66MA
66MA
    STARRETT(施泰力)
    量具 折叶尺寸12.7 x 77mm ;折叶数量20,折叶厚度 0.05-1.0mm,增量0.05mm
66MA 数据手册
fIXED gAGE sTANDARDS Gage Sets Features S4000 Precision Steel Pin Gage Sets Fixed Gage Standards .011-1.000" Precision gage pins are used to determine small hole sizes, for gaging slots, and finding hole distances. S4000 Pin Gages - Plus Sets Cat. No. EDP S4000-060 67480 S4002-250 67482 S4004-500 67484 S4006-625 67486 S4008-750 67488 S4010-832 67490 S4012-916 67492 S4014-1 67494 S4000 Pin Gages - Minus Sets Cat. No. EDP S4001-060 67481 S4003-250 67483 S4005-500 67485 S4007-625 67487 S4009-750 67489 S4011-832 67491 S4013-916 67493 S4015-1 67495 Range .011-.060" (+) .061-.250" (+) .251-.500" (+) .501-.625" (+) .626-.750" (+) .751-.832" (+) .833-.916" (+) .917-1.000" (+) No. of Gages 50 190 250 125 125 82 84 84 Range .011-.060" (-) .061-.250" (-) .251-.500" (-) .501-.625" (-) .626-.750" (-) .751-.832" (-) .833-.916" (-) .917-1.000" (-) No. of Gages 50 190 250 125 125 82 84 84 • Color coded, fully adjustable Go/No-Go gage handle furnished with each set • Sets are supplied in rugged, high impact protective cases with each space marked for the appropriate gage • Inspection certificate with every set • All Starrett pin gages are manufactured to a 0.0002" tolerance • Plus and minus tolerance sets --A plus tolerance gage would be e.g.; gage pin size as labelled + 0.0002" - 0.0" --A minus tolerance gage would be the gage pin size as labelled -0.0002" + 0.0 • Offered in 0.001" increments • Each pin is centerless lapped and is clearly etched with the stated size • All gages are 2 inches long and hardened to RC 60/64 • All sharp corners are broken Handles for 4000 Pin Gages Cat. No. EDP PT45065 45060 PT45250 45250 PT45500 45500 PT45625 45625 PT45750 45750 PT45832 45832 PT45916 45916 PT45066 45001 Description Handle for .011-.060" Pin Gages Handle for .061-.250" Pin Gages Handle for .251-.500" Pin Gages Handle for .501-.625" Pin Gages Handle for .626-.750" Pin Gages Handle for .751-.832" Pin Gages Handle for .833-.916" Pin Gages Handle for .917-1.000" Pin Gages Go/No-Go Gage S4002-250 190, piece set 326 and Wire Gages 185 Time Saver® Tap and Drill Gage 186 D rill a nd S teel W ire G ag e NOS. 1-60/.228-.040" NOS. 1-60/.228-.040" • Correct sizing of tap drill for any common size machine screw tap in "NF" National Fine or "NC" National Coarse Thread • Leaves the right amount of stock for approximately 65% full thread • Shows correct drill body size • 60 holes with number sizes and decimal equivalents • Black matte finish with information steel stamped on one side and white marked on the reverse side for quick, clear reading • Carefully tested for accuracy after hardening • Widely used by mechanics for twist drills and steel drill rod • Similar to 185, without the tap and drill information • 60 holes from 1 to 60 • Marked with number sizes and decimal equivalents • Black matte finish with gage information steel stamped on one side and white marked on reverse for quick, clear reading • Carefully tested for accuracy after hardening 185 185 Time Saver Tap and Drill Gage Range Dimensions Cat. No. EDP Tap Size Tap Drill Body Drill Thickness x Width x Length 185 50675 2-56 to 1/4-28 50 to 3 44 to 1/4 5/64" x 2-5/16" x 6-1/4" 187 Jobbers' Drill Gage 186 Fixed Gages Cat. No. 186 EDP 50676 Description Drill and Steel Wire Gage A-Z .234-.413" DIA. • Quick sizing of any twist drill from 1/16-1/2" by 64ths • 29 holes marked with drill size in inches and decimal equivalents • Black matte finish with gage information steel stamped on one side and white marked on reverse for quick, clear reading • Carefully tested for accuracy after hardening • Quick, convenient checking of letter size drills • Twenty-six holes provided, giving corresponding drill sizes from "A" through "Z" with decimal equivalents from .234" diameter through .413" diameter • Satin finish • Carefully tested for accuracy after hardening 187 198 Fixed Gages EDP 50677 Dimensions Thickness x Width x Length 5/64" x 1-1/2" x 5-1/2" 198 Standard Letter Size Drill Gage 1/16-1/2" Cat. No. 187 Fixed Gage Standards Hardened Drill Fixed Gages Dimensions Thickness x Width x Length 5/64" x 2-5/16" x 6-1/4" Description Jobbers' Drill Gage Cat. No. EDP 198 50718 Dimensions Thickness x Width x Length Description 5/64 " x 2-5/16" x 6-1/4" Standard Letter Size Drill Gage starrett.com 327 Wire 286 Drill Fixed Gage Standards Standard Gages and and Steel Wire Gage HARDENED 61-80/.039-.0135" This gage is for selecting the correct size of twist drills and steel drill rod in smaller sizes ranging from 61 to 80. For convenience, each hole is marked with the size number and the corresponding decimal equivalent. Attractive satin finish. Small compact size, approximately 1/16" thick, 3/4" wide and 2" long. 286 Fixed Gages Cat. No. 286 EDP 51320 Description Drill and Steel Wire Gage 188 English Standard Wire Gage 281 American Standard Wire Gage (BIRMINGHAM OR STUBS' IRON WIRE GAGE) HARDENED 1-36/.300-.004" (OR B.