AC/DC CONVERTER 20W - REGULATED
Power Supplies
NEW 20W SERIES
MAIN FEATURES:
20W Small Compact Size - PCB Mount
Single Output - Secondary Side Regulated
Output Range: 3.3VDC - 24VDC
Input Range: 85VAC - 265VAC/47 - 63Hz or 120VDC - 370VDC
Very Low Standby Power Consumption ≤0.15W
High Energetic Efficiency: Meets the requirements of Energy Star
and the EC Code of Conduct
Safety: Meets IEC/EN61558-2-16, IEC/EN60335, IEC/EN62368,
UL/CUL62368, CE
Materials: Uses UL 94-V0 Plastic and Resin
EMC: Conducted and Radiated Emission conform to EN55032,
N55014 and FCC Part 15, CLASS B
Immunity conforms to EN61000-3-2 CLASS A, EN61000-3-3,
IEC61000-4-2, IEC61000-4-3, IEC61000-4-4, IEC61000-4-5,
IEC61000-4-6, IEC61000-4-11
Part
No
Power
Rating
Watts
Output
Voltage
(VDC)
Ambient Temp.
(°C)
3.3
Rated
Output
Current
(mA)
4400
-25°C ~ +70°C
>75%@230VAC
Efficiency Typical
Refer to “DERATING GRAPH”
49033G
14.5
49050G
4000
-25°C ~ +70°C
>78%@230VAC
49090G
2200
-25°C ~ +70°C
>81%@230VAC
1667
-25°C ~ +70°C
>82%@230VAC
49120G
49150G
49180G
49240G
(1800 Max)
1333
-25°C ~ +70°C
(1400 Max)
1111
Input
Range
-25°C ~ +70°C
85VAC265VAC
(120VDC370VDC)
>83%@230VAC
(1140 Max)
833
-25°C ~ +70°C
(900 Max)
NOTE: Other output voltages are available upon request.
Please refer to MYRRA’s website and catalogue for MYRRA SMPS application notes.
The information contained in this document is subject to change without notice.
www.myrra-powersupplies.com
Power Supplies
NEW 20W SERIES
Model : 20 Watt
AC Input
Characteristics
Specifications
Rated Input Voltage
100~240 VAC or 140VDC-340VDC
Input Voltage Range
85~265VAC or 120VDC-370VDC
AC Input Frequency Range
47Hz~63Hz
Rated AC Input Frequency
50/60Hz
Input Current
0.6A Max@85VAC~265VAC, at full load
Input Inrush Current
Standby Power
Output Voltage Accuracy
Output Voltage Line
Regulation
Output Voltage Load
Regulation
40A Max @100VAC~2240VAC input, cold start, full
load
0.15W Max (Meets the Requirements of Energy
Star and the EC Code Of Conduct)
+ 2.5% (9V,12V,15V,18V,24V Types)
+ 4% (3.3V Types and 5V Types)
+/- 1%
+ 2.5% (9V,12V,18V,24V Types)
+ 4% (3.3V Type,5V Type)
Ripple & Noise
Max 180mVp-p@ Rated AC input, at nominal
line (The measuring will be terminated with a
47µF AL E-Cap and a 0.1µF Ceramic-Cap. An
oscilloscope set at 20MHz bandwidth)
Dynamic Response
The output voltage shall not exceed + 10%
rated output voltage @ 10% → 90 % Load
change, 1A/µS, 1KHz 50% duty cycle
DC Output
Characteristics
Hold Up Time
Turn On Delay
Rise Time
Overshoot
Undershoot
5mS min@ 100 VAC~240VAC,
DC output with full load
3S max @ 85VAC~265VAC input and DC output
with full load
50ms max @ 85VAC~265VAC input and DC output
with full load
The output voltage shall not exceed +10% rated
output voltage @ Power on and 85VAC~265VAC
input, and DC with full load
The output voltage shall not exceed -10% rated
output voltage @ Power off and 85VAC~265VAC
input and DC output with full load
Power Supplies
NEW 20W SERIES
Efficiency
Over Current Protection
Protection
Characteristics
Output Short Circuit
Protection
Over temperature
protection
Operation Temperature
Environmental
Safety & EMC
Requirement
See table (Meets the requirements of Energy Star
and the EC Code of Conduct)
The power supply shall automatic protection. The
power supply shall auto-recovery normal operations
after the deformation is removed. No excessive heat,
odor, or plastic deformation shall occur with no
safety hazard
The power supply shall withstand a continuous
output short without damage in 24 hours; The short
may be applied before power on, or after power on;
The power supply shall resume normal operation
after the short is removed, no excessive heat, odour
or plastic deformation shall occur with no safety
hazard.
The power supply shall shut down when the junction
temperature of PWM controller exceeds the thermal
shutdown temperature, typically 140°C +10°C
-25°C~+70°C (Refer to« DERATING GRAPH »)
Operation Humidity
10~90% RH (No Condensing) @ full load
Storage Temperature
-10°C~ +35°C
Storage Humidity
很抱歉,暂时无法提供与“49120G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 6+144.661846+18.77447
- 国内价格 香港价格
- 6+147.227946+19.10750
