11RDT4
11RDT4
    GIC
    GIC - 11RDT4 - ANALOGUE TIMER, SPDT, 110V
11RDT4 数据手册
Electronic Timer - Series Micon® 175 • Compact 17.5mm Wide • Integrated Dual Voltage • Functions: ON Delay, Star Delta, One Shot • Wide Time Range: 0.3s - 30h • LED Indications for Power and Relay status • Low Power Consumption Ordering Information Cat. No. Description 11ODT4 110 VAC / 24 VAC/DC, ON Delay Timer, 1 C/O 12ODT4 240 VAC / 24 VAC/DC, ON Delay Timer, 1 C/O 15ODT4 12 VDC, ON Delay Timer, 1 C/O 11RDT4 110 VAC / 24 VAC/DC, Signal OFF Delay Timer, 1 C/O 12RDT4 240 VAC / 24 VAC/DC, Signal OFF Delay Timer, 1 C/O 11BDT4 110 VAC / 24 VAC/DC, One Shot Timer, 1 C/O 12BDT4 240 VAC / 24 VAC/DC, One Shot Timer, 1 C/O 15BDT4 12 VDC, One Shot Timer, 1 C/O 18 Electronic Timer - Series Micon® 175 12ODT4 12RDT4 ON Delay Timer ON Delay Signal OFF Delay Timer Signal OFF Delay Cat. No. Parameters Timer Description Mode Functional Diagram S R Supply Voltage ( ) Supply Variation Frequency Power Consumption (Max.) Timing Ranges Reset Time Setting Accuracy Repeat Accuracy Relay Output Contact Rating Output Electrical Life Mechanical Life AC - 15 Utilization Category DC - 13 Operating Temperature Storage Temperature Humidity (Non Condensing) LED Indication Enclosure Dimension (W x H x D) (in mm) Weight (unpacked) Approx. Mounting T R T T 240 VAC / 24 VAC/DC 240 VAC / 24 VAC/DC - 20% to +10% (of ) - 15% to +10% (of ) 50/60 Hz 50/60 Hz 8 VA 8 VA 0.3s to 30h 0.3s to 30h 100 ms (Max.) 150 ms (Max.) ± 5% of Full scale ± 1% 1 C/O 5A @ 240 VAC / 3A @ 30 VDC (Resistive) 5A @ 240 VAC / 28 VDC (Resistive) 1X105 5X106 Rated Voltage (Ue): 120/240 V, Rated Current (Ie): 3.0/1.5 A Rated Voltage (Ue): 24/125/250 V, Rated Current (Ie): 2.0/0.22/0.1 A -10°C to +55°C -20°C to +70°C 95% (Rh) Green LED Power ON, Red LED Relay ON Flame Retardant UL94-V0 17.5 X 90 X 58.5 65 g Base / DIN Rail Certification RoHS Compliant Degree of Protection IP 20 for Terminals, IP 40 for Enclosure EMI / EMC Harmonic Current Emissions ESD Radiated Susceptibility Electrical Fast Transients Surges Conducted Susceptibility Voltage Dips & Interruptions (AC) Voltage Dips & Interruptions (DC) Conducted Emission Radiated Emission IEC 61000-3-2 IEC 61000-4-2 IEC 61000-4-3 IEC 61000-4-4 IEC 61000-4-5 IEC 61000-4-6 IEC 61000-4-11 IEC 61000-4-29 CISPR 14-1 CISPR 14-1 Environmental Cold Heat Dry Heat Vibration Repetitive Shock Non-Repetitive Shock IEC 60068-2-1 IEC 60068-2-2 IEC 60068-2-6 IEC 60068-2-27 IEC 60068-2-27 19 Electronic Timer - Series Micon® 175 Ordering Information Cat. No. Description 11SDT0 110 VAC, Star Delta Timer, 1 NO (Star) + 1 NO (Delta) 12SDT0 240 VAC, Star Delta Timer, 1 NO (Star) + 1 NO (Delta) 14SDT1S 240-415V AC, Star Delta Timer, 1C/O (Star) + 1C/O (Delta), 3-30 Sec. 20 Electronic Timer - Series Micon® 175 Cat. No. 12SDT0 Parameters Timer Description Mode Star Delta Timer Star Delta Functional Diagram T Supply Voltage ( ) Supply Variation Frequency Power Consumption (Max.) Timing Ranges Pause Time Reset Time Setting Accuracy Repeat Accuracy Relay Output Contact Rating Output Electrical Life Mechanical Life AC - 15 Utilization Category