&S.) FOR NON-FERROUS METALS HARDENED 0-36/.325-.005" This gage is popular for gaging iron wire, hot and cold rolled sheet steel, and in some cases, sheet iron by the English Standard Wire system also known as Birmingham or Stubs. This gage is the generally accepted standard for non-ferrous metals as adopted by brass manufacturers. It is 281 especially useful for electricians and others to gage sheet, plate and wire made of non-ferrous metals like copper, brass, aluminum, etc. Screw slotting cutters are also made to this gage. Gage has convenient decimal equivalents of each number on the reverse side. Satin finish. Fixed Gages Cat. No. 188 EDP 50678 188 Gage has decimal equivalents on the reverse side. Satin finish. Fixed Gages Cat. No. 281 Description English Standard Wire Gage 287 American Steel and Wire Co. Gage (WASHBURN & MOEN) STANDARD 0-36/.3065-.009" EDP 51321 Description American Standard Wire Gage 280 Piano Tuners' Gage AMERICAN STEEL AND WIRE CO. STANDARD HARDENED 12-28/.029-.071" This gage is designed for gaging steel wire and drill rod to the American Steel & Wire Co. (Washburn & Moen) Standard and checks sizes from 0-36. (Also known as United States Steel Wire Gage.) Decimal equivalents are given on the back. Satin finish. Fixed Gages Cat. No. 287 EDP 51316 The 280 Gage is designed for gaging steel music wire and has a range from 12 to 28. Convenient decimal equivalents on reverse side. Diameter of the gage is 1-9/16" and it has a satin finish. 287 Description American Steel and Wire Co. Steel Wire Gage 280 Fixed Gages Cat. No. 280 EDP 51315 Description Piano Tuners' Gage 283 U.S. Standard Gage SHEET, PLATE IRON AND STEEL GAGE HARDENED 0-36/.3125-.007" This gage is made to the United States Standard for uncoated sheet, plate iron and steel, and is based on weights in ounces per square foot. The gage has a satin finish and decimal equivalents on the reverse side. Fixed Gages Cat. No. 283 283 EDP 51318 Description U.S. Standard Gage NOTE: Like other Starrett gages, these tools are carefully tested for accuracy after hardening. 328 284 Acme Standard Screw Thread Gage This gage is a standard for grinding and setting tools when cutting Acme threads. Acme threads have the same depth as square threads but the sides of the threads are at an inclination of 14-1/2º (29º included angle). This form of thread is used extensively and has in many instances replaced the square thread in machine construction. The advantages of the Acme thread are its strength and the ease by which it can be cut compared with square threads. The angles and edges of this gage are hardened, ground and carefully tested. 284 In use, the angle on the thread cutting tool is checked on the large precision-ground V at the end of the gage. The tool is then ground on the end to the width of the slot of whatever pitch is being turned. It is then set in the lathe using the half angle. Fixed Gages Cat. No. 284 Standards EDP 51319 for Sheet Description Acme Standard Screw Thread Gage and Wire Gages Dimensions of Sizes in Decimal Parts of an Inch 281 188 and 245 Birmingham or No. of Wire Gage American or Brown & Sharpe Stubs' Iron Wire 00000000 0.7314 0000000 0.6514 000000 0.5800 00000 0.5165 0000 0.46 0.454 000 0.4096 0.425 00 0.3648 0.38 0 0.3249 0.34 1 0.2893 0.3 2 0.2576 0.284 3 0.2294 0.259 4 0.2043 0.238 5 0.1819 0.22 6 0.1620 0.203 7 0.1443 0.18 8 0.1285 0.165 9 0.1144 0.148 10 0.1019 0.134 11 0.0907 0.12 12 0.0808 0.109 13 0.0720 0.095 14 0.0641 0.083 15 0.0571 0.072 16 0.0508 0.065 17 0.0453 0.058 18 0.0403 0.049 19 0.0359 0.042 20 0.0320 0.035 21 0.0285 0.032 22 0.0253 0.028 23 0.0226 0.025 24 0.0201 0.022 25 0.0179 0.02 26 0.0159 0.018 27 0.0142 0.016 28 0.0126 0.014 29 0.0113 0.013 30 0.0100 0.012 31 0.0089 0.01 32 0.0080 0.009 33 0.0071 0.008 34 0.0063 0.007 35 0.0056 0.005 36 0.005 0.004 37 0.0045 38 0.0040 39 0.0035 40 0.0031 with Corresponding Starrett Gages 287 280 283 Washburn & Moen, American S. & W. Co's. U.S. Standard Gage for Sheet Worcester, MA* Music Wire Gage Stubs' Steel Wire and Plate Iron