49050C
49050C
    MYRRA
    49050C
49050C 数据手册
Power Supplies Power Supplies AC/DC CONVERTER - 5W REGULATED High Accuracy Family Power Supplies NEW 5W SERIES MAIN FEATURES: 2W to 5W Small Compact Size - PCB Mount Single Output - Secondary Side Regulated Output Range : 3.3VDC - 24VDC Input Range : 85VAC - 265VAC/47 - 63Hz Or 120VDC -370VDC Very Low Standby Power Consumption ≤ 0.1W High Energetic Efficiency : Meets Requirements Of Energy Star and EC Code Of Conduct Encapsulated Design and same Footprint as an EI30 Transformer: Upgrade Your Application without redesigning the PCB Safety: Meets All Requirements of IEC/EN61558-2-16, IEC/EN60335, IEC/EN62368, UL/CUL62368 Materials: Uses UL 94-VO Plastic And Resin EMC : Conducted And Radiated Emission conform To EN55032, FCC Part 15, CLASS B without any additional components Immunity Conform To EN61000-3-2 CLASS A, EN61000-3-3, IEC61000-4-2, IEC61000-4-3, IEC61000-4-4, IEC61000-4-5, IEC61000-4-6, IEC61000-4-11 DATA SHEET Part No Power Rating Watts Output Voltage (VDC) Output Current (mA) Ambient Temp. (°C) 1500 50 830 70 2.0 610 80 5.0 1000 60 600 70 2.0 400 85 5.0 560 60 5.0 49033C 49050C 49090C 49120C 2.75 3.0 3.0 3.3 5.0 330 70 2.0 220 85 5.0 420 60 250 70 170 85 3.0 2.0 9.0 12 Efficiency Input Range Typical >71%@230VAC >72%@230VAC >70%@230VAC >75%@230VAC >73%@230VAC >76%@230VAC >74%@230VAC 85VAC-265VAC (120VDC- 370VDC) Power Supplies Power Supplies AC/DC CONVERTER - 5W REGULATED High Accuracy Family Part No Power Rating Watts Output Voltage (VDC) Output Current (mA) Ambient Temp. (°C) 330 60 200 70 2.0 130 85 5.0 280 60 170 70 2.0 110 85 5.0 210 60 125 70 84 85 5.0 49150C 49180C 49240C 3.0 3.0 3.0 2.0 15 18 24 Efficiency Input Range Typical >77%@230VAC >74%@230VAC >78%@230VAC 85V85VAC-265VAC (120VDC- 370VDC) >76%@230VAC >80%@230VAC >76%@230VAC NOTE : Other output voltage are available upon request. Please refer to MYRRA’s website and catalogue for MYRRA SMPS application notes. The information contained in this document is subject to change without notice. www.myrra-powersupplies.com AC/DC CONVERTER - 5W REGULATED High Accuracy Family Power Supplies NEW 5W SERIES Specifications Model : 5 Watt AC Input Characteristics Rated AC Input Voltage 100~240 VAC or 140VDC-340VDC AC Input Voltage Range 85~265VAC or 120VDC-370VDC AC Input Frequency 47Hz~63Hz Rated AC Input Frequency 50/60Hz Input Current 0.2A Max@85VAC~265VAC, at full load Standby Power O.1W Max (Meets the requirements of Energy Star and the EC Code Of Conduct) Output Voltage Accuracy + 2% Output Voltage Line Regulation + 0.5% Output Voltage Load Regulation + 2% Ripple & Noise Dynamic Response DC Output Characteristics Hold Up Time Max 180mVp-p@ Rated AC input, at nominal line (The measuring will be terminated with a 47µF AL E-Cap and a 0.1µF Ceramic-Cap. An oscilloscope set at 20MHz bandwidth) The output voltage shall not exceed + 10% rated output voltage @ 50%  → 100 % Load change, 1A/µS, 1KHz 50% duty cycle 5mS min@ 100 VAC~240VAC, DC output with full load Turn On Delay 3S max @ 85VAC~265VAC input and DC output with full load Rise Time 50ms max @ 85VAC~265VAC input and DC output with full load Overshoot Undershoot The output voltage shall not exceed +10% rated output voltage @ Power on and 85VAC~265VAC input, and DC with full load The output voltage shall not exceed -10% rated output voltage @ Power off and 85VAC~265VAC input and DC output with full load Efficiency See table (Meets the requirements of Energy Star and the EC Code of Conduct) Please refer to MYRRA’s website and catalogue for MYRRA SMPS application