CA14442_VERONICA-SQ-W
    LEDIL(芬兰)
    LENSASSY1POS22.5MMSQCLEAR
CA14442_VERONICA-SQ-W 数据手册
PRODUCT DATASHEET CA14442_VERONICA-SQ-W VERONICA-SQ-W ~50° wide beam SPECIFICATION: Dimensions Height 22.5 x 22.5 mm 11.8 mm Fastening ROHS compliant tape yes MATERIALS: Component Type Material Colour Finish Length VERONICA-SQ-W Single lens PMMA clear 22.5 VERONICA-TAPE Tape Acrylic foam clear 22.0 ORDERING INFORMATION: Component CA14442_VERONICA-SQ-W » Box size: 476 x 273 x 197 mm Single lens Qty in box MOQ MPQ 1980 360 180 Last update: 14/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. Box weight (kg) 8.8 1/21 PRODUCT DATASHEET CA14442_VERONICA-SQ-W See also our general installation guide: www.ledil.com/installation_guide Last update: 14/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/21 PRODUCT DATASHEET CA14442_VERONICA-SQ-W OPTICAL RESULTS (MEASURED): LED XB-H FWHM / FWTM 50.0° / 90.0° Efficiency 80 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XHP35 HD FWHM / FWTM 52.0° / 92.0° Efficiency 78 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XHP35 HI FWHM / FWTM 49.0° / 86.0° Efficiency 81 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 14/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/21 PRODUCT DATASHEET CA14442_VERONICA-SQ-W OPTICAL RESULTS (MEASURED): LED XHP50.2 FWHM / FWTM 47.0° / 89.0° Efficiency 86 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XM-L FWHM / FWTM 53.0° / 90.0° Efficiency 81 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XM-L2 FWHM / FWTM 53.0° / 91.0° Efficiency 80 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 14/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/21 PRODUCT DATASHEET CA14442_VERONICA-SQ-W OPTICAL RESULTS (MEASURED): LED XM-L3 FWHM / FWTM 52.0° / 90.0° Efficiency 87 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XP-E FWHM / FWTM 51.0° / 88.0° Efficiency 81 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XP-E2 FWHM / FWTM 52.0° / 94.0° Efficiency 92 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 14/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/21 PRODUCT DATASHEET CA14442_VERONICA-SQ-W OPTICAL RESULTS (MEASURED): LED XP-G FWHM / FWTM 53.0° / 90.0° Efficiency 81 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XT-E FWHM / FWTM 46.0° / 81.0° Efficiency 80 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON 3030 2D (Round LES) FWHM / FWTM 42.0° / 76.0° Efficiency 83 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 14/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/21 PRODUCT DATASHEET CA14442_VERONICA-SQ-W OPTICAL RESULTS (MEASURED): LED LUXEON 3030 2D (Square LES) FWHM / FWTM 42.0° / 76.0° Efficiency 83 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON 5050 Round LES FWHM / FWTM 41.0° / 77.0° Efficiency 90 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON A FWHM / FWTM 50.0° / 86.0° Efficiency 79 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 14/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/21 PRODUCT DATASHEET CA14442_VERONICA-SQ-W OPTICAL RESULTS (MEASURED): LED LUXEON MZ FWHM / FWTM 41.0° / 75.0° Efficiency 83 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON R FWHM / FWTM 48.0° / 85.0° Efficiency 80 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON Rebel ES FWHM / FWTM 46.0° / 82.0° Efficiency 80 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 14/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/21 PRODUCT DATASHEET CA14442_VERONICA-SQ-W OPTICAL RESULTS (MEASURED): LED LUXEON T FWHM / FWTM 49.0° / 86.0° Efficiency 82 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON TX FWHM / FWTM 48.0° / 85.0° Efficiency 81 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON V FWHM / FWTM 46.0° / 84.0° Efficiency 79 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 14/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/21 PRODUCT DATASHEET CA14442_VERONICA-SQ-W OPTICAL RESULTS (MEASURED): LED LUXEON V2 FWHM / FWTM 47.0° / 85.0° Efficiency 88 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED NCSxx19B FWHM / FWTM 45.0° / 80.0° Efficiency 80 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED NVSW219F FWHM / FWTM 52.0° / 92.0° Efficiency 88 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 14/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 10/21 PRODUCT DATASHEET CA14442_VERONICA-SQ-W OPTICAL RESULTS (MEASURED): LED NVSW3x9A FWHM / FWTM 48.0° / 83.0° Efficiency 78 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED NVSxx19B/NVSxx19C FWHM / FWTM 46.0° / 81.0° Efficiency 81 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED NWSx229A FWHM / FWTM 51.0° / 87.0° Efficiency 78 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 14/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 