C11714_ANNA-40-5-M-XP
    LEDIL(芬兰)
C11714_ANNA-40-5-M-XP 数据手册
PRODUCT DATASHEET Anna-40-5 series last update 4/6/2012 Ordering number C11714_ANNA-40-5-M Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Anna-40-5 Lens array XB-D Clear 40 mm 10.7 mm Round PMMA Pin, glue On production FWHM Efficiency cd/lm Gerber File 22 degrees 87 % 3.450 Available FWHM Efficiency cd/lm Gerber File 29 degrees 85 % 2.170 Available Ordering number C11715_ANNA-40-5-W Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Anna-40-5 Lens array XB-D Clear 40 mm 10.7 mm Round PMMA Pin, glue On production NOTE: The typical divergence will be changed by different color, chip size and chip position tolerance. The typical total divergence is the full angle measured where the luminous intensity is half of the peak value. October 28th 2013 10:50 Copyright Ledil Oy - Subject to change without prior notice - Page 1/2 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 PRODUCT DATASHEET Anna-40-5 series last update 4/6/2012 GENERAL INFORMATION - Product series especially designed & optimized for XB-D series of LEDs. - Special care taken to make light distribution as uniform as possible. - Lens material optical grade PMMA with high UV and temperature resistance. Allows use of high current and temperature conditions. Please find more information about used material from below: http://ledil.fi/sites/default/files/Documents/Technical/Material/PMMA%208N%20UL94_Yellow%20Card.pdf http://ledil.fi/sites/default/files/Documents/Technical/Material/PMMA%208N%20PLEXIGLAS-Datasheet.pdf October 28th 2013 10:50 Copyright Ledil Oy - Subject to change without prior notice - Page 2/2 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 A B C D 2.8 10.7 Anna-3 4 4 Anna-4 Anna-7 39. 9 Anna-5 1.5 3 Same top side in all versions 3 0.8 Anna-6 2 1 Versions: Anna-3-S Anna-3-M Anna-3-W Anna-4-S Anna-4-M Anna-4-W Anna-5-S Anna-5-M Anna-5-W Anna-6-S Anna-6-M Anna-6-W Anna-7-S Anna-7-M Anna-7-M2 Anna-7-W 2 25. 1 ah DATE CHECKED BY DATE pv 8.12.2011 DESIGNED BY DATE 30.07.2010 D 2 Same led-circle in all versions Ledil Oy Salorankau 10 FIN-24100 SALO Finland DRAWING TITLE Datasheet Anna40-series Lens 8.12.2011 hh 8 Number of cones varies; 3, 4, 5, 6 and 7pcs on bottom side depending the version. This drawing is our property. It can't be reproduced or communicated without our written agreement. DRAWN BY 30 Same location pin-circle in all versions 5 60 Material: PMMA SIZE A4 SCALE DRAWING NUMBER REV Anna-40 1:1 WEIGHT(g) 4 SHEET A 1/1 1
C11714_ANNA-40-5-M-XP 价格&库存
很抱歉,暂时无法提供与“C11714_ANNA-40-5-M-XP”相匹配的价格&库存,您可以联系我们找货
