10A240℃250V
10A240℃250V
    SANTE(三特电器)
10A240℃250V 数据手册
NO.STT-15A Series Features Applications With strong compact structures,high Widely used in follow various field such as transformer, Insulation resistance and quickly heated exhaust fan,fan and small power motor charger,adopter, advantages can be quickly action. secondary battery,household combined with gas water When the products work under abnormal or heater lightings and various heater equipment can't be reset,can soon cut off the power. ST T Dimension (unit:mm) 142C Rated functioning temperature is 142℃ T:15A Thermal Fuse series ST:Sante’s Brand Electrical characteristics at 25°C Operating No. Part Tf number temperature Th Tm Ir Ip Voltage Approvals (°C) (°C) (°C) (°C) (A) (A) (V) UL CCC TUV PSE VDE CB ○ ○ 1 STT073C 73 71±2 43 130 15A 150 250Vac ○ ○ ● ○ 2 STT077C 77 74±2 47 130 15A 150 250Vac ○ ○ ● ○ 3 STT113C 113 108±3 83 160 15A 150 250Vac ○ ○ ● ○ ○ ○ 4 STT121C 121 117±3 91 160 15A 150 250Vac ○ ○ ● ○ ○ ○ 5 STT133C 133 129±3 103 160 15A 150 250Vac ○ ○ ● ○ ○ ○ 6 STT142C 142 138±3 112 170 15A 150 250Vac ○ ○ ● ○ ○ ○ 7 STT157C 157 152±3 127 170 15A 150 250Vac ○ ○ ● ○ ○ ○ 8 STT167CC 167 164±3 137 190 15A 150 250Vac ○ ○ ● ○ ○ ○ 9 STT172C 172 169±3 142 190 15A 150 250Vac ○ ○ ● ○ ○ ○ 10 STT184C 184 180±3 154 210 15A 150 250Vac ○ ○ ● ○ ○ ○ 11 STT216C 216 213±3 186 260 15A 150 250Vac ○ ○ ● ○ ○ ○ ●= Approved ○=Going on Tf Functioning temperature,the standard tolerance:+0,-5℃ Th holding temperature:Maximum durative exposed exposed temperature. Tm maximum temperature:The highest temperature at which the thermal link wont change the condition Qty Order-number STT-15A Series Amp code Voltage Packaging ○ NO.STS-10A Series Features Applications With strong compact structures,high Widely used in follow various field such as transformer, Insulation resistance and quickly heated exhaust fan,fan and small power motor charger,adopter, advantages can be quickly action. secondary battery,household combined with gas water When the products work under abnormal or heater lightings and various heater equipment can't be reset,can soon cut off the power. ST S Dimension (unit:mm) 142C Rated functioning temperature is 142℃ S:10A Thermal Fuse series ST:Sante’s Brand Electrical characteristics at 25°C Operating No. Part Tf number temperature Th Tm Ir Ip Voltage Approvals (°C) (°C) (°C) (°C) (A) (A) (V) UL CCC TUV PSE VDE CB ○ ○ 1 STS073C 73 71±2 43 130 10A 150 250Vac ○ ○ ● ○ 2 STS077C 77 74±2 47 130 10A 150 250Vac ○ ○ ● ○ 3 STS113C 113 108±3 83 160 10A 150 250Vac ○ ○ ● ○ ○ ○ 4 STS121C 121 117±3 91 160 10A 150 250Vac ○ ○ ● ○ ○ ○ 5 STS133C 133 129±3 103 160 10A 150 250Vac ○ ○ ● ○ ○ ○ 6 STS142C 142 138±3 112 170 10A 150 250Vac ○ ○ ● ○ ○ ○ 7 STS157C 157 152±3 127 170 10A 150 250Vac ○ ○ ● ○ ○ ○ 8 STS167C 167 164±3 137 190 10A 150 250Vac ○ ○ ● ○ ○ ○ 9 STS172C 172 169±3 142 190 10A 150 250Vac ○ ○ ● ○ ○ ○ 10 STS184C 184 180±3 154 210 10A 150 250Vac ○ ○ ● ○ ○ ○ 11 STS216C 216 213±3 186 260 10A 150 250Vac ○ ○ ● ○ ○ ○ ●= Approved ○=Going on Tf Functioning temperature,the standard tolerance:+0,-5℃ Th holding temperature:Maximum durative exposed exposed temperature. Tm maximum temperature:The highest temperature at which the thermal link wont change the condition Qty Order-number STS-10A Series Amp code Voltage Packaging ○ Contents 1. SCOPE.......................................................................................................................................................................................... 2 2. AGENCY APPROVALS....................................................................................................................................................... 2 3. PART NUMBERING SYSTEM.......................................................................................................................................... 2 4. MECHANICAL SPECIFICATIONS................................................................................................................................ 3 5. OPERATING PRINCIPLE....................................................................................................................................................3 6. ELECTRICAL SPECIFICATIONS................................................................................................................................... 4 7. END................................................................................................................................................................................................. 5 1. SCOPE This Specification applies to STX series Thermal Fuses. 1.1General Information  Designed to EN 60691 (73℃ – 216℃)  RoHS compliant and HF 2. Agency Approvals Agency Agency File Number TUV R 50458082 3. Part Numbering System ST X 142 Rated functioning temperature is 142 ℃ S:Rated Current 10A T: Rated Current 15A ST:Sante’s Brand 4. MECHANICAL SPECIFICATIONS 5. Operating Principle Loaded the metal shell with movable electrode ,spring and heat-variable fusion cake for RY series thermal fuse. Spring B is encased into it on the state of compression, that’s can make spring B use copper backing to stand up to movable electrode in order to contact with lead A. In the state of normal times, current will be connect with lead B through lead A, movable electrode and metal shell
10A240℃250V 价格&库存
很抱歉,暂时无法提供与“10A240℃250V”相匹配的价格&库存,您可以联系我们找货
