F15382_JENNY-CY-G2
F15382_JENNY-CY-G2
    LEDIL(芬兰)
    Round Optical Lens Clear Silicone Tape Box
F15382_JENNY-CY-G2 数据手册
PRODUCT DATASHEET F15382_JENNY-CY-G2 JENNY-CY-G2 ~105° + 105° batwing light distribution for canopy and symmetrical tunnel lighting. TECHNICAL SPECIFICATIONS: Dimensions Height 35.0 x 35.0 mm 11.5 mm Fastening ROHS compliant tape yes MATERIAL SPECIFICATIONS: Component Type Material Colour JENNY-CY-G2 Single lens Silicone clear Finish ORDERING INFORMATION: Component F15382_JENNY-CY-G2 » Box size: 480 x 280 x 300 mm Qty in box MOQ MPQ 1200 120 60 Box weight (kg) 9.1 Last update: 28/09/2022 Subject to change without prior notice Published: 21/01/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 1/8 PRODUCT DATASHEET F15382_JENNY-CY-G2 See also our general installation guide: www.ledil.com/installation_guide Last update: 28/09/2022 Subject to change without prior notice Published: 21/01/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/8 PRODUCT DATASHEET F15382_JENNY-CY-G2 PHOTOMETRIC DATA (MEASURED): LED MK-R FWHM / FWTM 105.0° / 120.0° Efficiency % LEDs/each optic 1 Light colour White Required components: LED XHP50 FWHM / FWTM 102.0° / 118.0° Efficiency % LEDs/each optic 1 Light colour White Required components: LED XHP50.2 FWHM / FWTM 106.0° / 110.0° Efficiency % LEDs/each optic 1 Light colour White Required components: LED XM-L EZW FWHM / FWTM 103.0° / 119.0° Efficiency 94 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 28/09/2022 Subject to change without prior notice Published: 21/01/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/8 PRODUCT DATASHEET F15382_JENNY-CY-G2 PHOTOMETRIC DATA (MEASURED): LED LUXEON 5258 FWHM / FWTM 103.0° / 118.0 + 120.0° Efficiency % LEDs/each optic 1 Light colour White Required components: LED LUXEON M/MX FWHM / FWTM 102.0° / 120.0° Efficiency % LEDs/each optic 1 Light colour White Required components: LED Duris S8 FWHM / FWTM 102.0° / 118.0° Efficiency % LEDs/each optic 1 Light colour White Required components: Last update: 28/09/2022 Subject to change without prior notice Published: 21/01/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/8 PRODUCT DATASHEET F15382_JENNY-CY-G2 PHOTOMETRIC DATA (SIMULATED): LED J Series 2835 FWHM / FWTM 95.0° / 104.0° Efficiency 96 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED MX-6 FWHM / FWTM 102.0° / 118.0° Efficiency 93 % LEDs/each optic 1 Light colour White Required components: LED XHP50.3 HD FWHM / FWTM 103.0 + 102.0° / 112.0° Efficiency 96 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED XHP50.3 HI FWHM / FWTM 102.0° / 110.0° Efficiency 97 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 28/09/2022 Subject to change without prior notice Published: 21/01/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/8 PRODUCT DATASHEET F15382_JENNY-CY-G2 PHOTOMETRIC DATA (SIMULATED): LED XHP70.3 HD FWHM / FWTM 105.0° / 112.0° Efficiency 96 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON 5050 Round LES FWHM / FWTM 100.0° / 110.0° Efficiency 94 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON 7070 FWHM / FWTM 102.0° / 112.0° Efficiency 93 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED NCSU334A FWHM / FWTM 96.0° / 106.0° Efficiency 71 % LEDs/each optic 1 Light colour UV-C Required components: The UVC LED result tolerance is ±10 % Last update: 28/09/2022 Subject to change without prior notice Published: 21/01/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/8 PRODUCT DATASHEET F15382_JENNY-CY-G2 PHOTOMETRIC DATA (SIMULATED): LED NVSxE21A FWHM / FWTM 96.0° / 108.0° Efficiency 94 % Peak intensity 0.6 cd/lm LEDs/each optic 4 Light colour White Required components: LED OSCONIQ P 7070 FWHM / FWTM 100.0° / 106.0° Efficiency 93 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED Z8Y22 FWHM / FWTM 102.0° / 130.0 + 110.0° Efficiency 93 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 28/09/2022 Subject to change without prior notice Published: 21/01/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/8 PRODUCT DATASHEET F15382_JENNY-CY-G2 GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 28/09/2022 Subject to change without prior notice Published: 21/01/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/8
F15382_JENNY-CY-G2 价格&库存
很抱歉,暂时无法提供与“F15382_JENNY-CY-G2”相匹配的价格&库存,您可以联系我们找货