DC - 13 Operating Temperature Storage Temperature Humidity (Non Condensing) LED Indication Enclosure Dimension (W x H x D) (in mm) Weight (unpacked) Mounting Certification Degree of Protection TP 240 VAC - 20% to +10% (of ) 50 Hz 8 VA 3s to 120s 60 ms 150 ms (Max.) ± 5% of Full scale ± 1% Star - 1 'NO', Delta - 1 'NO' 5A @ 240 VAC / 3A @ 30 VDC (Resistive) 1X105 5X106 Rated Voltage (Ue): 120/240 V, Rated Current (Ie): 3.0/1.5 A Rated Voltage (Ue): 24/125/250 V, Rated Current (Ie): 2.0/0.22/0.1 A -10°C to +55°C -20°C to +70°C 95% (Rh) Red LED 1 ‘ ’ ON, Red LED 2 ‘ ’ ON Flame Retardant UL94-V0 17.5 X 90 X 58.5 60 g Base / DIN Rail RoHS Compliant IP 20 for Terminals, IP 40 for Enclosure EMI / EMC Harmonic Current Emissions ESD Radiated Susceptibility Electrical Fast Transients Surges Conducted Susceptibility Voltage Dips & Interruptions (AC) Voltage Dips & Interruptions (DC) Conducted Emission Radiated Emission IEC 61000-3-2 IEC 61000-4-2 IEC 61000-4-3 IEC 61000-4-4 IEC 61000-4-5 IEC 61000-4-6 IEC 61000-4-11 IEC 61000-4-29 CISPR 14-1 CISPR 14-1 Environmental Cold Heat Dry Heat Vibration Repetitive Shock Non-Repetitive Shock IEC 60068-2-1 IEC 60068-2-2 IEC 60068-2-6 IEC 60068-2-27 IEC 60068-2-27 21 Electronic Timer - Series Micon® 175 • Multi Function: 10 Different (Non Signal & Signal based) Modes • Wide Voltage range for both AC & DC • Wide Time range: 0.1s - 100h • LED Indications for Power and Relay status • Independent settings for both ON Time & OFF Time • Low Power Consumption Ordering Information Cat. No. Description 1CMDT0 12 - 240 VAC/DC, Multi Function Timer (10 Modes), 1 C/O (RAL 7016 Casing) 1CJDT0 12 - 240 VAC/DC, Asymmetric Timer, 1 C/O(RAL 7016 Casing) 1CMDTB 12 - 240 VAC/DC, Multi Function Timer (10 Modes), 1 C/O (RAL 7035 Casing) 1CJDTB 12 - 240 VAC/DC, Asymmetric Timer, 1 C/O (RAL 7035 Casing) 22 Electronic Timer - Series Micon® 175 Cat. No. Parameters Timer Description Modes Derived Modes Supply Voltage ( ) Supply Variation Frequency Power Consumption (Max.) Timing Range Reset Time Setting Accuracy Repeat Accuracy Relay Output Contact Rating Output Electrical Life Mechanical Life AC - 15 Utilization Category DC - 13 Operating Temperature Storage Temperature LED Indication Enclosure Dimension (W x H x D) (in mm) Weight (unpacked) Mounting Certification 1CJDT0 1CMDT0 Multi Function Timer Asymmetric Timer 1) Asymmetric ON-OFF, 2) Asymmetric OFF-ON 1) 2) 3) 4) 5) 6) 7) 8) 9) 10) Signal ON Delay Cyclic ON/OFF Cyclic OFF/ON Signal OFF Delay Signal OFF/ON Accumulative Delay on Signal Impulse ON/OFF Leading Edge Impulse Trailing Edge Impulse Leading Edge Bi-stable NA 12 - 240 VAC/DC -15% to +10% (of 50/60 Hz 2 VA 0.1s to 100h 200 ms (Max) ON Delay, Interval ) ± 5% of Full scale ± 1% 1 C/O 1 C/O 8A @ 240 VAC / 5A @ 24 VDC (Resistive) 8A @ 240 VAC / 5A @ 24 VDC (Resistive) 1X105 5X106 Rated Voltage (Ue): 120/240 V, Rated Current (Ie): 3.0/1.5 A Rated Voltage (Ue): 24/125/250 V, Rated Current (Ie): 2.0/0.22/0.1 A -10°C to +60°C -15°C to +70°C Green LED Power ON, Amber LED Flame Retardant UL94-V0 18 X 85 X 65 70 g DIN Rail RoHS Compliant Degree of Protection IP 