49S-4.9152-30-10-10/B
    LIMING(利明)
    HC49S
    无源晶振 4.9152MHz ±20ppm 30pF -40℃~+85℃
49S-4.9152-30-10-10/B 数据手册
RoHS Compliant APPROVAL SHEET Issued No. : DESCRIPTION : NOMINAL FREQ. : 4.9152MHz TAITIEN P/N : TAITIEN MODEL : 49S-4.9152-30-10-10/B REVISION : 1 DATE : 07/11/2017 DIP 11.1*4.68 METAL CAN CRYSTAL QA Checked CUSTOMER : CUSTOMER P/N : Prepared Customer Signature Approved: Date: Page 1 REVISION HISTORY Rev. 01 Revised Page N/A Revision Content InitialReleased Date 06/03/2017 Ref. No. N/A Reviser YU PING MA Please note that placing order with Taitien constitutes acknowledgement that you have read and agree to Taitien’s Terms and Conditions. Please refer to our website for more details. Thank you for choosing Taitien! Remedies and Limitation of Liability: BUYER’S SOLE AND EXCLUSIVE REMEDY AND TAITIEN’S SOLE LIABILITY, WITH RESPECT TO ANY BREACH OF WARRANTY, SHALL BE AT TAITIEN’S OPTION: (A) REPAIR OR REPLACEMENT OF THE DEFECTIVE OR NONCONFORMING CRYSTALS OR (B) REFUND OF BUYER’S PURCHASE PRICE FOR THE DEFECTIVE OR NONCONFORMING CRYSTALS. IN NO EVENT SHALL TAITIEN’S TOTAL LIABILITY FOR ANY AND ALL LOSSES AND DAMAGES ARISING OUT OF ANY CAUSE (INCLUDING, BUT NOT LIMITED TO, CONTRACT, NEGLIGENCE, STRICT LIABILITY OR OTHER TORT) EXCEED THE PURCHASE COST OF THE CRYSTALS. IN NO EVENT SHALL TAITIEN BE LIABLE FOR ANY INCIDENTAL, CONSEQUENTIAL OR PUNITIVE DAMAGES. Page 2 CONTENT SPECIFICATIONS ELECTRICAL SPECIFICATIONS PAGE 4~5 PRODUCT DIMENSIONS 6 PRODUCT IDENTIFICATION (MARKING) 6 PACKAGE INFORMATION 7 Page 3 ELECTRICAL SPECIFICATIONS Parameter 1-1 Nominal Frequency 1-2 Frequency Tolerance. Min. Typ. Max. 4.9152 -10 Units MHz +10 ppm 1-3 Operating Temperature range -40 +85 o 1-4 Storage Temperature range -55 +125 o 1-5 Temperature Characteristics -30 +30 1-6 Nominal Load Capacitance 1-7 Series Resistance 35 Ω 1-8 Shunt Capacitance 7 pF 1-9 Motion Capacitance 1-10 Motion Inductance 1-11 Q factor K 1-12 Spurious Response dB 1-13 Frequency Pull ability 1-14 C0/C1 Ratio 1-15 Aging 1-16 Insulation Resistance 500MΩ Min. @ DC100V 1-17 Nominal Drive Level 10 1-18 Dependency Condition 1-19 1-20 1-21 Drive Level Dependency Resistance Max. Minus Min. Drive Level Dependency Frequency Max. Minus Min. Drive Level Dependency Resistance Max. Test Condition 30 C C ppm at 25℃+/-2℃ -40℃ to +85℃ pF fF mH ppm/pF -5 +5 ppm/year μw μw into 40Ω Ω ppm Ω Page 4 CUSTOMER SPECIAL REQUIREMENT 2 ENVIRONMENTAL Parameter 3-1 Vibration Test 3-2 Thermal Shock 3-3 Mechanical Shock Reference Std. Test Condition MIL-STD-883 2007 Condition A 10~2000Hz, 1.52mm, 20g, each JESD22-B103 Condition 1 axis for 4 hrs MIL-STD-883 1010 Condition B -55℃, 125℃; soak time is 10 JESD22-A104 Condition B mins, with total 200 cycles MIL-STD-883 2002 Condition B 1500G, half-sine, 0.5ms, each JESD22-B104 Condition B axis for 3 times. Page 5 PRODUCT DIMENSIONS DIMENSIONS LEAD SIZE: L(mm) 13.2+/-1 7.5+/-1 3.6+/-0.2 3.8+/-0.3 4.5+/-0.5 16.0+/-1 4.0+/-0.5 Refer tp SPEC. Sheet PRODUCT IDENTIFICATION (MARKING) PROCEDURE: LASER FOR EXAMPLE: Page 6 PACKAGE INFORMATION Page 7
49S-4.9152-30-10-10/B 价格&库存
很抱歉,暂时无法提供与“49S-4.9152-30-10-10/B”相匹配的价格&库存,您可以联系我们找货
