30A6B1
30A6B1
    GIC
    GIC - 30A6B1 - Panel Mount Timer, 90 VAC, 264 VAC, 99999.9 h
30A6B1 数据手册
HOUR METERS & COUNTERS Hour Meter Series HM 36 Digital Hour Meters Impulse Counter Series CR 18 Impulse Counter Series CR 26 Impulse Counter Series CR 36 Digital Counters Digital Hour Meter & Counter Rate Indicator & Totaliser 67 Hour Meter Series HM36 • Robust design with high degree of Accuracy and Compact size • Frequency independent for AC applications • Indicates operating time in hours and tenths with running indicators • Totally sealed from Dust and Moisture • Panel mountable with 7 Bezel options • 6 Digit Non-Resettable with automatic recycle to zero • Wide supply voltage range: 4 - 30V AC/DC, 10 - 80V DC & 90 - 264V AC • Shock & Vibration Proof Ordering Information Cat. No. LA21F1 LA22F1 LA23F1 LA24F1 LA25F1 LA26F1 LA27F1 LD11F1 LD12F1 LD13F1 LD14F1 LD15F1 LD16F1 LD17F1 LC31F1 LC32F1 LC33F1 LC34F1 LC35F1 LC36F1 LC37F1 Description 90 - 264 VAC, Rectangular Bezel 90 - 264 VAC, Rectangular 2 holes Bezel 90 - 264 VAC, Round Bezel 90 - 264 VAC, Round 3 holes Bezel 90 - 264 VAC, Square Mount Bezel 90 - 264 VAC, Cup Mount Bezel 90 - 264 VAC, Stirrup Mount Bezel 10 - 80 VDC, Rectangular Bezel 10 - 80 VDC, Rectangular 2 holes Bezel 10 - 80 VDC, Round Bezel 10 - 80 VDC, Round 3 holes Bezel 10 - 80 VDC, Cup Mount Bezel 10 - 80 VDC, Stirrup Mount Bezel 10 - 80 VDC, Square Mount Bezel 4 - 30 VAC/DC, Rectangular Bezel 4 - 30 VAC/DC, Rectangular 2 holes Bezel 4 - 30 VAC/DC, Round Bezel 4 - 30 VAC/DC, Round 3 holes Bezel 4 - 30 VAC/DC, Cup Mount Bezel 4 - 30 VAC/DC, Stirrup Mount Bezel 4 - 30 VAC/DC, Square Mount Bezel 68 Hour Meter Series HM36 Cat. No. Parameters Supply Voltage ( ) Frequency Over Voltage & Reverse Polarity Protection Power Consumption (Max.) Bezel Register Read Out Least Count Accuracy Vibration Shock Weight (unpacked) Temperature Humidity (Non Condensing) Mounting Termination Degree of Protection Approvals LA25F1 LD15F1 LC36F1 90 - 264 VAC 50/60 Hz 10 - 80 VDC NA 4 - 30 VAC/DC 50/60 Hz Not applicable to AC and 48V for DC Application 1 VA Stirrup Mount Protected for 2 times Battery voltage and / or Reverse polarity 0.25 VA Cup Mount NA 0.5 VA Square Mount 6 Digit (3.6mm) 99999.9 1/10 h ± 0.02% over entire range 10-80Hz with 20g max (SAE J1378) 55g @ 9-13ms (SAE J1378) 47g -40° C to +85° C 95% (Rh) Panel ¼" [6.3] Spade Terminal IP 66 SAE & NEMA 4X SAE & NEMA 4X RoHS Compliant RoHS Compliant VIEWS OF DIFFERENT BEZELS Rectangular Bezel Rectangular 2 holes Bezel Cup Mount Bezel Stirrup Mount Bezel Round Bezel 69 Round 3 holes Bezel Hour Meter Series HM36 • Robust design with high degree of Accuracy and Compact size • Frequency independent for AC applications • Indicates operating time in hours and tenths with running indicators • Totally sealed from Dust and Moisture • 6 Digit Non-Resettable with automatic recycle to zero • Wide supply voltage range: 90 - 460V AC, 10 - 80V DC & 110 V DC • Suitable for Control Panel applications Ordering Information Cat. No. Description 30A6B1 90 - 264 / 270 - 460 V AC, Hour Meter, Base/DIN 30A7B1 48 V AC, Hour Meter, Base/DIN 30D1B1 10 - 80 V DC, Hour Meter, Base/DIN 30D4B1 110 VDC, Hour Meter, Base/DIN 70 Hour Meter Series HM36 30A6B1 Cat. No. Parameters Supply