CA12949_HEIDI-O
CA12949_HEIDI-O
    LEDIL(芬兰)
CA12949_HEIDI-O 数据手册
PRODUCT DATASHEET CA12949_HEIDI-O HEIDI-O ~50° x 11° oval beam SPECIFICATION: Dimensions Ø 21.6 mm Height 11.7 mm Fastening tape, pin ROHS compliant yes MATERIALS: Component Type Material Colour HEIDI-O Single lens PMMA clear HEIDI-TAPE Tape Acrylic foam black Finish Length 21.6 ORDERING INFORMATION: Component CA12949_HEIDI-O » Box size: 480 x 280 x 300 mm Single lens Qty in box MOQ MPQ 3264 204 204 Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. Box weight (kg) 11.1 1/12 PRODUCT DATASHEET CA12949_HEIDI-O See also our general installation guide: www.ledil.com/installation_guide Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/12 PRODUCT DATASHEET CA12949_HEIDI-O OPTICAL RESULTS (MEASURED): LED XHP35 HD FWHM / FWTM 51.0 + 18.0° / 84.0 + 50.0° Efficiency 77 % Peak intensity 2.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XHP35 HI FWHM / FWTM 53.0 + 14.0° / 80.0 + 40.0° Efficiency 79 % Peak intensity 3 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XP-G2 FWHM / FWTM 52.0 + 12.0° / 78.0 + 33.0° Efficiency 91 % Peak intensity 3.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/12 PRODUCT DATASHEET CA12949_HEIDI-O OPTICAL RESULTS (MEASURED): LED XP-G3 FWHM / FWTM 51.0 + 14.0° / 79.0 + 39.0° Efficiency 90 % Peak intensity 2.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XP-G4 FWHM / FWTM 54.0 + 11.5° / 77.0 + 31.0° Efficiency 92 % Peak intensity 3.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XP-L HD FWHM / FWTM 52.0 + 16.0° / 79.0 + 41.0° Efficiency 81 % Peak intensity 2.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/12 PRODUCT DATASHEET CA12949_HEIDI-O OPTICAL RESULTS (MEASURED): LED LUXEON Rebel ES FWHM / FWTM 53.0 + 12.0° / 76.0 + 33.0° Efficiency 82 % Peak intensity 3.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED SST-10-B130 FWHM / FWTM 54.0 + 9.5° / 77.0 + 28.0° Efficiency 90 % Peak intensity 3.8 cd/lm LEDs/each optic 1 Light colour/type Blue Required components: LED NVSW219D FWHM / FWTM 51.0 + 13.0° / 78.0 + 40.0° Efficiency 91 % Peak intensity 2.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/12 PRODUCT DATASHEET CA12949_HEIDI-O OPTICAL RESULTS (MEASURED): LED NVSW319B FWHM / FWTM 51.0 + 15.0° / 80.0 + 38.0° Efficiency 91 % Peak intensity 2.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED NVSW3x9A FWHM / FWTM 51.0 + 15.0° / 80.0 + 39.0° Efficiency 89 % Peak intensity 2.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED NVSW519A FWHM / FWTM 50.0 + 18.0° / 81.0 + 44.0° Efficiency 87 % Peak intensity 2.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/12 PRODUCT DATASHEET CA12949_HEIDI-O OPTICAL RESULTS (MEASURED): LED NWSx229A FWHM / FWTM 50.0 + 18.0° / 80.0 + 44.0° Efficiency 76 % Peak intensity 2.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED Z5M3 FWHM / FWTM 52.0 + 13.0° / 79.0 + 39.0° Efficiency 92 % Peak intensity 2.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED Z8Y22P FWHM / FWTM 52.0 + 14.0° / 79.0 + 39.0° Efficiency 90 % Peak intensity 2.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/12 PRODUCT DATASHEET CA12949_HEIDI-O OPTICAL RESULTS (SIMULATED): LED XP-G2 HE FWHM / FWTM 50.0 + 14.0° / 78.0 + 35.0° Efficiency 88 % Peak intensity 3 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON A FWHM / FWTM 51.0 + 12.0° / 76.0 + 30.0° Efficiency 84 % Peak intensity 3.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON HL2Z FWHM / FWTM 54.0 + 10.0° / 76.0 + 28.0° Efficiency 89 % Peak intensity 3.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/12 PRODUCT DATASHEET CA12949_HEIDI-O OPTICAL RESULTS (SIMULATED): LED LUXEON R FWHM / FWTM 53.0 + 12.0° Efficiency % LEDs/each optic 1 Light colour/type White Required components: LED LUXEON SunPlus 20 Line (120 deg) FWHM / FWTM 52.0 + 9.0° / 76.0 + 22.0° Efficiency 91 % Peak intensity 4.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON SunPlus 20 Line (150 deg) FWHM / FWTM 52.0 + 10.0° / 76.0 + 20.0° Efficiency 87 % Peak intensity 4.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/12 PRODUCT DATASHEET CA12949_HEIDI-O OPTICAL RESULTS (SIMULATED): LED NCSxE17A FWHM / FWTM 54.0 + 24.0° / 180.0 + 54.0° Efficiency 81 % Peak intensity 1.5 cd/lm LEDs/each optic 4 Light colour/type White Required components: LED OSLON Black FWHM / FWTM 53.0 + 9.0° / 54.0 + 23.0° Efficiency 88 % Peak intensity 4 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSLON Black Flat (LUW HWQP) FWHM / FWTM 54.0 + 8.0° / 74.0 + 18.0° Efficiency 89 % Peak intensity 4.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 10/12 PRODUCT DATASHEET CA12949_HEIDI-O OPTICAL RESULTS (SIMULATED): LED OSLON Pure 1414 FWHM / FWTM 52.0 + 8.0° / 74.0 + 17.0° Efficiency 93 % Peak intensity 5.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 11/12 PRODUCT DATASHEET CA12949_HEIDI-O GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Poznan, Poland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 12/12
CA12949_HEIDI-O 价格&库存
很抱歉,暂时无法提供与“CA12949_HEIDI-O”相匹配的价格&库存,您可以联系我们找货
