C17174_DAISY-4X1-W-US
    LEDIL(芬兰)
C17174_DAISY-4X1-W-US 数据手册
PRODUCT DATASHEET DAISY-4X1-WW DAISY-4X1-WW ~80° wide beam SPECIFICATION: Dimensions 182.0 x 40.0 mm Height 20.2 mm Fastening pin, screw, clips ROHS compliant yes MATERIALS: Component Type Material Colour Finish C16584_DAISY-4X1-WW Linear lens PMMA clear C19075_DAISY-4X1-SHD2 Shade PC black gloss C18414_DAISY-4X1-SHD-MET-MATT Shade PC metal matt C18412_DAISY-4X1-SHD2-MET Shade PC metal gloss C18411_DAISY-4X1-SHD2-MET-MATT Shade PC metal matt C18407_DAISY-4X1-SHD-MET Shade PC metal gloss C17423_DAISY-4X1-SHD2-WHT-MATT Shade PC white matt C17422_DAISY-4X1-SHD2-MATT Shade PC black matt C16784_DAISY-4X1-SHD-WHT Shade PC white gloss C16590_DAISY-4X1-SHD Shade PC black gloss ORDERING INFORMATION: Quantities for one set: Linear lens 1 Shade 1 Last update: 08/11/2023 Subject to change without prior notice Published: 24/08/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 1/21 PRODUCT DATASHEET DAISY-4X1-WW Component Qty in box MOQ MPQ Box weight (kg) C16584_DAISY-4X1-WW » Box size: 480 x 280 x 300 mm Linear lens 504 336 21 5.6 C18411_DAISY-4X1-SHD2-MET-MATT » Box size: 480 x 280 x 300 mm Shade 168 336 42 4.7 C17422_DAISY-4X1-SHD2-MATT » Box size: 480 x 280 x 300 mm Shade 168 336 42 4.7 C18412_DAISY-4X1-SHD2-MET » Box size: 480 x 280 x 300 mm Shade 168 336 42 C17423_DAISY-4X1-SHD2-WHT-MATT » Box size: 480 x 280 x 300 mm Shade 168 336 42 4.9 C18414_DAISY-4X1-SHD-MET-MATT » Box size: 480 x 280 x 300 mm Shade 168 336 42 4.3 C16590_DAISY-4X1-SHD » Box size: 480 x 280 x 300 mm Shade 168 336 42 4.9 C18407_DAISY-4X1-SHD-MET » Box size: 480 x 280 x 300 mm Shade 168 336 42 4.3 C19075_DAISY-4X1-SHD2 » Box size: 480 x 280 x 300 mm Shade 168 336 42 4.4 C16784_DAISY-4X1-SHD-WHT » Box size: 480 x 280 x 300 mm Shade 168 336 42 5.2 Last update: 08/11/2023 Subject to change without prior notice Published: 24/08/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/21 PRODUCT DATASHEET DAISY-4X1-WW Last update: 08/11/2023 Subject to change without prior notice Published: 24/08/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/21 PRODUCT DATASHEET DAISY-4X1-WW See also our general installation guide: www.ledil.com/installation_guide Last update: 08/11/2023 Subject to change without prior notice Published: 24/08/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/21 PRODUCT DATASHEET DAISY-4X1-WW OPTICAL RESULTS (MEASURED): LED LIGHT ENGINE DAISY 16 LEDs 156mm x 20mm FWHM / FWTM 76.0° / 87.5° Efficiency 95 % Peak intensity 0.7 cd/lm LEDs/each optic 4 Light colour White Required components: C16784_DAISY-4X1-SHD-WHT LED LIGHT ENGINE DAISY 16 LEDs 156mm x 20mm FWHM / FWTM 75.0° / 87.0° Efficiency 94 % Peak intensity 0.7 cd/lm LEDs/each optic 4 Light colour White Required components: C17535_DAISY-4X1-SHD2-MET-MATT LED LIGHT ENGINE DAISY 16 LEDs 156mm x 20mm FWHM / FWTM 76.0° / 87.0° Efficiency 86 % Peak intensity 0.6 cd/lm LEDs/each optic 4 Light colour White Required components: C17422_DAISY-4X1-SHD2-MATT LED LIGHT ENGINE DAISY 16 LEDs 156mm x 20mm FWHM / FWTM 76.0° / 87.5° Efficiency 95 % Peak intensity 0.7 cd/lm LEDs/each optic 4 Light colour White Required components: C17225_DAISY-7X1-SHD-WHT-MATT Last update: 08/11/2023 Subject to change without prior notice Published: 24/08/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/21 PRODUCT DATASHEET DAISY-4X1-WW OPTICAL RESULTS (MEASURED): LED LIGHT ENGINE DAISY 16 LEDs 156mm x 20mm FWHM / FWTM 