2A5DT5
2A5DT5
    GIC
    GIC - 2A5DT5 - Analogue Timer, Micon 225, Multifunction, 0.1 s, 10 h, 2 Changeover Relays
2A5DT5 数据手册
Electronic Timer - Series Micon® 225 Signal Based Multi - Function • Multi-function with Signal Start and Supply Start. • 16 Timing Functions selected by DIP switch. • Two independent relay outputs with either both relays timed or one timed and one instantaneous. • Wide Input Signal & Supply range - 24-240V AC/DC. • Wide Timing Range - 0.1 s to 120 days. • High timing Accuracy. • LED indicators for Power Supply & Relay Status. • 22.5mm DIN Mount Housing. Ordering Information Cat. No. Description 2A8DT6 24-240 VAC / DC, Signal Based Multi - Function, 1 C/O + 1 C/O 26 Electronic Timer - Series Micon® 225 Signal Based Multi - Function Cat. No. Parameters Timer Description Supply Voltage ( ) Supply Variation Frequency Power Consumption (Max.) Initiate Time Reset Time Signal Low Range (B1L-A2) Voltage High Range (B1H-A2) Signal Sensing Time Signal stabilization Delay Setting Accuracy Repeat Accuracy Relay Output Contact Rating Output Contact Material Electrical Life Mechanical Life Set Time (Ts) Functions LED Indication on front panel Mounting Max. Operating Altitude Housing Operating Temperature Storage Temperature Humidity (Non Condensing) LED Indication Enclosure Dimension (W x H x D) (in mm) Weight (unpacked) Pollution Degree 2A8DT6 Multi-function with Signal Start and Supply Start 24-240 VAC / DC - 20% to +10% (of ) 50/60 Hz 3 VA 100 ms (Max.) 200 ms (Max.) 24-60V AC/DC 85-265V AC, 100-265V DC For AC Signals: 50 ms Max. For DC Signals: 20 ms Max. 100 ms (Applicable at Power ON Only) ± 5% of Full scale ± 1% 1 C/O (Delayed) & 1 C/O (Configurable as either Delayed or Instant) 5A @ 240 VAC / 28 VDC (Resistive) AgNi 1x105 1x107 0.1 seconds to 120 Days Refer page no. 21 & 22 Green LED ON: Power ON, Amber LED ON :Relay ON for Delayed contact Base / DIN Rail 2000 m Flame retardant (UL 94-V0) -10°C to +60°C -20°C to +70°C 95% (Rh) Green LED Power ON, Red LED Relay ON Flame Retardant UL94-V0 22.5 X 83 X 100.5 130 g II Certification RoHS Compliant Degree of Protection IP 20 for Terminals, IP 40 for Enclosure EMI / EMC Harmonic Current Emissions ESD Radiated Susceptibility Electrical Fast Transients Surges Conducted Susceptibility Voltage Dips & Interruptions (AC) Conducted Emission Radiated Emission IEC 61000-3-2 IEC 61000-4-2 IEC 61000-4-3 IEC 61000-4-4 IEC 61000-4-5 IEC 61000-4-6 IEC 61000-4-11 CISPR 14-1 CISPR 14-1 Safety: Test Voltage between I/P and O/P IEC 60947-5-1 Test Voltage between all terminals IEC 60947-5-1 & enclosure Impulse Voltage between I/P and O/P IEC 60947-5-1 Single Fault IEC 61010-1 Insulation Resistance UL 508 Leakage Current UL 508 IEC 61812-1 Product Reference Standard Environmental Cold Heat Dry Heat Vibration Repetitive Shock Non-Repetitive Shock IEC 60068-2-1 IEC 60068-2-2 IEC 60068-2-6 IEC 60068-2-27 IEC 60068-2-27 27 Electronic Timer - Series Micon® 225 Signal Based Multi - Function FUNCTIONAL DIAGRAMS ON DELAY (Non Signal Based) When supply is applied, timing starts and after the preset time duration 'T', output switches ON and remains ON till the supply is present. T When the supply applied and signal is closed, output switches ON for the preset time duration ‘T' and then switches OFF for preset time duration 'T'. This cycle repeats while the supply is present. Changing