Voltage ( ) Frequency Over Voltage Reverse Polarity Protection Power Consumption (Max.) Register Read Out Least Count Accuracy Vibration Shock Weight (unpacked) Operating Temperature Storage Temperature Humidity (Non Condensing) Mounting Termination Degree of Protection 90 - 264 / 270 - 460 VAC 50/60 Hz NA NA 1 VA Max 6 Digit (3.6mm) 99999.9 1/10 h ± 0.02% over entire range 10-80Hz with 20g max (SAE J1378) 55g @ 9-13ms (SAE J1378) 70g -5° C to +55° C -20° C to +70° C 95% (Rh) Base/DIN Rail ¼" [6.3] Spade Terminal IP 20 for Terminals, IP 40 for Enclosure 30D1B1 30D4B1 10 - 80 VDC NA 96 VDC, 1 min Yes 0.25 VA 110 VAC NA 96 VDC, 1 min Yes 0.5 VA Approvals RoHS Compliant MOUNTING DIMENSIONS (mm) TERMINAL TORQUE & CAPACITY 45.0 Torque - 0.54 N.m (5 Lb.in) Terminal screw - M2.6 Ø 3.5...4.0 mm Solid Wire - 1 X 0.2...3.3 mm2 1 X 24 to 12 100.0 90.0 68.0 45.0 AWG CONNECTION DIAGRAM A1l A1 90 - 264 VAC 270 - 460 VAC 4.2 Ø 36.0 71 A2 Hour Meter Series HM36 MOUNTING DIMENSION (mm) CONNECTION DIAGRAM SQUARE MOUNT BEZEL (45 X 45 PANEL CUTOUT) FOR: DC SERIES + + GROUND R1 45.00 POWER SUPPLY .5 IGNITION SWITCH 0 HOUR METER (4 X ) + 45.00 + - POWER SUPPLY GROUND PRESSURE SWITCH HOUR METER ROUND BEZEL, ROUND 3 HOLES BEZEL, CUP MOUNT BEZEL & STIRRUP MOUNT BEZEL Ø 64.26 FOR: AC SERIES Ø 50.80 L N L N Ø 3.80 (3X) Single phase, 2 wire, 120/240 V system: Connect power wire to one terminal and neutral wire to opposite terminal. Single phase, 3 wire, 120/240 V system: Connect any one power wire to one terminal and neutral wire to opposite terminal. (3 Equispaced Hole) L1 L2 L3 N RECTANGULAR BEZEL MAX(1.50) Three phase, 4 wire, 120/240 V system: Connect any one power wire to one terminal and neutral wire to opposite terminal. 36.80 CAUTION Tighten terminals with flat head screwdriver with tip size 4.3 x 0.6 mm. Ø 3.80 Max. Panel Thickness : 0.76 to 16.00 24.10 MIN 44.50 72 Hour Meter Series HM36 VIEWS OF DIFFERENT BEZELS 26.20 2.50 24.20 37.20 24.20 27.40 ø56.90 ø 46.00 52.10 40.64 44.50 5.30 19.70 19.70 19.70 75.85 47.40 2.80 47.80 73.45 73.45 47.80 2.50 37.20 18 27.70 Rectangular Bezel 18 18 27.70 27.70 Round Bezel Rectangular 2 holes Bezel ø 70.46 ø 54.50 ø 57.70 ø 61.20 48.00 ø 50.80 9.70 47.20 19.70 74.84 18.00 52.70 26.80 45.70 81.40 3.00 3.00 45.70 9.70 62.40 2.60 ø 57.70 19.70 75.85 47.40 3.00 5.30 ø 64.34 4.50 48.00 ø 50.80 Round 3 holes Bezel 18.00 18 7.00 18 27.70 57.20 26.75 Stirrup Mount Bezel Cup Mount Bezel 27.70 Square Bezel Dimensions in mm 73 Digital Hour Meter • 6-digit LCD • In-built nonvolatile memory (EEPROM) offering exceptional reliability • Wide range of supply voltage • Remote reset • Available in 3 different Bezels • Low Power Consumption Ordering Information Cat. No. Description Z71FBX 85-265 VAC model ZJ1FBX 12-48 VAC/DC model ZH1FBX 10-80 VDC model X A = Round Bezel, B = 24x48 Bezel, C = Screw Mount Bezel 74 Digital Hour Meter Cat. No. Parameters Supply Voltage ( ) Frequency Power Consumption (Max.) Range Display Resolution Accuracy Memory Retention Operating Temperature Storage Temperature Humidity Degree of Protection Enclosure Terminals Panel cut outs Mounting Certification Z71FBX ZJ1FBX 85 - 265 VAC 12 - 48 VAC/DC 50/60 Hz 50/60 Hz 0.4 W 0.8 VA 99999.9 h 6-digit LCD 5mm Height 1/10 h ± 