notes. The information contained in this document is subject to change without notice. www.myrra-powersupplies.com AC/DC CONVERTER - 5W REGULATED High Accuracy Family Power Supplies NEW 5W SERIES Over Current Protection The power supply shall automatically protect against over current. The power supply shall auto-recover normal operation after the fault condition is removed. No excessive heat, odour, or plastic deformation shall occur with no safety hazard during the fault Output Short Circuit Protection The power supply shall withstand a continuous output short without damage; The short may be applied before power on, or after power on. The power supply shall resume normal operation after the short is removed. No excessive heat, odour, or plastic deformation shall occur with no safety hazard during the fault. Operation Temperature -25°C ~+85°C (see page 1 table) Operation Humidity 10~ 90% RH(No Condensing) @ full load Storage Temperature -10'C to +35'C Storage Humidity < 75%RH Cooling Method Ordinary or thermostat Dielectric Strength Primary to Secondary: 4000Vac 5mA, 3 secs. Radiation Meets EN55032,FCC part 15, Class B. under 3dB margin Conduction Meets EN55032,FCC part 15,Class B. under 3dB margin Harmonic Current Disturbance Meets EN61000-3-2:2014, Class A Voltage fluctuation and Flicker Meets EN61000-3-3:2013 Protection Characteristics Environmental Safety & EMC Requirement Please refer to MYRRA’s website and catalogue for MYRRA SMPS application notes. The information contained in this document is subject to change without notice. www.myrra-powersupplies.com AC/DC CONVERTER - 5W REGULATED High Accuracy Family Power Supplies NEW 5W SERIES Electrostatic Discharge Meets IEC61000-4-2:2008 Contact Discharge + 4KV, Air Discharge +8KV RF Field Strength Susceptibility Meets IEC61000-4-:2006+A1:2007+A2:2010 Meets IEC61000-4-5:2014,+1KV (line to line) Safety & EMC Requirement Electrical fast Transient Note: surge level can be extended to 6KV with an external circuit – please refer to Myrra's website and catalogue for MYRRA SMPS application notes Conducted Susceptibility Meets IEC61000-4-6:2013 Voltage Dips And Interruptions Meets IEC61000-4-11:2004 Safety Standards Meets all requirements of UL/CUL62368 IEC/EN60335 IEC/EN61558-2-16 IEC/EN62368 MTBF Reliability Requirements Calculated in accordance with MIL-HDBK-217-F2 Burn-in-Test Net Weight Guarantee >550K Hours @ 230VAC input at 24deg.C and DC output with 5W load. >200K Hours @ 230VAC input at max operation temperature and DC output with 5W load The power supply is subject to a burn in test for 2~5hours under 230VAC input and DC full load at an ambient temperature of 30~45 degrees C Approximately 30 grams per product unit This product is in accordance with the European RoHS & REACH directives Please refer to MYRRA’s website and catalogue for MYRRA SMPS application notes. The information contained in this document is subject to change without notice. www.myrra-powersupplies.com AC/DC CONVERTER - 5W REGULATED High Accuracy Family Power Supplies SCHEMATIC DERATING GRAPH (TYPICALLY 12V TYPE) DIMENSIONS AND PINOUT 4 PINS PRI: Pins 1-5: AC or DC Input SEC: Pin 7: DC Output +V Pin 9: DC Output 0V (view from pins side) Pease refer to MYRRA’s website and catalogue for MYRRA SMPS application notes. The information contained in this document is subject to change without notice. www.myrra-powersupplies.com
49050C 价格&库存
很抱歉,暂时无法提供与“49050C”相匹配的价格&库存,您可以联系我们找货
49050C
  • 14+106.0334314+13.71826
  • 25+78.2626325+10.12536
  • 50+74.6835550+9.66231
  • 100+68.16166100+8.81853
库存:103
49050C
库存:103