the state of signal during ‘T’ does not affect the output. T T-a R(D) R(I) T T-a S R(D) R(I) T T When the supply applied and signal is closed, output switches OFF for the preset time duration ‘T' and then switches ON for preset time duration 'T'. This cycle repeats while the supply is present. Changing the state of signal during ‘T’ does not affect the output. T T T-a T-a T T-a R(I) T T T T T T T S R(D) R(I) T + t1 + t2 T S Accumulative Delay ON Signal: On t1 t2 R(D) application of the supply voltage, the preset timing commences. Whenever signal is R(I) closed, timing pauses & resumes back only when the input signal is opened. The output switches ON at the end of the preset time duration 'T'. R(D) R(I) DELAYED IMPULSE T T T-a T-a T R(D) R(I) ONE SHOT T-a T One Shot: When the supply voltage is applied and signal is closed,timing starts and after the preset time duration‘T’, output switches ON for One sec. only. S R(D) R(I) Step Mode: When the supply voltage is applied and signal closed, output switches ON for preset time duration 'T', removal of the input signal during this time duration 'T' does not affect the output state. But if the signal is closed during time duration 'T', output switches OFF. S R(D) R(I) T T T-a T T T T Ton T off Ton T off Signal OFF Delay: When the supply is applied and signal is closed, output is switches ON. When signal is opened, the preset timing commences and output is switches OFF at the end of time duration ‘T’. If signal is closed during timing period, then timing stops and restarts when signal. S R(D) R(I) 28 T a T-a T R(D) R(I) a = 1 sec T T-a T-a T S R(D) R(I) SIGNAL OFF DELAY T T-a a S STEP MODE T-a T T off Delayed Impulse: When supply voltage is S applied and signal is closed, output R(D) switches ON at the end of the preset time 'TOFF'. Then the preset ON time 'TON' R(I) starts irrespective of the signal state and remains ON till the completion of preset time duration 'TON'. If signal closed during the timing 'TOFF', the timing restarts but the output state remains unaffected. The signal change does not have any effect during the timing period 'TON'. S CYCLIC OFF/ON T R(D) ACCUMULATIVE DELAY ON SIGNAL T S TRAILING EDGE IMPULSE When supply voltage is applied and signal is opened, output switches ON for the preset time duration 'T'. After completion of preset time 'T', output switches OFF. If the signal is closed during preset timing 'T', output switches OFF & timing stops. T S IMPULSE ON/OFF T When supply is applied and if signal closed or opened, output switches ON for Preset time duration 'T'. During time period 'T',changing state of input signal does not affect the output but resets the timing. LEADING EDGE IMPULSE When the supply applied and signal is closed, the output switches ON for preset time 'T'. After the completion of preset time ‘T’, the output switches OFF. If signal closed or opened during preset time duration ‘T’, the output remains unaffected. T T-a Signal ON/OFF Delay: When the supply is S applied and signal is closed, outputs R(D) switches ON after preset time 'T'. During the timing ‘T’ if signal is opened, the output R(I) switches ON immediately and OFF delay starts. Once this time period has elapsed the output switches OFF. During this OFF delay if signal is closed, the output switches OFF immediately and ON Delay restarts. INTERVAL When supply voltage is