD-3
Crimp profile
The PZD-3 is a precision, ratchet crimp tool designed to provide consistent and
reliable crimp connections on endsplices/ferrules on wires ranging from .
Easy to use
Open the tool. Insert terminal and wire in die nest from front. Close tool until ratchet
release. Attention: To release ratchet mechanism, push the trigger forward when
holding handles.
Calibration
To calibrate this tool the pre-load has to be measured. Gauge is required to ensure
that the die is according to specification. For more information; See instruction sheet.
Self adjusting tool with single die to
crimp all terminals within its range.
Front entry for easy access within
confined spaces.
Compact, pocketable design.
Bi-moulded comfort handles for
improved handgrip.
Ratchet action to ensure full crimp
cycle with safety release.
Tool is factory set with a precise
eccentric cam adjustment function to
guarantee performance.
Technical data
Prod. code:
Length:
Height:
Weight:
Connector:
Description:
Wire size:
Distributors address info
PZD-3
197 mm / 7,75"
59 mm / 2,32"
370 gr / 0,82 lbs
Endsplices / Ferrules
Insulated and Uninsulated
22-10 AWG
很抱歉,暂时无法提供与“4300-3047”相匹配的价格&库存,您可以联系我们找货