0.02% 100 Years -10° C to +50° C -20° C to +65° C 95% (Rh) IP54 (for front side only) UL94-V0 1, 2: Input Supply, 3: Enable 4: Reset Round Bezel, 24 x 48 Bezel, Screw Mount Bezel Flush / Panel Mounting ZH1FBX 10 - 80 VDC NA 0.6 W RoHS Compliant Weight (unpacked) With Round Bezel- 35g, with 24 x 48 Bezel- 29 g, with Screw Mount Bezel- 31 g EMI / EMC Harmonic Current Emissions ESD Radiated Susceptibility Electrical Fast Transients Surges Conducted Susceptibility Voltage Dips & Interruptions (AC) Voltage Dips & Interruptions (DC) Conducted Emission Radiated Emission IEC 61000-3-2 IEC 61000-4-2 IEC 61000-4-3 IEC 61000-4-4 IEC 61000-4-5 IEC 61000-4-6 IEC 61000-4-11 IEC 61000-4-29 CISPR 14-1 CISPR 14-1 Environmental Cold Heat Dry Heat Vibration Repetitive Shock Non-Repetitive Shock IEC 60068-2-1 IEC 60068-2-2 IEC 60068-2-6 IEC 60068-2-27 IEC 60068-2-27 75 Digital Hour Meter MOUNTING DIMENSION (mm) DIGITAL HOUR METER 24X48 BEZEL SCREW MOUNT BEZEL Black Bezel Thumb Nut (4mm) LCD Thumb Nut 4 mm 36.5 Black Bezel LCD 1/10 h 24.0 20.0 31.1 23.5 36.5 GIC 1/10 h 1.5 2.0 22.1 35.5 2.0 48.0 Recommended Panel Cutout : 45.5 (+0.5)mm x 23.0 (+0.5)mm Recommended Panel Cutout : 37.0 (+0.5)mm x 24.6 (+0.5)mm ROUND BEZEL Thumb Nut 4 mm Black Bezel LCD 1/10 h GIC 27.5 42.5 2.0 4.0 CONNECTION DIAGRAM Supply ~/+ Reset Supply ~/ 1 2 4 3 Reset TERMINAL DESCRIPTION Enable Pin 1: Supply (~ / +) Pin 2: Supply (~ / ) Pin 3: Enable Pin 4: Reset Enable DIGITAL HOUR METER 76 58.4 Recommended Panel Cutout : 37.0 (+0.5)mm x 24.6 (+0.5)mm GIC Impulse Counter Series CR 18 • 7-digit Compact Size • High Accuracy and Reliability • Requires no lubrication or maintenance • Ideal where space is limitation • Mounting options: Panel, PCB Ordering Information Cat. No. Description ED11A 12 V DC, Behind the panel (Screw mount) ED11B 12 V DC, Behind the Panel With out Seal Hole (Screw mount) ED22D 24 V DC, PCB mount (Straight) ED23D 24 V DC, PCB mount (Right angle) ED24C 24 V DC, Panel (Snap-in type) 77 Impulse Counter Series CR 18 Cat. No. Parameters Supply Voltage ( ) Supply Variation Power Consumption (Max.) Figure Maximum Range Operating Life Speed (Counts / Minute) ED11A ED11B ED23D ED22D 24 V DC ±10% 12 V DC -15% to +10% ED24C -15% to +10% 1.2 W 7 Digit, Black, 4.0 mm Height 99,99,999 10,000,000 counts minimum 600 (50ms-ON / 50ms-OFF) 1200 (25ms-ON / 25ms-OFF) 600 (50ms-ON / 50ms-OFF) 25 ms Terminal PIN (Pitch : 10 mm) 50 ms Lead Wire Panel Cutout 50 ms Lead wire with connector #39-01-4031 # 03-09-2022 #39-00-0039 #02-09-2116 N.A Protection for Housing Tamper Proof housing Pulse Width (minimum ) Connection Weight (unpacked) Operating Temperature Humidity (Non Condensing) Display Continuous Energizing Counting Method Reset Shock test Terminal PIN (Pitch : 3.80 mm) 1.20'(30.48) x 0.96'(24.38) Panel thickness - 0.04'(1.0) to 0.08'(2.0) N.A 142 g -5o C to +40o C (Non-Freezing) 45 to 85% (Rh) 0.12’(3.0) x 0.06’ (1.6) - White & black background Permissible One pulse - One count (energizing - ½ count, unenergized - ½ count) None Endurance: 300 m/s² (30g) XYZ 5 times each direction, Total : 3, Mismovement : 50 m/s² (5g) XYZ 4 times each direction, Total : 24. Vibrations test Endurance: 16.7 Hz, Width : 4mm ; XYZ each direction for 1 hour Mismovement :10~55 Hz, Width : 0.5mm ; XYZ each direction for 10 mins Type of Mounting Behind the panel (Screw mount) IP 30 Cover : Plastic (Noryl UL94V-1), Black Degree of Protection Construction Approvals PCB mount (Straight) PCB mou(Right angle) Panel (Snap-in type) RoHS Compliant VIEWS OF DIFFERENT BEZELS Behind the panel (Screw mount) PCB mount (Right angle) Housing Behind Panel with Out Seal Hole (Screw mount) Panel (Snap-in type) 78 PCB mount (Straight) Impulse Counter Series CR 18 MOUNTING DIMENSION (mm) BEHIND THE PANEL (SCREW MOUNT): BEHIND THE PANEL (SCREW MOUNT): PCB MOUNT(STRAIGHT): PCB MOUNT(RIGHT ANGLE): PANEL (SNAP-IN TYPE): BLACK WIRE 79 Impulse Counter Series CR 26 • 6-digit Compact and Robust Design • Push-button quick reset • High Accuracy and Reliability • Requires no lubrication or maintenance • Optional locking for reset button • Ideal where space is limitation • Three mounting options: Bail, Panel, Base X X X X X XXX Product Only for Rectangular - 2 Hole 356 Center Distance 35.6 385 Center Distance 38.5 S Resettable Series CR-26 N Non-Resettable Series CR-26 Termination Model A With 2 - way terminal strip B With 22 AWG 254 mm long wire A For AC D For DC Note: Terminal strip is not applicable for base mounting Voltage AC DC Mounting 1 2 3 24 V 50/60 Hz 4 115 V 50/60 Hz 5 230 V 50/60 Hz 1 9V 2 12 V 3 24 V 4 110 V 5 220 V 6 2.5 V 7 4V 8 6V 9 250 V A 125 V Note: Other voltages will be made available upon request. 80 1 Rectangular - 2 Hole 2 Bail Mounting 3 Base Mounting Impulse Counter Series CR 26 Cat. No. Parameters Supply Voltage ( ) Supply Variation Power Consumption (Max.) Figure Maximum Range Operating Life Speed Pulse Width Counting Method Continuous Energizing Reset Weight (unpacked) Operating Temperature Humidity (Non Condensing) Termination Type of Mounting Degree of Protection Certification Applications SD21A-385 12 VDC +10% to -15% (of SD31A-385 SA41A-356 SA51A-356 24 VDC 115 VAC 230 VAC ) 2W 3W 6 Digit, White on Black, (4.0 mm) Height 9,99,999 Beyond 100 million counts 10 Hz Maximum (600 Counts / Minute) 50 ms minimum One Pulse - One count (energizing - 1/2 count, de-energized - 1/2 count) Permissible Manual push button Reset (Reset button can be locked or sealed to avoid accidental reset) 142 g -5o C to +50o C (Non-Freezing) 45 to 85% (Rh) 22 AWG, 105o C wire leads, 254 mm long / 2 way Terminal Strip Panel, Bail & Base IP 30 RoHS Compliant Ideal for use in Machine tools, Business Machines, Test Instruments, Amusement Instruments and Measuring devices Note: Do not push reset button during change over. 81 Impulse Counter Series CR 26 (4-Digit) • 4-digit Compact and Robust Design • Push-button quick reset • High Accuracy and Reliability • Requires no lubrication or maintenance • Optional locking for reset button • Ideal where space is limitation • Three mounting options: Bail, Panel, Base 4 X X X X X XXX Only for Rectangular - 2 Hole 356 Center Distance 35.6 Product S Resettable Series CR-26 N Non-Resettable Series CR-26 Termination A With 2 - way terminal strip B With 22 AWG 254 mm long wire Model Note: Terminal strip is not applicable for base mounting A For AC D For DC Voltage AC DC 1 2 3 24 V 50/60 Hz 4 115 V 50/60 Hz 5 230 V 50/60 Hz Note: Other voltages will be made available upon request. 