69HDT0
69HDT0
    GIC
    GIC - 69HDT0 - DIN Rail Digital Timer, Crono Series, Multifunction, 25 Ranges
69HDT0 数据手册
® Digital Time Switches & • Precise time programming for • 12/24 h display formats Daily/Weekly/Pulse switching • 6 Years Battery reserve • 25 ON/OFF programs • Simple Reset & Manual override • Weekend Exclusion (FRI SAT or SAT SUN) • Settable DST & Keypad Lock Feature and Weekly OFF programming • LED Indication of Relay status Ordering Information Cat. No. Description 67DDT0 110 - 240 VAC, Digital Time Switch - Crono, 1 C/O 6GHDT0 24 VDC, Digital Time Switch - Crono, 1 C/O 69HDT0 12 VDC, Digital Time Switch - Crono, 1 C/O 67DDT9 110 - 240 VAC, Digital Time Switch - Pulse, 1 C/O 6GHDT9 24 VDC, Digital Time Switch - Pulse, 1 C/O 69HDT9 12 VDC, Digital Time Switch - Pulse, 1 C/O 56 ® Digital Time Switches Cat. No. Parameters Supply Voltage Supply Variation Frequency Power Consumption (Max.) Number of Programs Minimum Switching Time Pulse Duration Number of Operating Modes Description of Modes Display DST Clock Accuracy Power Reserve from Factory Relay Output Contact Rating Output Electrical Life Mechanical Life AC - 15 Utilization Category DC - 13 Operating Temperature Storage Temperature Humidity (Non Condensing) LED Indication Enclosure Dimension (W x H x D) (in mm) Weight (unpacked) Approx. Mounting Certification ® 67DDT0 ( ) 110 - 240 VAC -20 % to +10% 50/60 Hz 6 VA 25 ON/OFF Programs 1 min NA 5 - Program Run • AUTO • ON AUTO - Instant ON up to next Auto Event • AUTO OFF - Instant OFF up to next Auto Event - Continuous ON • ON - Continuous OFF • OFF 67DDT9 ( ) 16 Pulse Programs 1s 1 to 59 s (Programmable) 3 • AUTO - Program Run - Continuous ON • ON - Continuous OFF • OFF 3 Lines Text LCD Programmable ± 2 s/day max. over the Operating Temperature range 6 Years 1 C/O 16A (For 'NO') & 5A (For 'NC') @ 240 VAC / 24 VDC (Resistive), Inductive (cos ø = 0.6):- 6 A @ 250 VAC 3x104 5x104 Rated Voltage (Ue): 120/240 V, Rated Current (Ie): 3/1.5 A Rated Voltage (Ue): 24/125/250 V, Rated Current (Ie): 2.0/0.22/0.11 A -10°C to + 55°C -10°C to + 60°C 95% (Rh) Red LED Relay ON Flame Retardant UL94-V0 36 X 90 X 65 110 g Base / DIN rail RoHS Compliant Degree of Protection IP 20 for Terminals, IP 40 for Enclosure EMI / EMC Harmonic Current Emissions ESD Radiated Susceptibility Electrical Fast Transients Surges Conducted Susceptibility Voltage Dips & Interruptions (AC) Conducted Emission Radiated Emission IEC 61000-3-2 IEC 61000-4-2 IEC 61000-4-3 IEC 61000-4-4 IEC 61000-4-5 IEC 61000-4-6 IEC 61000-4-11 CISPR 14-1 CISPR 14-1 Environmental Cold Heat Dry Heat Vibration Repetitive Shock Non-Repetitive Shock IEC 60068-2-1 IEC 60068-2-2 IEC 60068-2-6 IEC 60068-2-27 IEC 60068-2-27 Applications & Ideal for Lighting applications like street lighting, Advertising Displays, Glowsigns. Also can be used for Air conditioners / Coolers, Geysers, conveyors, pumps etc. 57 Ideal for Siren, Bell applications Astronomical Time Switch ® Mini • Astronomical Time Switch in 35mm • DST, Offset, OFF Hours, Weekly OFF features • Latitude/Longitude precise to the minute • 12/24 Hour display format with time zone • 6 years Battery reserve • Sunrise/Sunset or Twilight rise/set trigger modes • Easy Manual Override & Keypad Lock feature • Ease of Programming & Navigation • Ideal for Outdoor & Street lighting applications Ordering Information Cat. No. Description T2DDT7 110 - 240 VAC, Astronomical Time Switch - Astro Mini, 1 C/O T2DDT8 110 - 240 VAC, Astronomical Time Switch - Astro Mini, 1 C/O (With Pre-defined City codes) 58 Astronomical Time Switch Cat. No. Parameters Supply Voltage ( ) Supply Variation Frequency Power Consumption Programming Trigger Modes Offset OFF Hours Weekly Off DST Number of Operating Modes Description of Modes Minimum Switching Time Display Clock Accuracy Power Reserve from Factory Relay Output Contact Rating Output Electrical Life Mechanical Life AC - 15 Utilization Category DC - 13 Operating Temperature Storage Temperature Humidity (Non Condensing) LED Indication Enclosure Dimension (W x H x D) (in mm) Weight (unpacked) Mounting Certification Mini T2DDT7 110 - 240 VAC -20 % to +10% (of ) 50/60 Hz 6 VA Based on Latitude/Longitude precise to the minute with time-zone Sunrise/Sunset or Twilight Rise/Set 1 min to 10 hr 59 min (Programmable) Programmable User Defined User Defined 3 - As per user defined program settings • AUTO • ON AUTO - Instant ON up to next Auto Event • AUTO OFF - Instant OFF up to next Auto Event 1 min 3 Lines Text LCD ± 2 s/day max. over the Operating Temperature range 6 Years 1 C/O 16A (For 'NO') & 5A (For 'NC') @ 240 VAC / 24 VDC (Resistive), Inductive (cos ø = 0.6) :- 6 A @ 250 VAC 3x104 5x104 Rated Voltage (Ue): 120/240 V, Rated Current (Ie): 3/1.5 A Rated Voltage (Ue): 24/125/250 V, Rated Current (Ie): 2.0/0.22/0.11 A -10°C to + 55°C -10°C to + 60°C 95% (Rh) Red LED Relay ON Flame Retardant UL94-V0 36 X 90 X 65 110 g Base / DIN rail RoHS Compliant Degree of Protection IP 20 for Terminals, IP 40 for Enclosure EMI / EMC Harmonic Current Emissions ESD Radiated Susceptibility Electrical Fast Transients Surges Conducted Susceptibility Voltage Dips & Interruptions (AC) Conducted Emission Radiated Emission IEC 61000-3-2 IEC 61000-4-2 IEC 61000-4-3 IEC 61000-4-4 IEC 61000-4-5 IEC 61000-4-6 IEC 61000-4-11 CISPR 14-1 CISPR 14-1 Environmental Cold Heat Dry Heat Vibration Repetitive Shock Non-Repetitive Shock IEC 60068-2-1 IEC 60068-2-2 IEC 60068-2-6 IEC 60068-2-27 IEC 60068-2-27 Applications ® Street lighting applications in cities, industrial townships, university campuses Lighting automation in sports complex, hotels, parks & other outdoor applications. 59 Astronomical Time Switch • Dynamic and Accurate control based on ® • Three Independent channel outputs Astronomical Mathematics • Active Phase selection • Sunrise / Sunset or Twilight rise / set trigger • Manual override facility • Yearly programming with Season mode, • Single phase and Three phase versions DST, Offset, OFF hours, Weekly Off features • Modbus Communication • Protection against Under Voltage and Over Voltage • User friendly software for device configuration • Alternate Mode with Auto Load Changeover feature Ordering Information Cat. No. Description T2DDT0 110 - 240 VAC, Single Phase Astronomical Time Switch - Astro, 2 NO T3DDT0 110 - 240 