and Steel 0.3938 0.3625 0.331 0.3065 0.283 0.2625 0.2437 0.2253 0.207 0.192 0.177 0.162 0.1483 0.135 0.1205 0.1055 0.0915 0.08 0.072 0.0625 0.054 0.0475 0.041 0.0348 0.0318 0.0286 0.0258 0.023 0.0204 0.0181 0.0173 0.0162 0.015 0.014 0.0132 0.0128 0.0118 0.0104 0.0095 0.009 0.004 0.005 0.006 0.007 0.008 0.009 0.01 0.011 0.012 0.013 0.014 0.016 0.018 0.02 0.022 0.024 0.026 0.029 0.031 0.033 0.035 0.037 0.039 0.041 0.043 0.045 0.047 0.049 0.051 0.055 0.059 0.063 0.067 0.071 0.075 0.08 0.085 0.09 0.095 0.227 0.219 0.212 0.207 0.204 0.201 0.199 0.197 0.194 0.191 0.188 0.185 0.182 0.18 0.178 0.175 0.172 0.168 0.164 0.161 0.157 0.155 0.153 0.151 0.148 0.146 0.143 0.139 0.134 0.127 0.12 0.115 0.112 0.11 0.108 0.106 0.103 0.101 0.099 0.097 0.4688 0.4375 0.4063 0.375 0.3438 0.3125 0.2813 0.2656 0.25 0.2344 0.2188 0.2031 0.1875 0.1719 0.1563 0.1406 0.125 0.1094 0.0938 0.0781 0.0703 0.0625 0.0563 0.05 0.0438 0.0375 0.0344 0.0313 0.0281 0.025 0.0219 0.0188 0.0172 0.0156 0.0141 0.0125 0.0109 0.0102 0.0094 0.0086 0.0078 0.0070 0.0066 0.0063 * Also called the U.S. Steel Wire Gage starrett.com 329 Fixed Gage Standards HARDENED 29º Wire and Standard Gages 1/8 3/32 178, 178M Fillet or Radius Gages with Locking Device 1/4 1/8 1/32-1/2"/1-15MM Fixed Gage Standards 1/16 These gages are very useful for tool and diemakers, machinists, screw machine operators, patternmakers and other mechanics to lay out and check radii of tools, dies, patterns, etc. 1/8 Made in two English and metric sizes as listed below, each gage has leaves for measuring both concave and convex radii, with each leaf stamped with the radius size. Any one of the leaves can be securely locked in position by a locking device. Made of nicely finished, high quality steel. Inch Reading Cat. No. EDP 178A 50664 178B 50666 Millimeter Reading Cat. No. EDP 178MA 50665 178MB 50667 Range (Concave and Convex) 1/32-1/4" 17/64-1/2" Increments Range (Concave and Convex) 1-3mm 3-7mm 7.5-15mm Increments 0.25mm 0.5mm 0.5mm 64ths 1/16 3/16 Leaves 30 32 Leaves 178B 34 32 272, 272M Fillet or Radius Gages 1/32-33/64"/0.75-13MM 1/4 An external and internal radius on each leaf permits both concave and convex surfaces to be measured. The leaves are specially shaped for use in any position at any angle to measure fillets and radii in corners or against shoulders. Each leaf is stamped with the radius size and has an eccentric mounting for clearance between the leaf and the case when the gage is opened. Inch Reading Cat. No. EDP 272A 51296 272B 51298 Millimeter Reading Cat. No. EDP 272MA 51297 272MB 51299 Range (Concave and Convex) Increments 1/32-17/64" 64ths 9/32-33/64" Leaves Range (Concave and Convex) Increments 0.75-5mm 0.25mm 5.5-13mm 0.5mm Leaves 18 16 16 272A 279 Fillet or Radius Gages .020-.4000 This gage is similar to our 272, except that it has twenty leaves with radii from .020-.400" inclusive. Nine leaves have concave and convex radii from .020-.10" in increments of .010", four leaves with concave and convex radii from .125-.20" in increments of .025", one leaf with concave and convex radii of .250", three leaves with concave radii only from .300-.400" in increments of .050" and three leaves with convex radii from .300-.400" by an increment of .050". Inch Reading Cat. No. 279 330 EDP 51314 Range (Concave and Convex) .020-.400" Leaves 20 279 Angle and Center Gages 466 Angle Gage A convenient, timesaving tool for inspectors, toolmakers, and diesinkers when checking angles. Tool also replaces a protractor in many instances. The gage has 18 leaves, each with a different angle including 14-1/2º (1/2 the Acme Standard of 29º). Leaves are made of the finest springtempered steel and both the angle edge and two sides are ground. Approximately 9/32" thick, 1-1/16" wide and 4-3/16" long. 466 Angle Gage Cat. No. EDP Range Leaves Angles Available 1º, 2º, 3º, 4º, 5º, 7º, 8º, 9º, 10º, 12º, 14º, 14-1/2º, 466 52463 1-45º 18 15º, 20º, 25º, 30º, 35º, 45º 466 C391 Center Gage 60º AMERICAN NATIONAL C396 Center Gage 55º WHITWORTH OR ENGLISH C398M Center Gage 60º METRIC • Extremely handy for use in grinding and setting screw cutting tools • Meets American National or U.S. 60º, Whitworth or English 55º, and Metric 60º standards • Very useful for finding number of threads per inch through graduations in 14ths, 20ths, 24ths and 32nds of an inch on C391 and C396 • Graduations on C398M are in mm and 1/2mm • C391 Gage also has a table of double depths of threads for determining size of tap drills • Made of spring-tempered steel with satin chrome