3225-25.00-10-10-10/A 数据手册
3.2×2.5×0.7mm typ
12MHz up to 60MHz
Feature
A small surface mount type crystal unit,especially suited for
small-sizing requirements.
Ultra compact and thin.(3.2×2.5×0.7 mm typ.)
Tight Tolerance 10ppm available.
Application:Bluetooth ;Mobile phone;W-LAN;Office Automation;
Audio & Visual.
Meets the requirements for re-flow profiling using lead-free solder.
Specifications
Type
Item
TX3-Type
12~13MHz
13~19.5MHz
19.5~27MHz
27~60MHz
Fundamental
Series,6~32pf,or speecify
10μW(200μW max.)
±10×10-6,±20×10-6,±30×10-6,±50×10 -6 (at 25°C)
150 Ω max.
80 Ω max.
60 Ω max.
50 Ω max.
-10~+60°C, -20~+70°C, -40~+85°C
-55~+125°C
3000pcs/reel(Ø180)
Frequency Range
Oscillator Mode
Load Capacitance
Drive Level
Frequency Tolerance
Series Resistance
Operating Temperature Range
Storage Temperature Range
Packing Unit
Outline Drawing(mm)
3.20±0.20
[TOP VIEW]
Internal connections
#3
2.50±0.20
GND #4
#2 GND
#1
[SIDE VIEW]
0.70±0.20
* # 2 and #4 are connected with
metal cap. Of top.
Solder Pad Layout
[BOTTOM VIEW]
#1
#4
1.10
0.90±0.10
1.60
1.50±0.10
#2
#3
0.90±0.10
1.20
2.20
2.10±0.10
Frequency Stability Vs. Temperature Range
±30
±50
Conditional
Available
±20
-40 ~ +105
-40 ~ +125
±15
PPm
±15
Temp.(°C)
±10
-10 ~ +60
-20 ~ +70
-40 ~ +85
±5
PPm
Temp.(°C)
Not Available
Oscillation Circuit of Fundamental Mode
RF
R
C1
Crystal
C2
CL=
C1*C2
C1+C2
+3~5pf
①
②
③
④
1612
2016
2520
3225
5032
6035
3225
5032
8045
49S
49MD
⑤
B
产 品编号 :
① ② ③ ④ ⑤
① 型号
② 频率
③ 负载电容 ④ 频率稳定度(X10- 6 ,+25℃)
范例: 3225 -12.00-20-20-20/A
① ② ③ ④ ⑤
⑤温度
3225-25.00-10-10-10/A 价格&库存
很抱歉,暂时无法提供与“3225-25.00-10-10-10/A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.66809
- 50+0.52812
- 150+0.45814
- 500+0.40565