applied & signal is closed, output switches ON & timing function starts. If signal is opened and closed during the preset time, the timing restarts. After preset time 'T' has elapsed, the output switches OFF. T SIGNAL ON/ OFF Delay T S INVERTED SIGNAL ON DELAY When supply is applied and signal is opened, preset time duration 'T' starts. On completion of the 'T', output switches ON. If the signal is closed during timing ‘T’, timing resets. CYCLIC ON/OFF T-a R(I) SIGNAL ON DELAY Time commences as supply and signal is present. When input signal is opened, the timing resets. The output is switched ON at the end of the preset time duration ‘T’. When output is ON if signal is opened then the output switches OFF. T R(D) SIGNAL ON DELAY TYPE 1 When the input supply & signal are applied, timing starts and after preset time duration ‘T’ output switches ON & remains ON till the supply is present. Changing the state of signal during ‘T’ does not affect the output. : Supply Voltage, S: Input Signal, R: Relay Output, R(I): Instant Relay, R(D): Delayed Relay T: Preset Time, TON: Preset ON Time, TOFF: Preset OFF Time, T-a: Timing Break Before completion T S R(D) R(I) T-a T a Electronic Timer - Series Micon® 225 Signal Based Multi - Function Selection of Function: Operating Mode & timing can be selected by using DIP switches Function 1234 On Delay (Non Signal) Function 1234 Signal OFF Delay Signal On Delay Type 1 Step Mode Signal On Delay One Shot Inverted Signal On Delay Delayed Impulse Interval Accumulative Delay On Signal Leading Edge Impulse Impulse ON / OFF Trailing Edge Impulse Signal ON / OFF Delay Cyclic OFF / ON Cyclic ON / OFF 1I + 1D or 2D Selection 5 1I + 1D Operation Timing Multiplier Selection 6 Timing = 'T' X 't' X 1 2 Delayed Operation Timing = 'T' X 't' X 12 MOUNTING DIMENSION (mm) 100.50 78.26 35.00 60.00 62.50 83.00 57.00 30 4. 22.5 10.0 12.5 CONNECTION DIAGRAM +A1 A2- 15 TERMINAL TORQUE & TERMINAL CAPACITY 25 Ø 3.5...4.0 mm Torque - 0.6 N.m (6 Lb.in) Terminal screw - M3 1 X 1...4 mm2 Solid /Stranded Wire B1H/B1L AWG 16 18 26 DLYD 28 INST OR DLYD 29 1 X 16 to 12 Electronic Timer - Series Micon® 225 • Compact 22.5mm Wide • Flush knobs for better security • Wide Time Range: 0.1s to 10h • LED Indications for Power and Relay status • Wide Voltage range for both AC & DC • Excellent Noise Immunity to the latest IEC standards Multi Function Timer Multi Function Timer with 1 Instant & 1 Delayed C/O • Multi Function Timer with 5 different modes • Multi Function Timer with 6 different modes • 2 C/O Configuration • 2 C/O Configuration (1 Instant + 1 Delayed) Ordering Information Cat. No. Description 2A5DT5 24 - 240 VAC/DC, Multi Function Timer (5 Modes), 2 C/O 2B5DT5 240 - 415 VAC, Multi Function Timer (5 Modes), 2 C/O 2A6DT6 24 - 240 VAC/DC, Multi Function Timer (6 Modes), 2 C/O (1 Instant + 1 Delayed for 6th Mode 2B6DT6 240 - 415 VAC, Multi Function Timer (6 Modes), 2 C/O (1 Instant + 1 Delayed for 6th Mode) 2AODT5 24 - 240 VAC/DC, ON Delay, 2 C/O UL Approval not applicable for Cat No. 2A6DT6 & 2B6DT6 30 Electronic Timer - Series Micon® 225 Cat. No. Parameters Timer Description Modes 2A5DT5 2B6DT6 Multi Function Timer ON Delay, Interval, Cyclic ON-OFF, Cyclic OFF-ON, One Shot Multi Function Timer ON Delay, Interval, Cyclic ON-OFF, Cyclic OFF-ON, One Shot, ON Delay with 1 Instant & 1 Delayed Functional Diagram R T ON DELAY T R T R T T CYCLIC ON/OFF INTERVAL INST R T T R T T 1s ONE SHOT CYCLIC OFF/ON DLYD T ON DELAY (1 INST. + 1 DLYD.)