Embla
Self-adjusting cut
and strip tool
Embla is a self-adjusting cutting and stripping tool
for modern electrical installation and equipment wires
(90% of wires can be stripped without adjusting the
tool). The introduction of easily interchangeable
multiple stripping cassettes enable precision stripping
of a wide range of insulations from PVC to PTFE with
just one tool. High priority has been given to the
ergonomic design of Embla resulting in a lightweight but
strong and comfortable tool equally qualified for high volume
production and portable/field usage.
Features
Easy change stripping blade
cassettes
V blade cassette for
stripping difficult
insulations
Versatile: The option of easily interchangeable stripping
cassettes makes possible the stripping of most modern
insulations within the tools specified range. Widest stripping
capacity of any tool of its type.
Precise: Fine adjustability ensures that thin insulations can
be stripped without damage to conductors. At the end of the
stripping function, the stripping blades open and remain
open during the return phase of the strip cycle facilitating
easy/snag free wire removal from the tool.
Ergonomic: Sculpted shape, soft grip main handle, low
friction moving handle, optimized grip span, angled head
and light weight guarantees comfortable, stress free operation.
Durable: Replacement stripping cassettes and cutting
blades available.
Cuts up to 10 mm2/8 AWG.
Reliable: Tested to over 150,000 cycles. Molded in new
high-strength plastic with twice the strength of standard
nylon/PA6.
Specifications
Ergonomic design with nonslip bi-moulded handles
Stripping capacity:
Cutting capacity:
Straight blade cassette, PVC insulations
V blade cassette, all insulations
Flexible wires
Rigid wires
Overall dimensions
Weight with straight blade cassette
191x123x20 mm/7.5 x 4.8 x 0.8 inch
136g/4.8oz
Embla + straight blade cassette
Embla + “V” blade cassette
Embla + straight and “V” blade cassettes
”V” blade cassette
Replacement cutting blade kit
4320-0612
4320-0613
4320-0624
4320-0614
4320-0615
4320-0625
0.02 – 10 mm2/34-8 AWG
0.02 – 6 mm2/34-10 AWG
10 mm2/8 AWG
1.5 mm2/16 AWG
很抱歉,暂时无法提供与“4320-0615”相匹配的价格&库存,您可以联系我们找货
