CA12163_LENA-M_CXA20 数据手册
PRODUCT DATASHEET
Lena-CXA20 series
Ordering number CA12106
Description
CA12106_Lena-S_CXA20
Family
Type
LED
Color
Diameter
Height
Style
Optic Material
Holder Material
Fastening
Status
Lena
Reflector
CXA20
Metal
111 mm
87 mm
Round
PC
PC
Screw
Ready
FWHM
Efficiency
cd/lm
Gerber File
10.5 degrees
Available
FWHM
Efficiency
cd/lm
Gerber File
17 degrees
5.700
Available
FWHM
Efficiency
cd/lm
Gerber File
41 degrees
Available
Ordering number CA12163
Description
CA12163_Lena-M_CXA20
Family
Type
LED
Color
Diameter
Height
Style
Optic Material
Holder Material
Fastening
Status
Lena
Reflector
CXA20
Metal
111 mm
87 mm
Round
PC
PC
Screw
Ready
Ordering number CA12108
Description
CA12108_Lena-W_CXA20
Family
Type
LED
Color
Diameter
Height
Style
Optic Material
Holder Material
Fastening
Status
Lena
Reflector
CXA20
Metal
111 mm
87 mm
Round
PC
PC
Screw
Ready
Ordering number CA12107
Description
CA12107_Lena-S-Diffuser-Lens_CXA20
Family
Type
LED
Color
Diameter
Height
Style
Optic Material
Holder Material
Fastening
Status
Lena
Reflector
CXA20
Metal
111 mm
88.6 mm
Round
PC
PC
Screw
Ready
FWHM
Efficiency
cd/lm
Gerber File
11 degrees
Available
February 13th 2012 16:19 Copyright Ledil Oy - Subject to change without prior notice - Page 1/3
Ledil Oy
Salorankatu 10
24240 SALO
Finland
http://www.ledil.com
email: ledil@ledil.com
FAX: +358-2-733 8001
PRODUCT DATASHEET
Lena-CXA20 series
Ordering number CA12167
Description
CA12167_Lena-M-Diffuser-Lens_CXA20
Family
Type
LED
Color
Diameter
Height
Style
Optic Material
Holder Material
Fastening
Status
Lena
Reflector
CXA20
Metal
111 mm
88.6 mm
Round
PC
PC
Screw
Ready
FWHM
Efficiency
cd/lm
Gerber File
19 degrees
4.100
Available
Ordering number CA12109
Description
CA12109_Lena-W-Diffuser-Lens_CXA20
Family
Type
LED
Color
Diameter
Height
Style
Optic Material
Holder Material
Fastening
Status
Lena
Reflector
CXA20
Metal
111 mm
88.6 mm
Round
PC
PC
Screw
Ready
FWHM
Efficiency
cd/lm
Gerber File
42 degrees
Available
NOTE: The typical divergence will be changed by different color, chip size and chip position
tolerance. The typical total divergence is the full angle measured where the luminous intensity
is half of the peak value.
February 13th 2012 16:19 Copyright Ledil Oy - Subject to change without prior notice - Page 2/3
Ledil Oy
Salorankatu 10
24240 SALO
Finland
PRODUCT DATASHEET
Lena-CXA20 series
GENERAL INFORMATION
- Product series especially designed & optimized for CXA20 series of LEDs.
- Special care taken to make light distribution as uniform as possible.
- Lens material optical grade PC with high UV and temperature resistance (120 degrees of Celcius / 248
degrees of Fahrenheit). Allows use of high current and temperature conditions.
Please find more information about used materials from below:
http://ledil.fi/sites/default/files/Documents/Technical/Material/PC%20Makrolon%202400_2407_2456_2458-UL
.pdf
- Reflector is made of aluminium coated PC (120 degrees of Celcius / 248 degrees of Fahrenheit) with
protective lacquer (110 degrees of Celcius / 230 degrees of Fahrenheit).
- Optic holder molded by high quality PC material (120 dergees of Celcius / 248 degrees of Fahrenheit).
February 13th 2012 16:19 Copyright Ledil Oy - Subject to change without prior notice - Page 3/3
Ledil Oy
Salorankatu 10
24240 SALO
Finland
A
B
D
C
4
2
3.
4
4
3.
2
4
17
A
Base part
Isometric view
43
Lena_reflector
3
88.6
87
Detail A
Scale: 1:1
w/o sublens
3
Lena_sublens
Lena-STD-base_CXA20
11
2
Material:
1
subLens
- PMMA
2
Reflector
- PC
- Metal coating and clear lacquer
Holder base
- PC
- Color white
1
This drawing is our property.
It can't be reproduced
or communicated without
our written agreement.
DRAWN BY
DATE
CHECKED BY
DATE
DESIGNED BY
DATE
Led
Teh
FIN
Fin
DRAWING TITLE
pv
26.05.2011
pl
26.05.2011
pl
11.02.2011
D
SIZE
Datasheet Lena-CXA20 series Assy
DRAWING NUMBER
REV
1
A4
SCALE
1:2 WEIGHT(g)
SHEET
A
1/1
1
CA12163_LENA-M_CXA20 价格&库存
很抱歉,暂时无法提供与“CA12163_LENA-M_CXA20”相匹配的价格&库存,您可以联系我们找货
