FA11208_TINA-RS
FA11208_TINA-RS
    LEDIL(芬兰)
    Lens with Holder Clear 15° Spot Osram Oslon SSL Adhesive, Position Pins
FA11208_TINA-RS 数据手册
PRODUCT DATASHEET FA11208_TINA-RS TINA-RS ~13° spot beam. Assembly with installation tape and location pins. holder, SPECIFICATION: Dimensions Height Fastening ROHS compliant Ø 16.1 mm 9.5 mm tape, pin yes MATERIALS: Component Type Material Colour Finish Length TINA-XP-RS Single lens PMMA clear 16.0 TINA-HLD-PIN-BLK Holder PC black 16.0 TINA-TAPE3 Tape Acrylic foam black 16.0 ORDERING INFORMATION: Component FA11208_TINA-RS » Box size: 470 x 240 x 105 mm Qty in box MOQ MPQ 2016 288 144 Box weight (kg) 4.1 Last update: 13/05/2024 Subject to change without prior notice Published: 16/11/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 1/9 PRODUCT DATASHEET FA11208_TINA-RS See also our general installation guide: www.ledil.com/installation_guide Last update: 13/05/2024 Subject to change without prior notice Published: 16/11/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/9 PRODUCT DATASHEET FA11208_TINA-RS OPTICAL RESULTS (MEASURED): LED XB-H FWHM / FWTM 15.0° / 27.0° Efficiency 88 % Peak intensity 10.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED NVSW3x9A FWHM / FWTM 20.0° / 37.0° Efficiency 88 % Peak intensity 5.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSLON SSL 80 FWHM / FWTM 11.0° / 23.0° Efficiency 90 % Peak intensity 14.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice Published: 16/11/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/9 PRODUCT DATASHEET FA11208_TINA-RS OPTICAL RESULTS (MEASURED): LED SFH 4715S FWHM / FWTM 15.0° / 26.0° Efficiency % LEDs/each optic 1 Light colour/type White Required components: LED SFH 4725S FWHM / FWTM 10.0° / 24.0° Efficiency % LEDs/each optic 1 Light colour/type White Required components: LED LH351A FWHM / FWTM 14.0° / 26.0° Efficiency 93 % Peak intensity 7.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice Published: 16/11/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/9 PRODUCT DATASHEET FA11208_TINA-RS OPTICAL RESULTS (MEASURED): LED Z8Y22P FWHM / FWTM 17.0° / 35.0° Efficiency 85 % Peak intensity 6.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice Published: 16/11/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/9 PRODUCT DATASHEET FA11208_TINA-RS OPTICAL RESULTS (SIMULATED): LED LUXEON C FWHM / FWTM 12.0° / 27.0° Efficiency 87 % Peak intensity 13.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON CZ FWHM / FWTM 10.0° / 21.0° Efficiency 92 % Peak intensity 23.3 cd/lm LEDs/each optic 1 Light colour/type Red Required components: LED NCSxE17A FWHM / FWTM 28.0° / 50.0° Efficiency 85 % Peak intensity 2.7 cd/lm LEDs/each optic 4 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice Published: 16/11/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/9 PRODUCT DATASHEET FA11208_TINA-RS OPTICAL RESULTS (SIMULATED): LED NF2x757G FWHM / FWTM 16.0° / 30.0° Efficiency 92 % Peak intensity 9.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSLON Square CSSRM2/CSSRM3 FWHM / FWTM 16.0° / 30.0° Efficiency 91 % Peak intensity 9.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED SYNIOS S2222 FWHM / FWTM 12.0 + 11.0° / 22.0° Efficiency 97 % Peak intensity 17.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice Published: 16/11/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/9 PRODUCT DATASHEET FA11208_TINA-RS OPTICAL RESULTS (SIMULATED): LED MGN1108MS FWHM / FWTM 10.0° / 22.0° Efficiency 91 % LEDs/each optic 1 Light colour/type IR Required components: LED MJN1108MS FWHM / FWTM 10.0° / 22.0° Efficiency 92 % LEDs/each optic 1 Light colour/type IR Required components: Last update: 13/05/2024 Subject to change without prior notice Published: 16/11/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/9 PRODUCT DATASHEET FA11208_TINA-RS GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Poznan, Poland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 13/05/2024 Subject to change without prior notice Published: 16/11/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/9
FA11208_TINA-RS 价格&库存
很抱歉,暂时无法提供与“FA11208_TINA-RS”相匹配的价格&库存,您可以联系我们找货
FA11208_TINA-RS
  • 1+23.154911+2.90479
  • 10+16.7535110+2.10174
  • 144+12.51393144+1.56988
  • 576+11.15795576+1.39977
  • 1008+10.725461008+1.34552
  • 2016+10.264382016+1.28767
  • 5040+9.761865040+1.22463
库存:5157
FA11208_TINA-RS
  • 144+12.38101
库存:216
FA11208_TINA-RS
  • 144+12.82979144+1.60950
  • 288+12.74131288+1.59840
  • 432+12.65283432+1.58730
  • 576+12.56435576+1.57620
FA11208_TINA-RS
  • 144+9.02510144+1.13220
  • 288+8.84813288+1.11000
  • 576+8.71541576+1.09335
  • 720+8.67117720+1.08780
  • 2160+8.405732160+1.05450
库存:2016
FA11208_TINA-RS
    • 2+18.09405
    • 36+17.69311
    • 72+17.31822
    库存:192