finish • Ground gaging surfaces Center Gages with Inch Graduations Cat. No. EDP Description C391 51475 American National Standard, 60º C396 51477 Whitworth or English Standard, 55º Center Gages with Millimeter Graduations Cat. No. EDP Description C398M 51478 Metric Standard, 60º C391 starrett.com 331 Fixed Gage Standards 1-45º Screw Pitch Gages Fixed Gage Standards English and Metric Screw Pitch Gages 2-1/4-84 PITCHES (INCH) 0.25-11.5 PITCHES (MILLIMETER) Screw pitch gages are among the most useful tools in any mechanics' tool box. They quickly determine the pitch of various threads. These gages consist of a substantial steel case with a number of folding leaves at both ends, each leaf having teeth corresponding to a specific pitch, marked on each leaf. 155 Starrett screw pitch gages are available in a wide range of sizes with different numbers of leaves in various pitch ranges. V, Unified, American National 60º threads Whitworth Standard 55º threads International Metric Standard 60º threads English and metric threads are similar in form, but English threads are described in threads per inch and metric threads by the distance from one crest to the next. 484 All screw pitch gages (except 473 and 476, which have a positive stop design) feature a locking device at both ends of the case, so leaves can be securely locked in position for use. Leaves on most gages have a special narrow design, permitting checking internal threads in nuts, etc., as well as external threads. Various types of Starrett screw pitch gages are illustrated on the following pages, with complete specifications. 6 NATIONAL FORM SHARP V Starrett Screw Pitch Gages have the tops of the teeth flatted, permitting use of a single gage for either National Form threads or Sharp V threads 474 Screw Pitch Gages Cat. No. EDP No. of Leaves TPI Range 155 50588 27 2-1/4–28 484 67447 28 3-1/2–36 6 50035 30 4–42 474 52486 28 4–80 Threads per Inch (TPI) 2-1/4, 2-3/8, 2-1/2, 2-5/8, 2-3/4, 2-7/8, 3, 3-1/4, 3-1/2, 4, 4-1/2, 5, 5-1/2, 6, 7, 8, 9, 10, 11, 12, 13, 14, 16, 18, 20, 24, 28 3-1/2, 4, 4-1/2, 5, 5-1/2, 6, 7, 8, 9, 10, 11, 11-1/2, 12, 13, 14, 15, 16, 18, 20, 22, 24, 26, 27, 28, 30, 32, 34, 36 4, 4-1/2, 5, 5-1/2, 6, 7, 8, 9, 10, 11, 11-1/2, 12, 13, 14, 15, 16, 18, 20, 22, 24, 26, 27, 28, 30, 32, 34, 36, 38, 40, 42 4, 4-1/2, 5, 6, 7, 8, 9, 10, 11, 11-1/2, 12, 13, 14, 16, 18, 20, 24, 27, 28, 32, 36, 40, 44, 48, 56, 64, 72, 80 Description With locking device and 60º center gage With locking device With locking device and 11-1/2 and 27 pipe thread pitches With locking device and 11-1/2 and 27 pipe thread pitches Formulas American Natational V Thread d = D –1.299 d = D – 1.732 N N D = Outside diameter of tap d = Bottom diameter of tap N = Number of threads per inch 332 Screw Pitch Gages 55º THREADS 3-1/2 - 60 TPI (INCH) 156M, 159M International Metric Standard Screw Pitch Gages 60º THREADS Screw Pitch Gages Cat. No. EDP No. of Leaves TPI Range 472 52484 51 473 52485 30 476 52488 30 156M 50589 28 159M 50591 28 Threads per Inch (TPI) First Corner 17 Leaves: 4, 4-1/2, 5, 5-1/2, 6, 7, 8, 9, 10, 11, 11-1/2, 12, 13, 14, 15, 16, 18 Second Corner 17 Leaves: 20, 22, 24, 26, 27, 28, 30, 32, 34, 36, 38, 40, 42, 4–84 44, 46, 48, 50 Third Corner 17 Leaves: 52, 54, 56, 58, 60, 62, 64, 66, 68, 70, 72, 74, 76, 78, 80, 82, 84 6, 7, 8, 9, 10, 11, 11-1/2, 12, 13, 14, 15, 16, 18, 20, 22, 24, 26, 27, 28, 30, 32, 6–60 34, 36, 38, 40, 42, 48, 50, 56, 60 3-1/2, 4, 4-1/2, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 16, 18, 19, 20, 22, 24, 25, 26, 3-1/2–60 28, 30, 32, 36, 40, 44, 48, 50, 60 0.25, 0.30, 0.35, 0.40, 0.45, 0.50, 0.55, 0.60, 0.65, 0.70, 0.75, 0.80, 0.85, 0.25-2.50mm 0.90, 1, 1.10, 1.20, 1.25, 1.30, 1.40, 1.50, 1.60, 1.70, 1.75, 1.80, 1.90, 2, 2.50 0.5, 0.75, 1, 1.10, 1.25, 1.5, 1.75, 2, 2.5, 3, 3.5, 4, 4.5, 5, 5.5, 6, 6.5, 7, 7.5, 8, 0.5-11.5mm 8.5, 9, 9.5, 10, 10.5, 11, 11.5 Description With Locking Device and 11-1/2 and 27 Pipe Thread Pitches With Positive Stop and 11-1/2 and 27 Pipe Thread Pitches With Positive Stop With Locking Device With Locking Device and 60º Center Gage 476 473 156M 159M 472 starrett.com 333 Fixed Gage Standards 476 Whitworth Standard Screw Pitch Gages Radius Gages Gaging radii using gage with holder 167, 167M Fixed Gage Standards 1/64-1/2"/0.5-15MM 167 .010-.500 110 Gage Holder S167, S167M Sets 1/64-1/2"/0.5-15MM SD167 Sets .010-.500 Radii or fillets can be checked or laid out easier, faster, and more accurately with Starrett 167 Radius Gages. Available individually and in