* * Available only with Cat. No. 2A6DT6 & 2B6DT6 Supply Voltage ( ) Supply Variation Frequency Power Consumption (Max.) Timing Range Reset Time Setting Accuracy Repeat Accuracy Relay Output Contact Rating Output Electrical Life Mechanical Life AC - 15 Utilization Category DC - 13 Operating Temperature Storage Temperature Humidity (Non Condensing) LED Indication Enclosure Dimension (W x H x D) (in mm) Weight (unpacked) Mounting Certification 24 - 240 VAC/DC - 20% to +10% (of ) 50/60 Hz 4 VA 0.1s to 10h 200 ms (Max.) 240 - 415 VAC 7 VA ± 5% of Full scale ± 1% 2 C/O, 1 Instant + 1 Delayed (for 6th mode) 2 C/O 5A @ 240 VAC / 28 VDC (Resistive) 1x105 1x107 Rated Voltage (Ue): 120/240 V, Rated Current (Ie): 3.0/1.5 A Rated Voltage (Ue): 24/125/250 V, Rated Current (Ie): 2.0/0.22/0.1 A -15°C to +60°C -20°C to +80°C 95% (Rh) Green LED Power ON, Red LED Relay ON Flame Retardant UL94V0 22.5 X 75 X 100.5 130 g Base / DIN Rail RoHS Compliant Degree of Protection IP 20 for Terminals, IP 40 for Enclosure EMI / EMC Harmonic Current Emissions ESD Radiated Susceptibility Electrical Fast Transients Surges Conducted Susceptibility Voltage Dips & Interruptions (AC) Voltage Dips & Interruptions (DC) Conducted Emission Radiated Emission IEC 61000-3-2 IEC 61000-4-2 IEC 61000-4-3 IEC 61000-4-4 IEC 61000-4-5 IEC 61000-4-6 IEC 61000-4-11 IEC 61000-4-29 CISPR 14-1 CISPR 14-1 Environmental Cold Heat Dry Heat Vibration Repetitive Shock Non-Repetitive Shock IEC 60068-2-1 IEC 60068-2-2 IEC 60068-2-6 IEC 60068-2-27 IEC 60068-2-27 31 Electronic Timer - Series Micon® 225 • Signal based Multi-function with Relay / Solid State Output • Asymmetric Timer with Solid State Output Ordering Information Cat. No. Description 2ANDT0 24 - 240 VAC/DC, Signal Based Multi Function Timer, 1 C/O 20NDTT 110 - 240 VAC, Signal Based Multi Function Timer with Solid State Output 20JDTT 110 - 240 VAC, Asymmetric Timer with Solid State Output 32 Electronic Timer - Series Micon® 225 2ANDT0 Cat. No. Parameters Description Modes Derived Modes Signal Based Multi Function Signal ON Delay, Accumulative ON Delay, Signal OFF Delay, Signal OFF/ON Delay, Leading Edge Impulse ON Delay, Interval S Functional Diagram S R R T SIGNAL ON DELAY Certification t1 t2 T+t1+t2 S T R ACCUMULATIVE ON DELAY S S R T R T T LEADING EDGE IMPULSE Supply Voltage ( ) Supply Variation Frequency Power Consumption (Max.) Timing Ranges Reset Time Setting Accuracy Repeat Accuracy Relay Output Contact Rating Output Electrical Life Mechanical Life Type & Form Rated Current Solid Max. Admissible Current State Vol. Breaking Capacity Output Max. Drop @ Terminals Minimum Load Current Electrical Life AC - 15 Utilization Category DC - 13 Operating Temperature Storage Temperature Humidity (Non Condensing) LED Indication Enclosure Dimension (W x H x D) (in mm) Weight (unpacked) Mounting 20NDTT S T T SIGNAL OFF DELAY R T T SIGNAL OFF/ON DELAY S R T ON DELAY T INTERVAL 24 - 240 VAC/DC 110 - 240 VAC - 20% to +10% (of ) 50/60 Hz 4 VA 0.1s to 10h 200 ms (Max.) ± 5% of Full scale ± 1% NA 1 C/O (SPDT) NA 5A @ 240 VAC / 28 VDC (Resistive) 1x105 NA 1x107 NA NA Optical Isolation, SPST NA 1A (AC) NA 20A (10 ms) NA 110 to 240 VAC NA
2A5DT5 价格&库存
很抱歉,暂时无法提供与“2A5DT5”相匹配的价格&库存,您可以联系我们找货
2A5DT5
    • 1+336.79391
    库存:6
