FA11027_TINA-WW-OSL
FA11027_TINA-WW-OSL
    LEDIL(芬兰)
FA11027_TINA-WW-OSL 数据手册
PRODUCT DATASHEET Tina series last update 3/10/2012 Ordering number FA11208_TINA-RS Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Tina Assembly Oslon SSL 80 Black 16.1 mm 9.5 mm Round PMMA PC Pin, tape Ready FWHM Efficiency cd/lm Gerber File 11 degrees 90 % 14.300 Available FWHM Efficiency cd/lm Gerber File 12 degrees 89 % 10.100 Available FWHM Efficiency cd/lm Gerber File 24 degrees 83 % 2.290 Available FWHM Efficiency cd/lm Gerber File 34+12 degrees 80 % 3.800 Available Ordering number FA11205_TINA-D Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Tina Assembly Oslon SSL 80 Black 16.1 mm 9.5 mm Round PMMA PC Pin, tape Ready Ordering number FA11206_TINA-M Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Tina Assembly Oslon SSL 80 Black 16.1 mm 9.5 mm Round PMMA PC Pin, tape Ready Ordering number FA11204_TINA-O Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Tina Assembly Oslon SSL 80 Black 16.1 mm 9.5 mm Round PMMA PC Pin, tape Ready October 6th 2012 0:12 Copyright Ledil Oy - Subject to change without prior notice - Page 1/3 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 PRODUCT DATASHEET Tina series last update 3/10/2012 Ordering number FA11207_TINA-W Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Tina Assembly Oslon SSL 80 Black 16.1 mm 9.5 mm Round PMMA PC Pin, tape Ready FWHM Efficiency cd/lm Gerber File 48 degrees 87 % 1.100 Available FWHM Efficiency cd/lm Gerber File 66 degrees 87 % 0.800 Available Ordering number FA11027_TINA-WW Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Tina Lens Oslon SSL 80 Black 16.1 mm 9.5 mm Round PMMA PC Pin, tape Ready NOTE: The typical divergence will be changed by different color, chip size and chip position tolerance. The typical total divergence is the full angle measured where the luminous intensity is half of the peak value. October 6th 2012 0:12 Copyright Ledil Oy - Subject to change without prior notice - Page 2/3 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 PRODUCT DATASHEET Tina series last update 3/10/2012 GENERAL INFORMATION - Product series especially designed & optimized for Oslon SSL 80 series of LEDs. - Special care taken to make light distribution as uniform as possible. - Lens material optical grade PMMA with high UV and temperature resistance (105 degrees of Celcius / 220 degrees of Fahrenheit). Allows use of high current and temperature conditions. Please find more information about used material from below: http://ledil.fi/sites/default/files/Documents/Technical/Material/PMMA%208N%20UL94_Yellow%20Card.pdf http://ledil.fi/sites/default/files/Documents/Technical/Material/PMMA%208N%20PLEXIGLAS-Datasheet.pdf - Optic holder molded by high quality PC material (120 dergees of Celcius / 248 degrees of Fahrenheit). - Fastening to heat sink with a PU foam adhesive tape of automotive grade. Please find fastening details by clicking link: http://www.ledil.com/datasheets/DataSheet_TAPE.pdf NOTE 1: We advise customer to ensure the suitability and sufficiency of the bond in the end product. For example, mechanical stress, vibration and holes on the surface of the circuit boar weaken the strength of the tape. NOTE 2: Assembly to the surface must be made straight, so the tape bonds constant and balanced with fastening surface. Slanted assembly might cause unbalanced bond to the surface. All surfaces where tape is applied must be clean, dry and free from grease and dirt. If cleaning of PCB surfaces is needed, please follow strictly the cleaning instructions of your LED manufacturer - this is important as cleaning shall under no circumstances damage LEDs or other electronics components on the PCB. Further note that optical components shall not be cleaned with any chemicals - only micro fiber cloth may be used to remove fingerprints or other traces from handling. October 6th 2012 0:12 Copyright Ledil Oy - Subject to change without prior notice - Page 3/3 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 A B C D 4 Tape 4 c/c 5.67 8.6 2 Isometric view 1.12 w/ tape 9.52 w/o tape 3 9.12 Bottom view 3 Front view 16.1 2 2 Materials Lens: PMMA Holder: PC Tape: PU Foam Top view This drawing is our property. It can't be reproduced or communicated without our written agreement. 1 DRAWN BY as DATE Ledil Oy Salorankatu 10 FIN 24240 SALO Finland DRAWING TITLE 10.9.2012 CHECKED BY DATE SIZE - DESIGNED BY DATE A4 sn - - D SCALE PART NUMBER Mechanical Drawing TINA-OSL 1 REV TINA-OSL 2:1 WEIGHT 1,47 g 001 SHEET A 1/1
FA11027_TINA-WW-OSL 价格&库存
很抱歉,暂时无法提供与“FA11027_TINA-WW-OSL”相匹配的价格&库存,您可以联系我们找货
