CA14601_VERONICA-SQ-MINI-RS
    LEDIL(芬兰)
CA14601_VERONICA-SQ-MINI-RS 数据手册
PRODUCT DATASHEET CA14601_VERONICA-SQ-MINI-RS VERONICA-SQ-MINI-RS ~17° spot beam SPECIFICATION: Dimensions Height Fastening ROHS compliant 13.9 x 13.9 mm 8.9 mm tape, pin yes MATERIALS: Component Type Material Colour VERONICA-SQ-MINI-RS Single lens PMMA clear VERONICA-SQ-MINI-TAPE Tape Acrylic foam clear Finish ORDERING INFORMATION: Component CA14601_VERONICA-SQ-MINI-RS » Box size: 480 x 280 x 300 mm Single lens Qty in box MOQ MPQ 5544 252 252 Last update: 05/02/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. Box weight (kg) 7.9 1/14 PRODUCT DATASHEET CA14601_VERONICA-SQ-MINI-RS See also our general installation guide: www.ledil.com/installation_guide Last update: 05/02/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/14 PRODUCT DATASHEET CA14601_VERONICA-SQ-MINI-RS OPTICAL RESULTS (MEASURED): LED XD16 FWHM / FWTM 19.0° / 36.0° Efficiency 92 % Peak intensity 4.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-E2 FWHM / FWTM 14.0° / 26.0° Efficiency 92 % Peak intensity 11 cd/lm LEDs/each optic 1 Light colour White Required components: LED XQ-E HI FWHM / FWTM 9.4° / 24.0° Efficiency 90 % Peak intensity 14.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON Rebel ES FWHM / FWTM 21.0° / 43.0° Efficiency 83 % Peak intensity 4.3 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 05/02/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/14 PRODUCT DATASHEET CA14601_VERONICA-SQ-MINI-RS OPTICAL RESULTS (MEASURED): LED LUXEON TX FWHM / FWTM 20.0° / 44.0° Efficiency 92 % Peak intensity 4 cd/lm LEDs/each optic 1 Light colour White Required components: LED NCSxE17A FWHM / FWTM 11.0° / 32.0° Efficiency 92 % Peak intensity 7.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSxx19B/NVSxx19C FWHM / FWTM 21.0° / 45.0° Efficiency 93 % Peak intensity 3.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSLON Square EC FWHM / FWTM 18.0° / 37.0° Efficiency 91 % Peak intensity 5.3 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 05/02/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/14 PRODUCT DATASHEET CA14601_VERONICA-SQ-MINI-RS OPTICAL RESULTS (MEASURED): LED SFH 4170S FWHM / FWTM 13.0° / 25.0° Efficiency % LEDs/each optic 1 Light colour IR Required components: LED SFH 4180S FWHM / FWTM 11.0° / 22.0° Efficiency % LEDs/each optic 1 Light colour IR Required components: LED LH181A FWHM / FWTM 21.0° / 44.0° Efficiency 86 % Peak intensity 3 cd/lm LEDs/each optic 1 Light colour White Required components: LED LH181B FWHM / FWTM 22.0° / 45.0° Efficiency 94 % Peak intensity 3.5 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 05/02/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/14 PRODUCT DATASHEET CA14601_VERONICA-SQ-MINI-RS OPTICAL RESULTS (MEASURED): LED Z8Y22P FWHM / FWTM 21.0° / 49.0° Efficiency 92 % Peak intensity 3 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 05/02/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/14 PRODUCT DATASHEET CA14601_VERONICA-SQ-MINI-RS OPTICAL RESULTS (SIMULATED): LED XP-E FWHM / FWTM 15.0° / 29.0° Efficiency 92 % Peak intensity 10.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-G FWHM / FWTM 21.0° / 40.0° Efficiency 91 % Peak intensity 5.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-G2 FWHM / FWTM 20.0° / 38.0° Efficiency 93 % Peak intensity 6 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-G2 HE FWHM / FWTM 24.0° / 47.0° Efficiency 97 % Peak intensity 3.5 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 05/02/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/14 PRODUCT DATASHEET CA14601_VERONICA-SQ-MINI-RS OPTICAL RESULTS (SIMULATED): LED XQ-E HD FWHM / FWTM 13.0° / 28.0° Efficiency 89 % Peak intensity 11 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON 2835 Line FWHM / FWTM 12.0° / 29.0° Efficiency 96 % Peak intensity 10 cd/lm LEDs/each optic 1 Light colour PC Amber Required components: LED LUXEON 3030 2D (Round LES) FWHM / FWTM 16.0° / 40.0° Efficiency 95 % Peak intensity 5.