C17434_ILONA-WW
C17434_ILONA-WW
    LEDIL(芬兰)
    仅透镜,需固定座 透明 55° 宽型 卡入式
C17434_ILONA-WW 数据手册
PRODUCT DATASHEET C17434_ILONA-WW ILONA-WW ~55° wide beam SPECIFICATION: Dimensions Height Ø 49.7 mm 29.4 mm Fastening socket ROHS compliant yes MATERIALS: Component Type Material Colour ILONA-WW Single lens PMMA clear Finish Length 49.7 ORDERING INFORMATION: Component C17434_ILONA-WW » Box size: 480 x 280 x 300 mm Qty in box 264 MOQ MPQ 99 33 Box weight (kg) 9.2 Last update: 13/05/2024 Subject to change without prior notice Published: 20/05/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 1/15 PRODUCT DATASHEET C17434_ILONA-WW See also our general installation guide: www.ledil.com/installation_guide Last update: 13/05/2024 Subject to change without prior notice Published: 20/05/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/15 PRODUCT DATASHEET C17434_ILONA-WW OPTICAL RESULTS (MEASURED): LED V11 HD Gen 8 FWHM / FWTM 45.0° / 77.0° Efficiency 93 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: Bender Wirth: 633d Hekla LED V6 HD Gen 7 FWHM / FWTM 50.0° / 74.0° Efficiency 94 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: Bender Wirth: 634c Hekla LED V6 HD Gen 7 FWHM / FWTM 54.0° / 78.0° Efficiency 95 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: F15255_HEKLA-SOCKET-C Last update: 13/05/2024 Subject to change without prior notice Published: 20/05/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/15 PRODUCT DATASHEET C17434_ILONA-WW OPTICAL RESULTS (MEASURED): LED Vesta DTW 13mm (21W) FWHM / FWTM 42.0° / 78.0° Efficiency 90 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type Tunable White Required components: C16142_HEKLA-SOCKET-K Bender Wirth: 491 Typ L8 LED Vesta TW 6mm DP FWHM / FWTM 50.0° / 73.0° Efficiency 91 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: C16142_HEKLA-SOCKET-K Bender Wirth: 504 Typ L8 LED LC010T (Tunable White) FWHM / FWTM 46.0° / 75.0° Efficiency 94 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour/type Tunable White Required components: C16142_HEKLA-SOCKET-K Bender Wirth: 501 Typ L8 Last update: 13/05/2024 Subject to change without prior notice Published: 20/05/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/15 PRODUCT DATASHEET C17434_ILONA-WW OPTICAL RESULTS (MEASURED): LED MJT COB LES 14.5 FWHM / FWTM 45.0° / 84.0° Efficiency 92 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: F17438_HEKLA-G2-I LED MJT COB LES 6 FWHM / FWTM 55.0° / 79.0° Efficiency 95 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: F17435_HEKLA-G2-C LED MJT COB LES 9.8 FWHM / FWTM 49.0° / 79.0° Efficiency 95 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: F17435_HEKLA-G2-C Last update: 13/05/2024 Subject to change without prior notice Published: 20/05/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/15 PRODUCT DATASHEET C17434_ILONA-WW OPTICAL RESULTS (MEASURED): LED SLE G7 LES09 FWHM / FWTM 50.0° / 79.0° Efficiency 95 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: F15255_HEKLA-SOCKET-C Last update: 13/05/2024 Subject to change without prior notice Published: 20/05/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/15 PRODUCT DATASHEET C17434_ILONA-WW OPTICAL RESULTS (SIMULATED): LED V13 Gen 8-9 FWHM / FWTM 47.0° / 83.0° Efficiency 88 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: F15859_HEKLA-SOCKET-I LED V4 HD Gen 7 FWHM / FWTM 58.0° / 78.0° Efficiency 85 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: F15253_HEKLA-SOCKET-A LED V6 HD Gen 7 FWHM / FWTM 57.0° / 79.0° Efficiency 84 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: F15255_HEKLA-SOCKET-C Last update: 13/05/2024 Subject to change without prior notice Published: 20/05/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/15 PRODUCT DATASHEET C17434_ILONA-WW OPTICAL RESULTS (SIMULATED): LED V9 HD Gen 8 FWHM / FWTM 52.0° / 78.0° Efficiency 91 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: Bender Wirth: 633d Hekla LED Vero SE 13 FWHM / FWTM 38.0° / 74.0° Efficiency 87 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: C16142_HEKLA-SOCKET-K LED VERO10 FWHM / FWTM 53.0° / 80.0° Efficiency 93 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: F15616_HEKLA-SOCKET-F Last update: 13/05/2024 Subject to change without prior notice Published: 20/05/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/15 PRODUCT DATASHEET C17434_ILONA-WW OPTICAL RESULTS (SIMULATED): LED Vesta DTW 9mm (4W/6W/12W) FWHM / FWTM 52.0° / 78.0° Efficiency 92 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C16142_HEKLA-SOCKET-K Bender Wirth: 490 