76.0° / 87.0° Efficiency 87 % Peak intensity 0.6 cd/lm LEDs/each optic 4 Light colour White Required components: C16590_DAISY-4X1-SHD LED LIGHT ENGINE DAISY 16 LEDs 156mm x 20mm FWHM / FWTM 74.0° / 87.0° Efficiency 96 % Peak intensity 0.7 cd/lm LEDs/each optic 4 Light colour White Required components: C17528_DAISY-4X1-SHD-MET LED J Series 2835 FWHM / FWTM 77.0° / 86.0° Efficiency 86 % Peak intensity 0.6 cd/lm LEDs/each optic 2 Light colour White Required components: C16590_DAISY-4X1-SHD LED LUXEON 2835 Line FWHM / FWTM 78.0° / 86.0° Efficiency 87 % Peak intensity 0.6 cd/lm LEDs/each optic 2 Light colour White Required components: C16590_DAISY-4X1-SHD Last update: 08/11/2023 Subject to change without prior notice Published: 24/08/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/21 PRODUCT DATASHEET DAISY-4X1-WW OPTICAL RESULTS (MEASURED): LED LinLED 156x28mm 2x200lm 827-865 2x2C 12V Opt G1 FWHM / FWTM 77.0° / 85.0° Efficiency 85 % Peak intensity 0.6 cd/lm LEDs/each optic 2 Light colour Tunable White Required components: C16590_DAISY-4X1-SHD LED LinLED 156x28mm 2x400lm 827-865 2x2C 12V Opt G1 FWHM / FWTM 76.0 + 76.5° / 87.5° Efficiency 87 % Peak intensity 0.6 cd/lm LEDs/each optic 4 Light colour Tunable White Required components: C16590_DAISY-4X1-SHD LED LinLED 156x28mm 2x400lm 827-865 2x2C 12V Opt G1 FWHM / FWTM 74.5 + 75.5° / 87.5° Efficiency 95 % Peak intensity 0.7 cd/lm LEDs/each optic 4 Light colour Tunable White Required components: C17528_DAISY-4X1-SHD-MET LED LinLED 156x28mm 2x400lm 827-865 2x2C 12V Opt G1 FWHM / FWTM 76.5 + 77.0° / 88.5° Efficiency 95 % Peak intensity 0.6 cd/lm LEDs/each optic 4 Light colour Tunable White Required components: C16784_DAISY-4X1-SHD-WHT Last update: 08/11/2023 Subject to change without prior notice Published: 24/08/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/21 PRODUCT DATASHEET DAISY-4X1-WW OPTICAL RESULTS (MEASURED): LED LinLED 156x28mm 2x400lm 827-865 2x2C 12V Opt G1 FWHM / FWTM 75.5° / 88.0 + 87.5° Efficiency 94 % Peak intensity 0.7 cd/lm LEDs/each optic 4 Light colour Tunable White Required components: C17535_DAISY-4X1-SHD2-MET-MATT LED LinLED 156x28mm 2x400lm 827-865 2x2C 12V Opt G1 FWHM / FWTM 76.0 + 76.5° / 87.5° Efficiency 86 % Peak intensity 0.6 cd/lm LEDs/each optic 4 Light colour Tunable White Required components: C17422_DAISY-4X1-SHD2-MATT LED LinLED 156x28mm 2x400lm 827-865 2x2C 12V Opt G1 FWHM / FWTM 76.5 + 77.0° / 88.5° Efficiency 95 % Peak intensity 0.6 cd/lm LEDs/each optic 4 Light colour Tunable White Required components: C17423_DAISY-4X1-SHD2-WHT-MATT LED LinLED 156x28mm 400lm 8x0 2C 12V Opt G1 FWHM / FWTM 77.0° / 86.0° Efficiency 87 % Peak intensity 0.6 cd/lm LEDs/each optic 2 Light colour White Required components: C16590_DAISY-4X1-SHD Last update: 08/11/2023 Subject to change without prior notice Published: 24/08/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/21 PRODUCT DATASHEET DAISY-4X1-WW OPTICAL RESULTS (MEASURED): LED LinLED 156x28mm 800lm 8x0 2C 12V Opt G1 FWHM / FWTM 75.5 + 76.0° / 87.5° Efficiency 85 % Peak intensity 0.6 cd/lm LEDs/each optic 4 Light colour White Required components: C17422_DAISY-4X1-SHD2-MATT LED LinLED 156x28mm 800lm 8x0 2C 12V Opt G1 FWHM / FWTM 76.0 + 76.5° / 88.0° Efficiency 94 % Peak intensity 0.6 cd/lm LEDs/each optic 4 Light colour White Required components: C17423_DAISY-4X1-SHD2-WHT-MATT LED LinLED 156x28mm 800lm 8x0 2C 12V Opt G1 FWHM / FWTM 76.0 + 75.5° / 87.5 + 87.0° Efficiency 