CA10932_FLARE-B-OSL-TAPE 数据手册
LEDIL F’FORM OPTICS
Flare-B-OSL lens for Osram Oslon SSL
series of LEDs
Flare-B-OSL
Lens designed for Osram Oslon SSL series of LEDs
Lens material optical grade PMMA with high UV and temperature resistance
(105°C/220°F). Allows use of high current and temperature conditions
Best available optical efficiency
Fastening to PCB & heat sink with 2 screws (C10946_Flare-B-OSL) or very easy
assembly with TAPE
LED can be assembled parallel or perpendicular to the x,y axis (to turn the light
distribution by 90°)
Compact dimensions 23 x 25 mm. Square form enables easy build of a line without
any gaps between lenses.
Especially suitable for Beacon and other 360°° solutions and in linear solutions
with high evenness requirements
NAME
ORDERING CODE
Flare-B-OSL Lens
Flare-B-OSL TAPE
C10946_Flare-B-OSL
CA10932_Flare-B-OSL-tape
FWHM Angle
±4.5° x ±44°
±4.5° x ±44°
© Ledil Oy - Subject to change without prior notice
Ledil Oy
Tehdaskatu 13
FIN-24100 SALO, Finland
www.ledil.com
email: ledil@ledil.com
FAX: +358-2-733 8001
2009-11-28
LEDIL F’FORM OPTICS
MEASUREMENTS
Relative Intensity of C10946_Flare-B-OSL
100%
75%
50%
25%
0%
80
70
60
50
40
30
-10 -20 -30 -40 -50 -60 -70 -80
DRAWINGS
Ledil Oy
Tehdaskatu 13
www.ledil.com
2009-11-28
CA10932_FLARE-B-OSL-TAPE 价格&库存
很抱歉,暂时无法提供与“CA10932_FLARE-B-OSL-TAPE”相匹配的价格&库存,您可以联系我们找货