VAC, Three Phase Astronomical Time Switch - Astro, 3 NO TGDDT6 Windows based Application software for Astro GFDNN3M Memory Card GFDNN2S RS 232 Serial Interface Cable GFDNN1 USB Interface Cable 60 Astronomical Time Switch Parameters Supply Voltage ( ) Supply Variation Frequency Programming Trigger Modes Offset OFF Hours Weekly Off Alternate Mode Seasonal Mode DST Number of Operating Modes Mode Description Minimum Switching Time Display Under Voltage Trip Level Over Voltage Trip Level Trip Time Recovery Time Clock Accuracy Power Reserve from Factory Relay Output Contact Rating Output Electrical Life Mechanical Life AC - 15 Utilization Category DC - 13 Operating Temperature Storage Temperature Humidity (Non Condensing) Enclosure Dimension (W x H x D) (in mm) Weight (unpacked) Mounting Certification T3DDT0 T2DDT0 Cat. No. ® 110 - 240 VAC 110 - 240 VAC (3 Phase, 4 Wire) -20 % to +10% (of ) 50/60 Hz Based on Latitude/Longitude precise to the minute with time-zone Sunrise/Sunset or Twilight Rise/Set 1 min to 10 hr 59 min (Programmable) Programmable User Defined Yes User Defined User Defined 3 - As per user defined program settings • AUTO • ON AUTO - Instant ON up to next Auto Event • AUTO OFF - Instant OFF up to next Auto Event 1 min (1s for Pulse) Backlit LCD NA 0 - 220 V (Settable) 130 - 330 V (Settable) NA NA 5 - 16 sec 1 - 4 sec NA ± 1 s/day max. over the Operating Temperature range 6 years 2 NO 3 NO 8A @ 240 VAC & 5A @ 30 VDC (Resistive) 1x105 1x107 Rated Voltage (Ue): 120/240 V, Rated Current (Ie): 3/1.5 A Rated Voltage (Ue): 24/125/250 V, Rated Current (Ie): 2.0/0.22/0.11 A -10°C to + 50°C -10°C to + 60°C 95% (Rh) Flame Retardant UL94-V0 72 X 90 X 65 208 g 190 g Base / DIN rail RoHS Compliant Degree of Protection IP 20 for Terminals, IP 40 for Enclosure EMI / EMC Harmonic Current Emissions ESD Radiated Susceptibility Electrical Fast Transients Surges Conducted Susceptibility Voltage Dips & Interruptions (AC) Conducted Emission Radiated Emission IEC 61000-3-2 IEC 61000-4-2 IEC 61000-4-3 IEC 61000-4-4 IEC 61000-4-5 IEC 61000-4-6 IEC 61000-4-11 CISPR 14-1 CISPR 14-1 Environmental Cold Heat Dry Heat Vibration Repetitive Shock Non-Repetitive Shock IEC 60068-2-1 IEC 60068-2-2 IEC 60068-2-6 IEC 60068-2-27 IEC 60068-2-27 61 ® Astronomical Time Switch MOUNTING DIMENSION (mm) Astro ® Crono , Pulse & Astro Mini ® ® 72.0 65.0 65.0 90.0 68.0 45.0 68.5 45.0 90.5 100.0 C/C 36.0 T2DDT0, T3DDT0 L/+ N/- N B Ph YPh R Ph 250mA N P L N R 110 -240 VAC 50 / 60 Hz BN Y 110 - 240 V Ph - N AC [ 3Ph 4 Wire ] 50 / 60 Hz DEL Z4 ALT DEL Z4 Z3 Z1 ESC Z2 OK ESC Astro Z2 OK Astro OUTPUT 2 X RELAY / 8A OUTPUT 3 X RELAY / 8A Q2 Q1 PHASE R Ph LOAD MC1 ALT Z3 Z1 Q1 Ø 4.2 67DDT0, 67DDT9, T2DDT7, T2DDT8 CONNECTION DIAGRAM 250mA 100.0 C/C 17.0 17.0 MC2 Q2 YPh MR Q3 BPh MY L/+ MB N/- T2DDT0, T3DDT0 67DDT0, 6GHDT0, 6GHDT9, 67DDT9, 69HDT0, 69HDT9, T2DDT7, T2DDT8 MC1, MC2, MR, MY, MB: CONTACTOR COILS TERMINAL TORQUE & CAPACITY Ø 3.5...5.0 mm Torque - 1.1 N.m (10 Lb.in) Terminal screw - M3.5 Solid Wire - 2 X 0.2...2.5 mm2 AWG 1 X 24 to 10 T2DDT0, T3DDT0, T2DDT7, T2DDT8, 67DDT0, 67DDT9 62 ® Lighting Automation with using GSM Technology • Most of the "ASTRO" parameters can be set remotely using SMS queries. I.e. Output mode, Offset Hrs etc, UV, OV settings. • Relay Output can be override remotely using SMS query. • Energy Meter Functionality. Parameter like Load current, Supply voltage, Power, Energy can be known remotely. • With the help of "Auto Error Code Update" following onsite error can be know remotely during output event. - Under Voltage - Over Voltage - Over Current - Output actuator short. - Load Open Ordering Information Cat. No. Description 19D2000C Surge Suppressor 19D20B00 Astro GSM Module (GSM-ERT5), Remote Side 19A1000B Communication Cable (TTL-TTL) between Astro & GSM Module TGDDT6 Windows based application software for Astro 63 ® Lighting Automation with using GSM Technology Cat. No. 19D20B00 (ERT 5) Parameters Supply Voltage ( ) Supply Variation Frequency Active Phase selection Operating Temperature GSM Type GPRS Packet data AT cCommand set Suitabiltiy SMS Type Functionality SIM Holder Antenna Antenna Impedance Energy Measurement Energy Measurement Accuracy Current Sensing Range CT Ratio LED Indications Pulse Out rate Auxiliary Output Mounting Enclosure Dimension (W x H x D) (in mm) Weight (unpacked) 240 VAC (3 Phase, 4 Wire) -30% to +25% (of ) 50/60 Hz Yes -15oC to + 60oC Dual band 900 / 1800 GSM Class 10 coding scheme N. A. Data Call through GSM, SMS Text, Cell Broadcast Connected with the product 50 Yes Class 0.5 5A Settable up to 40 Tx, Rx, Network, Power, Pulse Out 3200 pulses / kWh 12 V DC, 200 mA Base / DIN Rail Flame Retardant UL94-V0 72 X 90 X 67 190 g Certification RoHS Compliant EMI / EMC Harmonic Current Emissions ESD Radiated Susceptibility Electrical Fast Transients Surges Conducted Susceptibility Voltage Dips & Interruptions (AC) Conducted Emission Radiated Emission IEC 61000-3-2 IEC 61000-4-2 IEC 61000-4-3 IEC 61000-4-4 IEC 61000-4-5 IEC 61000-4-6 IEC 61000-4-11 CISPR 14-1 CISPR 14-1 Environmental Cold Heat Dry Heat Vibration Repetitive Shock Non-Repetitive Shock IEC 60068-2-1 IEC 60068-2-2 IEC 60068-2-6 IEC 60068-2-27 IEC 60068-2-27 Note: 1. ERT5 can measure maximum 5A & 1A current respectively. 2. Maximum current measurement limit for ERT-5 is 200A. Ex: 1. For CT selection if current required to be measured is upto 200A then CT of 200:5 A ( CT ratio 40) needs to be used. 64 ® Lighting Automation with using GSM Technology • Maximum 5 valid users can access the system remotely, using GSM functionality. • To avoid Remote module's SIM theft, "SIM PIN" facility can be enabled remotely using SMS query. • To avoid changes in system configuration by unauthorized user amongst valid users, important SMS queries are provided with "MODULE PIN" lock. • Device supports for 12 to 14 digit mobile number. i.e. (10 Digit Mobile number + 2/3/4 digit country code). CONNECTION DIAGRAM 1. MR: 2. MY: 3. MB: 4. MRC1: 5. MRC2: 6. MRC3: - Coil of Contactor 1 Coil of Contactor 2 Coil of Contactor 3 NO of Contactor 1 NO of Contactor 2 NO of Contactor 3 C. T. TERMINAL TORQUE & CAPACITY Ø 3.5...5.0 mm Torque - 1.1 N.m (10 Lb.in) Terminal screw - M3.5 Solid Wire - 2 X 0.2...2.5 mm2 AWG 1 X 24 to 10 65
69HDT0 价格&库存
很抱歉,暂时无法提供与“69HDT0”相匹配的价格&库存,您可以联系我们找货