86 % Peak intensity 0.6 cd/lm LEDs/each optic 4 Light colour White Required components: C16590_DAISY-4X1-SHD LED LinLED 156x28mm 800lm 8x0 2C 12V Opt G1 FWHM / FWTM 74.5° / 87.5 + 87.0° Efficiency 95 % Peak intensity 0.7 cd/lm LEDs/each optic 4 Light colour White Required components: C17528_DAISY-4X1-SHD-MET Last update: 08/11/2023 Subject to change without prior notice Published: 24/08/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/21 PRODUCT DATASHEET DAISY-4X1-WW OPTICAL RESULTS (MEASURED): LED LinLED 156x28mm 800lm 8x0 2C 12V Opt G1 FWHM / FWTM 76.5° / 88.5 + 88.0° Efficiency 94 % Peak intensity 0.6 cd/lm LEDs/each optic 4 Light colour White Required components: C16784_DAISY-4X1-SHD-WHT LED LinLED 156x28mm 800lm 8x0 2C 12V Opt G1 FWHM / FWTM 74.5° / 87.5° Efficiency 94 % Peak intensity 0.7 cd/lm LEDs/each optic 4 Light colour White Required components: C17535_DAISY-4X1-SHD2-MET-MATT LED NF2W757G-MT (Tunable White) FWHM / FWTM 79.0° / 85.0° Efficiency 86 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour Tunable White Required components: C16590_DAISY-4X1-SHD LED NF2W757G-MT (Tunable White) FWHM / FWTM 79.0° / 86.0° Efficiency 96 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour Tunable White Required components: C16784_DAISY-4X1-SHD-WHT Last update: 08/11/2023 Subject to change without prior notice Published: 24/08/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 10/21 PRODUCT DATASHEET DAISY-4X1-WW OPTICAL RESULTS (MEASURED): LED PL-LIN-1000 140x24mm FWHM / FWTM 75.0° / 89.0° Efficiency 83 % Peak intensity 0.6 cd/lm LEDs/each optic 4 Light colour White Required components: C17422_DAISY-4X1-SHD2-MATT LED LM28xB Series FWHM / FWTM 77.0° / 87.0° Efficiency 94 % Peak intensity 0.6 cd/lm LEDs/each optic 2 Light colour White Required components: C16784_DAISY-4X1-SHD-WHT LED LM28xB Series FWHM / FWTM 75.0° / 88.0° Efficiency 84 % Peak intensity 0.6 cd/lm LEDs/each optic 4 Light colour White Required components: C16590_DAISY-4X1-SHD LED LM28xB Series FWHM / FWTM 78.0° / 86.0° Efficiency 84 % Peak intensity 0.6 cd/lm LEDs/each optic 2 Light colour White Required components: C16590_DAISY-4X1-SHD Last update: 08/11/2023 Subject to change without prior notice Published: 24/08/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 11/21 PRODUCT DATASHEET DAISY-4X1-WW OPTICAL RESULTS (MEASURED): LED LM28xB Series FWHM / FWTM 76.0° / 89.0° Efficiency 94 % Peak intensity 0.6 cd/lm LEDs/each optic 4 Light colour White Required components: C16784_DAISY-4X1-SHD-WHT LED LM28xB Series FWHM / FWTM 76.0° / 85.0° Efficiency 86 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour White Required components: C17422_DAISY-4X1-SHD2-MATT LED SEOUL DC 3030 FWHM / FWTM 75.0° / 89.0° Efficiency 83 % Peak intensity 0.6 cd/lm LEDs/each optic 4 Light colour Tunable White Required components: C16590_DAISY-4X1-SHD LED SEOUL DC 3030 FWHM / FWTM 75.0° / 89.0° Efficiency 92 % Peak intensity 0.7 cd/lm LEDs/each optic 4 Light colour Tunable White Required components: C16784_DAISY-4X1-SHD-WHT Last update: 08/11/2023 Subject to change without prior notice Published: 24/08/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 12/21 PRODUCT DATASHEET DAISY-4X1-WW OPTICAL RESULTS (MEASURED): LED SEOUL DC 3528 FWHM / FWTM 77.0° / 86.0° Efficiency 87 % Peak intensity 0.6 cd/lm LEDs/each optic 2 Light colour White Required components: C16590_DAISY-4X1-SHD LED SEOUL DC 3528 FWHM / FWTM 78.0° / 86.0° Efficiency 