sets, fractional sizes 1/64-1/2", decimal sizes .010-.500" and in millimeters from 0.5-15mm. Many different sets for maximum convenience. Each set is furnished in an attractive case, providing complete protection and easy, instant selection of the right gage size for the job. Gage Features • Made of satin finish stainless steel – rust and stain resistant • Each gage is clearly marked with its radius • Each gage has five different gaging surfaces for both convex and concave radii • All gages have precision finished radii with extra smooth, accurate edges Gage Holder Features • Any gage can be used with the Starrett 110 holder which is especially useful for checking radii in confined or hard-to-reach locations • Two slots are provided in the holder permitting gages to be held at 30º or 45º, either square in the slot or tipped to one side • The holder is 4" (100mm) long, providing good reach and balance Holder 110 with 167-3/16 attached S167CHZ Radius Gage Set with 25 gages and holder in case 334 1 1/8 Fig 1. Checking concave (internal) radius with 90° arc. Also checks if sides are tangent to radius and 90° to each other. 2 1/4 Fig 2. Checking concave (internal) radius with arc up to 180°. Also will check radius shown in Fig. 1 but not relationship of sides. 3 1/8 Fig 3. Checking convex (external) radius with 90° arc. Also checks if sides are tangent to radius and 90° to each other. 4 1/8 Fig 4. Checking convex (external) radius with arc of 90° or greater, or radii with sides as shown which would interfere with gage used as in Fig. 3. 5 1/4 Fig 5. Checking convex (external) radius with arc of 180°; also less than 180° if sides of radius offer no interference. S167 Radius Gage Sets – Inch Cat. No. EDP Radii Range Increments S167AZ 50615 1/32-17/64" 64ths S167AHZ 50616 1/64-17/64" 64ths S167BZ 50617 9/32-1/2" 32nds 1/32-17/64" 64ths S167CZ 50618 9/32-1/2" 32nds S167CHZ 50619 1/64-17/64" 64ths S167CHZ W/SLC 66876 9/32-1/2" 32nds S167DZ 50620 1/32-1/2" 32nds S167M Radius Gage Sets – Millimeter Cat. No. EDP Radii Range Increments S167MAZ 55817 1-7mm 0.5mm S167MAHZ 55818 0.5-7mm 0.5mm S167MBZ 55819 8-15mm 1mm 1-7mm 0.5mm S167MCZ 55820 8-15mm 1mm 0.5-7mm 0.5mm S167MCHZ 55821 8-15mm 1mm S167MDZ 55822 1-15mm 1mm SD167 Radius Gage Sets – Decimal-Inch Cat. No. EDP Radii Range Increments SD167FZ 63464 .020-.300 0.02 SD167FHZ 63460 .350-.500 0.05 .010-.025 0.005 .030-.100 0.01 SD167GZ 63433 .120-.300 0.02 .350-.500 0.05 .010-.025 0.005 .030-.100 0.01 SD167GHZ 63463 .120-.300 0.02 .350-.500 0.05 167 Radius Gage - Accessories Cat. No. EDP Description 110 50475 Holder only Gages 16 17 8 Description Without holder With holder Without holder 24 Sets 167A and S167B Combined, without holder 16 Sets 167AH and S167B Combined, with holder Sets 167AH and S167B combined,with holder, Standard Letter of Certification* Without holder Gages 13 14 8 Description Without holder With holder Without holder 21 Sets S167MA and S167MB combined, without holder 22 Sets 167MB and S167MAH combined, with holder 15 Without holder 25 Gages Description Without holder 19 With holder 26 Without holder 26 With holder * Includes redemption card for Standard Letter of Certification (SLC). Individual Radius Gage Specifications 167 – Inch Cat. No. EDP Radius 167-1/64 50646 1/64" 167-1/32 50622 1/32" 167-3/64 50623 3/64" 167-1/16 50624 1/16" 167-5/64 50625 5/64" 167-3/32 50626 3/32" 167-7/64 50627 7/64" 167-1/8 50628 1/8" 167-9/64 50629 9/64" 167-5/32 50630 5/32" 167-11/64 50631 11/64" 167-3/16 50632 3/16" 167-13/64 50633 13/64" 167-7/32 50634 7/32" 167-15/64 50635 15/64" 167-1/4 50636 1/4" 167-17/64 50637 17/64" 167-9/32 50638 9/32" 167-5/16 50639 5/16" 167-11/32 50640 11/32" 167-3/8 50641 3/8" 167-13/32 50642 13/32" 167-7/16 50643 7/16" 167-15/32 50644 15/32" 167-1/2 50645 1/2" Individual Radius Gage Specifications 167M – mm Cat. No. EDP Radius 167M-1/2 55795 0.5mm 167M-1 55796 1mm 167M-1 1/2 55797 1.5mm 167M-2 55798 2mm 167M-2 1/2 55799 2.5mm 167M-3 55800 3mm 167M-3 1/2 55801 3.5mm 167M-4 55802 4mm 167M-4 1/2 55803 4.5mm 167M-5 55804 5mm 167M-5 1/2 55805 5.5mm 167M-6 55806 6mm 167M-6 1/2 55807 6.5mm 167M-7 55808 7mm 167M-8 55809 8mm 167M-9 55810 9mm 167M-10 55811 10mm 167M-11 55812 11mm 167M-12 55813 12mm 167M-13 55814 13mm 167M-14 55815 14mm 167M-15 55816 15mm Individual Radius Gage Specifications 167 - Decimal-Inch Cat. No. EDP Radius 167-010 63434 0.01 167-015 63435 0.015 167-020 63436 0.02 167-025 63437 0.025 167-030 63438 0.03 167-040 63439 0.04 167-050 63440 0.05 167-060 63441 0.06 167-070 