20 for Terminals, IP 40 for Enclosure EMI / EMC Harmonic Current Emissions ESD Radiated Susceptibility Electrical Fast Transients Surges Conducted Susceptibility Voltage Dips & Interruptions (AC) Voltage Dips & Interruptions (DC) Conducted Emission Radiated Emission IEC 61000-3-2 IEC 61000-4-2 IEC 61000-4-3 IEC 61000-4-4 IEC 61000-4-5 IEC 61000-4-6 IEC 61000-4-11 IEC 61000-4-29 CISPR 14-1 CISPR 14-1 Environmental Cold Heat Dry Heat Vibration Repetitive Shock Non-Repetitive Shock IEC 60068-2-1 IEC 60068-2-2 IEC 60068-2-6 IEC 60068-2-27 IEC 60068-2-27 23 Relay ON Green LED Power ON, Yellow LED Relay ON Electronic Timer - Series Micon® 175 FUNCTIONAL DIAGRAMS FOR 1CMDT0 : Supply Voltage, S: Input Signal, R: Relay Output T: Preset Time, TON: Preset ON Time, TOFF: Preset OFF Time SIGNAL ON DELAY [stn] On application of input signal, the preset delay time period starts. On completion of the preset time, the output is switched ON and remains ON till the input signal is present. ACCUMULATIVE DELAY On SIGNAL [san] S R S t1 On application of supply voltage, the t2 preset delay time period starts. If input R T+t 1+t2 T signal is applied during this period, the preset time stops and resumes only when the input signal is removed. On completion of the preset time, the output is switched ON. T CYCLIC ON/OFF [cnf] IMPULSE ON/OFF [inf] On application of supply voltage, the output R TON TOFF TON TOFF is initially switched ON for the preset time duration (T) after which it is switched OFF for the same time duration (T). This cycle continues till the power supply is present. On application or removal of input signal to the timer, the output is immediately switched ON for the preset time duration (T). If the state of the input signal is changed during the preset time, the output does not change state only the time is reset. CYCLIC OFF/ON [cfn] LEADING EDGE IMPULSE [iL] On application of supply voltage, the output is initially switched OFF for the preset time duration (T) after which it is switched ON for the same time duration (T). This cycle continues till the power supply is present. When input signal is applied to the timer the output is immediately switched ON. The output remains ON for the preset time duration (T) after which it is switched OFF. If the input signal is removed during the preset time, the output is immediately switched OFF. R TOFF TON TOFF TON SIGNAL OFF DELAY [sf] TRAILING EDGE IMPULSE [it] On application of input signal to the timer, the output is immediately switched ON. When the input signal is switched OFF, the preset time delay period starts. On completion of the time period the output is switched OFF. When the input signal to the timer is removed, the output is immediately switched ON for the preset time duration (T) after which it is switched OFF. If the input signal is applied during the preset time, the output is immediately switched OFF. S R T T S R T T T S R T S R T SIGNAL OFF/ON [sfn] LEADING EDGE BISTABLE [sbi] On application of input signal to the timer, S the preset delay time period (T) starts. On completion of the time preset time, the R T output is