82 1 9V 2 12 V 3 24 V 4 110 V 5 220 V 6 2.5 V 7 4V 8 6V 9 250 V A 125 V Mounting 1 Rectangular - 2 Hole 2 Bail Mounting 3 Base Mounting Impulse Counter Series CR 26 (4-Digit) Cat. No. Parameters Supply Voltage ( ) Supply Variation Power Consumption (Max.) Figure Maximum Range Operating Life Speed Pulse Width Counting Method Continuous Energizing Reset Weight (unpacked) Operating Temperature Humidity (Non Condensing) Termination Type of Mounting Degree of Protection Certification Applications 4SD21A-356 12 VDC +10% to -15% (of 4SD31A-356 4SA41A-356 4SA51A-356 24 VDC 115 VAC 230 VAC ) 3W 2W 4 Digit, White on Black, (4.0 mm) Height 9999 Beyond 100 million counts 10 Hz Maximum (600 Counts / Minute) 50 ms minimum One Pulse - One count (energizing - 1/2 count, de-energized - 1/2 count) Permissible Manual push button Reset (Reset button can be locked or sealed to avoid accidental reset) 113 g -5o C to +50o C (Non-Freezing) 45 to 85% (Rh) 22 AWG, 105o C wire leads, 254 mm long / 2 way Terminal Strip Panel, Bail & Base IP 30 RoHS Compliant Ideal for use in Machine tools, Business Machines, Test Instruments, Amusement Instruments and Measuring devices Note: Do not push reset button during change over. 83 Impulse Counter Series CR 36 • Compact Size & Robust Design • 7 Digit, Non-Resettable • High Degree of Accuracy & Reliability • Wide Temperature range • Shock & Vibration Proof Ordering Information Cat. No. Description QD11A 12 VDC, Rectangular Bezel QD21A 24 VDC, Rectangular Bezel QD12A 12 VDC, Rectangular 2 Hole Bezel QD22A 24 VDC, Rectangular 2 Hole Bezel QD23A 24 VDC, Round Bezel 84 Impulse Counter Series CR 36 Cat. No. Parameters Supply Voltage ( ) Supply Variation Power Consumption (Max.) Figure Maximum Range Speed Pulse Width Counting Method Weight Operating Temperature Humidity (Non Condensing) Mounting Degree of Protection Certification QD11A QD22A 12 VDC -15% to +10% 0.25 VA 7 Digit, White on Black, (3.6mm) High 9999999 10 Hz Maximum (600 counts/minute) 50 ms. minimum One Pulse - One Count (energizing - ½ count, de-energizing - ½ count) 45 gm -5°C to +50°C 45% to 85% (Rh) Panel NEMA 4X (IP 65) RoHS Compliant 85 24 VDC Digital Counters • 6-digit LCD • In-built nonvolatile memory (EEPROM) offering exceptional reliability • Wide range of supply voltage • Remote reset • Available in 3 different shaped Bezels • Low Power Consumption Ordering Information Cat. No. Description Z72FBX 85-265 VAC model ZJ2FBX 12-48V AC/DC model ZH2FBX 10-80V DC model X A=Round Bezel, B=24x48 Bezel, C=Screw Mount Bezel 86 Digital Counters Cat. No. Parameters Supply Voltage ( ) Frequency Power Consumption (Max.) Counting frequency Maximum Range Display Resolution Reset Memory Retention Operating Temperature Storage Temperature Accuracy Humidity (Non Condensing) Degree of Protection Enclosure Terminals Panel cut outs Mounting Certification Z72FBX ZJ2FBX ZH2FBX 85 - 265 VAC 50/60 Hz 0.8 VA 10Hz 12 - 48 VAC/DC 50/60 Hz 0.4 W 10Hz 10 - 80 VDC NA 0.6 W 30Hz 999999 Large 6-Digit display, easy to read 1 Count Electrical 100 Years - 10° C to +50° C - 20° C to +65° C ± 1 Count 95% (Rh) IP54 UL94-V0 1 & 2: Input Supply, 3: Count 4: Reset Round Bezel, 24 x 48 Bezel, Screw Mount Bezel Flush/ Panel Mounting RoHS Compliant