63442 0.07 167-080 63443 0.08 167-090 63444 0.09 167-100 63445 0.1 167-120 63446 0.12 167-140 63447 0.14 167-160 63448 0.16 167-180 63449 0.18 167-200 63450 0.2 167-220 63451 0.22 167-240 63452 0.24 167-260 63453 0.26 167-280 63454 0.28 167-300 63455 0.3 167-350 63456 0.35 167-400 63457 0.4 167-450 63458 0.45 167-500 63459 0.5 starrett.com 335 Fixed Gage Standards FIVE DIFFERENT GAGING SURFACES – Ideal for Checking Convex and Concave Radii of All Types New! Thickness Gages English and Metric Thickness Gages Fixed Gage Standards .0015-.200"/0.03-5MM These gages are used in automotive, aviation, diesel, food and agricultural industries. They're also used in jig, fixture, gage and experimental work. In automotive, they are especially useful when adjusting tappets, spark plugs, distributor points, checking bearing clearances and gear play, fitting pistons, rings and pins and gaging narrow slots. Made in a wide range of types and sizes, each having from 6 up to 26 leaves ranging in thickness from .0015-.200" and 0.03-5mm thick, straight or tapered. Inch Reading Thickness Gages with Straight Leaves Tempered Steel Stainless Steel No. of Cat. No. EDP Cat. No. EDP Leaves Size Leaves 172A 50649 172AS 50649 9 1/2 x 3-1/32" 66 50314 66S 73466 26 1/2 x 3-1/32" 66B 57097 66BS 73439 31 1/2 x 3-1/32" 467 172E 52464 467S 50654 172ES 73340 73343 13 8 1/2 x 4-1/2" 1/2 x 12" 572A 57098 22 1/2 x 3-1/32" 572B 57099 22 1/2 x 3-1/32" • Now available in stainless and tempered steel • Leaves carefully finished to correct thickness, individually tested and marked with thickness • Locking device on most gages permits securely locking of one or more leaves in position • Leaves are easily removed or replaced • Rugged, substantial steel case protect leaves • All include locking device Range Leaf Thickness (in) .0015, .002, .003, .004, .006, .008, .010, .012, .015 .0015, .002, .0025, .003, .004, .005, .006, .007, .008, .009, .010, .011, .012, .013, .014, .015, .016, .017, .018, .019, .020, .021, .022, .023, .024, .025 .0015, .002, .0025, .003, .004, .005, .006, .007, .008, .009, .010, .011, .012, .013, .014, .015, .016, .017, .018, .019, .020, .021, .022, .023, .024, .025, .026, .028, .030, .032, .035 .0015, .002, .003, .004, .006, .008, .010, .020, .030, .040, .075, .100, .200 .002, .003, .004, .005, .006, .008, .010, .015 .0015, .002, .0025, .003, .004, .005, .006, .007, .008, .009, .010, .012, .013, .014, .015, .016, .018, .020, .022, .025, .030, .035 6 Spark Plug Wire Gages: .025, .030, .034, .035, .040, .045 .0015, .002, .0025, .003, .004, .005, .006, .007, .008, .009, .010, .012, .013, .014, .015, .016, .018, .020, .022, .025, .030, .035 Inch Reading Thickness Gages with Tapered Leaves Tempered Steel Stainless Steel No. of Cat. No. EDP Cat. No. EDP Leaves Size Leaves Range Leaf Thickness (in) .0015, .002, .0025, .003, .004, .005, .006, .007, .008, .009, .010, .011, .012, .013, .014, .015, 66T 50315 66TS 73442 26 1/2-1/4 x 3-1/32" .016, .017, .018, .019, .020, .021, .022, .023, .024, .025 172AT 50650 172ATS 73342 9 1/2-1/4 x 3-1/32" .0015, .002, .003, .004, .006, .008, .010, .012, .015 172CT 50652 8 1/2-1/4 x 6" .002, .003, .004, .006, .008, .010, .012, .015 Millimeter Reading Thickness Gages with Straight Leaves Tempered Steel No. of Range Cat. No. EDP Leaves Size Leaves Leaf Thickness (in) 66MA 55974 20 12.7 x 77mm 0.05, 0.10, 0.15, 0.20, 0.25, 0.30, 0.35, 0.40, 0.45, 0.50, 0.55, 0.60, 0.65, 0.70, 0.75, 0.80, 0.85, 0.90, 0.95, 1.0 173MA 57086 13 12.7 x 77mm 0.03, 0.04, 0.05, 0.06, 0.07, 0.08, 0.09, 0.10, 0.15, 0.20, 0.30, 0.40, 0.50 467M 52465 13 12.7 x 114mm 0.04, 0.05, 0.06, 0.07, 0.08, 0.10, 0.15, 0.20, 0.30, 1.0, 2.0, 3.0, 5.0 Millimeter Reading Thickness Gages with Tapered Leaves Tempered Steel No. of Range Cat. No. EDP Leaves Size Leaves Leaf Thickness (in) 172MBT 50656 9 12.7-7 x 114mm 0.04, 0.05, 0.06, 0.07, 0.08, 0.10, 0.15, 0.20, 0.30 173MAT 57087 13 12.7-7 x 77mm 0.03, 0.04, 0.05, 0.06, 0.07, 0.08, 0.09, 0.10, 0.15, 0.20, 0.30, 0.40, 0.50 173MCT 57088 13 12.7-7 x 152mm 0.03, 0.04, 0.05, 0.06, 0.07, 0.08, 0.09, 0.10, 0.15, 0.20, 0.30, 0.40, 0.50 172AT 172MBT 66 467 172A 572A 336 66T 666 Thickness Gage or "Feeler" Stock in Rolls 2 5' DISPENSER CASES .001-.015" 20', 25' CARDBOARD BOXES .0005-.025" 666M Thickness Gage or "Feeler" Stock in Rolls 7.6M DISPENSER CASES 0.03-0.35MM 6.1M CARDBOARD BOXES 0.40-0.50MM This handy product includes thickness stock, housed in convenient rewindable dispenser rolls. Having the thickness stock in a case makes it very useful for