C10892 GT3-RE-M
C10892 GT3-RE-M
    LEDIL(芬兰)
    LEDIL  C10892 GT3-RE-M  LED Lens, 3 LED Optic, Spot, 35 mm, Round, PMMA (Polymethylmethacrylate)
C10892 GT3-RE-M 数据手册
PRODUCT DATASHEET Gt3 series Ordering number C10891 Description C10891_GT3-RE-S Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Gt3 Lens Luxeon-Rebel Transparent 35 mm 9 mm Round PMMA Ready FWHM Efficiency cd/lm Gerber File 16 degrees Available FWHM Efficiency cd/lm Gerber File 28 degrees Available FWHM Efficiency cd/lm Gerber File 38 degrees Available Ordering number C10892 Description C10892_GT3-RE-M Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Gt3 Lens Luxeon-Rebel Transparent 35 mm 9 mm Round PMMA Glue, pin Ready Ordering number C10893 Description C10893_GT3-RE-W Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Gt3 Lens Luxeon-Rebel Transparent 35 mm 9 mm Round PMMA Ready NOTE: The typical divergence will be changed by different color, chip size and chip position tolerance. The typical total divergence is the full angle measured where the luminous intensity is half of the peak value. August 22nd 2011 10:40 Copyright Ledil Oy - Subject to change without prior notice - Page 1/3 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 PRODUCT DATASHEET Gt3 series GENERAL INFORMATION - Product series especially designed & optimized for Luxeon-Rebel series of LEDs. - Special care taken to make light distribution as uniform as possible. - Lens material optical grade PMMA with high UV and temperature resistance (105 degrees of Celcius / 220 degrees of Fahrenheit). Allows use of high current and temperature conditions. Please find more information about used material from below: http://ledil.fi/sites/default/files/Documents/Technical/Material/PMMA%208N%20UL94_Yellow%20Card.pdf http://ledil.fi/sites/default/files/Documents/Technical/Material/PMMA%208N%20PLEXIGLAS-Datasheet.pdf - Fastening to PCB with appropriate adhesive. By clicking link below you can find Ledil recommended glue options. http://www.ledil.com/datasheets/DataSheet_GLUES.pdf NOTE 1: We advise customer to ensure the suitability and sufficiency of the bond in the end product. For example, mechanical stress, vibration and holes on the surface of the circuit boar weaken the strength of the glue. NOTE 2: All surfaces where glue is applied must be clean, dry and free from grease and dirt. If cleaning of PCB surfaces is needed, please follow strictly the cleaning instructions of your LED manufacturer -this is important as cleaning shall under no circumstances damage LEDs or other electronics components on the PCB. Further note that optical components shall not be cleaned with any chemicals - only micro fiber cloth may be used to remove fingerprints or other traces from handling. August 22nd 2011 10:40 Copyright Ledil Oy - Subject to change without prior notice - Page 2/3 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 PRODUCT DATASHEET Gt3 series C10891 C10892 C10893 August 22nd 2011 10:40 Copyright Ledil Oy - Subject to change without prior notice - Page 3/3 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 Relative intensity of C11624-GT3-RE-WW 100% 75% 50% 25% 0% 60 50 40 30 20 10 0 -10 -20 -30 -40 -50 -60 Relative intensity of C10891_GT3-RE-S 100% 75% 50% 25% 0% 70 60 50 40 30 20 10 0 -10 -20 -30 -40 -50 -60 -70 A B C D 28 4 4 17 Isometric view Scale: 1:1 3 Bottom view 60 35 2.2 3 This drawing is our property. It can't be reproduced or communicated without our written agreement. 1 30.35 DRAWN BY DATE Front view CHECKED BY DATE tk 07.01.2010 hh DATE 07.01.2010 D 2 Led Teh FIN Fin DRAWING TITLE pv 08.01.2010 DESIGNED BY 8.9 60 6.9 1.8 Part no.s: C10891_GT3-XP-S C10891_GT3-XP-G-S C10891_GT3-OSL-S C10891_GT3-DD-S C10891_GT3-RE-ES-M C10891_GT3-Z5-S C10892_GT3-XP-M C10892_GT3-XP-G-M C10892_GT3-OSL-M C10892_GT3-DD-M C10892_GT3-XP-M C10892_GT3-Z5-M C10893_GT3-XP-W C10893_GT3-XP-G-W C10893_GT3-OSL-W C10893_GT3-DD-W C10893_GT3-RE-ES-W C11623_GT3-RE-WW C11623_GT3-N19-WW C11624_GT3-XP-WW C11624_GT3-XP-G-WW C11624_GT3-OSL-WW C11624_GT3-DD-WW C11624_GT3-Z5-WW 1.45 2 3 Material: PMMA SIZE Datasheet GT3-Series Lens DRAWING NUMBER A4 SCALE 2:1 WEIGHT(g) REV - 1 SHEET A 1/1 1
C10892 GT3-RE-M 价格&库存
很抱歉,暂时无法提供与“C10892 GT3-RE-M”相匹配的价格&库存,您可以联系我们找货