Weight (unpacked) With Round Bezel - 35g, with 24 x 48 Bezel - 29 g, with Screw Mount Bezel - 31 g EMI / EMC Harmonic Current Emissions ESD Radiated Susceptibility Electrical Fast Transients Surges Conducted Susceptibility Voltage Dips & Interruptions (AC) Conducted Emission Radiated Emission IEC 61000-3-2 IEC 61000-4-2 IEC 61000-4-3 IEC 61000-4-4 IEC 61000-4-5 IEC 61000-4-6 IEC 61000-4-11 CISPR 14-1 CISPR 14-1 Environmental Cold Heat Dry Heat Vibration Repetitive Shock Non-Repetitive Shock IEC 60068-2-1 IEC 60068-2-2 IEC 60068-2-6 IEC 60068-2-27 IEC 60068-2-27 87 Impulse Counter Series CR 26 MOUNTING DIMENSION (mm) IMPULSE COUNTER CR 26 Resettable Counter SXXXA A=With terminal strip 60 1. B=With 22 AWG 254 mm long wire Panel cutout dimension X) Ø4.5(2 79 63,2 63,2 (2X) 79 24,6 24,6 45,7 35,6 SXXXX-356 63,2 63,2 79 63,2 Panel cutout 50,8 3. 56 29 Bail Mount 6 Figure 24,6 63,2 Panel cutout 50,8 10 78,7 4. 71,9 63,2 29 16 68,1 68,10 24,6 56 Base Mount 6 Figure 25,7 10 ,5(4 X) Ø3 10 5. Optional locking for reset button Ø1,2 To avoid the tampering with the reset button you can seal the counter as shown in the above figure NON RESETTABLE COUNTER- NXXXA A = Counter with Terminal Strip(not applicable for Base Mounting) B = Counter with Wire (22 AWG 254 mm Long) Note: For Non Resettable Counters, reset arm lever will not be present and all other details will be common with resettable counter. 88 35,6 Ø3,5 Panel Mount - 6 Figure 25,7 56 38,5 50,8 10 2. Panel cutout 25,7 24,6 24,6 SXXXX-385 51 38,5 Panel Mount - 6 Figure Impulse Counter Series CR 26 (4-Digit) MOUNTING DIMENSION (mm) IMPULSE COUNTER CR 26 (4 FIG) Resettable Counter 4XXXA A=With terminal strip 45.7 Panel cutout 64.8 2. 64.8 41.9 Bail Mount 4 Figure 4XXXXX 1 2 3 4 35.6 24,6 1 2 3 4 25,7 Dia 3 4XXXXX-356 35.6 ) ,5(2X 64.8 37.1 64.8 28.9 24.6 25,7 45.7 Panel Mount - 4 Figure Panel cutout dimension 24,6 1. B=With 22 AWG 254 mm long wire Panel cutout 24.6 37.1 Base Mount 4 Figure 16.0 4XXXXX 64.0 24.9 71.9 54.1 29.0 1 2 3 4 24.6 16 3. ) (4X 3,5 Dia 54.1 4. == ,2 8,2 Optional locking for reset button Dia1 To avoid the tampering with the reset button you can seal the counter as shown in the above figure NON RESETTABLE COUNTER- NXXXA A = Counter with Terminal Strip(not applicable for Base Mounting) B = Counter with Wire (22 AWG 254 mm Long) 1 2 3 4 1 2 3 4 1 2 3 4 Note: For Non Resettable Counters, reset arm lever will not be present and all other details will be common with resettable counter. 89 Impulse Counter Series CR 36 & Digital Counter MOUNTING DIMENSIONS (mm) IMPULSE COUNTER CR 36 CR-36 COUNTER (RECTANGULAR 2 HOLE TYPE) CR-36 COUNTER (RECTANGULAR TYPE) 8.13 24.2 26.2 .8 R3 2.5 36.3 44.5 51.94 47.8 55.95 24.2 27.4 33.52 37.2 37.2 2.5 40.64 50.8 50.3 56.56 36.8 1.5 PANEL CUT-OUT Max. Panel Thickness: 0.76mm to 10.20mm Panel Cut-out Dimensions: Tolerance - 0.30mm Panel Cut-out common for all models 24.1 3.8 44.5 DIGITAL COUNTER 24X48 BEZEL SCREW MOUNT BEZEL Thumb Nut (4mm) Black Bezel LCD Thumb Nut 4 mm 36.5 Black Bezel LCD 1/10 h 2.0 24.0 20.0 31.1 23.5 36.5 GIC 1/10 h 1.5 2.0 22.1 35.5 Recommended Panel Cutout : 37.0 (+0.5)mm x 24.6 (+0.5)mm 48.0 Recommended Panel Cutout : 45.5 (+0.5)mm x 23.0 (+0.5)mm ROUND BEZEL Thumb Nut 4 mm Black Bezel LCD 