cutting off the required length for adjusting tappets, spark plugs, distributor points, checking bearing clearances and gear play, fitting pistons, rings and pins, gaging narrow slots, etc. This stock is also useful for shimming in fixturing and die work. • Now available in stainless and tempered steel • Handy 25' and 7.6m rolls 1/2" and 12.7mm wide, in a compact, sturdy plastic rewindable dispenser case. This case handles stock up to .015" and 0.35mm only. • Rewind feature permits retracting thinner feeler stock into the case, preventing damage • Roll stock in thicknesses of .016" or 0.40mm and over are furnished in 20' or 6m (nondispensable) rolls in a cardboard box. Also, the .0005", 25' size is furnished in a cardboard box. • Marked every 6" or 150mm with a line, thickness in thousandths of an inch or in hundredths of a mm (exception 666-1/2) • Case provides the ability to snip off the desired length without any waste 666-1 Inch Reading Rolls – Dispenser Case Tempered Steel Stainless Steel Cat. No. EDP Cat. No. EDP Thickness 666-1 52796 666S-1 73350 .001" 666-1 1/2 52797 666S-1 1/2 73351 .0015" 666-2 52798 666S-2 73363 .002" 666-2 1/2 52799 666S-2 1/2 73364 .0025" 666-3 52800 666S-3 73371 .003" 666-4 52801 666S-4 73372 .004" 666-5 52802 666S-5 73373 .005" 666-6 52803 666S-6 73374 .006" 666-7 52804 666S-7 73375 .007" 666-8 52805 666S-8 73376 .008" 666-9 52806 666S-9 73377 .009" 666-10 52807 666S-10 73353 .010" 666-11 52808 666S-11 73354 .011" 666-12 52809 666S-12 73355 .012" 666-13 52810 666S-13 73356 .013" 666-14 52811 666S-14 73357 .014" 666-15 52812 666S-15 73358 .015" Inch Reading Rolls – Cardboard Box Tempered Steel Stainless Steel Cat. No. EDP Cat. No. EDP Thickness 666-1/2 64210 666S-1/2 73352 .0005" 666-16 52813 666S-16 73359 .016" 666-17 52814 666S-17 63370 .017" 666-18 52815 666S-18 73361 .018" 666-19 52816 666S-19 73362 .019" 666-20 52817 666S-20 73365 .020" 666-21 52818 666S-21 73366 .021" 666-22 52819 666S-22 73367 .022" 666-23 52820 666S-23 73368 .023" 666-24 52821 666S-24 73369 .024" 666-25 52822 666S-25 73370 .025" Millimeter Reading Rolls – Dispenser Case Tempered Steel Cat. No. EDP Thickness Length 666M-3 52823 0.03mm 666M-4 52824 0.04 mm 666M-5 52825 0.05mm 666M-6 52826 0.06mm 666M-8 52827 0.08mm 666M-10 52828 0.10mm 7.6m 666M-15 52829 0.15mm 666M-20 52830 0.20mm 666M-25 52831 0.25mm 666M-30 52832 0.30mm 666M-35 52833 0.35mm Millimeter Reading Rolls – Cardboard Box Tempered Steel Cat. No. EDP Thickness Length 666M-40 52834 0.40mm 666M-45 52835 0.45mm 6.1m 666M-50 52836 0.50mm starrett.com Length New! Fixed Gage Standards "Feeler" Stock 25' Length 25' 20' 337 New! "Feeler" Stock 667 Thickness Gages or "Feeler" Stock Fixed Gage Standards .0005-.030" 667M Thickness Gages or "Feeler" Stock 0.03-0.50MM These gages are widely used in automotive, aviation, diesel and farm equipment manufacture and service and also in jig, fixture, gage and experimental work. • Now available in stainless and tempered steel • Inch sizes are 12" long, 1/2" wide and furnished in 33 different thicknesses ranging from .0005-.030" • Millimeter sizes are furnished in 300mm lengths, 12.7mm wide in 14 different thicknesses ranging from 0.03-0.50mm • Rounded ends ­make stock easier to work with • Made of the finest tempered steel and stainless steel • Each piece marked every 6" with thickness (exception 667-1/2) and in individual envelope • With convenient 3/16" (5mm) hole punched in the end for hanging Millimeter Gages – 300mm Cat. No. EDP Thickness 667M-3 52869 0.03mm 667M-4 52870 0.04mm 667M-5 52871 0.05mm 667M-6 52872 0.06mm 667M-8 52873 0.08mm 667M-10 52874 0.10mm 667M-15 52875 0.15mm 667M-20 52876 0.20mm 667M-25 52877 0.25mm 667M-30 52878 0.30mm 667M-35 52879 0.35mm 667M-40 52880 0.40mm 667M-45 52881 0.45mm 667M-50 52882 0.50mm 667 Inch Gages – 12" Tempered Steel Cat. No. EDP 667-1/2 64209 667-1 52837 667-1 1/2 52838 667-2 52839 667-2 1/2 52840 667-3 52841 667-4 52842 667-5 52843 667-6 52844 667-7 52845 667-8 52846 667-9 52847 667-10 52848 667-11 52849 667-12 52850 667-13 52851 667-14 52852 667-15 52853 667-16 52854 667-17 52855 667-18 52856 667-19 52857 667-20 52858 667-21 52859 667-22 52860 667-23 52861 667-24 52862 667-25 52863 667-26 52864 667-27 52865 667-28 52866 667-29 52867 667-30 52868 Stainless Steel Cat. No. EDP 667S-1/2 73394 667S-1 73392 667S-1 1/2 73393 667S-2 73405 667S-2 1/2 43706 667S-3 73417 667S-4 73419 667S-5 73420 667S-6 73421 667S-7 73422 667S-8 73423 667-9 73424 667S-10 73395 667S-11 73396 667S-12 73397 667S-13 73398 667S-14 73399 