87 % Peak intensity 0.6 cd/lm LEDs/each optic 2 Light colour White Required components: C16590_DAISY-4X1-SHD LED PassivePAQ-L-0.5F35-SSA3-1.6K-840-3-DC FWHM / FWTM 80.0° / 91.0° Efficiency 94 % Peak intensity 0.6 cd/lm LEDs/each optic 4 Light colour White Required components: C16784_DAISY-4X1-SHD-WHT LED PassivePAQ-L-0.5F35-SSA3-1.6K-840-3-DC FWHM / FWTM 79.0° / 91.0° Efficiency 94 % Peak intensity 0.6 cd/lm LEDs/each optic 4 Light colour White Required components: C17423_DAISY-4X1-SHD2-WHT-MATT Last update: 08/11/2023 Subject to change without prior notice Published: 24/08/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 13/21 PRODUCT DATASHEET DAISY-4X1-WW OPTICAL RESULTS (MEASURED): LED PassivePAQ-L-0.5F35-SSA3-1.6K-840-3-DC FWHM / FWTM 80.0 + 77.0° / 91.0° Efficiency 83 % Peak intensity 0.6 cd/lm LEDs/each optic 4 Light colour White Required components: C17422_DAISY-4X1-SHD2-MATT LED PassivePAQ-L-0.5F35-SSA3-1.6K-840-3-DC FWHM / FWTM 79.0° / 91.0° Efficiency 85 % Peak intensity 0.6 cd/lm LEDs/each optic 4 Light colour White Required components: C16590_DAISY-4X1-SHD LED LLE 24x140mm 400lm 827-865 LVD ADV1 FWHM / FWTM 76.0° / 89.0° Efficiency 85 % Peak intensity 0.6 cd/lm LEDs/each optic 4 Light colour White Required components: C16590_DAISY-4X1-SHD LED LLE 24x140mm 400lm 827-865 LVD ADV1 FWHM / FWTM 76.0° / 90.0° Efficiency 94 % Peak intensity 0.6 cd/lm LEDs/each optic 4 Light colour White Required components: C16784_DAISY-4X1-SHD-WHT Last update: 08/11/2023 Subject to change without prior notice Published: 24/08/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 14/21 PRODUCT DATASHEET DAISY-4X1-WW OPTICAL RESULTS (MEASURED): LED LLE 24x140mm 400lm 8x0 LVD ADV1 FWHM / FWTM 77.0° / 90.0° Efficiency 94 % Peak intensity 0.6 cd/lm LEDs/each optic 4 Light colour White Required components: C16784_DAISY-4X1-SHD-WHT LED LLE 24x140mm 400lm 8x0 LVD ADV1 FWHM / FWTM 76.0° / 89.0° Efficiency 85 % Peak intensity 0.6 cd/lm LEDs/each optic 4 Light colour White Required components: C16590_DAISY-4X1-SHD LED LLE 24x280mm 750lm 8x0 LVD ADV1 FWHM / FWTM 76.0° / 90.0° Efficiency 94 % Peak intensity 0.6 cd/lm LEDs/each optic 4 Light colour White Required components: C16784_DAISY-4X1-SHD-WHT LED LLE 24x280mm 750lm 8x0 LVD ADV1 FWHM / FWTM 76.0° / 89.0° Efficiency 85 % Peak intensity 0.6 cd/lm LEDs/each optic 4 Light colour White Required components: C16590_DAISY-4X1-SHD Last update: 08/11/2023 Subject to change without prior notice Published: 24/08/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 15/21 PRODUCT DATASHEET DAISY-4X1-WW OPTICAL RESULTS (SIMULATED): LED J Series 2835 FWHM / FWTM 78.0° / 85.0° Efficiency 83 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour White Required components: C17422_DAISY-4X1-SHD2-MATT LED J Series 5050 Round LES FWHM / FWTM 78.0° / 86.0° Efficiency 84 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour White Required components: C17422_DAISY-4X1-SHD2-MATT LED LUXEON 3535L FWHM / FWTM 76.0° / 85.0° Efficiency 90 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour White Required components: C16590_DAISY-4X1-SHD LED LUXEON 5050 Round LES FWHM / FWTM 76.0° / 88.0° Efficiency 90 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour White Required components: C16590_DAISY-4X1-SHD Last update: 08/11/2023 Subject to change without prior notice Published: 24/08/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 16/21 PRODUCT DATASHEET DAISY-4X1-WW