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON 3030 HV FWHM / FWTM 17.0° / 41.0° Efficiency 95 % Peak intensity 5.5 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 05/02/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/14 PRODUCT DATASHEET CA14601_VERONICA-SQ-MINI-RS OPTICAL RESULTS (SIMULATED): LED LUXEON A FWHM / FWTM 21.0° / 42.0° Efficiency 89 % Peak intensity 4.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON C FWHM / FWTM 15.0° / 31.0° Efficiency 94 % Peak intensity 9.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON HL1Z FWHM / FWTM 12.0° / 30.0° Efficiency 96 % Peak intensity 10.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON Rebel FWHM / FWTM 16.0° / 34.0° Efficiency 87 % Peak intensity 7.5 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 05/02/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/14 PRODUCT DATASHEET CA14601_VERONICA-SQ-MINI-RS OPTICAL RESULTS (SIMULATED): LED LUXEON T FWHM / FWTM 22.0° / 42.0° Efficiency 96 % Peak intensity 4.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON Z ES FWHM / FWTM 14.0° / 31.0° Efficiency 89 % Peak intensity 9.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED NF2x757G FWHM / FWTM 19.0° / 40.0° Efficiency 97 % Peak intensity 5.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED NFSx757G FWHM / FWTM 14.0° / 33.0° Efficiency 96 % Peak intensity 7.8 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 05/02/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 10/14 PRODUCT DATASHEET CA14601_VERONICA-SQ-MINI-RS OPTICAL RESULTS (SIMULATED): LED NV4WB35AM FWHM / FWTM 28.0° / 68.0° Efficiency 95 % Peak intensity 2.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSxE21A FWHM / FWTM 15.0° / 41.0° Efficiency 94 % Peak intensity 5.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSCONIQ P 3737 (2W version) FWHM / FWTM 18.0° / 39.0° Efficiency 94 % Peak intensity 5.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSCONIQ P 3737 (3W version) FWHM / FWTM 25.0° / 43.0° Efficiency 89 % Peak intensity 2.6 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 05/02/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 11/14 PRODUCT DATASHEET CA14601_VERONICA-SQ-MINI-RS OPTICAL RESULTS (SIMULATED): LED OSLON Square CSSRM2/CSSRM3 FWHM / FWTM 18.0° / 39.0° Efficiency 92 % Peak intensity 5.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSLON SSL 150 FWHM / FWTM 14.0° / 28.0° Efficiency 89 % Peak intensity 10.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSLON SSL 80 FWHM / FWTM 14.0° / 29.0° Efficiency 90 % Peak intensity 10.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED LH351B FWHM / FWTM 24.0° / 46.0° Efficiency 94 % Peak intensity 3.9 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 05/02/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 12/14 PRODUCT DATASHEET CA14601_VERONICA-SQ-MINI-RS OPTICAL RESULTS (SIMULATED): LED LH351Z FWHM / FWTM 19.0° / 36.0° Efficiency 92 % Peak intensity 6.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED MJT 3030 FWHM / FWTM 16.0° / 38.0° Efficiency 96 % Peak intensity 6.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED Z8Y22T FWHM / FWTM 19.0° / 50.0° Efficiency 94 % Peak intensity 3.6 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 05/02/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 13/14 PRODUCT DATASHEET CA14601_VERONICA-SQ-MINI-RS GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 05/02/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 14/14
CA14601_VERONICA-SQ-MINI-RS 价格&库存
很抱歉,暂时无法提供与“CA14601_VERONICA-SQ-MINI-RS”相匹配的价格&库存,您可以联系我们找货
  • 1+10.01361
  • 252+8.06119
  • 756+7.46229
  • 1260+7.07900
  • 6+16.36743
  • 60+15.71240
  • 252+15.05841
库存:126