1/10 h GIC Recommended Panel Cutout : 37.0 (+0.5)mm x 24.6 (+0.5)mm 27.5 2.0 4.0 42.5 58.4 CONNECTION DIAGRAM Supply ~/+ Supply ~/+ Reset Supply ~/ 1 2 4 3 Reset Enable TERMINAL DESCRIPTION Pin 1: Supply (~ / +) Pin 2: Supply (~ / - ) Pin 3: Enable Pin 4: Reset Enable DIGITAL COUNTER 90 GIC Digital Hour Meter & Counter • Suitable for Hour meter & Counter (Up / Down) application • Wide Hour meter range from 1 sec to 9999999 hrs • Wide counter range from 1 to 9999999 counts • Prescaling facility for Counter • Alarm facility for both Hour meter & Counter • Relay & MOSFET Output with Over Load detection • Retentive & Non-Retentive modes • 7 Digit LCD with luxurious green backlight • Compact size • Suitable for panel mounting Ordering Information Cat. No. Description Z2301N0G1FT00 9-30 V DC (with dual MOSFET output) Z2221N0G2FT00 85-265 V AC/DC (with Relay output) 91 Digital Hour Meter & Counter Cat. No. Z2301N0G1FT00 Z2221N0G2FT00 Parameters Supply Voltage ( ) Power Consumption (W) Supply Frequency 9 - 30 VDC 2 W max. 50 / 60 Hz 85 - 265 VAC/DC 2 VA / 1W 9 - 30 VDC 2kV 85 - 265 VAC & 100 - 265 VDC 2 MOSFET: 30 VDC/60 mA (Max.) Note: Use isolated input supply Relay: 1 C/O, Contact Rating: 5 A(Res.) @ 250 VAC/30 VDC Contact Material: Ag Alloy I/P Signal Characteristics Signal Voltage Range Signal Isolation Output Characteristics Output type Functional Characteristics Display Number of keys Reset type Reset function Time (min.) Accuracy Hour Ranges Meter Functions Input Signal Accuracy Range Counter Decimal Point Position(max.) Functions Pre-scaler Input Switching Freq.(max.) Signal Pulse Width min. Environmental Characteristics Operating Temperature Storage Temperature Humidity Maximum Operating Altitude Pollution Degree Degree of Protection Enclosure material Casing color Other Characteristics Mounting 7 digit LCD , 6.5 mm Height, 12 O’ Clock, Transmissive 2 (SET key & RST key) Terminal Auto Reset Front 80 ms 3 Sec ± 2sec per Day Hrs : Min : Sec (999:59:59), Hrs : Min (99999:59), Hrs (9999999), Min (9999999), Sec (9999999) For Hour counting detection, Signal has to be present for min. 3msec & signal has to be absent for min 20msec. 100% 1 to 9999999.999 3 4 Digit 10 Hz for AC and 40 Hz for DC 50ms ON/50ms OFF for AC, 12.5ms ON/12.5ms OFF for DC -5° C to +55° C -10° C to +60° C 5 to 95% Rh (Without condensation) 2000 m II Front side: IP40; Terminals: IP20, Housing : IP30 UL 94 V0 Plastic Black Flush mounting on panel cut-out Termination wire Sizes 22mm X 44.8mm 52 gm Horizontal Wire size : 22-14 AWG, 0.3-2.5 mm EMI / EMC Harmonic Current Emissions Voltage Flicker & Fluctuation ESD Radiated Susceptibility Electrical Fast Transients (Supply) Electrical Fast Transients (Signal) Surge Conducted Susceptibility Power Frequency Magnetic Field Voltage Dips Conducted Emission Radiated Emission IEC 61000-3-2 IEC 61000-3-3 IEC 61000-4-2 IEC 61000-4-3 IEC 61000-4-4 IEC 61000-4-4 IEC 61000-4-5 IEC 61000-4-6 IEC 61000-4-8 IEC 61000-4-29 CISPR 11 CISPR 11 Safety Compliance: Test Voltage (All terminal to housing) Single fault Leakage Current IEC 60947-5-1 IEC 61010-1 UL 508 Environmental Cold Heat Dry Heat Vibration Repetitive Shock Non-Repetitive Shock IEC 60068-2-1 IEC 60068-2-2 IEC 60068-2-6 IEC 60068-2-27 IEC 60068-2-27 