switched ON When the input T signal is switched OFF, again the preset time delay period (T) starts. On completion of the time period the output is switched OFF. On application of input signal to the timer, the output is switched ON and remains ON even after the input signal is removed. On subsequent application of input signal, the output keeps on changing its state. DERIVED MODES FUNCTIONAL DIAGRAMS FOR 1CJDT0 S R Select mode, ‘Signal ON Delay’ and short the connection between A1 - B1 before power ON Select mode, ‘Accumulative Delay ON Signal’ and keep the connection between A1 - B1 open. ON DELAY ASYMMETRIC ON-OFF When supply power is applied to the timer, the preset delay time period starts. On completion of the preset time, the output is switched ON and remains ON till the input supply is present. On application of supply voltage, the R TON TOFF output is initially switched ON for the preset TON ‘ON’ time duration (T) after which it is switched OFF for the preset ‘OFF’ time duration (T). This cycle repeats and continues till the supply is present. The ON time & OFF time are set independently. R T T Select mode, “Leading Edge Impulse” and short the connection between A1 & B1. INTERVAL ASYMMETRIC OFF-ON When supply power is applied to the timer, the output is instantly switched ON. On completion of the preset time, the output is switched OFF. On application of supply voltage, the R TOFF TON TOFF output is initially switched OFF for the preset ‘OFF’ time duration (T) after which it is switched ON for the preset ‘ON’ time duration (T). This cycle repeats and continues till the supply is present. The ON time & OFF time are set independently. R T 24 Electronic Timer - Series Micon® 175 MOUNTING DIMENSIONS (mm) 76 65.0 60.0 18.0 85.0 85.0 65.0 45.0 65.0 45.0 49.5 49.5 VODDTS, VODDTD, VODDTS1, VODDTD1 18.0 1CMDT0, 1CJDT0, STAIRCASE TIMER 17.5 (± 0.5) CONNECTION DIAGRAM A1 100 C/C 90 24 VAC/DC A3 A2 A1 A1 12 VDC A3 110 VAC 240 VAC 12 - 240 VAC/DC A2 1CMDT0, 1CMDTB, 1CJDTB 15 15 A2 VODDTS, VODDTD, VODDTS1, VODDTD1 25 MODE 'A' 18 18 16 TERMINAL TORQUE & CAPACITY Torque - 0.40 N.m (3.5 Lb.in) Terminal screw - M2.5 Solid Wire - 1 X 0.3...2.5 mm2 AWG B1 58.5 110DT4, 120DT4, 150DT4, 11SDT0, 12SDT0 11ODT8, 12ODT8, 11BDT4, 12BDT4, 15BDT4 Ø 3.5 mm 24 - 240 VAC/DC A2 110DT4, 120DT4, 150DT4, 11SDT0, 12SDT0, 11ODT8, 12ODT8, 11BDT4, 12BDT4, 15BDT4 Ø4 B1 A1 110DT4, 120DT4, 150DT4, 11SDT0, 12SDT0, 11ODT8, 12ODT8, 11BDT4, 12BDT4, 15BDT4,1CMDT0. 1CJDT0, VODDTS, VODDTS1 28 VODDTD, VODDTD1, STAIRCASE TIMER MODE 'B' 1CJDT0 1 X 22 to 14 VODDTS, VODDTD, VODDTS1, VODDTD1 Ø 3.5...4.0 mm Torque - 0.6 N.m (6 Lb.in) Terminal screw - M3 Solid Wire - 1 X 1...4 mm2 AWG 1 X 18 to 10 1CMDT0, 1 CJDT0, STAIRCASE TIMER Ø 3.5...5.0 mm Torque - 1.1 N.m (10 Lb.in) Terminal screw - M3.5 Solid Wire - 2 X 0.2...2.5 mm2 AWG 1 X 24 to 10 3 Wire rising main without Loft illumination 110DT4, 120DT4, 150DT4, 11SDT0, 12SDT0 11ODT8, 12ODT8, 11BDT4, 12BDT4, 15BDT4 4 Wire rising main without connection for Loft illumination STAIRCASE TIMER 25
11RDT4 价格&库存
很抱歉,暂时无法提供与“11RDT4”相匹配的价格&库存,您可以联系我们找货
11RDT4
    • 1+262.62656
    库存:18