11/21 PRODUCT DATASHEET CA14442_VERONICA-SQ-W OPTICAL RESULTS (MEASURED): LED OSLON Square EC FWHM / FWTM 48.0° / 86.0° Efficiency 80 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSLON Square PC FWHM / FWTM 48.0° / 87.0° Efficiency 79 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSLON SSL 80 FWHM / FWTM 46.0° / 88.0° Efficiency 80 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 14/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 12/21 PRODUCT DATASHEET CA14442_VERONICA-SQ-W OPTICAL RESULTS (MEASURED): LED LH181A FWHM / FWTM 34.0° / 68.0° Efficiency 87 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LH181B FWHM / FWTM 37.0° / 71.0° Efficiency 90 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED Z5M3 FWHM / FWTM 46.0° / 85.0° Efficiency 88 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 14/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 13/21 PRODUCT DATASHEET CA14442_VERONICA-SQ-W OPTICAL RESULTS (MEASURED): LED Z8Y22P FWHM / FWTM 42.0° / 75.0° Efficiency 78 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED Z8Y50P FWHM / FWTM 42.0° / 77.0° Efficiency 77 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 14/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 14/21 PRODUCT DATASHEET CA14442_VERONICA-SQ-W OPTICAL RESULTS (SIMULATED): LED J Series 5050 Round LES FWHM / FWTM 42.0° / 71.0° Efficiency 94 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED J Series 5050B 6V K Class FWHM / FWTM 42.0° / 72.0° Efficiency 94 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XP-G2 HE FWHM / FWTM 62.0° / 105.0° Efficiency 97 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 14/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 15/21 PRODUCT DATASHEET CA14442_VERONICA-SQ-W OPTICAL RESULTS (SIMULATED): LED XP-G4 HI FWHM / FWTM 53.0 + 54.0° / 96.0 + 97.0° Efficiency 95 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XQ-E HI FWHM / FWTM 52.0° / 91.0° Efficiency 94 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON 7070 FWHM / FWTM 38.0° / 74.0° Efficiency 93 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 14/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 16/21 PRODUCT DATASHEET CA14442_VERONICA-SQ-W OPTICAL RESULTS (SIMULATED): LED LUXEON M/MX FWHM / FWTM 45.0° / 78.0° Efficiency 94 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED NCSxE17A FWHM / FWTM 36.0° / 64.0° Efficiency 91 % Peak intensity 1.8 cd/lm LEDs/each optic 4 Light colour/type White Required components: LED NV4x144A FWHM / FWTM 54.0° / 96.0° Efficiency 89 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 14/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 17/21 PRODUCT DATASHEET CA14442_VERONICA-SQ-W OPTICAL RESULTS (SIMULATED): LED OSCONIQ C 2424 FWHM / FWTM 32.0° / 67.0° Efficiency 94 % Peak intensity 2 cd/lm LEDs/each optic 4 Light colour/type White Required components: LED OSCONIQ P 3030 FWHM / FWTM 48.0° / 81.0° Efficiency 95 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSCONIQ P 7070 FWHM / FWTM 42.0° / 78.0° Efficiency 90 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 14/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 18/21 PRODUCT DATASHEET CA14442_VERONICA-SQ-W OPTICAL RESULTS (SIMULATED): LED OSLON Pure 1414 FWHM / FWTM 50.0° / 98.0 + 97.0° Efficiency 96 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSLON Square CSSRM2/CSSRM3 FWHM / FWTM 50.0° / 90.0° Efficiency 90 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED MJT 3030 FWHM / FWTM 48.0° / 80.0° Efficiency 94 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 14/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 19/21 PRODUCT DATASHEET CA14442_VERONICA-SQ-W OPTICAL RESULTS (SIMULATED): LED Z5M4 FWHM / FWTM 45.0° / 77.0° Efficiency 94 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED Z8Y22T FWHM / FWTM 41.0° / 69.0° Efficiency 94 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 14/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 20/21 PRODUCT DATASHEET CA14442_VERONICA-SQ-W GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Poznan, Poland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 14/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 21/21
CA14442_VERONICA-SQ-W 价格&库存
很抱歉,暂时无法提供与“CA14442_VERONICA-SQ-W”相匹配的价格&库存,您可以联系我们找货
    • 2+24.08395
    • 46+23.55235
    • 90+23.04100
    库存:186
    • 180+9.00501180+1.07670
    • 540+8.81934540+1.05450
    • 900+8.72651900+1.04340
    • 3600+8.494423600+1.01565
    • 5400+8.355175400+0.99900
    库存:180
      • 180+15.02956
      • 360+14.65390
      • 720+14.42810
      库存:186
      库存:346
      • 1+17.767481+2.12440
      • 180+14.17618180+1.69500
      • 540+13.32561540+1.59330
      • 900+12.38053900+1.48030
      库存:346
