FA10330_SSS-SS
FA10330_SSS-SS
    LEDIL(芬兰)
    LENS FOR SEOUL P4
FA10330_SSS-SS 数据手册
LEDIL F’FORM OPTICS SSS SQUARE lenses for SEOUL SC P3 LEDs - - Designed & optimized for SSC P3 series of LEDs Lens material optical grade PC with high UV and temperature resistance (130°C/220°F). Allows use of high current and temperature conditions Best available optical efficiency, up to 90% Very even color distribution over the whole beam angle Integrated holder. Fastening to heat sink with a PU foam adhesive tape of automotive grade Compact dimensions 21.6 x 21.6 mm. Square form enables easy build of matrix without any gaps between lenses. Easy build of a complete luminaire using SSS lens, SSC P3 LED and heat sink LENS TYPES NAME SS SQUARE SS SQUARE SS SQUARE SS SQUARE SS SQUARE SS SQUARE SS SQUARE ORDERING CODE REAL SPOT* SMOOTH SPOT* DIFFUSER MEDIUM OVAL OVAL TURNED 90° WIDE FA10311_SSS-RS FA10330_SSS-SS FA10312_SSS-D FA10313_SSS-M FA10314_SSS-O 4FA11149_SSS-O-90 FA10539_SSS-W FWHM Angle ±7° ±8° ±10° ±15° ±7° x ±23° ±7° x ±23° ±20° *) IMPORTANT NOTICE: REAL SPOT lens is a highly efficient pure collimator lens, which optically functions in an excellent way, giving a high intensity. REAL SPOT lens also reveals the chip level optical structure of the LED. We recommend REAL SPOT lens for applications, where light intensity is of highest priority, while we do not recommend it for white light applications, where color uniformity is of high importance. SMOOTH SPOT lens is a pure collimator lens with light mixing properties. It smoothens the beam pattern and makes a uniform color distribution over the whole beam angle. Light intensity is lower than for the REAL SPOT lens. SMOOTH SPOT lens is recommended for white light applications, where pleasant, high-quality illumination is wished. © Ledil Oy – PRELIMINARY - Subject to change without prior notice Ledil Oy Tehdaskatu 13 FIN-24100 SALO, Finland www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 2009-11-29 LEDIL F’FORM OPTICS MEASUREMENTS SSS-RS SSS-SS SSS-D SSS-M © Ledil Oy – PRELIMINARY - Subject to change without prior notice Ledil Oy Tehdaskatu 13 FIN-24100 SALO, Finland www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 2009-11-29 LEDIL F’FORM OPTICS SSS-O SSS-W Relative Intensity of SSS-W 100% 75% 50% 25% 0% 50 40 30 20 10 0 -10 -20 -30 -40 -50 Angle PHOTOS SSS-RS SSS-SS SSS-D COMING SOON SSS-M SSS-W SSS-O © Ledil Oy – PRELIMINARY - Subject to change without prior notice Ledil Oy Tehdaskatu 13 FIN-24100 SALO, Finland www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 2009-11-29 LEDIL F’FORM OPTICS DIMENSIONS Easy & accurate positioning Adhesive tape for quick and secure fastening. Space for D=5.0 mm screw head between the lenses for fastening of PCB PACKAGING SSS lenses are delivered on adhesive tape liner sheets, each sheet containing 60 lenses. SPECIAL VERSIONS Special versions available on request, e.g. different lens holder colors or packaging sizes. © Ledil Oy – PRELIMINARY - Subject to change without prior notice Ledil Oy Tehdaskatu 13 FIN-24100 SALO, Finland www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 2009-11-29
FA10330_SSS-SS 价格&库存
很抱歉,暂时无法提供与“FA10330_SSS-SS”相匹配的价格&库存,您可以联系我们找货
