2.5 x 2.0 mm SMD Crystal
FEATURE
- Typical 2.5 x 2.0 x 0.45 mm ultra thin ceramic package.
- 8 mm width Tape & Reel package for automatic assembly.
- Tight tolerance 10 ppm available.
T YPICAL APPLICATION
- Bluetooth , Mobile phone, Wireless LAN.
- Office Automation
- Audio & Video
XY
DIMENSION (mm)
SOLDER PAD L AYOUT (mm)
[ TOP VIEW ]
2.55±0.20
GND
#4
#3
2.05±0.20
1.62
#1
GND
1.10
1.60
#2 and #4 are connected to the cover
(please connect to ground)
#3
0.55±0.10
#4
#2
#2
1.25±0.10
[ BOTTOM VIEW ]
1.62±0.10
#1
0.45±0.10
[ SIDE VIEW ]
1.20
0.72±0.10
ELECTRICAL SPECIFICATION
Parameter
Min.
Storage Temp. Range
Standard Frequency
Level of Drive
Shunt Capacitance (Co)
Insulation Resistance
Aging
Typical
-40
500 MΩ@ DC100V
Max.
16, 24, 26, 40
10
±1.0 to ± 3.0
Unit
125
MHz
µw
pF
200
3.0
ppm / year
Standard frequencies are frequencies which the crystal has been designed and does not imply a stock position.
EQUIVALENT SERIES RESISTANCE (E. S. R.)
Frequency Range
12 MHz Fo < 20 MHz
20 MHz Fo 30 MHz
30 MHz < Fo 54 MHz
FREQ. STABILITY vs. TEMP. RANGE
Temp. ( o C)
ppm
±5
±10
MODE
E.S.R
A1
A1
A1
很抱歉,暂时无法提供与“2520-25-8-10-10/A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.90072
- 50+0.71205
- 150+0.61766
