EC799A-12/300
EC799A-12/300
    STARRETT(施泰力)
    数显卡尺
EC799A-12/300 数据手册
EC799 Electronic Calipers 0-12”/0-300MM Metrology Solutions The EC799 Electronic Caliper is light, comfortable, easy-to-use, and constructed with features that have made Starrett slide calipers the machinist's first choice for many years. Output now available. The 799 offers a slim, streamlined profile, a large, clear, easy-to-read LCD display, long battery life, and function buttons for zero and inch/mm. EC799 Electronic Slide Calipers Range Inches mm 0-6 0-150 0-8 0-200 0-12 0-300 FEATURES • Lightweight, ergonomic design • Inch/millimeter conversion reads .0005" or 0.01mm • Easy access to the single, long-life battery • Last measuring position retained when shut off • Hardened stainless steel body for long life Cat. No. EC799A-6/150 EC799B-6/150 EC799B-6/150 W/SLC* EC799A-8/200 EC799B-8/200 EC799B-8/200 W/SLC* EC799A-12/300 EC799B-12/300 EC700B-12/300 W/SLC* 799 Extended Slide Calipers 0-24 0-600 799AZ-24/600 0-40 0-1000 799AZ-40/1000 Accessories and Case Information for 799 Electronic Calipers Description Cat. No. Center distance attachment PT26151 Depth attachment for 6", 9" and 150mm calipers PT22431 3-volt battery; CR2032 PT99492 Deluxe padded case for 0-6" (150mm) calipers 723ZZ-6/722ZZ-6 Finished wood case for 0-8" (200mm) calipers 950 Finished wood case for 0-12" (300mm) calipers 946 • Fine adjustment thumb wheel EDP 00142 67410 67620 00145 67412 67413 00148 67621 00150 • Lock screw to hold the slide in position • Resolution is .0005" (0.01mm) • Zero at any position • Protective case 6”, 8” AND 12” CALIPERS ONLY • Large easy-to-read LCD, .32” high characters • Automatic shut-off after 5 minutes of non-use 11978 11979 • Linear accuracy meets DIN862 • Integrated depth rod EXTENDED RANGE 24” AND 40” CALIPERS EDP 64440 64640 65650 57070 63878 56695 • Preset and hold feature • Minimum and maximum limits set • I.D. jaw dimension is 0.800”/20.32mm • LCD characters are .50” high * Includes redemption card for Standard Letter of Certification (SLC). • Auto shut-off after 30 minutes of non-use EC799B-12/300 90 0 10 20 80 70 30 60 40 50 Outside Measurement Depth Measurement EC799B-8/200 90 0 10 .001" 80 90 20 0 10 80 70 30 60 50 40 Inside Measurement Bulletin 1201 20 70 30 60 AMERICAN MADE 50 40 Step Measurement xxM/T 1/15 specifications subject to change. starrett.com
EC799A-12/300 价格&库存
很抱歉,暂时无法提供与“EC799A-12/300”相匹配的价格&库存,您可以联系我们找货