667S-15 73400 667S-16 73401 667S-17 73402 667S-18 73403 667S-19 73404 667S-20 73407 667S-21 73408 667S-22 73409 667S-23 73410 667S-24 73411 667S-25 73412 667S-26 73413 667S-27 73414 667S-28 73415 667S-29 73416 667S-30 73418 Thickness .0005" .001" .0015" .002" .0025" .003" .004" .005" .006" .007" .008" .009" .010" .011" .012" .013" .014" .015" .016" .017" .018" .019" .020" .021" .022" .023" .024" .025" .026" .027" .028" .029" .030" S667A and S667D Thickness Gage or "Feeler" Stock Assortments Two complete, handy thickness gage assortments: S667A (Inch) set consists of one each of 32 different pieces, 1/2" x 12" long from .001" through .030" thick (the entire individual range, with exception of the .0005" thickness, as listed on previous page). S667MA (Millimeter) set consists of one each of 14 different pieces, 12.5mm x 300mm long from 0.03mm through 0.50mm thick (complete range, as on previous page). S667D Bulk inch-reading assortment consists of 108 pieces, 1/2" x 12", in nine different thicknesses from .0015" to .015" thick. Twelve pieces of a size are packed in a box and each piece in an individual envelope. The nine boxes, together with an extra box for holding odd pieces, are packed in a convenient storage carton. Individual Assortments Tempered Steel Stainless Steel Cat. No. EDP Cat. No. EDP S667A 63274 S667AS 73443 S667MA 64949 Bulk Assortment Tempered Steel Stainless Steel Cat. No. EDP Cat. No. EDP S667D 52883 S667DS 73444 Description Complete Starrett inch thickness gage assortment – One each, 32 different sizes Complete Starrett millimeter thickness gage assortment – One each, 14 different sizes Description Bulk quantity assortment: 108 pieces in nine thickness sizes; 12 pieces of a size per box; .0015, .002, .003, .004, .006, .008, .010, .012, .015" Packed 12 pieces of a size in a box; each piece in individual envelope; 9 boxes in a carton. 338 Thickness Gages 806 T hickness G age or "F eeler " S tock H olders 806D T hickness G age or "F eeler " S tock H olders CLAMP AT BOTH ENDS These 806 Thickness Gage Holders provide a handy, convenient means of rigidly holding single leaves or strips of thickness gage stock of any thickness from .001-.025" (0.03-0.5mm). Stock up to 6" (150mm) long is easily inserted in the holder and firmly gripped in the desired position by a cam lock. This permits all of the stock to be used, because as it wears from use, the defective end can be snipped off and new stock pulled out until entirely used up. Available in two types as listed in the chart on the right, either to clamp stock at one end or both ends. Dull nickel finish. Size approximately 3/32" thick x 9/16" wide x 5-1/4" long (2.4 x 14 x 130mm). 806D holders have contrasting finish to eliminate the possible confusion on which end holds the thicker or thinner stock. Thickness Gage or "Feeler" Stock Holders Cat. No. EDP Description 806 53039 Holder only - Clamps stock at one end 806D 53040 Holder only - Clamps stock at both ends 806 with stock clamped on one end 806D with stock clamped on both ends 245, 245M Engineers' Combination Taper, Wire and Thickness Gage INCH/MILLIMETER Consists of a wire gage, a taper gage for measuring slot widths, and an assortment of thickness gage leaves, all folding within a compact steel case. The gage measures 1/2" wide x 4-3/4" long (12.7 x 120mm) and has a locking device to lock any leaf or leaves in position. Both 245 and 245M have an English Standard wire gage leaf similar to our 188, but with shorter range, sizes numbered from 19-36 (.042-.004"), plus two additional sizes, 1/16" and 1/8". The reverse side has decimal equivalents in thousandths. 245 has a taper gage leaf for measuring slot widths from 1/64-3/16" in 64ths of an inch, the reverse side having a 3" scale graduated in 8ths and 16ths. It has nine thickness or feeler leaves as follows: .002, .003, .004, .006, .008, .010, .012, .015 and 1/16". 245M has a taper gage leaf for measuring slot widths from 0.5-5mm in 0.5mm, the reverse side having an 80mm scale graduated in mm and 1/2mm. It has eleven thickness or feeler leaves as follows: 0.04, 0.05, 0.06, 0.07, 0.08, 0.10, 0.15, 0.20, 0.30, 1 and 2mm. 245M Inch Reading Cat. No. EDP Description 245 51170 With taper gage, English standard wire gage and 9 Inch reading thickness gage leaves Millimeter Reading Cat. No. EDP Description 245M 51171 With taper gage, English standard wire gage and 11mm reading thickness gage leaves starrett.com 339 Fixed Gage Standards CLAMP AT ONE END
很抱歉,暂时无法提供与“66MA”相匹配的价格&库存,您可以联系我们找货