OPTICAL RESULTS (SIMULATED): LED NF2W757G-MT (Tunable White) FWHM / FWTM 76.0° / 88.0° Efficiency 90 % Peak intensity 0.7 cd/lm LEDs/each optic 4 Light colour Tunable White Required components: C16590_DAISY-4X1-SHD LED NF2W757G-MT (Tunable White) FWHM / FWTM 76.0 + 78.0° / 86.0° Efficiency 90 % Peak intensity 0.7 cd/lm LEDs/each optic 2 Light colour Tunable White Required components: C16590_DAISY-4X1-SHD LED Duris E 2835 FWHM / FWTM 76.0° / 88.0° Efficiency 89 % Peak intensity 0.7 cd/lm LEDs/each optic 4 Light colour White Required components: C16585_DAISY-28X1-SHD LED Duris E 2835 FWHM / FWTM 80.0° / 86.0° Efficiency 83 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour White Required components: C16590_DAISY-4X1-SHD Last update: 08/11/2023 Subject to change without prior notice Published: 24/08/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 17/21 PRODUCT DATASHEET DAISY-4X1-WW OPTICAL RESULTS (SIMULATED): LED Duris E 2835 FWHM / FWTM 76.0° / 88.0° Efficiency 95 % Peak intensity 0.7 cd/lm LEDs/each optic 2 Light colour White Required components: C16590_DAISY-4X1-SHD LED Duris S8 FWHM / FWTM 76.0° / 88.0° Efficiency 90 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour White Required components: C16590_DAISY-4X1-SHD LED Duris S8 FWHM / FWTM 76.0° / 86.0° Efficiency 95 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour White Required components: C16784_DAISY-4X1-SHD-WHT LED LH351B FWHM / FWTM 79.0° / 88.0° Efficiency 90 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour White Required components: C16590_DAISY-4X1-SHD Last update: 08/11/2023 Subject to change without prior notice Published: 24/08/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 18/21 PRODUCT DATASHEET DAISY-4X1-WW OPTICAL RESULTS (SIMULATED): LED LM28xB Series FWHM / FWTM 75.0° / 88.0° Efficiency 95 % Peak intensity 0.8 cd/lm LEDs/each optic 4 Light colour White Required components: C17423_DAISY-4X1-SHD2-WHT-MATT LED LM28xB Series FWHM / FWTM 74.0° / 88.0° Efficiency 93 % Peak intensity 0.7 cd/lm LEDs/each optic 4 Light colour White Required components: C18411_DAISY-4X1-SHD2-MET-MATT LED LM28xB Series FWHM / FWTM 76.0° / 88.0° Efficiency 90 % Peak intensity 0.7 cd/lm LEDs/each optic 4 Light colour White Required components: C17422_DAISY-4X1-SHD2-MATT LED LM28xB Series FWHM / FWTM 75.0° / 88.0° Efficiency 93 % Peak intensity 0.7 cd/lm LEDs/each optic 4 Light colour White Required components: C18412_DAISY-4X1-SHD2-MET Last update: 08/11/2023 Subject to change without prior notice Published: 24/08/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 19/21 PRODUCT DATASHEET DAISY-4X1-WW OPTICAL RESULTS (SIMULATED): LED LM28xB Series FWHM / FWTM 76.0° / 88.0° Efficiency 89 % Peak intensity 0.7 cd/lm LEDs/each optic 4 Light colour White Required components: C19075_DAISY-4X1-SHD2 LED LLE 24x140mm 400lm 8x0 LVD ADV1 FWHM / FWTM 75.0° / 88.0° Efficiency 94 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour White Required components: C17423_DAISY-4X1-SHD2-WHT-MATT Last update: 08/11/2023 Subject to change without prior notice Published: 24/08/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 20/21 PRODUCT DATASHEET DAISY-4X1-WW GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 08/11/2023 Subject to change without prior notice Published: 24/08/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 21/21
C17174_DAISY-4X1-W-US 价格&库存
很抱歉,暂时无法提供与“C17174_DAISY-4X1-W-US”相匹配的价格&库存,您可以联系我们找货