Panel Cut-out Weight (Un-packed) Operating position 92 Digital Hour Meter & Counter TERMINAL TORQUE & CAPACITY Ø 3.5 mm Torque - 0.40 N.m (3.5 Lb.in) Terminal screw - M2.5 2 Solid Wire - 1 X 0.3...2.5 mm AWG 22 to 14 MOUNTING DIMENSIONS (mm) LCD 24 32.23 21.8 60.5 48 2.0 2.4 62 66 FRONT VIEW GRID RING - RESET 44.6 +0.3 22.0 A B C D H BACK VIEW PANEL CUTOUT CONNECTION DIAGRAM 93 E FG - SET I A B C D E - Prescaler - Hour - Minute - Second - Alarm F - Counter G - Hour Meter Symbol H - RESET(RST) I - SET Rate Indicator & Totaliser • Wide input signal sensing range 0.01Hz to 20KHz. • Wide Totalizer range from 1 to 9999999. • Wide Rate range from 1 to 999999. • Prescaling facility for Rate Indicator. • Alarm facility for both Rate Indicator & Totalizer. • Password enabled. • Signal Over-range displayed. Ordering Information Cat. No. Description Z3301N0G2FT00 9 VDC - 30 VDC (with Relay output) 94 Rate Indicator & Totaliser Cat. No. Z3301N0G2FT00 Parameters Supply Voltage ( ) Max. Power Consumption (W) Input Signal Frequency Range Output Type Display Rate Display Number of keys Reset Reset type Time (min.) Function Rate Accuracy Totalizer Accuracy Decimal Point Position (max.) Pre-scaler Operating Temperature Storage Temperature Humidity Maximum Operating Altitude Pollution Degree Degree of Protection Enclosure material Casing color Weight (Unpacked) Operating Position Termination wire Sizes Panel Cut-out Mounting 9 VDC to 30 VDC 0.73 W Range 1 : 0.1 Hz to 40 Hz Range 2 : 0.1 Hz to 20 KHz Relay: 1 C/O, Contact Rating:5 A(Res.) @250 VAC / 30VDC Contact Material: Ag Alloy 7 digit LCD, 6.5mm Height, 12 O’ Clock, Transmissive 6 digit Display 2 (SET & RST) Front Auto Reset Terminal 3 Sec 80 ms ± 0.01% 100 % 4 4 digits before decimal point & 3 digits after decimal point. - 10° C to +55° C - 10° C to +60° C 5 to 95% Rh (Without condensation) 2000 m II Front side : IP40; Terminals: IP20, Housing: IP30 UL 94 V0 Plastic Black 52g Horizontal Wire size : 22-14 AWG, 0.3-2.5 mm 22mm X 44.8mm Flush / Panel Mounting Certification RoHS Compliant EMI / EMC ESD Radiated Susceptibility Electrical Fast Transients (Supply) Electrical Fast Transients (Signal) Surge Conducted Susceptibility Power Frequency Magnetic Field Voltage Dips Conducted Emission Radiated Emission IEC 61000-4-2 IEC 61000-4-3 IEC 61000-4-4 IEC 61000-4-4 IEC 61000-4-5 IEC 61000-4-6 IEC 61000-4-8 IEC 61000-4-29 CISPR 11 CISPR 11 Safety Compliance: Test Voltage (All Terminal & Housing) Signal Fault Leakage Current IEC 60947-5-1 IEC 61010-1 UL 508 Environmental Cold Heat Dry Heat Vibration Repetitive Shock Non-Repetitive Shock IEC 60068-2-1 IEC 60068-2-2 IEC 60068-2-6 IEC 60068-2-27 IEC 60068-2-27 95 Rate Indicator & Totaliser TERMINAL TORQUE & CAPACITY Ø 3.5 mm Torque - 0.40 N.m (3.5 Lb.in) Terminal screw - M2.5 2 Solid Wire - 1 X 0.3...2.5 mm AWG 22 to 14 MOUNTING DIMENSIONS (mm) LCD 24 32.23 21.8 60.5 48 2.0 FRONT VIEW 2.4 62 66 A B C D E - 22.0 RESET 44.6 +0.3 GRID RING BACK VIEW H PANEL CUTOUT Magnetic pickup: Proximity Switch Connection Diagram: 96 SET A - Prescaler B - Hour C - Minute D - Second E - Alarm H - RESET(RST) I - SET CONNECTION DIAGRAM Z3301N0G2FT00 - I
30A6B1 价格&库存
很抱歉,暂时无法提供与“30A6B1”相匹配的价格&库存,您可以联系我们找货
30A6B1
    • 1+170.80776
    库存:26