Typ L8 LED Vesta TW 15mm DP FWHM / FWTM 49.0° / 87.0° Efficiency 87 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED CLL02x/CLU02x (LES10) FWHM / FWTM 52.0° / 80.0° Efficiency 79 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: F15255_HEKLA-SOCKET-C Last update: 13/05/2024 Subject to change without prior notice Published: 20/05/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/15 PRODUCT DATASHEET C17434_ILONA-WW OPTICAL RESULTS (SIMULATED): LED CLU700/701/702/703 FWHM / FWTM 57.0° / 78.0° Efficiency 83 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: F15255_HEKLA-SOCKET-C LED CLU712/713 FWHM / FWTM 54.0° / 82.0° Efficiency 93 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: F17438_HEKLA-G2-I LED CHA0304 FWHM / FWTM 60.0° / 78.0° Efficiency 94 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: F17435_HEKLA-G2-C Last update: 13/05/2024 Subject to change without prior notice Published: 20/05/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 10/15 PRODUCT DATASHEET C17434_ILONA-WW OPTICAL RESULTS (SIMULATED): LED CHA0410 FWHM / FWTM 59.0° / 80.0° Efficiency 94 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: F17435_HEKLA-G2-C LED CMA1825 FWHM / FWTM 52.0° / 84.0° Efficiency 90 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: F15254_HEKLA-SOCKET-B LED LZ4 (00xW00) FWHM / FWTM 59.0° / 78.0° Efficiency 96 % LEDs/each optic 1 Light colour/type IR Required components: F15255_HEKLA-SOCKET-C Last update: 13/05/2024 Subject to change without prior notice Published: 20/05/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 11/15 PRODUCT DATASHEET C17434_ILONA-WW OPTICAL RESULTS (SIMULATED): LED LZ4-00XX08 FWHM / FWTM 52.0° / 70.0° Efficiency 95 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: F15255_HEKLA-SOCKET-C LED COB S-Type (LES 7) FWHM / FWTM 56.0° / 81.0° Efficiency 94 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: F15848_HEKLA-SOCKET-G LED Fortimo SLM L09 CoB FWHM / FWTM 46.0° / 74.0° Efficiency 92 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: F17437_HEKLA-G2-H Last update: 13/05/2024 Subject to change without prior notice Published: 20/05/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 12/15 PRODUCT DATASHEET C17434_ILONA-WW OPTICAL RESULTS (SIMULATED): LED Fortimo SLM L13 CoB FWHM / FWTM 48.0° / 81.0° Efficiency 89 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: Bender Wirth: 632a Hekla XL LED Fortimo SLM L15 CoB FWHM / FWTM 44.0° / 82.0° Efficiency 87 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: Bender Wirth: 632a Hekla XL LED LC003D / LC006D / LC009D / LC013D FWHM / FWTM 51.0° / 79.0° Efficiency 79 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: F15255_HEKLA-SOCKET-C Last update: 13/05/2024 Subject to change without prior notice Published: 20/05/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 13/15 PRODUCT DATASHEET C17434_ILONA-WW OPTICAL RESULTS (SIMULATED): LED LC020T (Tunable white) FWHM / FWTM 52.0° / 84.0° Efficiency 91 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: F15859_HEKLA-SOCKET-I LED XOB 9.8 mm FWHM / FWTM 52.0° / 80.0° Efficiency 91 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: F17435_HEKLA-G2-C LED XTM - 9mm LES FWHM / FWTM 54.0° / 82.0° Efficiency 93 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C15743_XTM-ADAPTER-50-B Last update: 13/05/2024 Subject to change without prior notice Published: 20/05/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 14/15 PRODUCT DATASHEET C17434_ILONA-WW GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. Due to use of high power COB's with this product, special attention to proper thermal design is highly recommended. LEDiL has no liability for direct, indirect or consecutive damages arising from the LEDiL products being used outside of the recommended temperature range. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Poznan, Poland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 13/05/2024 Subject to change without prior notice Published: 20/05/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 15/15
C17434_ILONA-WW 价格&库存
很抱歉,暂时无法提供与“C17434_ILONA-WW”相匹配的价格&库存,您可以联系我们找货
C17434_ILONA-WW
    • 1+64.00345
    • 9+62.58716
    • 17+61.24378
    库存:50
    C17434_ILONA-WW
    • 1+82.788811+10.70827
    • 33+56.5583333+7.31550
    • 132+50.83085132+6.57468
    • 528+46.72160528+6.04318
    • 1023+45.196171023+5.84587
    库存:285
    C17434_ILONA-WW
      C17434_ILONA-WW
        C17434_ILONA-WW
        • 33+53.69791
        • 66+52.62321
        • 132+51.04551
        库存:50
        C17434_ILONA-WW
