CA10932_FLARE-B-XP-TAPE
    LEDIL(芬兰)
CA10932_FLARE-B-XP-TAPE 数据手册
LEDIL F’FORM OPTICS Flare-B-XP lens for Cree XP-E/C series of LEDs Flare-B-XP - - Lens designed for Cree’s XP-E series of LEDs Lens material optical grade PMMA with high UV and temperature resistance (105°C/220°F). Allows use of high current and temperature conditions Best available optical efficiency Fastening to PCB & heat sink with 2 screws (C10946_Flare-B-XP) or very easy assembly with TAPE LED can be assembled parallel or perpendicular to the x,y axis (to turn the light distribution by 90°) Compact dimensions 23 x 25 mm. Square form enables easy build of a line without any gaps between lenses. Especially suitable for Beacon and other 360°° solutions and in linear solutions with high evenness requirements NAME ORDERING CODE Flare-B-XP LENS Flare-B-XP LENS+ TAPE C10946_Flare-B-XP CA10932_Flare-B-XP-tape FWHM Angle ±6° x ±48° ±6° x ±48° © Ledil Oy - Subject to change without prior notice Ledil Oy Tehdaskatu 13 FIN-24100 SALO, Finland www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 2009-11-28 LEDIL F’FORM OPTICS MEASUREMENTS Relative Intensity of C10946_Flare-B-XP 100% 75% 50% 25% 0% 80 70 60 50 40 30 20 10 0 -10 -20 -30 -40 -50 -60 -70 -80 © Ledil Oy - Subject to change without prior notice Ledil Oy Tehdaskatu 13 FIN-24100 SALO, Finland www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 2009-11-28 LEDIL F’FORM OPTICS DRAWINGS © Ledil Oy - Subject to change without prior notice Ledil Oy Tehdaskatu 13 FIN-24100 SALO, Finland www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 2009-11-28
CA10932_FLARE-B-XP-TAPE 价格&库存
很抱歉,暂时无法提供与“CA10932_FLARE-B-XP-TAPE”相匹配的价格&库存,您可以联系我们找货
