CA12167_LENA-M-DIFFUSER-LENS_CXA20
    LEDIL(芬兰)
CA12167_LENA-M-DIFFUSER-LENS_CXA20 数据手册
PRODUCT DATASHEET Lena-CXA20 series Ordering number CA12106 Description CA12106_Lena-S_CXA20 Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Lena Reflector CXA20 Metal 111 mm 87 mm Round PC PC Screw Ready FWHM Efficiency cd/lm Gerber File 10.5 degrees Available FWHM Efficiency cd/lm Gerber File 17 degrees 5.700 Available FWHM Efficiency cd/lm Gerber File 41 degrees Available Ordering number CA12163 Description CA12163_Lena-M_CXA20 Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Lena Reflector CXA20 Metal 111 mm 87 mm Round PC PC Screw Ready Ordering number CA12108 Description CA12108_Lena-W_CXA20 Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Lena Reflector CXA20 Metal 111 mm 87 mm Round PC PC Screw Ready Ordering number CA12107 Description CA12107_Lena-S-Diffuser-Lens_CXA20 Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Lena Reflector CXA20 Metal 111 mm 88.6 mm Round PC PC Screw Ready FWHM Efficiency cd/lm Gerber File 11 degrees Available February 13th 2012 16:19 Copyright Ledil Oy - Subject to change without prior notice - Page 1/3 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 PRODUCT DATASHEET Lena-CXA20 series Ordering number CA12167 Description CA12167_Lena-M-Diffuser-Lens_CXA20 Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Lena Reflector CXA20 Metal 111 mm 88.6 mm Round PC PC Screw Ready FWHM Efficiency cd/lm Gerber File 19 degrees 4.100 Available Ordering number CA12109 Description CA12109_Lena-W-Diffuser-Lens_CXA20 Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Lena Reflector CXA20 Metal 111 mm 88.6 mm Round PC PC Screw Ready FWHM Efficiency cd/lm Gerber File 42 degrees Available NOTE: The typical divergence will be changed by different color, chip size and chip position tolerance. The typical total divergence is the full angle measured where the luminous intensity is half of the peak value. February 13th 2012 16:19 Copyright Ledil Oy - Subject to change without prior notice - Page 2/3 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 PRODUCT DATASHEET Lena-CXA20 series GENERAL INFORMATION - Product series especially designed & optimized for CXA20 series of LEDs. - Special care taken to make light distribution as uniform as possible. - Lens material optical grade PC with high UV and temperature resistance (120 degrees of Celcius / 248 degrees of Fahrenheit). Allows use of high current and temperature conditions. Please find more information about used materials from below: http://ledil.fi/sites/default/files/Documents/Technical/Material/PC%20Makrolon%202400_2407_2456_2458-UL .pdf - Reflector is made of aluminium coated PC (120 degrees of Celcius / 248 degrees of Fahrenheit) with protective lacquer (110 degrees of Celcius / 230 degrees of Fahrenheit). - Optic holder molded by high quality PC material (120 dergees of Celcius / 248 degrees of Fahrenheit). February 13th 2012 16:19 Copyright Ledil Oy - Subject to change without prior notice - Page 3/3 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 A B D C 4 2 3. 4 4 3. 2 4 17 A Base part Isometric view 43 Lena_reflector 3 88.6 87 Detail A Scale: 1:1 w/o sublens 3 Lena_sublens Lena-STD-base_CXA20 11 2 Material: 1 subLens - PMMA 2 Reflector - PC - Metal coating and clear lacquer Holder base - PC - Color white 1 This drawing is our property. It can't be reproduced or communicated without our written agreement. DRAWN BY DATE CHECKED BY DATE DESIGNED BY DATE Led Teh FIN Fin DRAWING TITLE pv 26.05.2011 pl 26.05.2011 pl 11.02.2011 D SIZE Datasheet Lena-CXA20 series Assy DRAWING NUMBER REV 1 A4 SCALE 1:2 WEIGHT(g) SHEET A 1/1 1
CA12167_LENA-M-DIFFUSER-LENS_CXA20 价格&库存
很抱歉,暂时无法提供与“CA12167_LENA-M-DIFFUSER-LENS_CXA20”相匹配的价格&库存,您可以联系我们找货
