CP16108_CARMEN-50-M-C
    LEDIL(芬兰)
    LENSROUND1 POS50MM (D)25,45MM(H)
CP16108_CARMEN-50-M-C 数据手册
PRODUCT DATASHEET CP16108_CARMEN-50-M-C CARMEN-50-M-C ~35° medium beam. Assembly with holder C compatible with LEDiL HEKLA. TECHNICAL SPECIFICATIONS: Dimensions Ø 50.0 mm Height 25.5 mm Fastening socket ROHS compliant yes MATERIAL SPECIFICATIONS: Component Type Material Colour CARMEN-50-M Single lens PMMA clear CARMEN-50-HLD-C Holder PC black Finish ORDERING INFORMATION: Component CP16108_CARMEN-50-M-C » Box size: 476 x 273 x 292 mm Qty in box Single lens 308 MOQ MPQ 112 28 Box weight (kg) 5.9 Last update: 05/05/2020 Subject to change without prior notice Published: 02/01/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 1/15 PRODUCT DATASHEET CP16108_CARMEN-50-M-C Last update: 05/05/2020 Subject to change without prior notice Published: 02/01/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/15 PRODUCT DATASHEET CP16108_CARMEN-50-M-C PHOTOMETRIC DATA (MEASURED): LED V4 HD FWHM 35.0° Efficiency 84 % Peak intensity 2.2 cd/lm LEDs/each optic 1 Light colour White Required components: F15253_HEKLA-SOCKET-A LED V6 HD FWHM 38.0° Efficiency 81 % Peak intensity 1.9 cd/lm LEDs/each optic 1 Light colour White Required components: F15255_HEKLA-SOCKET-C LED V9 HD FWHM 43.0° Efficiency 75 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: F15859_HEKLA-SOCKET-I LED VERO13 FWHM 49.0° Efficiency 62 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: C16142_HEKLA-SOCKET-K Last update: 05/05/2020 Subject to change without prior notice Published: 02/01/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/15 PRODUCT DATASHEET CP16108_CARMEN-50-M-C PHOTOMETRIC DATA (MEASURED): LED Vesta TW 9mm (9W) DP FWHM 41.0° Efficiency 62 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour White Required components: C16142_HEKLA-SOCKET-K Bender Wirth: 489 Typ L8 LED CLL02x/CLU02x (LES10) FWHM 46.0° Efficiency 76 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour White Required components: F15255_HEKLA-SOCKET-C LED CLU700/701/702 FWHM 36.0° Efficiency 80 % Peak intensity 1.9 cd/lm LEDs/each optic 1 Light colour White Required components: F15255_HEKLA-SOCKET-C LED CLU710/711 FWHM 41.0° Efficiency 73 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: F15859_HEKLA-SOCKET-I Last update: 05/05/2020 Subject to change without prior notice Published: 02/01/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/15 PRODUCT DATASHEET CP16108_CARMEN-50-M-C PHOTOMETRIC DATA (MEASURED): LED CLU7A2 (LES 4.2mm) FWHM 35.0° Efficiency 84 % Peak intensity 2.2 cd/lm LEDs/each optic 1 Light colour White Required components: F15255_HEKLA-SOCKET-C LED CLU7B2 FWHM 32.0° Efficiency 82 % Peak intensity 2.4 cd/lm LEDs/each optic 1 Light colour White Required components: F15255_HEKLA-SOCKET-C LED CMA1516 FWHM 46.0° Efficiency 79 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: F15256_HEKLA-SOCKET-D LED CMT14xx FWHM 47.0° Efficiency 51 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: F15255_HEKLA-SOCKET-C Last update: 05/05/2020 Subject to change without prior notice Published: 02/01/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/15 PRODUCT DATASHEET CP16108_CARMEN-50-M-C PHOTOMETRIC DATA (MEASURED): LED CXA/B 13xx FWHM 37.0° Efficiency 83 % Peak intensity 1.9 cd/lm LEDs/each optic 1 Light colour White Required components: F15956_HEKLA-SOCKET-J LED CXA/B 13xx FWHM 38.0° Efficiency 83 % Peak intensity 1.8 cd/lm LEDs/each optic 1 Light colour White Required components: F15956_HEKLA-SOCKET-J LED CXA/B 15xx FWHM 45.0° Efficiency 79 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: F15256_HEKLA-SOCKET-D LED LUXEON CoB 1202HD FWHM 38.0° Efficiency 82 % Peak intensity 1.8 cd/lm LEDs/each optic 1 Light colour White Required components: F15848_HEKLA-SOCKET-G Last update: 05/05/2020 Subject to change without prior notice Published: 02/01/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/15 PRODUCT DATASHEET CP16108_CARMEN-50-M-C PHOTOMETRIC DATA (MEASURED): LED LUXEON CoB 1202s FWHM 37.0° Efficiency 81 % Peak intensity 1.9 cd/lm LEDs/each optic 1 Light colour White Required components: F15848_HEKLA-SOCKET-G LED LUXEON CX Plus CoB - HD S01H4 FWHM 32.0° Efficiency 73 % Peak intensity 2.2 cd/lm LEDs/each optic 1 Light colour White Required components: Bender Wirth: 634c Hekla LED LUXEON CX Plus CoB - HD S01H6 / HD S02H6 FWHM 32.0° Efficiency 72 % Peak intensity 2.1 cd/lm LEDs/each optic 1 Light colour White Required components: Bender Wirth: 634c Hekla LED LUXEON CX Plus CoB - HD S04H9 FWHM 41.0° Efficiency 70 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: Bender Wirth: 634c Hekla Last update: 05/05/2020 Subject to change without prior notice Published: 02/01/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/15 PRODUCT DATASHEET CP16108_CARMEN-50-M-C PHOTOMETRIC DATA (MEASURED): LED CDM-6 (Dim-To-Warm) FWHM 34.0° Efficiency 63 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour White Required components: C16142_HEKLA-SOCKET-K Bender Wirth: 490 Typ L8 LED CDM-9 (Dim-To-Warm) FWHM 40.0° Efficiency 61 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: C16142_HEKLA-SOCKET-K Bender Wirth: 490 Typ L8 LED CXM-3 FWHM 32.0° Efficiency 83 % Peak intensity 2.5 cd/lm LEDs/each optic 1 Light colour White Required components: F15255_HEKLA-SOCKET-C LED CXM-4 FWHM 32.0° Efficiency 79 % Peak intensity 2.2 cd/lm LEDs/each optic 1 Light colour White Required components: F15255_HEKLA-SOCKET-C Last update: 05/05/2020 Subject to change without prior notice Published: 02/01/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/15 PRODUCT DATASHEET CP16108_CARMEN-50-M-C PHOTOMETRIC DATA (MEASURED): LED CxM-9 (13.5x13.5) FWHM 46.0° Efficiency 77 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: F15255_HEKLA-SOCKET-C LED COB S-Type (LES 7) FWHM 39.0° Efficiency 80 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour White Required components: F15848_HEKLA-SOCKET-G LED NJCWL024Z-V1MT: COB L-Type Tunable White FWHM 34.0° Efficiency 62 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour White Required components: C16142_HEKLA-SOCKET-K Bender Wirth: 497 Typ L8 LED NVCWJ024Z-V1MT: COB J-Type Tunable White FWHM 42.0° Efficiency 61 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour White Required components: C16142_HEKLA-SOCKET-K Bender Wirth: 498 Typ L8 Last update: 05/05/2020 Subject to change without prior notice Published: 02/01/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/15 PRODUCT DATASHEET CP16108_CARMEN-50-M-C PHOTOMETRIC DATA (MEASURED): LED Fortimo SLM L09 CoB FWHM 45.0° Efficiency 76 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: F15858_HEKLA-SOCKET-H LED LC003D / LC006D / LC009D / LC013D FWHM 47.0° Efficiency 77 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED LC010C G2 FWHM 36.0° Efficiency 80 % Peak intensity 2 cd/lm LEDs/each optic 1 Light colour White Required components: F15255_HEKLA-SOCKET-C LED LC010T (Tunable White) FWHM 39.0° Efficiency 61 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour Tunable White Required components: C16142_HEKLA-SOCKET-K Bender Wirth: 501 Typ L8 Last update: 05/05/2020 Subject to change without prior notice Published: 02/01/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 10/15 PRODUCT DATASHEET CP16108_CARMEN-50-M-C PHOTOMETRIC DATA (MEASURED): LED LC020C G2 FWHM 43.0° Efficiency 73 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: F15859_HEKLA-SOCKET-I LED SLE G7 LES09 FWHM 44.0° Efficiency 77 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: F15255_HEKLA-SOCKET-C LED SLE G7 LES13 FWHM 57.0° Efficiency 67 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: F15859_HEKLA-SOCKET-I LED XOB 6 mm FWHM 36.0° Efficiency 78 % Peak intensity 1.9 cd/lm LEDs/each optic 1 Light colour White Required components: F15255_HEKLA-SOCKET-C Last update: 05/05/2020 Subject to change without prior notice Published: 02/01/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 11/15 PRODUCT DATASHEET CP16108_CARMEN-50-M-C PHOTOMETRIC DATA (MEASURED): LED XOB 9.8 mm FWHM 44.0° Efficiency 76 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: F15255_HEKLA-SOCKET-C Last update: 05/05/2020 Subject to change without prior notice Published: 02/01/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 12/15 PRODUCT DATASHEET CP16108_CARMEN-50-M-C PHOTOMETRIC DATA (SIMULATED): LED V10 Gen7 FWHM 44.0° Efficiency 75 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: F15255_HEKLA-SOCKET-C LED V6 Gen6 FWHM 29.0° Efficiency 77 % Peak intensity 3 cd/lm LEDs/each optic 1 Light colour White Required components: F15253_HEKLA-SOCKET-A LED V8 Gen7 FWHM 40.0° Efficiency 83 % Peak intensity 1.8 cd/lm LEDs/each optic 1 Light colour White Required components: F15253_HEKLA-SOCKET-A LED VERO10 FWHM 40.0° Efficiency 74 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour White Required components: F15616_HEKLA-SOCKET-F Last update: 05/05/2020 Subject to change without prior notice Published: 02/01/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 13/15 PRODUCT DATASHEET CP16108_CARMEN-50-M-C PHOTOMETRIC DATA (SIMULATED): LED VERO13 FWHM 52.0° Efficiency 73 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour White Required components: C16142_HEKLA-SOCKET-K LED COB S-Type (LES 6) FWHM 32.0° Efficiency 69 % Peak intensity 2.3 cd/lm LEDs/each optic 1 Light colour White Required components: F15848_HEKLA-SOCKET-G LED LH231B FWHM 41.0° Efficiency 73 % Peak intensity 1.5 cd/lm LEDs/each optic 7 Light colour White Required components: F15255_HEKLA-SOCKET-C LED XTM - 9mm LES FWHM 42.0° Efficiency 79 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour White Required components: C15743_XTM-ADAPTER-50-B Last update: 05/05/2020 Subject to change without prior notice Published: 02/01/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 14/15 PRODUCT DATASHEET CP16108_CARMEN-50-M-C GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. Due to use of high power COB's with this product, special attention to proper thermal design is highly recommended. LEDiL has no liability for direct, indirect or consecutive damages arising from the LEDiL products being used outside of the recommended temperature range. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 05/05/2020 Subject to change without prior notice Published: 02/01/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 15/15
CP16108_CARMEN-50-M-C 价格&库存
很抱歉,暂时无法提供与“CP16108_CARMEN-50-M-C”相匹配的价格&库存,您可以联系我们找货
      库存:246
        • 28+17.69151
        库存:192
